[GRASS-SVN] r45675 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Mar 15 19:10:50 EDT 2011
Author: martinl
Date: 2011-03-15 16:10:50 -0700 (Tue, 15 Mar 2011)
New Revision: 45675
grass/trunk/scripts/g.extension/g.extension.py
g.extension: install wxGUI extensions
implement `-s` flag
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-03-15 21:48:37 UTC (rev 45674)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-03-15 23:10:50 UTC (rev 45675)
@@ -52,7 +52,7 @@
#% key: prefix
#% type: string
#% key_desc: path
-#% description: Prefix where to install extension
+#% description: Prefix where to install extension (ignored when flag -s is given)
#% answer: $GRASS_ADDON_PATH
#% required: yes
#%end
@@ -73,6 +73,10 @@
#% guisection: Print
#%end
#%flag
+#% key: s
+#% description: Install system-wide (may need system administrator rights)
+#%end
+#%flag
#% key: d
#% description: Don't delete downloaded source code when installing new extension
#%end
@@ -97,23 +101,23 @@
os.mkdir(tmpdir)
def check():
- # check if we have the svn client
- if not grass.find_program('svn', ['help']):
- grass.fatal(_('svn client required. Please install subversion first.'))
- # probably test here if we have "make" and "install" programs as well. how about gcc?
+ for prog in ('svn', 'make', 'install', 'gcc'):
+ if not grass.find_program(prog, ['--help']):
+ grass.fatal(_("%s required. Please install '%s' first.") % (prog, prog))
def expand_module_class_name(c):
- name = { 'd' : 'display',
- 'db' : 'database',
- 'g' : 'general',
- 'i' : 'imagery',
- 'm' : 'misc',
- 'ps' : 'postscript',
- 'p' : 'paint',
- 'r' : 'raster',
- 'r3' : 'raster3D',
- 's' : 'sites',
- 'v' : 'vector' }
+ name = { 'd' : 'display',
+ 'db' : 'database',
+ 'g' : 'general',
+ 'i' : 'imagery',
+ 'm' : 'misc',
+ 'ps' : 'postscript',
+ 'p' : 'paint',
+ 'r' : 'raster',
+ 'r3' : 'raster3D',
+ 's' : 'sites',
+ 'v' : 'vector',
+ 'gui' : 'gui/wxpython' }
if name.has_key(c):
return name[c]
@@ -121,11 +125,12 @@
return c
def list_available_modules(svnurl, full = False, shell = False):
+ mlist = list()
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
i = 0
- prefix = ['d', 'db', 'g', 'i', 'ps',
- 'p', 'r', 'r3', 'v']
+ prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
+ 'p', 'r', 'r3', 's', 'v']
nprefix = len(prefix)
for d in prefix:
if shell:
@@ -133,7 +138,10 @@
i += 1
modclass = expand_module_class_name(d)
- url = svnurl + '/' + modclass
+ grass.verbose(_("Checking for '%s' modules...") % modclass)
+ url = '%s/%s' % (svnurl, modclass)
+ grass.debug("url = %s" % url, debug = 2)
f = urllib.urlopen(url)
if not f:
grass.warning(_("Unable to fetch '%s'") % url)
@@ -142,13 +150,46 @@
for line in f.readlines():
# list modules
sline = pattern.search(line)
- if sline and sline.group(2).split('.', 1)[0] == d:
- name = sline.group(2).rstrip('/')
+ if not sline:
+ continue
+ name = sline.group(2).rstrip('/')
+ if name.split('.', 1)[0] == d:
print_module_desc(name, url, full, shell)
+ mlist.append(name)
+ mlist += list_wxgui_extensions(svnurl, full, shell)
if shell:
grass.percent(1, 1, 1)
+ return mlist
+def list_wxgui_extensions(svnurl, full = False, shell = False, print_module = True):
+ mlist = list()
+ grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
+ pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
+ grass.verbose(_("Checking for '%s' modules...") % 'gui/wxpython')
+ url = '%s/%s' % (svnurl, 'gui/wxpython')
+ f = urllib.urlopen(url)
+ if not f:
+ grass.warning(_("Unable to fetch '%s'") % url)
+ return
+ for line in f.readlines():
+ # list modules
+ sline = pattern.search(line)
+ if not sline:
+ continue
+ if name not in ('..', 'Makefile'):
+ if print_module:
+ print_module_desc(name, url, full, shell)
+ return mlist
def print_module_desc(name, url, full = False, shell = False):
if not full and not shell:
print name
@@ -258,10 +299,17 @@
if grass.find_program(module):
grass.warning(_("Extension '%s' already installed. Will be updated...") % module)
- classchar = module.split('.', 1)[0]
- moduleclass = expand_module_class_name(classchar)
- url = svnurl + '/' + moduleclass + '/' + module
+ gui_list = list_wxgui_extensions(svnurl, print_module = False)
+ if module not in gui_list:
+ classchar = module.split('.', 1)[0]
+ moduleclass = expand_module_class_name(classchar)
+ url = svnurl + '/' + moduleclass + '/' + module
+ else:
+ url = svnurl + '/gui/wxpython/' + module
+ if not flags['s']:
+ grass.fatal(_("Installation of wxGUI extension requires -%s flag") % 's')
grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
global tmpdir
os.chdir(tmpdir)
@@ -273,7 +321,7 @@
if grass.call(['svn', 'checkout',
url], stdout = outdev) != 0:
grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
os.chdir(os.path.join(tmpdir, module))
grass.message(_("Compiling '%s'...") % module)
@@ -282,29 +330,28 @@
grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
- if no_install:
+ if no_install or module in gui_list:
return
grass.message(_("Installing '%s'...") % module)
- # can we write ?
- try:
- # replace with something better
- file = os.path.join(prefix, 'test')
- f = open(file, "w")
- f.close()
- os.remove(file)
+ # replace with something better
+ file = os.path.join(prefix, 'test')
+ f = open(file, "w")
+ f.close()
+ os.remove(file)
ret = grass.call(['make',
'MODULE_TOPDIR=%s' % gisbase,
'INST_DIR=%s' % prefix,
'install'],
- stdout = outdev)
- except IOError:
+ stdout = outdev)
+ else:
ret = grass.call(['sudo', 'make',
'install'],
- stdout = outdev)
+ stdout = outdev)
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
@@ -353,6 +400,8 @@
grass.fatal(_('You need to define an extension name or use -l'))
# define path
+ if flags['s']:
+ options['prefix'] = os.environ['GISBASE']
if options['prefix'] == '$GRASS_ADDON_PATH':
if not os.environ.has_key('GRASS_ADDON_PATH') or \
not os.environ['GRASS_ADDON_PATH']:
