[GRASS-SVN] r45592 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Mar 6 18:45:53 EST 2011
Author: martinl
Date: 2011-03-06 15:45:53 -0800 (Sun, 06 Mar 2011)
New Revision: 45592
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
wxGUI: clean up CommandThread class
(merge r45591 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-03-06 23:40:58 UTC (rev 45591)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-03-06 23:45:53 UTC (rev 45592)
@@ -123,13 +123,13 @@
         subprocess.Popen.__init__(self, *args, **kwargs)
-    def recv(self, maxsize=None):
+    def recv(self, maxsize = None):
         return self._recv('stdout', maxsize)
-    def recv_err(self, maxsize=None):
+    def recv_err(self, maxsize = None):
         return self._recv('stderr', maxsize)
-    def send_recv(self, input='', maxsize=None):
+    def send_recv(self, input = '', maxsize = None):
         return self.send(input), self.recv(maxsize), self.recv_err(maxsize)
     def get_conn_maxsize(self, which, maxsize):
@@ -239,7 +239,7 @@
 message = "Other end disconnected!"
-def recv_some(p, t=.1, e=1, tr=5, stderr=0):
+def recv_some(p, t = .1, e = 1, tr = 5, stderr = 0):
     if tr < 1:
         tr = 1
     x = time.time()+t
@@ -296,9 +296,9 @@
     @param stdout  redirect standard output or None
     @param stderr  redirect standard error output or None
-    def __init__ (self, cmd, stdin=None,
-                  verbose=None, wait=True, rerr=False,
-                  stdout=None, stderr=None):
+    def __init__ (self, cmd, stdin = None,
+                  verbose = None, wait = True, rerr = False,
+                  stdout = None, stderr = None):
         Debug.msg(1, "gcmd.Command(): %s" % ' '.join(cmd))
         self.cmd = cmd
         self.stderr = stderr
@@ -441,8 +441,8 @@
 class CommandThread(Thread):
     """!Create separate thread for command. Used for commands launched
     on the background."""
-                  stdout=sys.stdout, stderr=sys.stderr):
+                  stdout = sys.stdout, stderr = sys.stderr):
         @param cmd command (given as list)
         @param stdin standard input stream
@@ -450,7 +450,7 @@
         Thread.__init__(self)
         self.cmd    = cmd
         self.stdin  = stdin
         self.stdout = stdout
@@ -479,13 +479,15 @@
         if len(self.cmd) == 0:
             return
+        Debug.msg(1, "gcmd.CommandThread(): %s" % ' '.join(self.cmd))
         self.startTime = time.time()
         try:
             self.module = Popen(self.cmd,
-                                stdin=subprocess.PIPE,
-                                stdout=subprocess.PIPE,
-                                stderr=subprocess.PIPE,
-                                shell=sys.platform=="win32")
+                                stdin = subprocess.PIPE,
+                                stdout = subprocess.PIPE,
+                                stderr = subprocess.PIPE,
+                                shell = sys.platform == "win32")
         except OSError, e:
             self.error = str(e)
             return 1
@@ -495,10 +497,9 @@
             self.module.stdin.close()
         # redirect standard outputs...
-        if self.stdout or self.stderr:
-            self.__redirect_stream()
-    def __redirect_stream(self):
+        self._redirect_stream()
+    def _redirect_stream(self):
         """!Redirect stream"""
         if self.stdout:
             # make module stdout/stderr non-blocking
@@ -521,20 +522,20 @@
                 self.aborted = True
                 return
             if self.stdout:
-                line = recv_some(self.module, e=0, stderr=0)
+                line = recv_some(self.module, e = 0, stderr = 0)
                 self.stdout.write(line)
             if self.stderr:
-                line = recv_some(self.module, e=0, stderr=1)
+                line = recv_some(self.module, e = 0, stderr = 1)
                 self.stderr.write(line)
                 if len(line) > 0:
                     self.error = line
         # get the last output
         if self.stdout:
         if self.stderr:
             if len(line) > 0:
                 self.error = line
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2011-03-06 23:40:58 UTC (rev 45591)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2011-03-06 23:45:53 UTC (rev 45592)
@@ -1219,7 +1219,7 @@
                 cmd.append('--overwrite')
             # run in Layer Manager
-            self.parent.goutput.RunCmd(cmd, switchPage=True,
+            self.parent.goutput.RunCmd(cmd, switchPage = True,
                                        onDone = self.AddLayers)
         self.OnCancel()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2011-03-06 23:40:58 UTC (rev 45591)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2011-03-06 23:45:53 UTC (rev 45592)
@@ -49,10 +49,10 @@
 wxCmdDone,     EVT_CMD_DONE     = NewEvent()
 wxCmdAbort,    EVT_CMD_ABORT    = NewEvent()
-def GrassCmd(cmd, stdout, stderr):
+def GrassCmd(cmd, stdout = None, stderr = None):
     """!Return GRASS command thread"""
     return gcmd.CommandThread(cmd,
-                              stdout=stdout, stderr=stderr)
+                              stdout = stdout, stderr = stderr)
 class CmdThread(threading.Thread):
     """!Thread for GRASS commands"""
@@ -70,11 +70,11 @@
         self.start()
-    def RunCmd(self, callable, onDone, *args, **kwds):
+    def RunCmd(self, *args, **kwds):
         CmdThread.requestId += 1
         self.requestCmd = None
-        self.requestQ.put((CmdThread.requestId, callable, onDone, args, kwds))
+        self.requestQ.put((CmdThread.requestId, args, kwds))
         return CmdThread.requestId
@@ -85,23 +85,31 @@
     def run(self):
         os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
         while True:
-            requestId, callable, onDone, args, kwds = self.requestQ.get()
+            requestId, args, kwds = self.requestQ.get()
+            for key in ('callable', 'onDone', 'userData'):
+                if kwds.has_key(key):
+                    vars()[key] = kwds[key]
+                    del kwds[key]
+                else:
+                    vars()[key] = None
+            if not vars()['callable']:
+                vars()['callable'] = GrassCmd
             requestTime = time.time()
-            event = wxCmdRun(cmd=args[0],
-                             pid=requestId)
+            event = wxCmdRun(cmd = args[0],
+                             pid = requestId)
             wx.PostEvent(self.parent, event)
             time.sleep(.1)
-            self.requestCmd = callable(*args, **kwds)
+            self.requestCmd = vars()['callable'](*args, **kwds)
             if self._want_abort_all:
                 self.requestCmd.abort()
                 if self.requestQ.empty():
                     self._want_abort_all = False
             self.resultQ.put((requestId, self.requestCmd.run()))
             try:
                 returncode = self.requestCmd.module.returncode
             except AttributeError:
@@ -135,7 +143,7 @@
                     argsColor[0] = [ 'r.colors',
                                      'map=%s' % mapName,
                                      'color=%s' % colorTable ]
-                    self.requestCmdColor = callable(*argsColor, **kwds)
+                    self.requestCmdColor = vars()['callable'](*argsColor, **kwds)
                     self.resultQ.put((requestId, self.requestCmdColor.run()))
             event = wxCmdDone(cmd = args[0],
@@ -143,7 +151,8 @@
                               returncode = returncode,
                               time = requestTime,
                               pid = requestId,
-                              onDone = onDone)
+                              onDone = vars()['onDone'],
+                              userData = vars()['userData'])
             # send event
@@ -529,10 +538,8 @@
                     menuform.GUI(parent = self).ParseCommand(command)
                 else:
                     # process GRASS command with argument
-                    self.cmdThread.RunCmd(GrassCmd,
-                                          onDone,
-                                          command,
-                                          self.cmd_stdout, self.cmd_stderr)
+                    self.cmdThread.RunCmd(command, stdout = self.cmd_stdout, stderr = self.cmd_stderr,
+                                          onDone = onDone)
                     self.cmd_output_timer.Start(50)
                     return None
@@ -556,10 +563,8 @@
                 # process GRASS command without argument
             else:
-                                      onDone,
-                                      command,
+                                      onDone = onDone)
         return None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-03-06 23:40:58 UTC (rev 45591)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-03-06 23:45:53 UTC (rev 45592)
@@ -307,7 +307,7 @@
             if dlg.ShowModal() == wx.ID_YES:
                 mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetName()
                 self._layerManager.goutput.RunCmd(['v.digit', 'map=%s' % mapName],
-                                                      switchPage=False)
+                                                  switchPage = False)
             dlg.Destroy()
             self.toolbars['map'].combo.SetValue(_("2D view"))
