[GRASS-SVN] r45665 - in grass/trunk/gui/wxpython: . gui_modules xml
svn_grass at osgeo.org
Mon Mar 14 19:05:31 EDT 2011
Author: martinl
Date: 2011-03-14 16:05:31 -0700 (Mon, 14 Mar 2011)
New Revision: 45665
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: add OnPsMap handler for ps.map's GUI
update menudata
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2011-03-14 22:01:34 UTC (rev 45664)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2011-03-14 23:05:31 UTC (rev 45665)
@@ -19,7 +19,7 @@
- commands
- dump
-(C) 2007-2010 by the GRASS Development Team
+(C) 2007-2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-03-14 22:01:34 UTC (rev 45664)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-03-14 23:05:31 UTC (rev 45665)
@@ -265,6 +265,22 @@
win.Show()
+ def OnPsMap(self, event):
+ """!Launch Hardcopy Map Output Utility
+ try:
+ import psmap
+ except:
+ gcmd.GError(parent = self.parent,
+ message = _("Hardcopy Map Output Utility is not available. You can install it by "
+ "'g.extension -s svnurl=https://svn.osgeo.org/grass/grass-addons extension=psmap'"))
+ return
+ win = psmap.PsMapFrame(parent = self)
+ win.CentreOnScreen()
+ win.Show()
def OnDone(self, returncode):
"""Command execution finised"""
if hasattr(self, "model"):
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2011-03-14 22:01:34 UTC (rev 45664)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2011-03-14 23:05:31 UTC (rev 45665)
@@ -534,7 +534,7 @@
<menuitem>
<label>Link external vector data</label>
<help>Creates a new pseudo-vector map as a link to an OGR-supported layer.</help>
- <keywords>vector,external,ogr</keywords>
+ <keywords>vector,external,ogr,postgis</keywords>
<handler>OnLinkOgrLayers</handler>
<command>v.external</command>
</menuitem>
@@ -561,8 +561,8 @@
<items>
<menuitem>
<label>Copy</label>
- <help>Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset.</help>
- <keywords>general,map management</keywords>
+ <help>Copies available data files in the current mapset search path to the user's current mapset.</help>
+ <keywords>general,map management,copy</keywords>
<handler>OnMenuCmd</handler>
<command>g.copy</command>
</menuitem>
@@ -570,14 +570,14 @@
<menuitem>
<label>List</label>
<help>Lists available GIS elements of the user-specified data type.</help>
+ <keywords>general,map management,list</keywords>
<command>g.list</command>
</menuitem>
<menuitem>
<label>List filtered</label>
<help>Lists available GRASS data base files of the user-specified data type to standard output.</help>
<command>g.mlist</command>
</menuitem>
@@ -585,7 +585,7 @@
<menuitem>
<label>Rename</label>
<help>Renames data base element files in the user's current mapset.</help>
+ <keywords>general,map management,rename</keywords>
<command>g.rename</command>
</menuitem>
@@ -593,14 +593,14 @@
<menuitem>
<label>Delete</label>
<help>Removes data base element files from the user's current mapset.</help>
+ <keywords>general,map management,remove</keywords>
<command>g.remove</command>
</menuitem>
<menuitem>
<label>Delete filtered</label>
+ <keywords>general,map management,remove,multi</keywords>
<command>g.mremove</command>
</menuitem>
@@ -711,8 +711,15 @@
</menuitem>
<separator />
<menuitem>
+ <label>Hardcopy Map Output Utility</label>
+ <help>Launch Hardcopy Map Output Utility</help>
+ <keywords>postscript,map,printing</keywords>
+ <handler>OnPsMap</handler>
+ <command>ps.map</command>
+ </menuitem>
+ <menuitem>
<label>Postscript plot</label>
- <help>Hardcopy PostScript map output utility.</help>
+ <help>Produces hardcopy PostScript map output.</help>
@@ -793,14 +800,14 @@
<menuitem>
<label>Show settings</label>
<help>Outputs and modifies the user's current GRASS variable settings.</help>
- <keywords>general</keywords>
+ <keywords>general,settings</keywords>
<handler>RunMenuCmd</handler>
<command>g.gisenv -n</command>
</menuitem>
<menuitem>
<label>Change settings</label>
<command>g.gisenv</command>
</menuitem>
@@ -808,7 +815,7 @@
<menuitem>
<label>Version</label>
<help>Displays version and copyright information.</help>
+ <keywords>general,version</keywords>
<command>g.version -c</command>
</menuitem>
@@ -965,7 +972,7 @@
<separator />
<menuitem>
<label>Reproject raster map</label>
- <help>Re-projects a raster map from one location to the current location.</help>
+ <help>Re-projects a raster map from given location to the current location.</help>
<keywords>raster,projection,transformation</keywords>
<command>r.proj</command>
@@ -1644,7 +1651,7 @@
<separator />
<menuitem>
<label>Gaussian kernel density surface</label>
- <help>Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or optionally generates a vector density map on vector network with a 1D kernel.</help>
+ <help>Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network.</help>
<keywords>vector,kernel density</keywords>
<command>v.kernel</command>
@@ -2429,7 +2436,7 @@
<menuitem>
<label>Basic vector metadata</label>
<help>Outputs basic information about a vector map.</help>
- <keywords>vector,metadata,history</keywords>
+ <keywords>vector,metadata,history,attribute columns</keywords>
<command>v.info</command>
</menuitem>
@@ -2695,7 +2702,7 @@
<menuitem>
<label>Modis quality control</label>
<help>Extract quality control parameters from Modis QC layers</help>
- <keywords>QC,Quality Control,surface reflectance,Modis</keywords>
+ <keywords>QC,Quality Control,Surface Reflectance,Land Surface Temperature,Vegetation,Modis</keywords>
<command>i.modis.qc</command>
</menuitem>
@@ -2737,7 +2744,7 @@
<menuitem>
<label>Tasseled cap vegetation index</label>
<help>Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data</help>
- <keywords>raster,imagery,Landsat</keywords>
+ <keywords>raster,imagery</keywords>
<command>i.tasscap</command>
</menuitem>
@@ -2771,8 +2778,8 @@
<items>
<menuitem>
<label>Instantaneaous Net Radiation</label>
- <help>Instantaneous Net Radiation approximation (Bastiaanssen, 1995)</help>
- <keywords>imagery,Instantaneous Net Radiation,energy balance,SEBAL</keywords>
+ <help>net radiation approximation (Bastiaanssen, 1995)</help>
+ <keywords>net radiation,energy balance,SEBAL,energy balance,SEBAL</keywords>
<command>i.eb.netrad</command>
</menuitem>
@@ -2807,30 +2814,30 @@
</menuitem>
<menuitem>
<label>Temporal integration of ETa</label>
- <help>Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)</help>
- <keywords>imagery,evapotranspiration,temporal,integration</keywords>
+ <help>Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s).</help>
+ <keywords>imagery,evapotranspiration</keywords>
<command>i.evapo.time</command>
</menuitem>
<separator />
<menuitem>
<label>Hargreaves methods Evapotranspiration</label>
- <help>reference evapotranspiration (Hargreaves, modified-H, H and Samani)</help>
- <keywords>imagery,reference evapotranspiration,Hargreaves,Samani</keywords>
+ <help>Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001.</help>
<command>i.evapo.mh</command>
</menuitem>
<menuitem>
<label>Penman-Monteith Evapotranspiration</label>
- <help>reference evapotranspiration (FAO 56 and Penman, 1972)</help>
- <keywords>imagery,reference evapotranspiration,FAO56,Penman-Monteith,HydroFOSS</keywords>
+ <help>Computes potontial evapotranspiration calculation with hourly Penman-Monteith.</help>
<command>i.evapo.pm</command>
</menuitem>
<menuitem>
<label>Priestley-Taylor Evapotranspiration</label>
- <help>reference evapotranspiration (Priestley and Taylor, 1972)</help>
- <keywords>imagery,reference evapotranspiration,Priestley-Taylor</keywords>
+ <help>Computes evapotranspiration calculation Prestley and Taylor formulation, 1972.</help>
<command>i.evapo.pt</command>
</menuitem>
