[GRASS-SVN] r45607 - in grass/trunk/raster/simwe: r.sim.sediment
r.sim.water simlib
svn_grass at osgeo.org
Tue Mar 8 07:26:02 EST 2011
Author: huhabla
Date: 2011-03-08 04:26:02 -0800 (Tue, 08 Mar 2011)
New Revision: 45607
grass/trunk/raster/simwe/r.sim.sediment/main.c
grass/trunk/raster/simwe/r.sim.water/main.c
grass/trunk/raster/simwe/r.sim.water/spearfish.sh
grass/trunk/raster/simwe/simlib/Makefile
grass/trunk/raster/simwe/simlib/erod.c
grass/trunk/raster/simwe/simlib/hydro.c
grass/trunk/raster/simwe/simlib/input.c
grass/trunk/raster/simwe/simlib/output.c
grass/trunk/raster/simwe/simlib/waterglobs.h
Added walker vector points output generation.
Removed confusing code, which seems to make things more complicted.
Added time series support to the r.sim.water spearfish example with vtk output.
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -161,6 +161,13 @@
parm.maninval->description = _("Name of mannings n value");
parm.maninval->guisection = _("Input");
+ parm.outwalk = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.outwalk->key = "outwalk";
+ parm.outwalk->required = NO;
+ parm.outwalk->description =
+ _("Base name of the output walkers vector points map");
+ parm.outwalk->guisection = _("Output_options");
/* needs to be updated to GRASS 6 vector format !!
parm.sfile = G_define_standard_option(G_OPT_V_INPUT);
parm.sfile->key = "vector";
@@ -309,7 +316,7 @@
conc = parm.conc->answer;
flux = parm.flux->answer;
erdep = parm.erdep->answer;
-/* sfile = parm.sfile->answer; */
+ outwalk = parm.outwalk->answer;
/* sscanf(parm.nwalk->answer, "%d", &maxwa); */
sscanf(parm.niter->answer, "%d", ×ec);
Modified: grass/trunk/raster/simwe/r.sim.water/main.c
--- grass/trunk/raster/simwe/r.sim.water/main.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/r.sim.water/main.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -212,14 +212,12 @@
parm.err->description = _("Name for output simulation error raster map [m]");
parm.err->guisection = _("Output");
- _("Name of the output walkers vector points map");
parm.nwalk = G_define_option();
parm.nwalk->key = "nwalk";
@@ -334,7 +332,7 @@
depth = parm.depth->answer;
disch = parm.disch->answer;
err = parm.err->answer;
-/* outwalk = parm.outwalk->answer; */
Modified: grass/trunk/raster/simwe/r.sim.water/spearfish.sh
--- grass/trunk/raster/simwe/r.sim.water/spearfish.sh 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/r.sim.water/spearfish.sh 2011-03-08 12:26:02 UTC (rev 45607)
@@ -3,43 +3,48 @@
# sample script for Spearfish
# written by
# andreas.philipp geo.uni-augsburg.de
-# modified by JH, HM, MN
+# modified by JH, HM, MN, SG
-dem=elevation.dem
-g.region rast=${dem} -p
+dem=elevation.10m
+output=simwe
+g.region rast=${output}
+g.region n=4920800 s=4917800 w=602500 e=606000
+g.region -p
# Manning n
man05=0.05
# rainfall [mm/hr]
-rain01=5
+rain01=2.5
# infitration [mm/hr]
infil0=0.
echo "Preparing input maps..."
-r.slope.aspect --o elevation=$dem dx=${dem}_dx dy=${dem}_dy
-r.mapcalc "${dem}_rain =if(${dem},$rain01,null())"
-r.mapcalc "${dem}_manin=if(${dem},$man05,null())"
-r.mapcalc "${dem}_infil=if(${dem},$infil0,null())"
+r.slope.aspect --o elevation=$dem dx=${output}_dx dy=${output}_dy
+r.mapcalc --o expr="${output}_rain =if(${dem},$rain01,null())"
+r.mapcalc --o expr="${output}_manin=if(${dem},$man05,null())"
+r.mapcalc --o expr="${output}_infil=if(${dem},$infil0,null())"
-echo "r.sim.water --o elevin=${dem} dxin=${dem}_dx dyin=${dem}_dy \
- rain=${dem}_rain manin=${dem}_manin infil=${dem}_infil \
- depth=${dem}_depth disch=${dem}_disch err=${dem}_err"
-r.sim.water --o elevin=${dem} dxin=${dem}_dx dyin=${dem}_dy \
+echo "r.sim.water --o -t elevation=${dem} dx=${output}_dx dy=${output}_dy rain=${output}_rain man=${output}_manin infil=${output}_infil depth=${output}_depth disch=${output}_disch err=${output}_err outwalk=${output}_walker niter=5 outiter=1"
+ r.sim.water --o -t elevation=${dem} dx=${output}_dx dy=${output}_dy rain=${output}_rain man=${output}_manin infil=${output}_infil depth=${output}_depth disch=${output}_disch err=${output}_err outwalk=${output}_walker niter=5 outiter=1
-r.info -r ${dem}_depth
-r.info -r ${dem}_disch
-r.info -r ${dem}_err
+echo "Build topology and exporting walker vector points for each time step"
+for i in `g.mlist vect | grep ${output}` ; do
+ v.build $i
+ echo "v.out.vtk input=$i output=$i.vtk"
+ v.out.vtk input=$i output=$i.vtk
+done
-echo "Written:
- Output water depth raster file: ${dem}_depth
- Output water discharge raster file: ${dem}_disch
- Output simulation error raster file: ${dem}_err
+echo "Exporting the raster maps for each time step"
+for i in `g.mlist rast | grep ${output}` ; do
+ echo "r.out.vtk elevation=${dem} input=$i output=$i.vtk null=0.0"
+ r.out.vtk elevation=${dem} input=$i output=$i.vtk null=0.0
+done
+echo "Now open paraview from this command line and load the vtk files as time series using the File->Open menu entry"
+echo "Step throu the time steps and adjust the color tables"
# cleanup
-g.remove --q rast=${dem}_dx,${dem}_dy,${dem}_rain,${dem}_manin,${dem}_infil
+g.remove --q rast=${output}_dx,${output}_dy,${output}_rain,${output}_manin,${output}_infil
Modified: grass/trunk/raster/simwe/simlib/Makefile
--- grass/trunk/raster/simwe/simlib/Makefile 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/Makefile 2011-03-08 12:26:02 UTC (rev 45607)
@@ -1,7 +1,7 @@
MODULE_TOPDIR = ../../..
-LIBES = $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB)
-DEPENDENCIES = $(GISDEP) $(BITMAPDEP) $(DBMIDEP) $(GMATHDEP) $(LINKMDEP) $(XDRDEP) $(SITESDEP) $(VECTDEP) $(RASTERDEP)
+LIBES = $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB) $(VECTLIB)
+DEPENDENCIES = $(GISDEP) $(BITMAPDEP) $(DBMIDEP) $(GMATHDEP) $(LINKMDEP) $(XDRDEP) $(SITESDEP) $(VECTDEP) $(RASTERDEP) $(VECTDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/raster/simwe/simlib/erod.c
--- grass/trunk/raster/simwe/simlib/erod.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/erod.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -19,7 +19,6 @@
#include <stdlib.h>
#include <math.h>
#include <grass/gis.h>
-/* #include <grass/site.h> */
#include <grass/bitmap.h>
#include <grass/linkm.h>
Modified: grass/trunk/raster/simwe/simlib/hydro.c
--- grass/trunk/raster/simwe/simlib/hydro.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/hydro.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -29,6 +29,21 @@
struct options parm;
struct flags flag;
+ * Soeren 8. Mar 2011 TODO:
+ * Put all these global variables into several meaningful structures and
+ * document use and purpose.
+ * Example:
+ * Put all file descriptors into a input_files struct and rename the variables:
+ * input_files.elev
+ * input_files.dx
+ * input_files.dy
+ * input_files.drain
FILE *fdelevin, *fddxin, *fddyin, *fdrain, *fdinfil, *fdtraps,
*fdmanin, *fddepth, *fddisch, *fderr;
FILE *fdwdepth, *fddetin, *fdtranin, *fdtauin, *fdtc, *fdet, *fdconc,
@@ -46,7 +61,7 @@
char *depth;
char *disch;
char *err;
-/* char *outwalk; */
+char *outwalk;
char *mapset;
char *mscale;
char *tserie;
@@ -69,12 +84,6 @@
struct Cell_head cellhd;
-struct Point *points;
-int npoints;
-int npoints_alloc;
double xmin, ymin, xmax, ymax;
double mayy, miyy, maxx, mixx;
int mx, my;
@@ -93,12 +102,10 @@
float **dc, **tau, **er, **ct, **trap;
float **dif;
-/* double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3]; */
-double vavg[MAXW][2], w[MAXW][3];
+double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3];
int iflag[MAXW];
double hbeta;
-/* int ldemo; */
double hhmax, sisum, vmean;
double infsum, infmean;
int maxw, maxwa, nwalk;
@@ -106,10 +113,9 @@
double stepx, stepy, xp0, yp0;
double chmean, si0, deltap, deldif, cch, hhc, halpha;
double eps;
-/* int maxwab, nstack; */
-int maxwab;
+int maxwab, nstack;
int iterout, mx2o, my2o;
-int miter, nwalka, lwwfin;
+int miter, nwalka;
double timec;
int ts, timesec;
@@ -128,8 +134,7 @@
int i, ii, l, k;
-/* int icoub, lwout, nmult; */
- int icoub, nmult;
+ int icoub, nmult;
int iw, iblock, lw;
int itime, iter1;
int nfiterh, nfiterw;
@@ -149,7 +154,7 @@
nblock = 1;
icoub = 0;
icfl = 0;
-/* nstack = 0; */
+ nstack = 0;
if (maxwa > (MAXW - mx * my)) {
mitfac = maxwa / (MAXW - mx * my);
@@ -168,7 +173,6 @@
sarea = bresx * bresy;
G_debug(2, " barea,sarea,rwalk,sisum: %f %f %f %f", barea, sarea,
rwalk, sisum);
- lwwfin = 0;
/* write hh.walkers0 */
for (k = 0; k < my; k++) {
@@ -225,20 +229,11 @@
iflag[lw] = 1;
- lwout = lw / ldemo;
- lwout *= ldemo;
- if (lwout == lw) {
- ++lwwfin;
} /*DEFined area */
nwalk = lw;
- G_debug(2, " number of written walkers: %d", lwwfin);
G_debug(2, " nwalk, maxw %d %d", nwalk, MAXW);
G_debug(2, " walkwe (walk weight),frac %f %f", walkwe, frac);
@@ -283,6 +278,7 @@
addac = factor * .5;
nwalka = 0;
+ nstack = 0;
for (lw = 1; lw <= nwalk; lw++) {
if (w[lw][3] > EPS) { /* check the walker weight */
@@ -302,9 +298,7 @@
if (zz[k][l] != UNDEF) {
if (infil != NULL) { /* infiltration part */
if (inf[k][l] - si[k][l] > 0.) {
decr = pow(addac * w[lw][3], 3. / 5.); /* decreasing factor in m */
@@ -317,12 +311,9 @@
inf[k][l] = 0.;
gama[k][l] += (addac * w[lw][3]); /* add walker weigh to water depth or conc. */
d1 = gama[k][l] * conn;
@@ -348,10 +339,8 @@
velx = -0.1 * v1[k][l]; /* move it slightly back */
vely = -0.1 * v2[k][l];
gaux = gasdev();
gauy = gasdev();
@@ -380,59 +369,49 @@
w[lw][3] = 1e-10; /* eliminate walker if it is out of area */
+ } /* lw loop */
+ /* Changes made by Soeren 8. Mar 2011 to replace the site walker output implementation */
+ /* Save all walkers located within the computational region and with valid
+ z coordinates */
+ if ((i == miter || i == iter1)) {
+ nstack = 0;
+ for (lw = 1; lw <= nwalk; lw++) {
+ /* Compute the elevation raster map index */
+ l = (int)((w[lw][1] + stxm) / stepx) - mx - 1;
+ k = (int)((w[lw][2] + stym) / stepy) - my - 1;
+ /* Check for correct elevation raster map index */
+ if(l < 0 || l >= mx || k < 0 || k >= my)
+ continue;
-/* output walkers commented out */
- /* write the walkers which reach the box */
- if (w[lw][1] >= xmin && w[lw][2] >= ymin && w[lw][1]
- <= xmax && w[lw][2] <= ymax && iflag[lw] == 0) {
+ if (w[lw][3] > EPS && zz[k][l] != UNDEF) {
- lwout *= ldemo;
- if (lwout == lw && (i == miter || i == iter1)) {
- stack[nstack][1] = mixx / conv + w[lw][1] / conv;
- stack[nstack][2] = miyy / conv + w[lw][2] / conv;
- stack[nstack][3] = w[lw][3];
+ /* Save the 3d position of the walker */
+ stack[nstack][1] = mixx / conv + w[lw][1] / conv;
+ stack[nstack][2] = miyy / conv + w[lw][2] / conv;
+ stack[nstack][3] = zz[k][l];
- nstack++;
- /* iflag[lw] = 1; */
+ nstack++;
+ } /* lw loop */
- /* walker is leaving the box */
+ if (i == iter1 && ts == 1) {
+ /* call output for iteration output */
+ if (erdep != NULL)
+ erod(gama); /* divergence of gama field */
- /* if (w[lw][1] <= mixx && w[lw][2] <= bymi && w[lw][1]
- >= bxma && w[lw][2] >= byma && iflag[lw] == 1) {
- iflag[lw] = 0;
- /* every iterout iteration write out the selected ldemo walkers */
- /* and water depth and time */
- } /* lw loop */
- if (i == iter1) {
- /* call output for iteration output */
- if (ts == 1) {
- if (erdep != NULL)
- erod(gama); /* divergence of gama field */
- conn = (double)nblock / (double)iblock;
- itime = (int)(i * deltap * timec);
- ii = output_data(itime, conn);
-/* nstack = 0; */
- if (ii != 1)
- G_fatal_error(_("Unable to write raster maps"));
+ conn = (double)nblock / (double)iblock;
+ itime = (int)(i * deltap * timec);
+ ii = output_data(itime, conn);
+ if (ii != 1)
+ G_fatal_error(_("Unable to write raster maps"));
+ /* Soeren 8. Mar 2011 TODO:
+ * This hould be replaced by vector functionality and sql database storage */
/* ascii data site file output for gamma - hydrograph or sediment*/
/* cchez incl. sqrt(sinsl) */
/* sediment */
@@ -469,6 +448,7 @@
} /* miter */
L_800:
+ /* Soeren 8. Mar 2011: Why is this commented out?*/
/* if (iwrib != nblock) {
icount = icoub / iwrib;
Modified: grass/trunk/raster/simwe/simlib/input.c
--- grass/trunk/raster/simwe/simlib/input.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/input.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -18,7 +18,7 @@
* \brief allocate memory, read input rasters, assign UNDEF to NODATA
* \return int
* sites related input/output commented out - needs update to vect, HM nov 2008
@@ -32,7 +32,7 @@
DCELL *dxin_cell, *dyin_cell, *rain_cell, *infil_cell, *wdepth_cell;
int elevin_fd, dxin_fd, dyin_fd, rain_fd, infil_fd, traps_fd, manin_fd, row, row_rev;
int detin_fd, trainin_fd, tauin_fd, wdepth_fd;
- int l, j;
+ int j;
/* int nn, cc, ii, dd; */
double unitconv = 0.0000002; /* mm/hr to m/s */
const char *mapset;
@@ -116,7 +116,6 @@
wdepth_cell = Rast_allocate_d_buf();
/* Allocate some double dimension arrays for each input */
- /* with length of matrix Y */
zz = G_alloc_fmatrix(my, mx);
v1 = G_alloc_matrix(my, mx);
v2 = G_alloc_matrix(my, mx);
@@ -143,7 +142,7 @@
if (wdepth != NULL)
gama = G_alloc_matrix(my, mx);
- G_debug(3, "Running JAN 2010 version, started modifications on 20080211");
+ G_debug(3, "Running MAR 2011 version, started modifications on 20080211");
/* Check if data available in mapsets
* if found, then open the files */
Modified: grass/trunk/raster/simwe/simlib/output.c
--- grass/trunk/raster/simwe/simlib/output.c 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/output.c 2011-03-08 12:26:02 UTC (rev 45607)
@@ -5,13 +5,70 @@
#include <math.h>
#include <grass/raster.h>
+#include <grass/vector.h>
#include <grass/waterglobs.h>
#include <grass/glocale.h>
+static void output_walker_as_vector(int tt, int ndigit);
+/* This function was added by Soeren 8. Mar 2011
+ * It replaces the site walker output implementation */
+void output_walker_as_vector(int tt, int ndigit)
+ char buf[256];
+ char *outwalk_time = NULL;
+ double x, y, z;
+ struct Map_info Out;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ int i;
+ if (outwalk != NULL) {
+ /* In case of time series we extent the output name with the time value */
+ if (ts == 1) {
+ sprintf(buf, "%s_%.*d", outwalk, ndigit, tt);
+ outwalk_time = G_store(buf);
+ Vect_open_new(&Out, outwalk_time, WITH_Z);
+ G_message("Writing %i walker into vector file %s", nstack, outwalk_time);
+ else {
+ Vect_open_new(&Out, outwalk, WITH_Z);
+ G_message("Writing %i walker into vector file %s", nstack, outwalk);
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ for (i = 0; i < nstack; i++) {
+ x = (float)stack[i][1];
+ y = (float)stack[i][2];
+ z = (float)stack[i][3];
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, i + 1);
+ Vect_append_point(Points, x, y, z);
+ Vect_write_line(&Out, GV_POINT, Points, Cats);
+ /* Close vector file */
+ Vect_close(&Out);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ return;
+/* Soeren 8. Mar 2011 TODO:
+ * This function needs to be refractured and splittet into smaller parts */
int output_data(int tt, double ft)
@@ -25,7 +82,6 @@
struct History hist, hist1; /* hist2, hist3, hist4, hist5 */
char *depth0 = NULL, *disch0 = NULL, *err0 = NULL;
char *conc0 = NULL, *flux0 = NULL;
-/* char *erdep0 = NULL, *outwalk0 = NULL; */
char *erdep0 = NULL;
const char *mapst = NULL;
char *type;
@@ -33,9 +89,6 @@
int ndigit;
FCELL dat1, dat2;
float a1, a2;
-/* Site_head walkershead;
- Site *sd;
ndigit = 2;
if (timesec >= 10)
@@ -46,50 +99,11 @@
ndigit = 5;
if (timesec >= 10000)
ndigit = 6;
+ /* Write the output walkers */
+ output_walker_as_vector(tt, ndigit);
Rast_set_window(&cellhd);
- if (outwalk) {
- if (ts == 1) {
- sprintf(buf, "%s%.*d", outwalk, ndigit, tt);
- outwalk0 = G_store(buf);
- fdoutwalk = G_fopen_sites_new(outwalk0);
- else
- fdoutwalk = G_fopen_sites_new(outwalk);
- if (fdoutwalk == NULL)
- G_fatal_error("Cannot open %s", outwalk);
- else {
- char buf[GNAME_MAX + 40];
- if (NULL == (sd = G_site_new_struct(-1, 2, 0, 1)))
- G_fatal_error("memory allocation failed for site");
- if (ts == 1)
- walkershead.name = outwalk0;
- else
- walkershead.name = outwalk;
- sprintf(buf, "output walkers of %s [raster]", depth);
- walkershead.desc = G_store(buf);
- walkershead.time = NULL;
- walkershead.stime = NULL;
- walkershead.labels = NULL;
- walkershead.form = NULL;
- G_site_put_head(fdoutwalk, &walkershead);
- for (i = 0; i < nstack; i++) {
- sd->east = (float)stack[i][1];
- sd->north = (float)stack[i][2];
- sd->fcat = (float)stack[i][3];
- G_site_put(fdoutwalk, sd);
if (depth) {
depth_cell = Rast_allocate_f_buf();
if (ts == 1) {
@@ -477,8 +491,8 @@
&hist, "duration (sec.)=%d, time-serie iteration=%d",
timesec, tt);
Rast_append_format_history(
- &hist, "written walkers=%d, deltap=%f, mean vel.=%f",
- lwwfin, deltap, vmean);
+ &hist, "written deltap=%f, mean vel.=%f",
+ deltap, vmean);
&hist, "mean source (si)=%e, mean infil=%e",
si0, infmean);
@@ -517,8 +531,8 @@
timesec, tt);
+ deltap, vmean);
si0, infmean);
@@ -557,8 +571,8 @@
timesec, tt);
+ deltap, vmean);
&hist, "mean source (si)=%f", si0);
Modified: grass/trunk/raster/simwe/simlib/waterglobs.h
--- grass/trunk/raster/simwe/simlib/waterglobs.h 2011-03-08 00:48:45 UTC (rev 45606)
+++ grass/trunk/raster/simwe/simlib/waterglobs.h 2011-03-08 12:26:02 UTC (rev 45607)
@@ -28,7 +28,7 @@
extern char *depth;
extern char *disch;
extern char *err;
-/* extern char *outwalk; */
+extern char *outwalk;
extern char *mapset;
extern char *mscale;
extern char *tserie;
@@ -120,12 +120,10 @@
extern float **dc, **tau, **er, **ct, **trap;
extern float **dif;
-/* extern double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3]; */
-extern double vavg[MAXW][2], w[MAXW][3];
+extern double vavg[MAXW][2], stack[MAXW][3], w[MAXW][3];
extern int iflag[MAXW];
extern double hbeta;
-/* extern int ldemo; */
extern double hhmax, sisum, vmean;
extern double infsum, infmean;
extern int maxw, maxwa, nwalk;
@@ -133,10 +131,9 @@
extern double stepx, stepy, xp0, yp0;
extern double chmean, si0, deltap, deldif, cch, hhc, halpha;
extern double eps;
-/* extern int maxwab, nstack; */
-extern int maxwab;
+extern int maxwab, nstack;
extern int iterout, mx2o, my2o;
-extern int miter, nwalka, lwwfin;
+extern int miter, nwalka;
extern double timec;
extern int ts, timesec;
