[GRASS-SVN] r45585 - grass/trunk/ps/ps.map
Sun Mar 6 06:57:18 EST 2011
Author: martinl
Date: 2011-03-06 03:57:18 -0800 (Sun, 06 Mar 2011)
New Revision: 45585
Added:
   grass/trunk/ps/ps.map/r_instructions.c
Removed:
   grass/trunk/ps/ps.map/read_key.c
   grass/trunk/ps/ps.map/local_proto.h
   grass/trunk/ps/ps.map/main.c
ps.map: read_from_keyboard() renamed to read_instructions()
Modified: grass/trunk/ps/ps.map/local_proto.h
--- grass/trunk/ps/ps.map/local_proto.h	2011-03-06 10:45:16 UTC (rev 45584)
+++ grass/trunk/ps/ps.map/local_proto.h	2011-03-06 11:57:18 UTC (rev 45585)
@@ -198,10 +198,10 @@
 void reset_map_location(void);
 void print_papers(void);
-/* read_key.c */
-void read_from_keyboard(FILE *, struct PS_data *, int, int, int,
-			struct scalebar *, int *, int *,
-			struct PS_group *);
+/* r_instructions.c */
+void read_instructions(FILE *, struct PS_data *, int, int, int,
+		       struct scalebar *, int *, int *,
+		       struct PS_group *);
 /* r_border.c */
 int read_border(void);
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c	2011-03-06 10:45:16 UTC (rev 45584)
+++ grass/trunk/ps/ps.map/main.c	2011-03-06 11:57:18 UTC (rev 45585)
@@ -245,8 +245,8 @@
     G_get_set_window(&PS.w);
     Rast_set_window(&PS.w);
-    read_from_keyboard(inputfd, &PS, copies_set, ps_copies, can_reset_scale,
-		       &sb, &do_mapinfo, &do_vlegend, &grp);
+    read_instructions(inputfd, &PS, copies_set, ps_copies, can_reset_scale,
+		      &sb, &do_mapinfo, &do_vlegend, &grp);
     /* reset map location base on 'paper' on 'location' */
     reset_map_location();
Copied: grass/trunk/ps/ps.map/r_instructions.c (from rev 45580, grass/trunk/ps/ps.map/read_key.c)
--- grass/trunk/ps/ps.map/r_instructions.c	                        (rev 0)
+++ grass/trunk/ps/ps.map/r_instructions.c	2011-03-06 11:57:18 UTC (rev 45585)
@@ -0,0 +1,464 @@
+#include <string.h>
+#include <grass/colors.h>
+#include <grass/imagery.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+#define KEY(x) (strcmp(key,x)==0)
+static char *help[] = {
+    "rast       rastermap             setcolor   val_range(s) color",
+    "vpoints    vector points map     scalebar   [f|s]",
+    "vlines     vector lines map      paper      [a4|a3|us-letter|...]",
+    "vareas     vector areas map      maploc     x y [width height]",
+    "labels     labelfile             text       east north text",
+    "region     regionfile            line       east north east north",
+    "grid       spacing               point      east north",
+    "geogrid    spacing               header",
+    "outline                          mapinfo",
+    "colortable [y|n]                 vlegend",
+    "comments   [unix-file]           psfile     PostScript include file",
+    "read       unix-file             eps        Encapsulated PostScript file",
+    "rectangle  east north east north",
+    "scale      1:#|# inches|# panels|1 inch = # miles",
+    "border     [y|n]",
+void read_instructions(FILE *inputfd, struct PS_data *PS,
+		       int copies_set, int ps_copies, int can_reset_scale,
+		       struct scalebar *sb, int *do_mapinfo, int *do_vlegend,
+		       struct PS_group *grp)
+    int i;
+    int iflag;
+    char name[GNAME_MAX], mapset[GMAPSET_MAX];
+    char buf[1024];
+    iflag = 0;
+    while (1) {
+	char *key;
+	char *data;
+	if (!input(1, buf, help)) {
+	    if (!iflag) {
+		if (G_getl2(buf, 12, inputfd))
+		    G_warning(_("Data exists after final 'end' instruction!"));
+		break;
+	    iflag = 0;
+	    continue;
+	if (!key_data(buf, &key, &data))
+	    continue;
+	if (KEY("read")) {
+	    if (inputfd != stdin)
+		fclose(inputfd);
+	    if (sscanf(data, "%s", name) != 1) {
+		error(key, data, "no file specified");
+		inputfd = stdin;
+	    else if ((inputfd = fopen(name, "r")) == NULL) {
+		error(key, data, "unable to open");
+		inputfd = stdin;
+	    else
+		iflag = 1;
+	    continue;
+	if (KEY("paper")) {
+	    if (strlen(data) > 0) {
+		set_paper(data);
+	    read_paper();
+	    continue;
+	if (KEY("maploc")) {
+	    int n;
+	    double x, y, w, h;
+	    n = sscanf(data, "%lf %lf %lf %lf", &x, &y, &w, &h);
+	    if (n == 2 || n == 4) {
+		PS->map_x_orig = x;
+		PS->map_y_loc = y;
+		if (n == 4) {
+		    PS->map_width = w;
+		    PS->map_height = h;
+	    else {
+		error(key, data, "illegal maploc request");
+		gobble_input();
+	    continue;
+	if (KEY("copies")) {
+	    int n, copies;
+	    if (copies_set)
+		continue;
+	    n = sscanf(data, "%d", &copies);
+	    if (n != 1 || copies < 1 || copies > 20) {
+		ps_copies = 1;
+		error(key, data, "illegal copies request");
+	    ps_copies = copies;
+	    continue;
+	if (KEY("setcolor")) {
+	    float R, G, B;
+	    int r, g, b;
+	    int color;
+	    int count;
+	    DCELL *val_list;
+	    DCELL dmin, dmax;
+	    char colorbuf[100];
+	    char catsbuf[100];
+	    if (PS->cell_fd < 0) {
+		error(key, data, "no raster map selected yet");
+		continue;
+	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
+		color = get_color_number(colorbuf);
+		if (color < 0) {
+		    error(key, data, "illegal color");
+		    continue;
+		get_color_rgb(color, &R, &G, &B);
+		r = 255.0 * R;
+		g = 255.0 * G;
+		b = 255.0 * B;
+		if (strncmp(catsbuf, "null", 4) == 0) {
+		    Rast_set_null_value_color(r, g, b, &(PS->colors));
+		    continue;
+		if (strncmp(catsbuf, "default", 7) == 0) {
+		    Rast_set_default_color(r, g, b, &(PS->colors));
+		    continue;
+		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
+		    error(key, data, "illegal value list");
+		    continue;
+		for (i = 0; i < count; i += 2) {
+		    dmin = val_list[i];
+		    dmax = val_list[i + 1];
+		    Rast_add_d_color_rule(&dmin, r, g, b, &dmax, r, g, b,
+					  &(PS->colors));
+		G_free(val_list);
+	    continue;
+	if (KEY("colortable")) {
+	    PS->do_colortable = 0;
+	       else
+	    PS->do_colortable = yesno(key, data);
+	    if (PS->do_colortable)
+		read_colortable();
+	    continue;
+	if (KEY("border")) {
+	    PS->do_border = yesno(key, data);
+	    if (PS->do_border)
+		read_border();
+	    continue;
+	if (KEY("scalebar")) {
+	    if (G_projection() == PROJECTION_LL) {
+		error(key, data,
+		      "scalebar is not appropriate for this projection");
+		gobble_input();
+	    PS->do_scalebar = 1;
+	    if (sscanf(data, "%s", sb->type) != 1)
+		strcpy(sb->type, "f");	/* default to fancy scalebar */
+	    read_scalebar();
+	    if (sb->length <= 0.) {
+		error(key, data, "Bad scalebar length");
+		gobble_input();
+	    continue;
+	if (KEY("text")) {
+	    double e, n;
+	    char east[50], north[50];
+	    char text[1024];
+	    if (sscanf(data, "%s %s %[^\n]", east, north, text) == 3
+		&& (scan_easting(east, &e) && scan_northing(north, &n)))
+		read_text(east, north, text);
+	    else {
+		gobble_input();
+		error(key, data, "illegal text request");
+	    continue;
+	if (KEY("point")) {
+	    double e, n;
+	    if (sscanf(data, "%s %s", east, north) == 2
+		read_point(e, n);
+	    else {
+		gobble_input();
+		error(key, data, "illegal point request");
+	    continue;
+	if (KEY("eps")) {
+	    double e, n;
+		read_eps(e, n);
+	    else {
+		gobble_input();
+		error(key, data, "illegal eps request");
+	    continue;
+	if (KEY("line")) {
+	    char east1[50], north1[50];
+	    char east2[50], north2[50];
+	    double e1, n1, e2, n2;
+	    if (sscanf(data, "%s %s %s %s", east1, north1, east2, north2) == 4
+		&& (scan_easting(east1, &e1) && scan_easting(east2, &e2)
+		    && scan_northing(north1, &n1) &&
+		    scan_northing(north2, &n2)))
+		read_line(e1, n1, e2, n2);
+	    else {
+		gobble_input();
+		error(key, data, "illegal line request");
+	    continue;
+	if (KEY("rectangle")) {
+		read_rectangle(e1, n1, e2, n2);
+	    else {
+		gobble_input();
+		error(key, data, "illegal rectangle request");
+	    continue;
+	if (KEY("comments")) {
+	    switch (sscanf(data, "%s %s", name, mapset)) {
+	    case 1:
+		read_comment(name);
+		break;
+	    case 2:
+		error(key, data, "illegal comments request");
+		break;
+	    default:
+		read_comment("");
+		break;
+	    continue;
+	if (KEY("scale")) {
+	    if (!can_reset_scale)
+		continue;
+	    if (check_scale(data))
+		strcpy(PS->scaletext, data);
+	    else {
+		PS->scaletext[0] = 0;
+		error(key, data, "illegal scale request");
+	    continue;
+	if (KEY("labels")) {
+	    if (scan_gis("paint/labels", "label", key, data, name, mapset, 1))
+		read_labels(name, mapset);
+	    continue;
+	if (KEY("header")) {
+	    read_header();
+	    PS->do_header = 1;
+	    continue;
+	if (KEY("mapinfo")) {
+	    read_info();
+	    *do_mapinfo = 1;
+	    continue;
+	if (KEY("vlegend")) {
+	    read_vlegend();
+	    *do_vlegend = 1;
+	    continue;
+	if (KEY("outline")) {
+		gobble_input();
+	    else
+		read_outline();
+	    continue;
+	if (KEY("cell") || KEY("rast") || KEY("raster")) {
+	    if (scan_gis("cell", "raster", key, data, name, mapset, 0))
+		read_cell(name, mapset);
+	    continue;
+	if (KEY("greyrast") || KEY("grayrast")) {
+	    PS->grey = 1;
+	    continue;
+	if (KEY("group")) {
+	    G_strip(data);
+	    if (I_find_group(data)) {
+		grp->group_name = G_store(data);
+		grp->do_group = 1;
+		read_group();
+	    else
+		error(key, data, "group not found");
+	    continue;
+	if (KEY("rgb")) {
+	    G_strip(data);
+	    read_rgb(key, data);
+	    continue;
+	if (KEY("vpoints")) {
+	    if (scan_gis("vector", "vector", key, data, name, mapset, 1))
+		read_vpoints(name, mapset);
+	    continue;
+	if (KEY("vlines")) {
+		read_vlines(name, mapset);
+	    continue;
+	if (KEY("vareas")) {
+		read_vareas(name, mapset);
+	    continue;
+	if (KEY("window") || KEY("region")) {
+	    if (scan_gis("windows", "region definition", key, data, name,
+			 mapset, 1))
+		read_wind(name, mapset);
+	    continue;
+	if (KEY("grid")) {
+	    PS->grid = -1;
+	    PS->grid_numbers = 0;
+	    sscanf(data, "%d", &(PS->grid));
+	    if (PS->grid < 0) {
+		PS->grid = 0;
+		error(key, data, "illegal grid spacing");
+		gobble_input();
+	    else
+		getgrid();
+	    continue;
+	if (KEY("geogrid")) {
+	    if (G_projection() == PROJECTION_XY) {
+		error(key, data,
+		      "geogrid is not available for this projection");
+		gobble_input();
+	    /*          if (G_projection() == PROJECTION_LL)
+	       G_message(_("geogrid referenced to [???] ellipsoid"));  */
+	    PS->geogrid = -1.;
+	    PS->geogrid_numbers = 0;
+	    sscanf(data, "%d %s", &(PS->geogrid), PS->geogridunit);
+	    if (PS->geogrid < 0) {
+		PS->geogrid = 0;
+		error(key, data, "illegal geo-grid spacing");
+		gobble_input();
+	    else
+		getgeogrid();
+	    continue;
+	if (KEY("psfile")) {
+	    if (PS->num_psfiles >= MAX_PSFILES)
+		continue;
+	    G_strip(data);
+	    PS->psfiles[PS->num_psfiles] = G_store(data);
+	    PS->num_psfiles++;
+	    continue;
+	if (KEY("maskcolor")) {
+	    int ret, r, g, b;
+	    ret = G_str_to_color(data, &r, &g, &b);
+	    if (ret == 1) {
+		PS->mask_r = r / 255.0;
+		PS->mask_g = g / 255.0;
+		PS->mask_b = b / 255.0;
+		PS->mask_color = 1;
+		continue;
+	    else if (ret == 2) {	/* none */
+		continue;
+	    else {
+		error(key, data, "illegal color request");
+	if (*key)
+	    error(key, "", "illegal request");
Deleted: grass/trunk/ps/ps.map/read_key.c
--- grass/trunk/ps/ps.map/read_key.c	2011-03-06 10:45:16 UTC (rev 45584)
+++ grass/trunk/ps/ps.map/read_key.c	2011-03-06 11:57:18 UTC (rev 45585)
@@ -1,464 +0,0 @@
-#include <string.h>
-#include <grass/colors.h>
-#include <grass/imagery.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-#define KEY(x) (strcmp(key,x)==0)
-static char *help[] = {
-    "rast       rastermap             setcolor   val_range(s) color",
-    "vpoints    vector points map     scalebar   [f|s]",
-    "vlines     vector lines map      paper      [a4|a3|us-letter|...]",
-    "vareas     vector areas map      maploc     x y [width height]",
-    "labels     labelfile             text       east north text",
-    "region     regionfile            line       east north east north",
-    "grid       spacing               point      east north",
-    "geogrid    spacing               header",
-    "outline                          mapinfo",
-    "colortable [y|n]                 vlegend",
-    "comments   [unix-file]           psfile     PostScript include file",
-    "read       unix-file             eps        Encapsulated PostScript file",
-    "rectangle  east north east north",
-    "scale      1:#|# inches|# panels|1 inch = # miles",
-    "border     [y|n]",
-void read_from_keyboard(FILE *inputfd, struct PS_data *PS,
-			int copies_set, int ps_copies, int can_reset_scale,
-			struct scalebar *sb, int *do_mapinfo, int *do_vlegend,
-			struct PS_group *grp)
-    int i;
-    int iflag;
-    char name[GNAME_MAX], mapset[GMAPSET_MAX];
-    char buf[1024];
-    iflag = 0;
-    while (1) {
-	char *key;
-	char *data;
-	if (!input(1, buf, help)) {
-	    if (!iflag) {
-		if (G_getl2(buf, 12, inputfd))
-		    G_warning(_("Data exists after final 'end' instruction!"));
-		break;
-	    iflag = 0;
-	    continue;
-	if (!key_data(buf, &key, &data))
-	    continue;
-	if (KEY("read")) {
-	    if (inputfd != stdin)
-		fclose(inputfd);
-	    if (sscanf(data, "%s", name) != 1) {
-		error(key, data, "no file specified");
-		inputfd = stdin;
-	    else if ((inputfd = fopen(name, "r")) == NULL) {
-		error(key, data, "unable to open");
-		inputfd = stdin;
-	    else
-		iflag = 1;
-	    continue;
-	if (KEY("paper")) {
-	    if (strlen(data) > 0) {
-		set_paper(data);
-	    read_paper();
-	    continue;
-	if (KEY("maploc")) {
-	    int n;
-	    double x, y, w, h;
-	    n = sscanf(data, "%lf %lf %lf %lf", &x, &y, &w, &h);
-	    if (n == 2 || n == 4) {
-		PS->map_x_orig = x;
-		PS->map_y_loc = y;
-		if (n == 4) {
-		    PS->map_width = w;
-		    PS->map_height = h;
-	    else {
-		error(key, data, "illegal maploc request");
-		gobble_input();
-	    continue;
-	if (KEY("copies")) {
-	    int n, copies;
-	    if (copies_set)
-		continue;
-	    n = sscanf(data, "%d", &copies);
-	    if (n != 1 || copies < 1 || copies > 20) {
-		ps_copies = 1;
-		error(key, data, "illegal copies request");
-	    ps_copies = copies;
-	    continue;
-	if (KEY("setcolor")) {
-	    float R, G, B;
-	    int r, g, b;
-	    int color;
-	    int count;
-	    DCELL *val_list;
-	    DCELL dmin, dmax;
-	    char colorbuf[100];
-	    char catsbuf[100];
-	    if (PS->cell_fd < 0) {
-		error(key, data, "no raster map selected yet");
-		continue;
-	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
-		color = get_color_number(colorbuf);
-		if (color < 0) {
-		    error(key, data, "illegal color");
-		    continue;
-		get_color_rgb(color, &R, &G, &B);
-		r = 255.0 * R;
-		g = 255.0 * G;
-		b = 255.0 * B;
-		if (strncmp(catsbuf, "null", 4) == 0) {
-		    Rast_set_null_value_color(r, g, b, &(PS->colors));
-		    continue;
-		if (strncmp(catsbuf, "default", 7) == 0) {
-		    Rast_set_default_color(r, g, b, &(PS->colors));
-		    continue;
-		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
-		    error(key, data, "illegal value list");
-		    continue;
-		for (i = 0; i < count; i += 2) {
-		    dmin = val_list[i];
-		    dmax = val_list[i + 1];
-		    Rast_add_d_color_rule(&dmin, r, g, b, &dmax, r, g, b,
-					  &(PS->colors));
-		G_free(val_list);
-	    continue;
-	if (KEY("colortable")) {
-	    PS->do_colortable = 0;
-	       else
-	    PS->do_colortable = yesno(key, data);
-	    if (PS->do_colortable)
-		read_colortable();
-	    continue;
-	if (KEY("border")) {
-	    PS->do_border = yesno(key, data);
-	    if (PS->do_border)
-		read_border();
-	    continue;
-	if (KEY("scalebar")) {
-	    if (G_projection() == PROJECTION_LL) {
-		error(key, data,
-		      "scalebar is not appropriate for this projection");
-		gobble_input();
-	    PS->do_scalebar = 1;
-	    if (sscanf(data, "%s", sb->type) != 1)
-		strcpy(sb->type, "f");	/* default to fancy scalebar */
-	    read_scalebar();
-	    if (sb->length <= 0.) {
-		error(key, data, "Bad scalebar length");
-		gobble_input();
-	    continue;
-	if (KEY("text")) {
-	    double e, n;
-	    char east[50], north[50];
-	    char text[1024];
-	    if (sscanf(data, "%s %s %[^\n]", east, north, text) == 3
-		&& (scan_easting(east, &e) && scan_northing(north, &n)))
-		read_text(east, north, text);
-	    else {
-		gobble_input();
-		error(key, data, "illegal text request");
-	    continue;
-	if (KEY("point")) {
-	    double e, n;
-	    if (sscanf(data, "%s %s", east, north) == 2
-		read_point(e, n);
-	    else {
-		gobble_input();
-		error(key, data, "illegal point request");
-	    continue;
-	if (KEY("eps")) {
-	    double e, n;
-		read_eps(e, n);
-	    else {
-		gobble_input();
-		error(key, data, "illegal eps request");
-	    continue;
-	if (KEY("line")) {
-	    char east1[50], north1[50];
-	    char east2[50], north2[50];
-	    double e1, n1, e2, n2;
-	    if (sscanf(data, "%s %s %s %s", east1, north1, east2, north2) == 4
-		&& (scan_easting(east1, &e1) && scan_easting(east2, &e2)
-		    && scan_northing(north1, &n1) &&
-		    scan_northing(north2, &n2)))
-		read_line(e1, n1, e2, n2);
-	    else {
-		gobble_input();
-		error(key, data, "illegal line request");
-	    continue;
-	if (KEY("rectangle")) {
-		read_rectangle(e1, n1, e2, n2);
-	    else {
-		gobble_input();
-		error(key, data, "illegal rectangle request");
-	    continue;
-	if (KEY("comments")) {
-	    switch (sscanf(data, "%s %s", name, mapset)) {
-	    case 1:
-		read_comment(name);
-		break;
-	    case 2:
-		error(key, data, "illegal comments request");
-		break;
-	    default:
-		read_comment("");
-		break;
-	    continue;
-	if (KEY("scale")) {
-	    if (!can_reset_scale)
-		continue;
-	    if (check_scale(data))
-		strcpy(PS->scaletext, data);
-	    else {
-		PS->scaletext[0] = 0;
-		error(key, data, "illegal scale request");
-	    continue;
-	if (KEY("labels")) {
-	    if (scan_gis("paint/labels", "label", key, data, name, mapset, 1))
-		read_labels(name, mapset);
-	    continue;
-	if (KEY("header")) {
-	    read_header();
-	    PS->do_header = 1;
-	    continue;
-	if (KEY("mapinfo")) {
-	    read_info();
-	    *do_mapinfo = 1;
-	    continue;
-	if (KEY("vlegend")) {
-	    read_vlegend();
-	    *do_vlegend = 1;
-	    continue;
-	if (KEY("outline")) {
-		gobble_input();
-	    else
-		read_outline();
-	    continue;
-	if (KEY("cell") || KEY("rast") || KEY("raster")) {
-	    if (scan_gis("cell", "raster", key, data, name, mapset, 0))
-		read_cell(name, mapset);
-	    continue;
-	if (KEY("greyrast") || KEY("grayrast")) {
-	    PS->grey = 1;
-	    continue;
-	if (KEY("group")) {
-	    G_strip(data);
-	    if (I_find_group(data)) {
-		grp->group_name = G_store(data);
-		grp->do_group = 1;
-		read_group();
-	    else
-		error(key, data, "group not found");
-	    continue;
-	if (KEY("rgb")) {
-	    G_strip(data);
-	    read_rgb(key, data);
-	    continue;
-	if (KEY("vpoints")) {
-	    if (scan_gis("vector", "vector", key, data, name, mapset, 1))
-		read_vpoints(name, mapset);
-	    continue;
-	if (KEY("vlines")) {
-		read_vlines(name, mapset);
-	    continue;
-	if (KEY("vareas")) {
-		read_vareas(name, mapset);
-	    continue;
-	if (KEY("window") || KEY("region")) {
-	    if (scan_gis("windows", "region definition", key, data, name,
-			 mapset, 1))
-		read_wind(name, mapset);
-	    continue;
-	if (KEY("grid")) {
-	    PS->grid = -1;
-	    PS->grid_numbers = 0;
-	    sscanf(data, "%d", &(PS->grid));
-	    if (PS->grid < 0) {
-		PS->grid = 0;
-		error(key, data, "illegal grid spacing");
-		gobble_input();
-	    else
-		getgrid();
-	    continue;
-	if (KEY("geogrid")) {
-	    if (G_projection() == PROJECTION_XY) {
-		error(key, data,
-		      "geogrid is not available for this projection");
-		gobble_input();
-	    /*          if (G_projection() == PROJECTION_LL)
-	       G_message(_("geogrid referenced to [???] ellipsoid"));  */
-	    PS->geogrid = -1.;
-	    PS->geogrid_numbers = 0;
-	    sscanf(data, "%d %s", &(PS->geogrid), PS->geogridunit);
-	    if (PS->geogrid < 0) {
-		PS->geogrid = 0;
-		error(key, data, "illegal geo-grid spacing");
-		gobble_input();
-	    else
-		getgeogrid();
-	    continue;
-	if (KEY("psfile")) {
-	    if (PS->num_psfiles >= MAX_PSFILES)
-		continue;
-	    G_strip(data);
-	    PS->psfiles[PS->num_psfiles] = G_store(data);
-	    PS->num_psfiles++;
-	    continue;
-	if (KEY("maskcolor")) {
-	    int ret, r, g, b;
-	    ret = G_str_to_color(data, &r, &g, &b);
-	    if (ret == 1) {
-		PS->mask_r = r / 255.0;
-		PS->mask_g = g / 255.0;
-		PS->mask_b = b / 255.0;
-		PS->mask_color = 1;
-		continue;
-	    else if (ret == 2) {	/* none */
-		continue;
-	    else {
-		error(key, data, "illegal color request");
-	if (*key)
-	    error(key, "", "illegal request");
