[GRASS-SVN] r45682 - in grass-addons/gui/wxpython/psmap:
gui_modules xml
svn_grass at osgeo.org
Wed Mar 16 16:55:05 EDT 2011
Author: annakrat
Date: 2011-03-16 13:55:05 -0700 (Wed, 16 Mar 2011)
New Revision: 45682
grass-addons/gui/wxpython/psmap/gui_modules/psmap.py
grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py
grass-addons/gui/wxpython/psmap/xml/menudata_psmap.xml
instruction file reading, needs testing
Modified: grass-addons/gui/wxpython/psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/psmap/gui_modules/psmap.py 2011-03-16 19:09:47 UTC (rev 45681)
+++ grass-addons/gui/wxpython/psmap/gui_modules/psmap.py 2011-03-16 20:55:05 UTC (rev 45682)
@@ -59,6 +59,9 @@
label = _('Generate instruction file')),
'export' : MetaIcon(img = iconSet['ps-export'],
label = _('Generate PostScript output')),
+ 'loadFile' : MetaIcon(img = iconSet['open'],
+ label = _('Load file'),
+ desc = _('Load file with mapping instructions')),
'pageSetup' : MetaIcon(img = iconSet['settings'],
label = _('Page setup'),
desc = _('Specify paper size, margins and orientation')),
@@ -138,6 +141,7 @@
self.preview = wx.NewId()
self.instructionFile = wx.NewId()
self.generatePS = wx.NewId()
+ self.loadFile = wx.NewId()
self.pan = wx.NewId()
icons = Icons['psMap']
@@ -172,6 +176,8 @@
self.parent.OnInstructionFile),
(self.generatePS, 'generatePS', icons['export'],
self.parent.OnPSFile),
+ (self.loadFile, 'loadFile', icons['loadFile'],
+ self.parent.OnLoadFile),
(None, ),
(self.quit, 'quit', icons['quit'],
self.parent.OnCloseWindow))
@@ -295,11 +301,7 @@
self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
self.Bind(EVT_CMD_DONE, self.OnCmdDone)
-## # load instructions
-## self.readObjectId = []
-## self.readInstruction = Instruction(parent = self, objectsToDraw = self.readObjectId)
-## self.readInstruction.Read('/home/anna/Desktop/reading.txt')
-## print '%%%%%%%%%%%%%%%%%%%\n',self.readInstruction
def _layout(self):
"""!Do layout
@@ -430,8 +432,38 @@
if filename:
instrFile = open(filename, "w")
instrFile.write(self.InstructionFile())
- instrFile.close()
+ instrFile.close()
+ def OnLoadFile(self, event):
+ """!Load file and read instructions"""
+ #find file
+ filename = ''
+ dlg = wx.FileDialog(self, message = "Find instructions file", defaultDir = "",
+ defaultFile = '', wildcard = "All files (*.*)|*.*",
+ style = wx.CHANGE_DIR|wx.OPEN)
+ if dlg.ShowModal() == wx.ID_OK:
+ filename = dlg.GetPath()
+ dlg.Destroy()
+ if not filename:
+ return
+ # load instructions
+ #filename = '/home/anna/Desktop/reading.txt'
+ readObjectId = []
+ readInstruction = Instruction(parent = self, objectsToDraw = readObjectId)
+ ok = readInstruction.Read(filename)
+ if not ok:
+ GMessage(_("Failed to read file {0}.").format(filename))
+ else:
+ self.instruction = self.canvas.instruction = readInstruction
+ self.objectId = self.canvas.objectId = readObjectId
+ self.pageId = self.canvas.pageId = self.instruction.FindInstructionByType('page').id
+ self.canvas.UpdateMapLabel()
+ self.canvas.dragId = -1
+ self.canvas.Clear()
+ #self.canvas.ZoomAll()
+ self.DialogDataChanged(self.objectId)
def OnPageSetup(self, event = None):
"""!Specify paper size, margins and orientation"""
id = self.instruction.FindInstructionByType('page').id
@@ -504,7 +536,10 @@
self.toolbar.ToggleTool(self.actionOld, True)
self.toolbar.ToggleTool(self.toolbar.action['id'], False)
self.toolbar.action['id'] = self.actionOld
- self.canvas.SetCursor(self.cursorOld)
+ try:
+ self.canvas.SetCursor(self.cursorOld)
+ except AttributeError:
+ pass
dlg = MapDialog(parent = self, id = id, settings = self.instruction,
notebook = notebook)
@@ -910,9 +945,14 @@
self.pdcPaper.SetBackground(bg)
self.pdcPaper.Clear()
self.pdcPaper.EndDrawing()
+ self.pdcObj.RemoveAll()
+ self.pdcTmp.RemoveAll()
if not self.preview:
self.SetPage()
def CanvasPaperCoordinates(self, rect, canvasToPaper = True):
@@ -981,7 +1021,7 @@
texts = self.instruction.FindInstructionByType('text', list = True)
for text in texts:
- e, n = PaperMapCoordinates(self, mapId = mapId, x = self.instruction[text.id]['where'][0],
+ e, n = PaperMapCoordinates(map = self.instruction[mapId], x = self.instruction[text.id]['where'][0],
y = self.instruction[text.id]['where'][1], paperToMap = True)
self.instruction[text.id]['east'], self.instruction[text.id]['north'] = e, n
@@ -1480,6 +1520,7 @@
def UpdateMapLabel(self):
"""!Updates map frame label"""
mapId = self.instruction.FindInstructionByType('map').id
vector = self.instruction.FindInstructionByType('vector')
vectorId = vector.id if vector else None
Modified: grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py
--- grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py 2011-03-16 19:09:47 UTC (rev 45681)
+++ grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py 2011-03-16 20:55:05 UTC (rev 45682)
@@ -32,9 +32,9 @@
'gui_modules'))
import globalvar
import dbm_base
-from utils import CmdToTuple
+from utils import CmdToTuple, GetCmdString
from gselect import Select
-from gcmd import RunCommand, GError, GMessage
+from gcmd import RunCommand, GError, GMessage, GWarning
import wx
import wx.lib.scrolledpanel as scrolled
@@ -49,11 +49,14 @@
grass.set_raise_on_error(True)
-class UnitConversion():
+class UnitConversion:
"""! Class for converting units"""
- def __init__(self, parent):
+ def __init__(self, parent = None):
self.parent = parent
- ppi = wx.PaintDC(self.parent).GetPPI()
+ if self.parent:
+ ppi = wx.PaintDC(self.parent).GetPPI()
+ else:
+ ppi = (72, 72)
self._unitsPage = { 'inch' : 1.0,
'point' : 72.0,
'centimeter' : 2.54,
@@ -243,7 +246,10 @@
def AddInstruction(self, instruction):
"""!Add instruction"""
- self.instruction.append(instruction)
+ if instruction.type == 'map':
+ self.instruction.insert(0, instruction)
+ else:
+ self.instruction.append(instruction)
if instruction.type not in ('page', 'raster', 'vector', 'vProperties', 'initMap'):
self.objectsToDraw.append(instruction.id)
@@ -261,101 +267,188 @@
def Read(self, filename):
"""!Reads instruction file and creates instruction objects"""
- print 'Starts to read...'
+ self.filename = filename
# open file
try:
file = open(filename, 'r')
except IOError:
GError(message = _("Unable to open file\n{0}").format(filename))
return
- # read lines
+ # first read file to get information about region and scaletype
+ isRegionComment = False
+ for line in file:
+ if '# g.region' in line:
+ self.SetRegion(regionInstruction = line)
+ isRegionComment = True
+ break
+ if not isRegionComment:
+ self.SetRegion(regionInstruction = None)
+ # then run ps.map -b to get information for maploc
+ # compute scale and center
+ map = self.FindInstructionByType('map')
+ region = grass.region()
+ map['center'] = (region['n'] + region['s']) / 2, (region['w'] + region['e']) / 2
+ mapRect = GetMapBounds(self.filename)
+ map['rect'] = mapRect
+ proj = projInfo()
+ toM = 1.0
+ if proj['units']:
+ toM = float(proj['meters'])
+ units = UnitConversion(self.parent)
+ w = units.convert(value = mapRect.Get()[2], fromUnit = 'inch', toUnit = 'meter') / toM
+ map['scale'] = w / abs((region['w'] - region['e']))
+ # read file again, now with information about map bounds
isBuffer = False
buffer = []
instruction = None
- isRegionComment = False
+ vectorMapNumber = 1
+ file.seek(0)
for line in file:
line = line.strip()
if isBuffer:
buffer.append(line)
if line.startswith('end'):
isBuffer = False
- self.SendToRead(instruction, buffer)
+ kwargs = {}
+ if instruction == 'scalebar':
+ kwargs['scale'] = map['scale']
+ elif instruction == 'text':
+ kwargs['mapInstruction'] = map
+ elif instruction in ('vpoints', 'vlines', 'vareas'):
+ kwargs['id'] = wx.NewId()
+ kwargs['vectorMapNumber'] = vectorMapNumber
+ vectorMapNumber += 1
+ ok = self.SendToRead(instruction, buffer, **kwargs)
+ if not ok: return False
buffer = []
- continue
- if line.startswith('#'):
- if 'g.region' in line:
- instruction = 'gregion'
- self.SendToRead(instruction, line)
- isRegionComment = True
- else:
- continue
+ continue
- if line.startswith('paper'):
+ elif line.startswith('paper'):
instruction = 'paper'
isBuffer = True
buffer.append(line)
- continue
- if line.startswith('border'):
- if line == 'border n':
- self.SendToRead('border', [line])
- continue
- elif line == 'border y':
+ elif line.startswith('border'):
+ if line.split()[1].lower() in ('n', 'no', 'none'):
+ ok = self.SendToRead('border', [line])
+ elif line.split()[1].lower() in ('y', 'yes'):
instruction = 'border'
isBuffer = True
buffer.append(line)
- continue
- if line.startswith('scale'):
- self.SendToRead('scale', line)
- continue
+ elif line.startswith('scale '):
+ ok = self.SendToRead('scale', line, isRegionComment = isRegionComment)
- if line.startswith('maploc'):
- self.SendToRead(instruction = 'maploc', text = line, filename = filename)
- continue
+ elif line.startswith('maploc'):
+ ok = self.SendToRead(instruction = 'maploc', text = line)
- if line.startswith('raster'):
- self.SendToRead(instruction = 'raster', text = line)
- continue
+ elif line.startswith('raster'):
+ ok = self.SendToRead(instruction = 'raster', text = line)
+ elif line.startswith('mapinfo'):
+ instruction = 'mapinfo'
+ isBuffer = True
+ buffer.append(line)
isBuffer = True
buffer.append(line)
- continue
+ if line.startswith('scalebar'):
+ instruction = 'scalebar'
+ isBuffer = True
+ if line.startswith('text'):
+ instruction = 'text'
+ isBuffer = True
+ if line.startswith('colortable'):
+ if len(line.split()) == 2 and line.split()[1].lower() in ('n', 'no', 'none'):
+ break
+ instruction = 'colortable'
+ isBuffer = True
- # check at the end
- if not isRegionComment:
- map = self.FindInstructionByType('map')
- if map:
- map['scaleType'] = 2 # current region
- if not map['rect']:
- map['rect'] = GetMapBounds(filename)
- if map['rect']:
- region = grass.region()
- units = UnitConversion(self.parent)
- realWidth = units.convert(value = abs(region['w'] - region['e']), fromUnit = 'meter', toUnit = 'inch')
- scale = map['rect'].Get()[2]/realWidth
- map['scale'] = scale
+ if line.startswith('vlegend'):
+ instruction = 'vlegend'
+ isBuffer = True
+ if line.startswith('vpoints'):
+ instruction = 'vpoints'
+ isBuffer = True
+ if line.startswith('vlines'):
+ instruction = 'vlines'
+ isBuffer = True
+ if line.startswith('vareas'):
+ instruction = 'vareas'
+ isBuffer = True
+ # rasterLegend
+ rasterLegend = self.FindInstructionByType('rasterLegend')
+ raster = self.FindInstructionByType('raster')
+ page = self.FindInstructionByType('page')
+ if rasterLegend:
+ if rasterLegend['rasterDefault'] and raster['raster']:
+ rasterLegend['raster'] = raster['raster']
+ if not rasterLegend['discrete']:
+ rasterType = getRasterType(map = rasterLegend['raster'])
+ if rasterType == 'CELL':
+ rasterLegend['discrete'] = 'y'
+ else:
+ rasterLegend['discrete'] = 'n'
+ #estimate size
+ height = rasterLegend.EstimateHeight(raster = rasterLegend['raster'], discrete = rasterLegend['discrete'],
+ fontsize = rasterLegend['fontsize'],
+ cols = rasterLegend['cols'],
+ height = rasterLegend['height'])
+ width = rasterLegend.EstimateWidth(raster = rasterLegend['raster'], discrete = rasterLegend['discrete'],
+ cols = rasterLegend['cols'] ,
+ width = rasterLegend['width'],
+ paperInstr = page)
+ rasterLegend['rect'] = wx.Rect2D(x = float(rasterLegend['where'][0]), y = float(rasterLegend['where'][1]),
+ w = width, h = height)
+ # vectors, vlegend
+ vector = self.FindInstructionByType('vector')
+ vectorLegend = self.FindInstructionByType('vectorLegend')
+ vectorMaps = self.FindInstructionByType('vProperties', list = True)
+ if vector:
+ for vmap in vectorMaps:
+ for i, each in enumerate(vector['list']):
+ if each[2] == vmap.id:
- else:
- rect = GetMapBounds(filename)
- if rect:
- initMap = InitMap(wx.NewId())
- self.instruction.AddInstruction(initMap)
- initMap['rect'] = rect
- scale = rect.Get()[2]/realWidth
- initMap['scale'] = scale
- print 'end of reading'
+ vector['list'][i][4] = vmap['label']
+ vector['list'][i][3] = vmap['lpos']
+ if vectorLegend:
+ size = vectorLegend.EstimateSize(vectorInstr = vector, fontsize = vectorLegend['fontsize'],
+ width = vectorLegend['width'], cols = vectorLegend['cols'])
+ vectorLegend['rect'] = wx.Rect2D(x = float(vectorLegend['where'][0]), y = float(vectorLegend['where'][1]),
+ w = size[0], h = size[1])
+ if not page:
+ page = PageSetup(wx.NewId())
+ self.AddInstruction(page)
+ return True
def SendToRead(self, instruction, text, **kwargs):
#print 'send to read', instruction, text
psmapInstrDict = dict( paper = ['page'],
@@ -370,9 +463,7 @@
vlines = ['vector', 'vProperties'],
vareas = ['vector', 'vProperties'],
colortable = ['rasterLegend'],
- vlegend = ['vectorLegend'],
- # not a real instruction, just help in commentary
- gregion = ['map']
+ vlegend = ['vectorLegend']
myInstrDict = dict( page = PageSetup,
@@ -392,23 +483,65 @@
for i in myInstruction:
instr = self.FindInstructionByType(i)
if i in ('text', 'vProperties') or not instr:
id = wx.NewId() #!vProperties expect subtype
- newInstr = myInstrDict[i](id)
+ if i == 'vProperties':
+ id = kwargs['id']
+ newInstr = myInstrDict[i](id, subType = instruction[1:])
+ else:
+ newInstr = myInstrDict[i](id)
ok = newInstr.Read(instruction, text, **kwargs)
if ok:
self.AddInstruction(newInstr)
else:
- GMessage(_("Failed to read"))
+ return False
else:
ok = instr.Read(instruction, text, **kwargs)
if not ok:
+ return False
+ return True
+ def SetRegion(self, regionInstruction):
+ """!Sets region from file comment or sets current region in case of no comment"""
+ map = MapFrame(wx.NewId())
+ self.AddInstruction(map)
+ if regionInstruction:
+ cmd = CmdToTuple(regionInstruction.strip('# ').split())
+ # define scaleType
+ if len(cmd[1]) == 1:
+ if 'rast' in cmd[1]:
+ map['scaleType'] = 0
+ map['mapType'] = 'raster'
+ map['map'] = cmd[1]['rast']
+ elif 'vect' in cmd[1]:
+ map['mapType'] = 'vector'
+ map['map'] = cmd[1]['vect']
+ elif 'region' in cmd[1]:
+ map['scaleType'] = 1
+ map['region'] = cmd[1]['region']
+ else:
+ map['scaleType'] = 2
+ else:
+ grass.del_temp_region()
+ grass.use_temp_region()
+ cmd = ['g.region', region]
+ cmdString = GetCmdString(cmd).replace('g.region', '')
+ GMessage(_("Instruction file will be loaded with following region: {0}\n").format(cmdString))
+ try:
+ RunCommand(cmd[0], **cmd[1])
+ except ScriptError, e:
+ GError(_("Region cannot be set\n{0}").format(e))
+ return False
class InstructionObject:
"""!Abtract class representing single instruction"""
def __init__(self, id):
@@ -417,7 +550,9 @@
# default values
self.defaultInstruction = dict()
# current values
- self.instruction = self.defaultInstruction
+ self.instruction = self.defaultInstruction
+ # converting units
+ self.unitConv = UnitConversion()
def __str__(self):
"""!Returns particular part of text instruction"""
@@ -475,13 +610,13 @@
if self.instruction['scaleType'] == 0: #match map
map = self.instruction['map']
mapType = 'rast' if self.instruction['mapType'] == 'raster' else 'vect'
- comment = "# set region: g.region {0}={1}\n".format(mapType, map)
+ comment = "# g.region {0}={1}\n".format(mapType, map)
elif self.instruction['scaleType'] == 1:# saved region
region = self.instruction['region']
- comment = "# set region: g.region region={0}\n".format(region)
- elif self.instruction['scaleType'] == 3: #fixed scale
+ comment = "# g.region region={0}\n".format(region)
+ elif self.instruction['scaleType'] in (2, 3): #current region, fixed scale
- comment = "# set region: g.region n={n} s={s} e={e} w={w}\n".format(**region)
+ comment = "# g.region n={n} s={s} e={e} w={w} rows={rows} cols={cols}\n".format(**region)
instr += comment
instr += '\n'
# maploc
@@ -511,40 +646,19 @@
def Read(self, instruction, text, **kwargs):
"""!Read instruction and save information"""
+ if 'isRegionComment' in kwargs:
+ isRegionComment = kwargs['isRegionComment']
instr = {}
- if instruction == 'gregion':
- start = text.find('g.region')
- cmd = text[start:].split()
- if len(cmd) == 2:
- if cmd[1].split('=')[0] == 'rast':
- instr['scaleType'] = 0
- instr['mapType'] = 'raster'
- instr['map'] = cmd[1].split('=')[1]
- elif cmd[1].split('=')[0] == 'vect':
- instr['mapType'] = 'vector'
- elif cmd[1].split('=')[0] == 'region':
- instr['scaleType'] = 1
- instr['region'] = cmd[1].split('=')[1]
- elif len(text[start:].split()[1:]) == 4:
- instr['scaleType'] = 3
- region = grass.parse_key_val(text[start:].split(' ',1)[1], val_type = float, vsep = ' ')
- instr['center'] = (region['n'] + region['s']) / 2, (region['w'] + region['e']) / 2
- cmd = CmdToTuple(cmd)
- RunCommand(cmd[0], **cmd[1])
- elif instruction == 'border':
+ if instruction == 'border':
for line in text:
+ if line.startswith('end'):
+ break
try:
instr['border'] = 'n'
break
instr['border'] = 'y'
elif line.startswith('width'):
instr['width'] = line.split()[1]
@@ -556,17 +670,31 @@
elif instruction == 'scale':
try:
- scale = text.strip('scale ').split(':')[1]
- instr['scale'] = 1/float(scale)
+ scaleText = text.strip('scale ').split(':')[1]
+ # when scale instruction given and region comment also, then scaletype is fixed scale
+ instr['scaleType'] = 2 if not isRegionComment else 3
+ scale = 1/float(scaleText)
+ if abs(scale - self.instruction['scale']) > (0.01 * scale):
+ GWarning(_("Scale has changed, old value: {0}\nnew value: {1}").format(scale, self.instruction['scale']))
except (ValueError, IndexError):
GError(_("Failed to read instruction {0}.\nUse 1:25000 notation.").format(instruction))
return False
elif instruction == 'maploc':
- #TODO: run psmap -b always?
- instr['rect'] = GetMapBounds(kwargs['filename'])
+ maploc = text.strip('maploc ').split()
+ if len(maploc) >= 2:
+ if abs(self.instruction['rect'].Get()[0] - float(maploc[0])) > 0.5 or \
+ abs(self.instruction['rect'].Get()[1] - float(maploc[1])) > 0.5:
+ GWarning(_("Map frame position changed, old value: {0} {1}\nnew value: {2} {3}").format(
+ maploc[0], maploc[1], *self.instruction['rect'].Get()[0:2]))
+ #instr['rect'] = wx.Rect2D(float(maploc[0]), float(maploc[1]), self.instruction['rect'][2], self.instruction['rect'][3])
+ if len(maploc) == 4:
+ if abs(self.instruction['rect'].Get()[2] - float(maploc[2])) > 0.5 or \
+ abs(self.instruction['rect'].Get()[3] - float(maploc[3])) > 0.5:
+ GWarning(_("Map frame size changed, old value: {0} {1}\nnew value: {2} {3}").format(
+ maploc[2], maploc[3], *self.instruction['rect'].Get()[2:]))
+ #instr['rect'] = wx.Rect2D(*map(float, maploc))
self.instruction.update(instr)
return True
@@ -664,7 +792,7 @@
instr = {}
try:
for line in text:
- sub = line.split(' ',1)
+ sub = line.split(None,1)
if sub[0] == 'font':
instr['font'] = sub[1]
elif sub[0] == 'fontsize':
@@ -676,13 +804,22 @@
elif sub[0] == 'border':
instr['border'] = sub[1]
elif sub[0] == 'where':
- instr['where'] = tuple(sub[2].split())
+ instr['where'] = tuple(sub[1].split())
GError(_("Failed to read instruction {0}").format(instruction))
+ return False
+ self.instruction['rect'] = self.EstimateRect(mapinfoDict = self.instruction)
return True
+ def EstimateRect(self, mapinfoDict):
+ """!Estimate size to draw mapinfo"""
+ w = mapinfoDict['fontsize'] * 20 # any better estimation?
+ h = mapinfoDict['fontsize'] * 7
+ width = self.unitConv.convert(value = w, fromUnit = 'point', toUnit = 'inch')
+ height = self.unitConv.convert(value = h, fromUnit = 'point', toUnit = 'inch')
+ return wx.Rect2D(x = float(mapinfoDict['where'][0]), y = float(mapinfoDict['where'][1]), w = width, h = height)
class Text(InstructionObject):
"""!Class representing text instruction"""
@@ -717,14 +854,75 @@
instr += "end"
return instr
+ def Read(self, instruction, text, **kwargs):
+ """!Read instruction and save information"""
+ map = kwargs['mapInstruction']
+ instr = {}
+ for line in text:
+ try:
+ sub = line.split(None, 1)[0]
+ if sub == 'text':
+ e, n = line.split(None, 3)[1:3]
+ if '%' in e and '%' in n:
+ instr['XY'] = True
+ instr['east'], instr['north'] = self.PercentToReal(e, n)
+ else:
+ instr['XY'] = False
+ instr['east'], instr['north'] = float(e), float(n)
+ instr['text'] = line.split(None, 3)[3]
+ elif sub == 'font':
+ instr['font'] = line.split(None, 1)[1]
+ elif sub == 'fontsize':
+ instr['fontsize'] = float(line.split(None, 1)[1])
+ elif sub == 'color':
+ instr['color'] = line.split(None, 1)[1]
+ elif sub == 'width':
+ instr['width'] = line.split(None, 1)[1]
+ elif sub == 'hcolor':
+ instr['hcolor'] = line.split(None, 1)[1]
+ elif sub == 'hwidth':
+ instr['hwidth'] = line.split(None, 1)[1]
+ elif sub == 'background':
+ instr['background'] = line.split(None, 1)[1]
+ elif sub == 'border':
+ instr['border'] = line.split(None, 1)[1]
+ elif sub == 'ref':
+ instr['ref'] = line.split(None, 1)[1]
+ elif sub == 'rotate':
+ instr['rotate'] = float(line.split(None, 1)[1])
+ elif sub == 'xoffset':
+ instr['xoffset'] = float(line.split(None, 1)[1])
+ elif sub == 'yoffset':
+ instr['yoffset'] = float(line.split(None, 1)[1])
+ elif sub == 'opaque':
+ if line.split(None, 1)[1].lower() in ('n', 'none'):
+ instr['background'] = 'none'
+ except(IndexError, ValueError):
+ GError(_("Failed to read instruction {0}").format(instruction))
+ return False
+ instr['where'] = PaperMapCoordinates(map = map, x = instr['east'], y = instr['north'], paperToMap = False)
+ self.instruction.update(instr)
+ return True
+ def PercentToReal(self, e, n):
+ """!Converts text coordinates from percent of region to map coordinates"""
+ e, n = float(e.strip('%')), float(n.strip('%'))
+ N = region['s'] + (region['n'] - region['s']) / 100 * n
+ E = region['w'] + (region['e'] - region['w']) / 100 * e
+ return E, N
class Scalebar(InstructionObject):
"""!Class representing scalebar instruction"""
InstructionObject.__init__(self, id = id)
self.type = 'scalebar'
# default values
- self.defaultInstruction = dict( unit = 'inch', where = (0,0),
+ self.defaultInstruction = dict( unit = 'inch', where = (1,1),
unitsLength = 'auto', unitsHeight = 'inch',
length = None, height = 0.1, rect = None,
fontsize = 10, background = 'y',
@@ -741,7 +939,64 @@
instr += " fontsize {fontsize}\n background {background}\n".format(**self.instruction)
instr += "end"
return instr
+ scale = kwargs['scale']
+ instr = {}
+ for line in text:
+ try:
+ if 'scalebar s' in line:
+ instr['scalebar'] = 's'
+ else:
+ instr['scalebar'] = 'f'
+ elif line.startswith('where'):
+ instr['where'] = line.split()[1:3]
+ elif line.startswith('length'):
+ instr['length'] = float(line.split()[1])
+ elif line.startswith('units'):
+ if line.split()[1] in ['auto', 'meters', 'kilometers', 'feet', 'miles', 'nautmiles']:
+ instr['unitsLength'] = line.split()[1]
+ elif line.startswith('height'):
+ instr['height'] = float(line.split()[1])
+ elif line.startswith('fontsize'):
+ instr['fontsize'] = float(line.split()[1])
+ elif line.startswith('numbers'):
+ instr['numbers'] = int(line.split()[1])
+ elif line.startswith('segment'):
+ instr['segment'] = int(line.split()[1])
+ elif line.startswith('background'):
+ if line.split()[1].strip().lower() in ('y','yes'):
+ instr['background'] = 'y'
+ elif line.split()[1].strip().lower() in ('n','no', 'none'):
+ instr['background'] = 'n'
+ return False
+ w, h = self.EstimateSize(scalebarDict = self.instruction, scale = scale)
+ x = float(self.instruction['where'][0]) - w / 2
+ y = float(self.instruction['where'][1]) - h / 2
+ self.instruction['rect'] = wx.Rect2D(x, y, w, h)
+ return True
+ def EstimateSize(self, scalebarDict, scale):
+ """!Estimate size to draw scalebar"""
+ units = projInfo()['units']
+ if not units or units not in self.unitConv.getAllUnits():
+ units = 'meters'
+ if scalebarDict['unitsLength'] != 'auto':
+ length = self.unitConv.convert(value = scalebarDict['length'], fromUnit = scalebarDict['unitsLength'], toUnit = 'inch')
+ else:
+ length = self.unitConv.convert(value = scalebarDict['length'], fromUnit = units, toUnit = 'inch')
+ length *= scale
+ length *= 1.1 #for numbers on the edge
+ height = scalebarDict['height'] + 2 * self.unitConv.convert(value = scalebarDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
+ return (length, height)
class RasterLegend(InstructionObject):
"""!Class representing colortable instruction"""
@@ -750,11 +1005,11 @@
# default values
self.defaultInstruction = dict(rLegend = False, unit = 'inch', rasterDefault = True, raster = None,
discrete = None, type = None,
- where = (0, 0), defaultSize = True,
- width = 0, height = 0, cols = 1, font = "Serif", fontsize = 10,
+ where = (0, 0),
+ width = None, height = None, cols = 1, font = "Helvetica", fontsize = 10,
#color = '0:0:0', tickbar = False, range = False, min = 0, max = 0,
- color = 'black', tickbar = False, range = False, min = 0, max = 0,
- nodata = False)
+ color = 'black', tickbar = 'n', range = False, min = 0, max = 0,
+ nodata = 'n')
# current values
self.instruction = dict(self.defaultInstruction)
@@ -762,11 +1017,11 @@
instr = "colortable y\n"
instr += " raster {raster}\n".format(**self.instruction)
instr += " where {where[0]} {where[1]}\n".format(**self.instruction)
- if not self.instruction['defaultSize']:
+ if self.instruction['width']:
instr += " width {width}\n".format(**self.instruction)
instr += " discrete {discrete}\n".format(**self.instruction)
if self.instruction['discrete'] == 'n':
+ if self.instruction['height']:
instr += " height {height}\n".format(**self.instruction)
instr += " tickbar {tickbar}\n".format(**self.instruction)
if self.instruction['range']:
@@ -778,8 +1033,122 @@
instr += "end"
return instr
+ instr = {}
+ instr['rLegend'] = True
+ for line in text:
+ try:
+ if line.startswith('where'):
+ elif line.startswith('font '):
+ instr['font'] = line.split()[1]
+ elif line.startswith('color '):
+ instr['color'] = line.split()[1]
+ instr['raster'] = line.split()[1]
+ elif line.startswith('width'):
+ instr['width'] = float(line.split()[1])
+ elif line.startswith('cols'):
+ instr['cols'] = int(line.split()[1])
+ elif line.startswith('range'):
+ instr['range'] = True
+ instr['min'] = float(line.split()[1])
+ instr['max'] = float(line.split()[2])
+ elif line.startswith('nodata'):
+ instr['nodata'] = 'y'
+ instr['nodata'] = 'n'
+ elif line.startswith('tickbar'):
+ instr['tickbar'] = 'y'
+ instr['tickbar'] = 'n'
+ elif line.startswith('discrete'):
+ instr['discrete'] = 'y'
+ instr['discrete'] = 'n'
+ return False
+ if 'raster' in instr:
+ instr['rasterDefault'] = False
+ if 'discrete' not in instr:
+ rasterType = getRasterType(map = instr['raster'])
+ instr['type'] = rasterType
+ else:
+ else:
+ instr['rasterDefault'] = True
+ # add 'rect' in the end
+ return True
+ def EstimateHeight(self, raster, discrete, fontsize, cols = None, height = None):
+ """!Estimate height to draw raster legend"""
+ if discrete == 'n':
+ if height:
+ height = height
+ else:
+ height = self.unitConv.convert(value = fontsize * 10,
+ fromUnit = 'point', toUnit = 'inch')
+ if discrete == 'y':
+ cols = cols if cols else 1
+ try:
+ cat = grass.read_command('r.category', map = raster,
+ fs = ':').strip().split('\n')
+ rows = ceil( float(len(cat)) / cols )
+ except grass.ScriptError:
+ range = grass.read_command('r.info', flags = 'r', map = raster).strip().split('\n')
+ minim, maxim = range[0].split('=')[1], range[1].split('=')[1]
+ rows = ceil( float(maxim) / cols )
+ height = self.unitConv.convert(value = 1.5 * rows * fontsize, fromUnit = 'point', toUnit = 'inch')
+ return height
+ def EstimateWidth(self, raster, discrete, fontsize, cols = None, width = None, paperInstr = None):
+ """!Estimate size to draw raster legend"""
+ if width:
+ width = width
+ else:
+ width = self.unitConv.convert(value = fontsize * 2,
+ text = len(max(minim, maxim, key = len))
+ textPart = self.unitConv.convert(value = text * fontsize / 2,
+ width += textPart
+ elif discrete == 'y':
+ if width:
+ width = width
+ else:
+ paperWidth = paperInstr['Width'] - paperInstr['Right'] - paperInstr['Left']
+ width = (paperWidth / cols) * (cols - 1) + 1
+ return width
class VectorLegend(InstructionObject):
@@ -787,7 +1156,8 @@
self.type = 'vectorLegend'
# default values
self.defaultInstruction = dict(vLegend = False, unit = 'inch', where = (0, 0),
- defaultSize = True, width = 0.4, cols = 1, span = None, font = "Serif", fontsize = 10,
+ defaultSize = True, width = 0.4, cols = 1, span = None,
+ font = "Helvetica", fontsize = 10,
border = 'none')
# current values
@@ -802,7 +1172,51 @@
instr += " border {border}\n".format(**self.instruction)
instr += "end"
return instr
+ instr = {}
+ instr['vLegend'] = True
+ for line in text:
+ try:
+ elif line.startswith('span'):
+ instr['span'] = float(line.split()[1])
+ instr['border'] = line.split()[1]
+ return False
+ return True
+ def EstimateSize(self, vectorInstr, fontsize, width = None, cols = None):
+ """!Estimate size to draw vector legend"""
+ width = width if width else fontsize/24.0
+ vectors = vectorInstr['list']
+ labels = [vector[4] for vector in vectors if vector[3] != 0]
+ extent = (len(max(labels, key = len)) * fontsize / 2, fontsize)
+ wExtent = self.unitConv.convert(value = extent[0], fromUnit = 'point', toUnit = 'inch')
+ hExtent = self.unitConv.convert(value = extent[1], fromUnit = 'point', toUnit = 'inch')
+ w = (width + wExtent) * cols
+ h = len(labels) * hExtent / cols
+ h *= 1.1
+ return (w, h)
class Raster(InstructionObject):
"""!Class representing raster instruction"""
@@ -843,12 +1257,47 @@
self.type = 'vector'
# default values
- self.defaultInstruction = dict(list = None)
+ self.defaultInstruction = dict(list = None)# [vmap, type, id, lpos, label]
# current values
def __str__(self):
return ''
+ instr = {}
+ for line in text:
+ if line.startswith('vpoints') or line.startswith('vlines') or line.startswith('vareas'):
+ # subtype
+ subType = 'points'
+ elif line.startswith('vlines'):
+ subType = 'lines'
+ elif line.startswith('vareas'):
+ subType = 'areas'
+ # name of vector map
+ vmap = line.split()[1]
+ try:
+ info = grass.find_file(vmap, element = 'vector')
+ except grass.ScriptError, e:
+ GError(message = e.value)
+ return False
+ vmap = info['fullname']
+ # id
+ id = kwargs['id']
+ # lpos
+ lpos = kwargs['vectorMapNumber']
+ #label
+ label = '('.join(vmap.split('@')) + ')'
+ break
+ instr = [vmap, subType, id, lpos, label]
+ if not self.instruction['list']:
+ self.instruction['list'] = []
+ self.instruction['list'].append(instr)
+ return True
class VProperties(InstructionObject):
"""!Class represents instructions vareas, vlines, vpoints"""
def __init__(self, id, subType):
@@ -857,17 +1306,20 @@
self.subType = subType
# default values
if self.subType == 'points':
- dd = dict(subType = 'points', name = None, type = 'point or centroid', connection = False, layer = '1', masked = 'n', color = '0:0:0', width = 1,
+ dd = dict(subType = 'points', name = None, type = 'point or centroid', connection = False, layer = '1',
+ masked = 'n', color = '0:0:0', width = 1,
fcolor = '255:0:0', rgbcolumn = None, symbol = os.path.join('basic', 'x'), eps = None,
size = 5, sizecolumn = None, scale = None,
rotation = False, rotate = 0, rotatecolumn = None, label = None, lpos = None)
elif self.subType == 'lines':
- dd = dict(subType = 'lines', name = None, type = 'line or boundary', connection = False, layer = '1', masked = 'n', color = '0:0:0', hwidth = 1,
+ dd = dict(subType = 'lines', name = None, type = 'line or boundary', connection = False, layer = '1',
+ masked = 'n', color = '0:0:0', hwidth = 1,
hcolor = 'none', rgbcolumn = None,
width = 1, cwidth = None,
style = 'solid', linecap = 'butt', label = None, lpos = None)
else: # areas
- dd = dict(subType = 'areas', name = None, type = 'point or centroid', connection = False, layer = '1', masked = 'n', color = '0:0:0', width = 1,
+ dd = dict(subType = 'areas', name = None, connection = False, layer = '1',
fcolor = 'none', rgbcolumn = None,
pat = None, pwidth = 1, scale = 1, label = None, lpos = None)
self.defaultInstruction = dd
@@ -938,6 +1390,119 @@
vInstruction += "end"
return vInstruction
+ instr = {}
+ try:
+ info = grass.find_file(name = text[0].split()[1], element = 'vector')
+ return False
+ instr['name'] = info['fullname']
+ #connection
+ instr['connection'] = True
+ try:
+ self.mapDBInfo = dbm_base.VectorDBInfo(instr['name'])
+ instr['connection'] = False
+ # points
+ if text[0].startswith('vpoints'):
+ for line in text[1:]:
+ if line.startswith('type'):
+ tp = []
+ if line.find('point') != -1:
+ tp.append('point')
+ if line.find('centroid') != -1:
+ tp.append('centroid')
+ instr['type'] = ' or '.join(tp)
+ elif line.startswith('fcolor'):
+ instr['fcolor'] = line.split()[1]
+ elif line.startswith('rgbcolumn'):
+ instr['rgbcolumn'] = line.split()[1]
+ elif line.startswith('symbol'):
+ instr['symbol'] = line.split()[1]
+ elif line.startswith('eps'):
+ instr['eps'] = line.split()[1]
+ elif line.startswith('size '):
+ instr['size'] = line.split()[1]
+ elif line.startswith('sizecolumn'):
+ instr['size'] = None
+ instr['sizecolumn'] = line.split()[1]
+ instr['scale'] = float(line.split()[1])
+ elif line.startswith('rotate '):
+ instr['rotation'] = True
+ instr['rotate'] = line.split()[1]
+ elif line.startswith('rotatecolumn'):
+ instr['rotatecolumn'] = line.split()[1]
+ instr['rotate'] = None
+ # lines
+ elif text[0].startswith('vlines'):
+ tp = []
+ if line.find('line') != -1:
+ tp.append('line')
+ if line.find('boundary') != -1:
+ tp.append('boundary')
+ elif line.startswith('hwidth'):
+ instr['hwidth'] = float(line.split()[1])
+ elif line.startswith('hcolor'):
+ instr['hcolor'] = line.split()[1]
+ elif line.startswith('cwidth'):
+ instr['cwidth'] = float(line.split()[1])
+ instr['width'] = None
+ elif line.startswith('style'):
+ instr['style'] = line.split()[1]
+ elif line.startswith('linecap'):
+ instr['linecap'] = line.split()[1]
+ elif text[0].startswith('vareas'):
+ if line.startswith('fcolor'):
+ elif line.startswith('pat'):
+ instr['pat'] = line.split()[1]
+ elif line.startswith('pwidth'):
+ instr['pwidth'] = float(line.split()[1])
+ elif line.startswith('scale'):
+ # same properties for all
+ if line.startswith('lpos'):
+ instr['lpos'] = int(line.split()[1])
+ elif line.startswith('label'):
+ instr['label'] = line.split()[1]
+ elif line.startswith('layer'):
+ instr['layer'] = int(line.split()[1])
+ elif line.startswith('masked'):
+ if line.split()[1].lower() in ('y', 'yes'):
+ instr['masked'] = 'y'
+ else:
+ instr['masked'] = 'n'
+ elif line.startswith('color'):
+ if 'label' not in instr:
+ instr['label'] = '('.join(instr['name'].split('@')) + ')'
+ if 'lpos' not in instr:
+ instr['lpos'] = kwargs['vectorMapNumber']
+ return True
class PsmapDialog(wx.Dialog):
def __init__(self, parent, id, title, settings, apply = True):
wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY,
@@ -994,8 +1559,11 @@
'Helvetica-Oblique', 'Helvetica-Bold', 'Helvetica-BoldOblique', 'Courier',\
'Courier-Oblique', 'Courier-Bold', 'Courier-BoldOblique']
parent.font['fontCtrl'] = wx.Choice(parent, id = wx.ID_ANY, choices = fontChoices)
- parent.font['fontCtrl'].SetStringSelection(dialogDict['font'])
- parent.font['fontSizeCtrl']= wx.SpinCtrl(parent, id = wx.ID_ANY, min = 4, max = 50, initial = 10)
+ if dialogDict['font'] in fontChoices:
+ parent.font['fontCtrl'].SetStringSelection(dialogDict['font'])
+ else:
+ parent.font['fontCtrl'].SetStringSelection('Helvetica')
+ parent.font['fontSizeCtrl'] = wx.SpinCtrl(parent, id = wx.ID_ANY, min = 4, max = 50, initial = 10)
parent.font['fontSizeCtrl'].SetValue(dialogDict['fontsize'])
if color:
@@ -1880,7 +2448,6 @@
self.listbox.InsertItems([record], 0)
vector = VProperties(id, type)
- #self.instruction.AddInstruction(vector)
self.tmpDialogDict[id] = vector.GetInstruction()
self.tmpDialogDict[id]['name'] = vmap
@@ -2776,11 +3343,12 @@
currPage = self.instruction[self.pageId].GetInstruction()
#raster legend
if self.id[0] is not None:
- self.rLegendDict = self.instruction[self.id[0]].GetInstruction()
+ self.rasterLegend = self.instruction[self.id[0]]
+ self.rLegendDict = self.rasterLegend.GetInstruction()
else:
self.id[0] = wx.NewId()
- rasterLegend = RasterLegend(self.id[0])
- self.rLegendDict = rasterLegend.GetInstruction()
+ self.rasterLegend = RasterLegend(self.id[0])
self.rLegendDict['where'] = currPage['Left'], currPage['Top']
@@ -2801,7 +3369,7 @@
self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
self.panelRaster = self._rasterLegend(self.notebook)
self.panelVector = self._vectorLegend(self.notebook)
- self.OnDefaultSize(None)
+## self.OnDefaultSize(None)
self.OnRaster(None)
self.OnRange(None)
self.OnIsLegend(None)
@@ -2835,7 +3403,7 @@
self.rasterDefault.SetValue(self.rLegendDict['rasterDefault'])#
self.rasterOther.SetValue(not self.rLegendDict['rasterDefault'])#
- rasterType = self.getRasterType(map = self.currRaster)
+ rasterType = getRasterType(map = self.currRaster)
self.rasterCurrent = wx.StaticText(panel, id = wx.ID_ANY, label = _("{0}: type {1}").format(self.currRaster, str(rasterType)))
self.rasterSelect = Select( panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
@@ -2913,7 +3481,7 @@
self.Bind(wx.EVT_CHECKBOX, self.OnIsLegend, self.isRLegend)
self.Bind(wx.EVT_RADIOBUTTON, self.OnDiscrete, self.discrete)
self.Bind(wx.EVT_RADIOBUTTON, self.OnDiscrete, self.continuous)
- self.Bind(wx.EVT_CHECKBOX, self.OnDefaultSize, panel.defaultSize)
+## self.Bind(wx.EVT_CHECKBOX, self.OnDefaultSize, panel.defaultSize)
self.Bind(wx.EVT_CHECKBOX, self.OnRange, self.range)
self.rasterSelect.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnRaster)
@@ -3044,23 +3612,29 @@
#size
width = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width:"))
- w = self.unitConv.convert(value = float(legendDict['width']), fromUnit = 'inch', toUnit = legendDict['unit'])
+ if legendDict['width']:
+ w = self.unitConv.convert(value = float(legendDict['width']), fromUnit = 'inch', toUnit = legendDict['unit'])
+ else:
+ w = ''
panel.widthCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(w), validator = TCValidator("DIGIT_ONLY"))
if legendType == 'raster':
- panel.defaultSize = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Use default size"))
- panel.defaultSize.SetValue(legendDict['defaultSize'])
+## panel.defaultSize = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Use default size"))
+## panel.defaultSize.SetValue(legendDict['defaultSize'])
panel.heightOrColumnsLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Height:"))
- h = self.unitConv.convert(value = float(legendDict['height']), fromUnit = 'inch', toUnit = legendDict['unit'])
+ if legendDict['height']:
+ h = self.unitConv.convert(value = float(legendDict['height']), fromUnit = 'inch', toUnit = legendDict['unit'])
+ else:
+ h = ''
panel.heightOrColumnsCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(h), validator = TCValidator("DIGIT_ONLY"))
self.rSizeGBSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- self.rSizeGBSizer.Add(panel.defaultSize, pos = (0,0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.rSizeGBSizer.Add(width, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.rSizeGBSizer.Add(panel.widthCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.rSizeGBSizer.Add(panel.heightOrColumnsLabel, pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.rSizeGBSizer.Add(panel.heightOrColumnsCtrl, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+## self.rSizeGBSizer.Add(panel.defaultSize, pos = (0,0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.rSizeGBSizer.Add(width, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.rSizeGBSizer.Add(panel.widthCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.rSizeGBSizer.Add(panel.heightOrColumnsLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.rSizeGBSizer.Add(panel.heightOrColumnsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
sizeSizer.Add(self.rSizeGBSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
if legendType == 'vector':
@@ -3137,7 +3711,6 @@
for i,widget in enumerate(children):
widget.Enable()
self.OnRaster(None)
self.OnRange(None)
self.OnDiscrete(None)
else:
@@ -3159,11 +3732,11 @@
def OnRaster(self, event):
if self.rasterDefault.GetValue():#default
self.rasterSelect.Disable()
- type = self.getRasterType(self.currRaster)
+ type = getRasterType(self.currRaster)
else:#select raster
self.rasterSelect.Enable()
map = self.rasterSelect.GetValue()
- type = self.getRasterType(map)
+ type = getRasterType(map)
if type == 'CELL':
self.discrete.SetValue(True)
@@ -3193,7 +3766,10 @@
self.ticks.Disable()
else:
self.panelRaster.heightOrColumnsLabel.SetLabel(_("Height:"))
- h = self.unitConv.convert(value = float(self.rLegendDict['height']), fromUnit = 'inch', toUnit = self.rLegendDict['unit'])
+ if self.rLegendDict['height']:
+ h = self.unitConv.convert(value = float(self.rLegendDict['height']), fromUnit = 'inch', toUnit = self.rLegendDict['unit'])
+ else:
+ h = ''
self.panelRaster.heightOrColumnsCtrl = wx.TextCtrl(self.panelRaster, id = wx.ID_ANY,
self.panelRaster.heightOrColumnsCtrl.Enable(enabledSize)
@@ -3206,18 +3782,18 @@
self.max.Enable()
self.ticks.Enable()
- self.rSizeGBSizer.Add(self.panelRaster.heightOrColumnsCtrl, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.rSizeGBSizer.Add(self.panelRaster.heightOrColumnsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
self.panelRaster.Layout()
self.panelRaster.Fit()
- def OnDefaultSize(self, event):
- if self.panelRaster.defaultSize.GetValue():
- self.panelRaster.widthCtrl.Disable()
- self.panelRaster.heightOrColumnsCtrl.Disable()
- else:
- self.panelRaster.widthCtrl.Enable()
- self.panelRaster.heightOrColumnsCtrl.Enable()
+## def OnDefaultSize(self, event):
+## if self.panelRaster.defaultSize.GetValue():
+## self.panelRaster.widthCtrl.Disable()
+## self.panelRaster.heightOrColumnsCtrl.Disable()
+## else:
+## self.panelRaster.widthCtrl.Enable()
+## self.panelRaster.heightOrColumnsCtrl.Enable()
def OnRange(self, event):
if not self.range.GetValue():
@@ -3309,7 +3885,7 @@
if self.rLegendDict['raster']:
# type and range of map
- rasterType = self.getRasterType(self.rLegendDict['raster'])
+ rasterType = getRasterType(self.rLegendDict['raster'])
self.rLegendDict['type'] = rasterType
range = RunCommand('r.info', flags = 'r', read = True, map = self.rLegendDict['raster']).strip().split('\n')
@@ -3328,64 +3904,88 @@
## self.rLegendDict['font'] = font.GetFaceName()
## self.rLegendDict['fontsize'] = font.GetPointSize()
self.rLegendDict['color'] = self.panelRaster.font['colorCtrl'].GetColour().GetAsString(wx.C2S_NAME)
- dc = wx.PaintDC(self)
- font = dc.GetFont()
- dc.SetFont(wx.Font( pointSize = self.rLegendDict['fontsize'], family = font.GetFamily(),
- style = font.GetStyle(), weight = wx.FONTWEIGHT_NORMAL))
+## dc = wx.PaintDC(self)
+## font = dc.GetFont()
+## dc.SetFont(wx.Font( pointSize = self.rLegendDict['fontsize'], family = font.GetFamily(),
+## style = font.GetStyle(), weight = wx.FONTWEIGHT_NORMAL))
# position
x = self.unitConv.convert(value = float(self.panelRaster.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
y = self.unitConv.convert(value = float(self.panelRaster.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
self.rLegendDict['where'] = (x, y)
# estimated size
- if not self.panelRaster.defaultSize.GetValue():
- self.rLegendDict['defaultSize'] = False
+## if not self.panelRaster.defaultSize.GetValue():
+## self.rLegendDict['defaultSize'] = False
+ width = self.panelRaster.widthCtrl.GetValue()
+ try:
+ width = float(width)
+ width = self.unitConv.convert(value = width, fromUnit = currUnit, toUnit = 'inch')
+ except ValueError:
+ width = None
+ self.rLegendDict['width'] = width
+ if self.rLegendDict['discrete'] == 'n':
+ height = self.panelRaster.heightOrColumnsCtrl.GetValue()
+ try:
+ height = float(height)
+ height = self.unitConv.convert(value = height, fromUnit = currUnit, toUnit = 'inch')
+ height = None
+ self.rLegendDict['height'] = height
+ else:
+ cols = self.panelRaster.heightOrColumnsCtrl.GetValue()
+ self.rLegendDict['cols'] = cols
+ drawHeight = self.rasterLegend.EstimateHeight(raster = self.rLegendDict['raster'], discrete = self.rLegendDict['discrete'],
+ fontsize = self.rLegendDict['fontsize'], cols = self.rLegendDict['cols'],
+ height = self.rLegendDict['height'])
+ drawWidth = self.rasterLegend.EstimateWidth(raster = self.rLegendDict['raster'], discrete = self.rLegendDict['discrete'],
+ width = self.rLegendDict['width'], paperInstr = self.instruction[self.pageId])
+ self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
- width = self.unitConv.convert(value = float(self.panelRaster.widthCtrl.GetValue()), fromUnit = currUnit, toUnit = 'inch')
- height = self.unitConv.convert(value = float(self.panelRaster.heightOrColumnsCtrl.GetValue()), fromUnit = currUnit, toUnit = 'inch')
- if self.rLegendDict['discrete'] == 'n': #rasterType in ('FCELL', 'DCELL'):
- self.rLegendDict['width'] = width
- self.rLegendDict['height'] = height
- textPart = self.unitConv.convert(value = dc.GetTextExtent(maxim)[0], fromUnit = 'pixel', toUnit = 'inch')
- drawWidth = width + textPart
- drawHeight = height
- self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
- else: #categorical map
- self.rLegendDict['cols'] = self.panelRaster.heightOrColumnsCtrl.GetValue()
- cat = RunCommand( 'r.category', read = True, map = self.rLegendDict['raster'],
- fs = ':').strip().split('\n')
- rows = ceil(float(len(cat))/self.rLegendDict['cols'])
+## if self.rLegendDict['discrete'] == 'n': #rasterType in ('FCELL', 'DCELL'):
+## self.rLegendDict['width'] = width
+## self.rLegendDict['height'] = height
+## textPart = self.unitConv.convert(value = dc.GetTextExtent(maxim)[0], fromUnit = 'pixel', toUnit = 'inch')
+## drawWidth = width + textPart
+## drawHeight = height
+## self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
+## else: #categorical map
+## self.rLegendDict['cols'] = self.panelRaster.heightOrColumnsCtrl.GetValue()
+## cat = RunCommand( 'r.category', read = True, map = self.rLegendDict['raster'],
+## fs = ':').strip().split('\n')
+## rows = ceil(float(len(cat))/self.rLegendDict['cols'])
+## drawHeight = self.unitConv.convert(value = 1.5 *rows * self.rLegendDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
+## self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = width, h = drawHeight)
+## else:
+## self.rLegendDict['defaultSize'] = True
+## drawWidth = self.unitConv.convert( value = self.rLegendDict['fontsize'] * 2,
+## fromUnit = 'point', toUnit = 'inch') + textPart
+## drawHeight = self.unitConv.convert(value = self.rLegendDict['fontsize'] * 10,
+## else:#categorical map
+## if len(cat) == 1:# for discrete FCELL
+## rows = float(maxim)
+## else:
+## paperWidth = self.instruction[self.pageId]['Width']- self.instruction[self.pageId]['Right']\
+## - self.instruction[self.pageId]['Left']
+## drawWidth = (paperWidth / self.rLegendDict['cols']) * (self.rLegendDict['cols'] - 1) + 1
- drawHeight = self.unitConv.convert(value = 1.5 *rows * self.rLegendDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
- self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = width, h = drawHeight)
- else:
- self.rLegendDict['defaultSize'] = True
- drawWidth = self.unitConv.convert( value = self.rLegendDict['fontsize'] * 2,
- fromUnit = 'point', toUnit = 'inch') + textPart
- drawHeight = self.unitConv.convert(value = self.rLegendDict['fontsize'] * 10,
- else:#categorical map
- if len(cat) == 1:# for discrete FCELL
- rows = float(maxim)
- else:
- paperWidth = self.instruction[self.pageId]['Width']- self.instruction[self.pageId]['Right']\
- - self.instruction[self.pageId]['Left']
- drawWidth = (paperWidth / self.rLegendDict['cols']) * (self.rLegendDict['cols'] - 1) + 1
# no data
if self.rLegendDict['discrete'] == 'y':
@@ -3415,7 +4015,8 @@
if self.id[0] not in self.parent.objectId:
self.parent.objectId.append(self.id[0])
return True
def updateVectorLegend(self):
"""!Save information from vector legend dialog to dictionary"""
@@ -3507,10 +4108,7 @@
return True
return False
- def getRasterType(self, map):
- rasterType = RunCommand('r.info', flags = 't', read = True,
- map = map).strip().split('=')
- return (rasterType[1] if rasterType[0] else None)
@@ -3519,12 +4117,13 @@
PsmapDialog.__init__(self, parent = parent, id = id, title = "Mapinfo settings", settings = settings)
self.instruction = settings
if self.id is not None:
- self.mapinfoDict = self.instruction[id].GetInstruction()
+ self.mapinfo = self.instruction[self.id]
+ self.mapinfoDict = self.mapinfo.GetInstruction()
else:
self.id = wx.NewId()
- mapinfo = Mapinfo(self.id)
+ self.mapinfo = Mapinfo(self.id)
- self.mapinfoDict = mapinfo.GetInstruction()
page = self.instruction.FindInstructionByType('page').GetInstruction()
self.mapinfoDict['where'] = page['Left'], page['Top']
@@ -3665,11 +4264,8 @@
## if self.colors['borderCtrl'].GetValue() else 'none')
# estimation of size
- w = self.mapinfoDict['fontsize'] * 20 # any better estimation?
- h = self.mapinfoDict['fontsize'] * 7
- width = self.unitConv.convert(value = w, fromUnit = 'point', toUnit = 'inch')
- height = self.unitConv.convert(value = h, fromUnit = 'point', toUnit = 'inch')
- self.mapinfoDict['rect'] = wx.Rect2D(x = x, y = y, w = width, h = height)
+ self.mapinfoDict['rect'] = self.mapinfo.EstimateRect(self.mapinfoDict)
if self.id not in self.instruction:
@@ -3688,11 +4284,12 @@
PsmapDialog.__init__(self, parent = parent, id = id, title = "Scale bar settings", settings = settings)
- self.scalebarDict = self.instruction[id].GetInstruction()
+ self.scalebar = self.instruction[id]
+ self.scalebarDict = self.scalebar.GetInstruction()
else:
- scalebar = Scalebar(self.id)
- self.scalebarDict = scalebar.GetInstruction()
+ self.scalebar = Scalebar(self.id)
self.scalebarDict['where'] = page['Left'], page['Top']
@@ -3870,7 +4467,14 @@
x = self.unitConv.convert(value = float(self.panel.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
y = self.unitConv.convert(value = float(self.panel.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
+ #style
+ self.scalebarDict['scalebar'] = self.sbCombo.GetClientData(self.sbCombo.GetSelection())
+ self.scalebarDict['segment'] = self.sbSegmentsCtrl.GetValue()
+ self.scalebarDict['numbers'] = self.sbLabelsCtrl.GetValue()
+ self.scalebarDict['fontsize'] = self.fontsizeCtrl.GetValue()
+ self.scalebarDict['background'] = 'n' if self.backgroundCheck.GetValue() else 'y'
# size
# height
@@ -3897,31 +4501,28 @@
return False
self.scalebarDict['length'] = length
- if self.scalebarDict['unitsLength'] != 'auto':
- length = self.unitConv.convert(value = length, fromUnit = self.unitsLength.GetStringSelection(), toUnit = 'inch')
- else:
- length = self.unitConv.convert(value = length, fromUnit = self.mapUnit, toUnit = 'inch')
+## if self.scalebarDict['unitsLength'] != 'auto':
+## length = self.unitConv.convert(value = length, fromUnit = self.unitsLength.GetStringSelection(), toUnit = 'inch')
+## else:
+## length = self.unitConv.convert(value = length, fromUnit = self.mapUnit, toUnit = 'inch')
map = self.instruction.FindInstructionByType('map')
if not map:
map = self.instruction.FindInstructionByType('initMap')
mapId = map.id
- length *= self.instruction[mapId]['scale']
- length *= 1.1 #for numbers on the edge
- fontsize = 10
- height = height + 2 * self.unitConv.convert(value = fontsize, fromUnit = 'point', toUnit = 'inch')
- self.scalebarDict['rect'] = wx.Rect2D(x, y, length, height)
+## length *= self.instruction[mapId]['scale']
+## length *= 1.1 #for numbers on the edge
+## height = height + 2 * self.unitConv.convert(value = self.scalebarDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
+## self.scalebarDict['rect'] = wx.Rect2D(x, y, length, height)
- self.scalebarDict['where'] = self.scalebarDict['rect'].GetCentre()
+ rectSize = self.scalebar.EstimateSize( scalebarDict = self.scalebarDict,
+ scale = self.instruction[mapId]['scale'])
+ self.scalebarDict['rect'] = wx.Rect2D(x = x, y = y, w = rectSize[0], h = rectSize[1])
+ self.scalebarDict['where'] = self.scalebarDict['rect'].GetCentre()
- #style
- self.scalebarDict['scalebar'] = self.sbCombo.GetClientData(self.sbCombo.GetSelection())
- self.scalebarDict['segment'] = self.sbSegmentsCtrl.GetValue()
- self.scalebarDict['numbers'] = self.sbLabelsCtrl.GetValue()
- self.scalebarDict['fontsize'] = self.fontsizeCtrl.GetValue()
- self.scalebarDict['background'] = 'n' if self.backgroundCheck.GetValue() else 'y'
@@ -3953,7 +4554,7 @@
self.mapId = map.id
- self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(self, mapId = self.mapId, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
+ self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(map = map, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
self.textPanel = self._textPanel(notebook)
@@ -4016,12 +4617,12 @@
self.effect['highlightCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("highlight"))
self.effect['highlightColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
- self.effect['highlightWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, value = 'pts',min = 0, max = 5, initial = 1)
+ self.effect['highlightWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, min = 0, max = 5, initial = 1)
self.effect['highlightWidthLabel'] = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
self.effect['borderCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("text border"))
self.effect['borderColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
- self.effect['borderWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, value = 'pts',min = 1, max = 25, initial = 1)
+ self.effect['borderWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, min = 1, max = 25, initial = 1)
self.effect['borderWidthLabel'] = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
#set values
self.effect['backgroundCtrl'].SetValue(True if self.textDict['background'] != 'none' else False)
@@ -4116,7 +4717,7 @@
self.northingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "N:")
self.eastingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
self.northingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
- east, north = PaperMapCoordinates(self, mapId = self.mapId, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
+ east, north = PaperMapCoordinates(map = self.instruction[self.mapId], x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
self.eastingCtrl.SetValue(str(east))
self.northingCtrl.SetValue(str(north))
@@ -4283,12 +4884,12 @@
x = self.unitConv.convert(value = float(x), fromUnit = currUnit, toUnit = 'inch')
y = self.unitConv.convert(value = float(y), fromUnit = currUnit, toUnit = 'inch')
self.textDict['where'] = x, y
- self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(self, self.mapId, x, y, paperToMap = True)
+ self.textDict['east'], self.textDict['north'] = PaperMapCoordinates( self.instruction[self.mapId], x, y, paperToMap = True)
else:
self.textDict['XY'] = False
self.textDict['east'] = self.eastingCtrl.GetValue() if self.eastingCtrl.GetValue() else self.textDict['east']
self.textDict['north'] = self.northingCtrl.GetValue() if self.northingCtrl.GetValue() else self.textDict['north']
- self.textDict['where'] = PaperMapCoordinates(self, mapId = self.mapId, x = float(self.textDict['east']),
+ self.textDict['where'] = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.textDict['east']),
y = float(self.textDict['north']), paperToMap = False)
#rotation
if self.rotCtrl.GetValue():
@@ -4311,13 +4912,6 @@
return True
-def find_key(dic, val, multiple = False):
- """!Return the key of dictionary given the value"""
- result = [k for k, v in dic.iteritems() if v == val]
- if len(result) == 0 and not multiple:
- return None
- return sorted(result) if multiple else result[0]
def convertRGB(rgb):
"""!Converts wx.Colour(255,255,255,255) and string '255:255:255',
@@ -4328,15 +4922,15 @@
return wx.Colour(*map(int, rgb.split(':')))
-def PaperMapCoordinates(self, mapId, x, y, paperToMap = True):
+def PaperMapCoordinates(map, x, y, paperToMap = True):
"""!Converts paper (inch) coordinates -> map coordinates"""
- unitConv = UnitConversion(self)
+ unitConv = UnitConversion()
currRegionDict = grass.region()
cornerEasting, cornerNorthing = currRegionDict['w'], currRegionDict['n']
- xMap = self.instruction[mapId]['rect'][0]
- yMap = self.instruction[mapId]['rect'][1]
- widthMap = self.instruction[mapId]['rect'][2] * 0.0254 # to meter
- heightMap = self.instruction[mapId]['rect'][3] * 0.0254
+ xMap = map['rect'][0]
+ yMap = map['rect'][1]
+ widthMap = map['rect'][2] * 0.0254 # to meter
+ heightMap = map['rect'][3] * 0.0254
xScale = widthMap / abs(currRegionDict['w'] - currRegionDict['e'])
yScale = heightMap / abs(currRegionDict['n'] - currRegionDict['s'])
currScale = (xScale + yScale) / 2
@@ -4365,7 +4959,10 @@
if scaleType == 0 and map:# automatic, region from raster or vector
res = ''
if mapType == 'raster':
- res = grass.read_command("g.region", flags = 'gu', rast = map)
+ try:
+ res = grass.read_command("g.region", flags = 'gu', rast = map)
+ pass
elif mapType == 'vector':
res = grass.read_command("g.region", flags = 'gu', vect = map)
currRegionDict = grass.parse_key_val(res, val_type = float)
@@ -4388,7 +4985,7 @@
return None, None, None
if not currRegionDict:
- return None, None
+ return None, None, None
rX = rect.x
rY = rect.y
rW = rect.width
@@ -4479,10 +5076,20 @@
def GetMapBounds(filename):
"""!Run ps.map -b to get information about map bounding box"""
try:
- bb = map(float, RunCommand('ps.map', read = True,
+ bb = map(float, grass.read_command('ps.map',
flags = 'b',
input = filename).strip().split('=')[1].split(','))
except (grass.ScriptError, IndexError):
GError(message = _("Unable to run ps.map -b "))
return None
return wx.Rect2D(bb[0], bb[3], bb[2] - bb[0], bb[1] - bb[3])
+def getRasterType(map):
+ """!Returns type of raster map (CELL, FCELL, DCELL)"""
+ try:
+ rasterType = RunCommand('r.info', flags = 't', read = True,
+ map = map).strip().split('=')
+ except ScriptError:
+ GError(_("Unable to get type of raster map"))
+ return None
+ return (rasterType[1] if rasterType[0] else None)
\ No newline at end of file
Modified: grass-addons/gui/wxpython/psmap/xml/menudata_psmap.xml
--- grass-addons/gui/wxpython/psmap/xml/menudata_psmap.xml 2011-03-16 19:09:47 UTC (rev 45681)
+++ grass-addons/gui/wxpython/psmap/xml/menudata_psmap.xml 2011-03-16 20:55:05 UTC (rev 45682)
@@ -9,7 +9,14 @@
<handler>OnPageSetup</handler>
<shortcut>Ctrl+P</shortcut>
</menuitem>
+ <separator/>
<menuitem>
+ <label>Load file</label>
+ <help>Load text file with mapping instructions</help>
+ <handler>OnLoadFile</handler>
+ <shortcut>Ctrl+O</shortcut>
+ </menuitem>
+ <menuitem>
<label>Export to text file</label>
<help>Generate text file with mapping instructions</help>
<handler>OnInstructionFile</handler>
