[GRASS-SVN] r45651 - grass/branches/develbranch_6/lib/python
Sat Mar 12 16:29:23 EST 2011
Author: martinl
Date: 2011-03-12 13:29:23 -0800 (Sat, 12 Mar 2011)
New Revision: 45651
   grass/branches/develbranch_6/lib/python/core.py
pythonlib: force 'plain' format when raise_on_error is True
(merge r45650 from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2011-03-12 21:27:35 UTC (rev 45650)
+++ grass/branches/develbranch_6/lib/python/core.py	2011-03-12 21:29:23 UTC (rev 45651)
@@ -189,9 +189,15 @@
     if get_raise_on_error():
         kwargs['stderr'] = PIPE
+        env = os.getenv('GRASS_MESSAGE_FORMAT')
+        os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
     ps = start_command(*args, **kwargs)
         err = ps.communicate()[1]
+        if env:
+            os.environ['GRASS_MESSAGE_FORMAT'] = env
         if ps.returncode != 0:
             raise ScriptError(_("Error in %s(%s): %s") % ('run_command', args[0], _get_error(err)))
         return ps.returncode
@@ -246,9 +252,15 @@
     ps = pipe_command(*args, **kwargs)
         out, err = ps.communicate()
+        if env:
             raise ScriptError(_("Error in %s(%s): %s") % ('read_command', args[0], _get_error(err)))
         return _decode(out)
@@ -298,10 +310,16 @@
     stdin = kwargs['stdin']
     p = feed_command(*args, **kwargs)
     p.stdin.write(stdin)
         err = p.communicate()[1]
+        if env:
         p.stdin.close()
         if p.returncode != 0:
             raise ScriptError(_("Error in %s(%s): %s") % ('write_command', args[0], _get_error(err)))
@@ -309,7 +327,7 @@
     else:
         p.stdin.close()
         return p.wait()
 def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
     """!Interface to os.execvpe(), but with the make_command() interface.
@@ -416,11 +434,6 @@
     tmp_raise = raise_on_error
     raise_on_error = raise_exp
-    if raise_on_error:
-        os.environ['GRASS_MESSAGE_FORMAT'] = 'plain'
-    else:
-        os.environ['GRASS_MESSAGE_FORMAT'] = 'standard'
     return tmp_raise
 def get_raise_on_error():
