[GRASS-SVN] r45673 - in grass/trunk/lib/db: dbmi_base dbmi_driver
svn_grass at osgeo.org
Tue Mar 15 13:49:40 EDT 2011
Author: martinl
Date: 2011-03-15 10:49:40 -0700 (Tue, 15 Mar 2011)
New Revision: 45673
grass/trunk/lib/db/dbmi_base/error.c
grass/trunk/lib/db/dbmi_base/value.c
grass/trunk/lib/db/dbmi_driver/d_close_cur.c
grass/trunk/lib/db/dbmi_driver/driver_state.c
fix r45515 - incorect usage of db_free_string() on `char *`
(merge r45671 from relbr64)
Modified: grass/trunk/lib/db/dbmi_base/error.c
--- grass/trunk/lib/db/dbmi_base/error.c 2011-03-15 17:47:52 UTC (rev 45672)
+++ grass/trunk/lib/db/dbmi_base/error.c 2011-03-15 17:49:40 UTC (rev 45673)
@@ -33,7 +33,7 @@
void db_set_error_who(const char *me)
if (who)
- db_free_string(who);
+ db_free(who);
who = db_store(me);
@@ -59,7 +59,7 @@
if (s == NULL)
s = "<NULL error message>";
if (err_msg)
- db_free_string(err_msg);
+ db_free(err_msg);
err_msg = db_store(s);
err_flag = 1;
if (auto_print_errors)
Modified: grass/trunk/lib/db/dbmi_base/value.c
--- grass/trunk/lib/db/dbmi_base/value.c 2011-03-15 17:47:52 UTC (rev 45672)
+++ grass/trunk/lib/db/dbmi_base/value.c 2011-03-15 17:49:40 UTC (rev 45673)
@@ -353,7 +353,6 @@
for (i = 0; i < arr->n_values; i++) {
if (arr->ctype == DB_C_TYPE_STRING && arr->value[i].val.s) {
db_free_string(arr->value[i].val.s);
- db_free(arr->value[i].val.s);
if (arr->ctype == DB_C_TYPE_DATETIME && arr->value[i].val.t) {
db_free(arr->value[i].val.t);
Modified: grass/trunk/lib/db/dbmi_driver/d_close_cur.c
--- grass/trunk/lib/db/dbmi_driver/d_close_cur.c 2011-03-15 17:47:52 UTC (rev 45672)
+++ grass/trunk/lib/db/dbmi_driver/d_close_cur.c 2011-03-15 17:49:40 UTC (rev 45673)
@@ -44,7 +44,7 @@
db_drop_token(token);
db_free_cursor(cursor);
db__drop_cursor_from_driver_state(cursor);
- db_free(cursor);
+ db_free(cursor); /* ?? */
/* send the return code */
if (stat != DB_OK) {
Modified: grass/trunk/lib/db/dbmi_driver/driver_state.c
--- grass/trunk/lib/db/dbmi_driver/driver_state.c 2011-03-15 17:47:52 UTC (rev 45672)
+++ grass/trunk/lib/db/dbmi_driver/driver_state.c 2011-03-15 17:49:40 UTC (rev 45673)
@@ -66,8 +66,8 @@
void db__mark_database_closed(void)
- db_free_string(state.dbname);
- db_free_string(state.dbschema);
+ db_free(state.dbname);
+ db_free(state.dbschema);
state.open = 0;
