[GRASS-SVN] r45617 - in grass/branches/develbranch_6/vector:
v.out.ascii v.split
svn_grass at osgeo.org
Thu Mar 10 04:22:55 EST 2011
Author: neteler
Date: 2011-03-10 01:22:55 -0800 (Thu, 10 Mar 2011)
New Revision: 45617
grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
grass/branches/develbranch_6/vector/v.split/main.c
no dots in msgvector/v.split/main.c
Modified: grass/branches/develbranch_6/vector/v.out.ascii/b2a.c
--- grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2011-03-10 01:00:48 UTC (rev 45616)
+++ grass/branches/develbranch_6/vector/v.out.ascii/b2a.c 2011-03-10 09:22:55 UTC (rev 45617)
@@ -212,6 +212,8 @@
fprintf(ascii, "%s%s%s", xstring, fs, ystring);
+ Vect_field_cat_get(Cats, field, fcats);
if (fcats->n_values > 0) {
if (fcats->n_values > 1) {
G_warning(_("Feature has more categories. Only first category (%d) "
Modified: grass/branches/develbranch_6/vector/v.split/main.c
--- grass/branches/develbranch_6/vector/v.split/main.c 2011-03-10 01:00:48 UTC (rev 45616)
+++ grass/branches/develbranch_6/vector/v.split/main.c 2011-03-10 09:22:55 UTC (rev 45617)
@@ -51,14 +51,14 @@
length_opt->type = TYPE_DOUBLE;
length_opt->required = NO;
length_opt->multiple = NO;
- length_opt->description = "Maximum segment length.";
+ length_opt->description = "Maximum segment length";
vertices_opt = G_define_option();
vertices_opt->key = "vertices";
vertices_opt->type = TYPE_INTEGER;
vertices_opt->required = NO;
vertices_opt->multiple = NO;
- vertices_opt->description = "Maximum number of vertices in segment.";
+ vertices_opt->description = "Maximum number of vertices in segment";
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
