[GRASS-SVN] r45734 - grass-addons/gui/wxpython/psmap/gui_modules
svn_grass at osgeo.org
Wed Mar 23 07:22:45 EDT 2011
Author: annakrat
Date: 2011-03-23 04:22:45 -0700 (Wed, 23 Mar 2011)
New Revision: 45734
grass-addons/gui/wxpython/psmap/gui_modules/psmap.py
grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py
draw map checkbox added to mapframe
Modified: grass-addons/gui/wxpython/psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/psmap/gui_modules/psmap.py 2011-03-23 10:16:46 UTC (rev 45733)
+++ grass-addons/gui/wxpython/psmap/gui_modules/psmap.py 2011-03-23 11:22:45 UTC (rev 45734)
@@ -19,7 +19,6 @@
import os
import sys
-import tempfile
import textwrap
import Queue
try:
@@ -27,8 +26,7 @@
haveImage = True
except ImportError:
haveImage = False
-from math import ceil, sin, cos, pi
-from collections import namedtuple
+from math import sin, cos, pi
import grass.script as grass
if int(grass.version()['version'].split('.')[0]) > 6:
@@ -41,14 +39,12 @@
import menu
from goutput import CmdThread, EVT_CMD_DONE
from menudata import MenuData, etcwxdir
-from gselect import Select
from toolbars import AbstractToolbar
from icon import Icons, MetaIcon, iconSet
from gcmd import RunCommand, GError, GMessage
from psmap_dialogs import *
import wx
-import wx.lib.scrolledpanel as scrolled
try:
from agw import flatnotebook as fnb
@@ -1432,10 +1428,6 @@
fontsize = str(textDict['fontsize'] * self.currScale)
background = textDict['background'] if textDict['background'] != 'none' else None
- dc = wx.PaintDC(self) # dc created because of method GetTextExtent, which pseudoDC lacks
- dc.SetFont(wx.FontFromNativeInfoString(textDict['font'] + " " + fontsize))
- textExtent = dc.GetTextExtent(textDict['text'])
pdc.RemoveId(drawId)
pdc.SetId(drawId)
pdc.BeginDrawing()
@@ -1446,6 +1438,7 @@
else:
pdc.SetBackground(wx.TRANSPARENT_BRUSH)
pdc.SetBackgroundMode(wx.TRANSPARENT)
pdc.SetFont(wx.FontFromNativeInfoString(textDict['font'] + " " + fontsize))
## pdc.SetTextForeground(convertRGB(textDict['color']))
pdc.SetTextForeground(textDict['color'])
@@ -1530,7 +1523,6 @@
def UpdateMapLabel(self):
"""!Updates map frame label"""
- mapId = self.instruction.FindInstructionByType('map').id
vector = self.instruction.FindInstructionByType('vector')
vectorId = vector.id if vector else None
raster = self.instruction.FindInstructionByType('raster')
Modified: grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py
--- grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py 2011-03-23 10:16:46 UTC (rev 45733)
+++ grass-addons/gui/wxpython/psmap/gui_modules/psmap_dialogs.py 2011-03-23 11:22:45 UTC (rev 45734)
@@ -17,6 +17,7 @@
@author Martin Landa <landa.martin gmail.com> (mentor)
import os
import sys
import string
@@ -222,7 +223,7 @@
if each.id == id:
return each
return None
def __contains__(self, id):
"""!Test if instruction is included"""
for each in self.instruction:
@@ -359,54 +360,71 @@
instruction = 'mapinfo'
isBuffer = True
buffer.append(line)
- if line.startswith('mapinfo'):
- instruction = 'mapinfo'
- isBuffer = True
- buffer.append(line)
- if line.startswith('scalebar'):
+ elif line.startswith('scalebar'):
instruction = 'scalebar'
isBuffer = True
buffer.append(line)
- if line.startswith('text'):
+ elif line.startswith('text'):
instruction = 'text'
isBuffer = True
buffer.append(line)
- if line.startswith('colortable'):
+ elif line.startswith('colortable'):
if len(line.split()) == 2 and line.split()[1].lower() in ('n', 'no', 'none'):
break
instruction = 'colortable'
isBuffer = True
buffer.append(line)
- if line.startswith('vlegend'):
+ elif line.startswith('vlegend'):
instruction = 'vlegend'
isBuffer = True
buffer.append(line)
- if line.startswith('vpoints'):
+ elif line.startswith('vpoints'):
instruction = 'vpoints'
isBuffer = True
buffer.append(line)
- if line.startswith('vlines'):
+ elif line.startswith('vlines'):
instruction = 'vlines'
isBuffer = True
buffer.append(line)
- if line.startswith('vareas'):
+ elif line.startswith('vareas'):
instruction = 'vareas'
isBuffer = True
- # rasterLegend
+ buffer.append(line)
+ elif line.startswith('end'):
+ break
rasterLegend = self.FindInstructionByType('rasterLegend')
raster = self.FindInstructionByType('raster')
page = self.FindInstructionByType('page')
+ vector = self.FindInstructionByType('vector')
+ vectorLegend = self.FindInstructionByType('vectorLegend')
+ vectorMaps = self.FindInstructionByType('vProperties', list = True)
+ # check (in case of scaletype 0) if map is drawn also
+ map['drawMap'] = False
+ if map['scaleType'] == 0:
+ mapForRegion = map['map']
+ if map['mapType'] == 'raster' and raster:
+ if mapForRegion == raster['raster']:
+ map['drawMap'] = True
+ elif map['mapType'] == 'vector' and vector:
+ for vmap in vector['list']:
+ if mapForRegion == vmap[0]:
+ # rasterLegend
if rasterLegend:
- if rasterLegend['rasterDefault'] and raster['raster']:
+ if rasterLegend['rasterDefault'] and raster:
rasterLegend['raster'] = raster['raster']
if not rasterLegend['discrete']:
rasterType = getRasterType(map = rasterLegend['raster'])
@@ -429,9 +447,7 @@
w = width, h = height)
# vectors, vlegend
- vector = self.FindInstructionByType('vector')
- vectorLegend = self.FindInstructionByType('vectorLegend')
- vectorMaps = self.FindInstructionByType('vProperties', list = True)
if vector:
for vmap in vectorMaps:
for i, each in enumerate(vector['list']):
@@ -451,6 +467,8 @@
page = PageSetup(wx.NewId())
self.AddInstruction(page)
return True
def SendToRead(self, instruction, text, **kwargs):
@@ -601,7 +619,7 @@
InstructionObject.__init__(self, id = id)
self.type = 'map'
# default values
- self.defaultInstruction = dict( map = None, mapType = None, region = None,
+ self.defaultInstruction = dict( map = None, mapType = None, drawMap = True, region = None,
rect = wx.Rect2D(), scaleType = 0, scale = None, center = None,
border = 'y', width = 1, color = '0:0:0')
# current values
@@ -1643,7 +1661,6 @@
paperString = RunCommand('ps.map', flags = 'p', read = True)
self.paperTable = self._toList(paperString)
self.unitsList = self.unitConv.getPageUnits()
- pageId = id
self.pageSetupDict = settings[id].GetInstruction()
self._layout()
@@ -1857,8 +1874,11 @@
self.scaleType = self.mapFrameDict['scaleType']
self.mapType = self.mapFrameDict['mapType']
self.scaleChoice.SetSelection(self.mapFrameDict['scaleType'])
+ if self.instruction[self.id]:
+ self.drawMap.SetValue(self.mapFrameDict['drawMap'])
+ else:
+ self.drawMap.SetValue(True)
if self.mapFrameDict['scaleType'] == 0 and self.mapFrameDict['map']:
self.select.SetValue(self.mapFrameDict['map'])
if self.mapFrameDict['mapType'] == 'raster':
self.rasterTypeRadio.SetValue(True)
@@ -1907,6 +1927,7 @@
self.rasterTypeRadio = wx.RadioButton(self, id = wx.ID_ANY, label = " {0} ".format(_("raster")), style = wx.RB_GROUP)
self.vectorTypeRadio = wx.RadioButton(self, id = wx.ID_ANY, label = " {0} ".format(_("vector")))
+ self.drawMap = wx.CheckBox(self, id = wx.ID_ANY, label = "draw selected map")
self.mapOrRegionText = [_("Map:"), _("Region:")]
dc = wx.PaintDC(self)# determine size of labels
@@ -1918,8 +1939,9 @@
self.mapSizer.Add(self.rasterTypeRadio, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
self.mapSizer.Add(self.vectorTypeRadio, pos = (0, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.mapSizer.Add(self.drawMap, pos = (0, 3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
self.mapSizer.Add(self.mapText, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.mapSizer.Add(self.select, pos = (1, 1), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.mapSizer.Add(self.select, pos = (1, 1), span = (1, 3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
sizerM.Add(self.mapSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
gridBagSizer.Add(sizerM, pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
@@ -2042,6 +2064,7 @@
# set map selection
self.rasterTypeRadio.Show()
self.vectorTypeRadio.Show()
+ self.drawMap.Show()
self.staticBox.SetLabel(" {0} ".format(_("Map selection")))
type = 'raster' if self.rasterTypeRadio.GetValue() else 'vector'
self.select.SetElementList(type = type)
@@ -2052,6 +2075,7 @@
# set region selection
self.rasterTypeRadio.Hide()
self.vectorTypeRadio.Hide()
+ self.drawMap.Hide()
self.staticBox.SetLabel(" {0} ".format(_("Region selection")))
type = 'region'
@@ -2122,10 +2146,54 @@
if mapFrameDict['scaleType'] == 0:
if self.select.GetValue():
+ mapFrameDict['drawMap'] = self.drawMap.GetValue()
mapFrameDict['map'] = self.select.GetValue()
mapFrameDict['mapType'] = self.mapType
mapFrameDict['region'] = None
+ if mapFrameDict['drawMap']:
+ if mapFrameDict['mapType'] == 'raster':
+ raster = self.instruction.FindInstructionByType('raster')
+ if raster:
+ raster['raster'] = mapFrameDict['map']
+ else:
+ raster = Raster(wx.NewId())
+ raster['isRaster'] = True
+ self.instruction.AddInstruction(raster)
+ elif mapFrameDict['mapType'] == 'vector':
+ vector = self.instruction.FindInstructionByType('vector')
+ isAdded = False
+ if vector:
+ for each in vector['list']:
+ if each[0] == mapFrameDict['map']:
+ isAdded = True
+ if not isAdded:
+ try:
+ topoInfo = grass.vector_info_topo(map = mapFrameDict['map'])
+ if bool(topoInfo['areas']):
+ topoType = 'areas'
+ elif bool(topoInfo['lines']):
+ topoType = 'lines'
+ else:
+ topoType = 'points'
+ label = '('.join(mapFrameDict['map'].split('@'))
+ except grass.ScriptError:
+ pass
+ else:
+ if not vector:
+ vector = Vector(wx.NewId())
+ vector['list'] = []
+ self.instruction.AddInstruction(vector)
+ id = wx.NewId()
+ vector['list'].insert(0, [mapFrameDict['map'], topoType, id, 1, label])
+ vProp = VProperties(id, topoType)
+ vProp['name'], vProp['label'], vProp['lpos'] = mapFrameDict['map'], label, 1
+ self.instruction.AddInstruction(vProp)
self.scale[0], self.center[0], self.rectAdjusted = AutoAdjust(self, scaleType = 0, map = mapFrameDict['map'],
mapType = self.mapType, rect = self.mapFrameDict['rect'])
@@ -2151,6 +2219,7 @@
elif mapFrameDict['scaleType'] == 1:
+ mapFrameDict['drawMap'] = False
mapFrameDict['map'] = None
mapFrameDict['mapType'] = None
mapFrameDict['region'] = self.select.GetValue()
@@ -2167,6 +2236,7 @@
return False
elif scaleType == 2:
@@ -2193,6 +2263,7 @@
e = region['east'], w = region['west'])
elif scaleType == 3:
@@ -2298,15 +2369,19 @@
def update(self):
#draw raster
+ map = self.instruction.FindInstructionByType('map')
if self.rasterNoRadio.GetValue() or not self.rasterSelect.GetValue():
self.rasterDict['isRaster'] = False
self.rasterDict['raster'] = None
if self.id in self.instruction:
del self.instruction[self.id]
else:
self.rasterDict['isRaster'] = True
self.rasterDict['raster'] = self.rasterSelect.GetValue()
+ if self.rasterDict['raster'] != map['drawMap']:
if self.id not in self.instruction:
raster = Raster(self.id)
@@ -3806,14 +3881,6 @@
self.panelRaster.Fit()
-## def OnDefaultSize(self, event):
-## if self.panelRaster.defaultSize.GetValue():
-## self.panelRaster.widthCtrl.Disable()
-## self.panelRaster.heightOrColumnsCtrl.Disable()
-## else:
-## self.panelRaster.widthCtrl.Enable()
-## self.panelRaster.heightOrColumnsCtrl.Enable()
def OnRange(self, event):
if not self.range.GetValue():
self.min.Disable()
@@ -3907,8 +3974,6 @@
rasterType = getRasterType(self.rLegendDict['raster'])
self.rLegendDict['type'] = rasterType
-## rinfo = grass.raster_info(self.rLegendDict['raster'])
-## minim, maxim = rinfo['min'], rinfo['max']
#discrete
if self.discrete.GetValue():
@@ -3923,17 +3988,12 @@
## self.rLegendDict['font'] = font.GetFaceName()
## self.rLegendDict['fontsize'] = font.GetPointSize()
self.rLegendDict['color'] = self.panelRaster.font['colorCtrl'].GetColour().GetAsString(wx.C2S_NAME)
-## dc = wx.PaintDC(self)
-## font = dc.GetFont()
-## dc.SetFont(wx.Font( pointSize = self.rLegendDict['fontsize'], family = font.GetFamily(),
-## style = font.GetStyle(), weight = wx.FONTWEIGHT_NORMAL))
# position
x = self.unitConv.convert(value = float(self.panelRaster.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
y = self.unitConv.convert(value = float(self.panelRaster.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
self.rLegendDict['where'] = (x, y)
# estimated size
-## if not self.panelRaster.defaultSize.GetValue():
-## self.rLegendDict['defaultSize'] = False
width = self.panelRaster.widthCtrl.GetValue()
try:
width = float(width)
@@ -3959,52 +4019,7 @@
fontsize = self.rLegendDict['fontsize'], cols = self.rLegendDict['cols'],
width = self.rLegendDict['width'], paperInstr = self.instruction[self.pageId])
self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
-## if self.rLegendDict['discrete'] == 'n': #rasterType in ('FCELL', 'DCELL'):
-## self.rLegendDict['width'] = width
-## self.rLegendDict['height'] = height
-## textPart = self.unitConv.convert(value = dc.GetTextExtent(maxim)[0], fromUnit = 'pixel', toUnit = 'inch')
-## drawWidth = width + textPart
-## drawHeight = height
-## self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
-## else: #categorical map
-## self.rLegendDict['cols'] = self.panelRaster.heightOrColumnsCtrl.GetValue()
-## cat = RunCommand( 'r.category', read = True, map = self.rLegendDict['raster'],
-## fs = ':').strip().split('\n')
-## rows = ceil(float(len(cat))/self.rLegendDict['cols'])
-## drawHeight = self.unitConv.convert(value = 1.5 *rows * self.rLegendDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
-## self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = width, h = drawHeight)
-## else:
-## self.rLegendDict['defaultSize'] = True
-## drawWidth = self.unitConv.convert( value = self.rLegendDict['fontsize'] * 2,
-## fromUnit = 'point', toUnit = 'inch') + textPart
-## drawHeight = self.unitConv.convert(value = self.rLegendDict['fontsize'] * 10,
-## else:#categorical map
-## if len(cat) == 1:# for discrete FCELL
-## rows = float(maxim)
-## else:
-## paperWidth = self.instruction[self.pageId]['Width']- self.instruction[self.pageId]['Right']\
-## - self.instruction[self.pageId]['Left']
-## drawWidth = (paperWidth / self.rLegendDict['cols']) * (self.rLegendDict['cols'] - 1) + 1
# no data
if self.rLegendDict['discrete'] == 'y':
@@ -4266,7 +4281,7 @@
y = self.unitConv.convert(value = float(self.panel.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
self.mapinfoDict['where'] = (x, y)
# font
- self.mapinfoDict['font'] = font = self.panel.font['fontCtrl'].GetStringSelection()
+ self.mapinfoDict['font'] = self.panel.font['fontCtrl'].GetStringSelection()
self.mapinfoDict['fontsize'] = self.panel.font['fontSizeCtrl'].GetValue()
## font = self.panel.font['fontCtrl'].GetSelectedFont()
## self.mapinfoDict['font'] = font.GetFaceName()
@@ -4519,23 +4534,12 @@
caption = _('Invalid input'), style = wx.OK|wx.ICON_ERROR)
return False
self.scalebarDict['length'] = length
-## if self.scalebarDict['unitsLength'] != 'auto':
-## length = self.unitConv.convert(value = length, fromUnit = self.unitsLength.GetStringSelection(), toUnit = 'inch')
-## else:
-## length = self.unitConv.convert(value = length, fromUnit = self.mapUnit, toUnit = 'inch')
# estimation of size
if not map:
map = self.instruction.FindInstructionByType('initMap')
mapId = map.id
-## length *= self.instruction[mapId]['scale']
-## length *= 1.1 #for numbers on the edge
-## height = height + 2 * self.unitConv.convert(value = self.scalebarDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
-## self.scalebarDict['rect'] = wx.Rect2D(x, y, length, height)
rectSize = self.scalebar.EstimateSize( scalebarDict = self.scalebarDict,
scale = self.instruction[mapId]['scale'])
@@ -4874,7 +4878,7 @@
return False
#font
- self.textDict['font'] = font = self.textPanel.font['fontCtrl'].GetStringSelection()
+ self.textDict['font'] = self.textPanel.font['fontCtrl'].GetStringSelection()
self.textDict['fontsize'] = self.textPanel.font['fontSizeCtrl'].GetValue()
## font = self.textPanel.font['fontCtrl'].GetSelectedFont()
## self.textDict['font'] = font.GetFaceName()
