[GRASS-SVN] r45701 -
grass/branches/releasebranch_6_4/vector/v.clean/test
svn_grass at osgeo.org
Fri Mar 18 04:49:07 EDT 2011
Author: neteler
Date: 2011-03-18 01:49:07 -0700 (Fri, 18 Mar 2011)
New Revision: 45701
grass/branches/releasebranch_6_4/vector/v.clean/test/topocheck.c
fix of bug #1317
Modified: grass/branches/releasebranch_6_4/vector/v.clean/test/topocheck.c
--- grass/branches/releasebranch_6_4/vector/v.clean/test/topocheck.c 2011-03-18 08:39:00 UTC (rev 45700)
+++ grass/branches/releasebranch_6_4/vector/v.clean/test/topocheck.c 2011-03-18 08:49:07 UTC (rev 45701)
@@ -51,7 +51,7 @@
"Write areas and isles as closed polygons instead of topo check";
if (G_parser(argc, argv))
- exit(EXIT_FAILURE));
+ exit(EXIT_FAILURE);
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -79,7 +79,7 @@
if (!poly_f->answer) { /* do check */
Vect_copy_map_lines(&In, &Out);
- Vect_build(&Out, NULL);
+ Vect_build(&Out);
Vect_close(&In);
Vect_close(&Out);
@@ -159,7 +159,7 @@
fprintf(stderr, "%d area polygons written.\n", n);
- Vect_build(&Out, stderr);
+ Vect_build(&Out);
Vect_close(&Out);
