[GRASS-SVN] r45709 -
grass/branches/releasebranch_6_4/raster3d/r3.stats
svn_grass at osgeo.org
Fri Mar 18 05:31:26 EDT 2011
Author: huhabla
Date: 2011-03-18 02:31:26 -0700 (Fri, 18 Mar 2011)
New Revision: 45709
grass/branches/releasebranch_6_4/raster3d/r3.stats/description.html
grass/branches/releasebranch_6_4/raster3d/r3.stats/main.c
Better NULL pointer handling.
Modified: grass/branches/releasebranch_6_4/raster3d/r3.stats/description.html
--- grass/branches/releasebranch_6_4/raster3d/r3.stats/description.html 2011-03-18 09:25:50 UTC (rev 45708)
+++ grass/branches/releasebranch_6_4/raster3d/r3.stats/description.html 2011-03-18 09:31:26 UTC (rev 45709)
@@ -9,7 +9,7 @@
<H2>NOTES</H2>
-As with most GRASS raster3D modules, <EM>r3.univar</EM> operates on the cell
+As with most GRASS raster3D modules, <EM>r3.stats</EM> operates on the cell
array defined by the current 3D region settings, not the original extent and
resolution of the input map. See <em><A HREF="g.region.html">g.region</A></em>.
<P>
Modified: grass/branches/releasebranch_6_4/raster3d/r3.stats/main.c
--- grass/branches/releasebranch_6_4/raster3d/r3.stats/main.c 2011-03-18 09:25:50 UTC (rev 45708)
+++ grass/branches/releasebranch_6_4/raster3d/r3.stats/main.c 2011-03-18 09:31:26 UTC (rev 45709)
@@ -52,16 +52,16 @@
} equal_val_array;
/*prototypes */
-equal_val_array *alloc_equal_val_array(int count);
-void free_equal_val_array(equal_val_array * vals);
-equal_val_array *add_equal_val_to_array(equal_val_array * array, double val);
-int check_equal_value(equal_val_array * array, double val);
-stat_table *create_stat_table(int nsteps, equal_val_array * values,
+static equal_val_array *alloc_equal_val_array(int count);
+static void free_equal_val_array(equal_val_array * vals);
+static equal_val_array *add_equal_val_to_array(equal_val_array * array, double val);
+static int check_equal_value(equal_val_array * array, double val);
+static stat_table *create_stat_table(int nsteps, equal_val_array * values,
double min, double max);
-void free_stat_table(stat_table * stats);
-void print_stat_table(stat_table * stats);
-void update_stat_table(stat_table * stats, G3D_Region * region);
-void heapsort_eqvals(equal_val_array * data, int n);
+static void free_stat_table(stat_table * stats);
+static void print_stat_table(stat_table * stats);
+static void update_stat_table(stat_table * stats, G3D_Region * region);
+static void heapsort_eqvals(equal_val_array * data, int n);
static void downheap_eqvals(equal_val_array * data, int n, int k);
static void check_range_value(stat_table * stats, double value);
static void tree_search_range(stat_table * stats, int left, int right,
@@ -546,14 +546,14 @@
float val_f; /* for misc use */
double val_d; /* for misc use */
- stat_table *stats;
+ stat_table *stats = NULL;
double min, max;
- equal_val_array *eqvals;
+ equal_val_array *eqvals = NULL;
unsigned int n = 0, nsteps;
int map_type;
- char *infile;
- void *map;
+ char *infile = NULL;
+ void *map = NULL;
G3D_Region region;
unsigned int rows, cols, depths;
unsigned int x, y, z;
@@ -660,18 +660,18 @@
- /* sort the equal values array */
- G_message(_("Sort non-null values"));
- heapsort_eqvals(eqvals, eqvals->count);
+ if (eqvals) {
+ /* sort the equal values array */
+ G_message(_("Sort non-null values"));
+ heapsort_eqvals(eqvals, eqvals->count);
- /* create the statistic table with equal values */
- stats = create_stat_table(eqvals->count, eqvals, 0, 0);
- /* compute the number of null values */
- stats->null->count = rows * cols * depths - n;
+ /* create the statistic table with equal values */
+ stats = create_stat_table(eqvals->count, eqvals, 0, 0);
+ /* compute the number of null values */
+ stats->null->count = rows * cols * depths - n;
- if (eqvals)
- free_equal_val_array(eqvals);
+ free_equal_val_array(eqvals);
else {
@@ -709,11 +709,14 @@
- /* Compute the volume and percentage */
- update_stat_table(stats, ®ion);
- /* Print the statistics to stdout */
- print_stat_table(stats);
+ if(stats) {
+ /* Compute the volume and percentage */
+ update_stat_table(stats, ®ion);
+ /* Print the statistics to stdout */
+ print_stat_table(stats);
- free_stat_table(stats);
+ free_stat_table(stats);
exit(EXIT_SUCCESS);
