[GRASS-SVN] r45649 - grass/branches/develbranch_6/lib/python
Sat Mar 12 16:08:38 EST 2011
Author: martinl
Date: 2011-03-12 13:08:38 -0800 (Sat, 12 Mar 2011)
New Revision: 45649
   grass/branches/develbranch_6/lib/python/core.py
pythonlib: raise ScriptError (run/read/write_command)
(merge r45648 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2011-03-12 21:05:50 UTC (rev 45648)
+++ grass/branches/develbranch_6/lib/python/core.py	2011-03-12 21:08:38 UTC (rev 45649)
@@ -20,7 +20,7 @@
 @author Glynn Clements
 @author Martin Landa <landa.martin gmail.com>
- at author Michael Barton <michael.barton at asu.edu>
+ at author Michael Barton <michael.barton asu.edu>
 import os
@@ -40,15 +40,15 @@
 # subprocess wrapper that uses shell on Windows
 class Popen(subprocess.Popen):
-    def __init__(self, args, bufsize=0, executable=None,
-                 stdin=None, stdout=None, stderr=None,
-                 preexec_fn=None, close_fds=False, shell=None,
-                 cwd=None, env=None, universal_newlines=False,
-                 startupinfo=None, creationflags=0):
+    def __init__(self, args, bufsize = 0, executable = None,
+                 stdin = None, stdout = None, stderr = None,
+                 preexec_fn = None, close_fds = False, shell = None,
+                 cwd = None, env = None, universal_newlines = False,
+                 startupinfo = None, creationflags = 0):
 	if shell == None:
 	    shell = (sys.platform == "win32")
 	subprocess.Popen.__init__(self, args, bufsize, executable,
                                   stdin, stdout, stderr,
                                   preexec_fn, close_fds, shell,
@@ -58,7 +58,7 @@
 PIPE = subprocess.PIPE
 STDOUT = subprocess.STDOUT
-class ScriptException(Exception):
+class ScriptError(Exception):
     def __init__(self, msg):
         self.value = msg
@@ -94,6 +94,12 @@
 	return _make_val(list(val))
     return str(val)
+def _get_error(string):
+    try:
+        return string.split('\n')[-2]
+    except:
+        return ''
 def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
     """!Return a list of strings suitable for use as the args parameter to
     Popen() or call(). Example:
@@ -181,9 +187,17 @@
     @return exit code (0 for success)
+    if get_raise_on_error():
+        kwargs['stderr'] = PIPE
     ps = start_command(*args, **kwargs)
-    return ps.wait()
+        err = ps.communicate()[1]
+        if ps.returncode != 0:
+            raise ScriptError(_("Error in %s(%s): %s") % ('run_command', args[0], _get_error(err)))
+        return ps.returncode
+    else:
+        return ps.wait()
 def pipe_command(*args, **kwargs):
     """!Passes all arguments to start_command(), but also adds
     "stdout = PIPE". Returns the Popen object.
@@ -230,8 +244,16 @@
     @return stdout
     ps = pipe_command(*args, **kwargs)
-    return _decode(ps.communicate()[0])
+        out, err = ps.communicate()
+            raise ScriptError(_("Error in %s(%s): %s") % ('read_command', args[0], _get_error(err)))
+        return _decode(out)
+    else:
+        return _decode(ps.communicate()[0])
 def parse_command(*args, **kwargs):
     """!Passes all arguments to read_command, then parses the output by
@@ -274,10 +296,19 @@
     @return return code
     stdin = kwargs['stdin']
     p = feed_command(*args, **kwargs)
     p.stdin.write(stdin)
-    p.stdin.close()
-    return p.wait()
+        err = p.communicate()[1]
+        p.stdin.close()
+        if p.returncode != 0:
+            raise ScriptError(_("Error in %s(%s): %s") % ('write_command', args[0], _get_error(err)))
+        return p.returncode
+    else:
+        p.stdin.close()
+        return p.wait()
 def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
     """!Interface to os.execvpe(), but with the make_command() interface.
@@ -361,7 +392,7 @@
     global raise_on_error
     if raise_on_error:
-        raise ScriptException(msg)
+        raise ScriptError(msg)
     else:
         message(msg, flag = 'e')
@@ -376,7 +407,7 @@
 def set_raise_on_error(raise_exp = True):
     """!Define behaviour on error (error() called)
-    @param raise_exp True to raise ScriptException instead of calling
+    @param raise_exp True to raise ScriptError instead of calling
     error()
     @return current status
@@ -384,7 +415,22 @@
     tmp_raise = raise_on_error
     raise_on_error = raise_exp
+    if raise_on_error:
+        os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
+    else:
+        os.environ['GRASS_MESSAGE_FORMAT'] = 'standard'
+    return tmp_raise
+def get_raise_on_error():
+    """!Get raise_on_error status
+    @return True to raise exception
+    global raise_on_error
+    return raise_on_error
 # interface to g.parser
 def _parse_opts(lines):
@@ -953,7 +999,7 @@
                     datum = None, desc = None):
     """!Create new location
-    Raise ScriptException on error.
+    Raise ScriptError on error.
     @param dbase path to GRASS database
     @param location location name to create
@@ -1015,7 +1061,7 @@
                     set = 'GISDBASE=%s' % gisdbase)
         if ps.returncode != 0 and error:
-            raise ScriptException(repr(error))
+            raise ScriptError(repr(error))
     try:
         fd = codecs.open(os.path.join(dbase, location,
@@ -1027,12 +1073,12 @@
             fd.write(os.linesep)
         fd.close()
     except OSError, e:
-        raise ScriptException(repr(e))
+        raise ScriptError(repr(e))
 def _create_location_xy(database, location):
     """!Create unprojected location
     @param database GRASS database where to create new location
@@ -1074,7 +1120,7 @@
         os.chdir(cur_dir)
     except OSError, e:
 # interface to g.version
