[GRASS-SVN] r45764 - in grass/branches/develbranch_6/gui: scripts
wxpython wxpython/gui_modules wxpython/xml
svn_grass at osgeo.org
Sat Mar 26 12:09:43 EDT 2011
Author: martinl
Date: 2011-03-26 09:09:43 -0700 (Sat, 26 Mar 2011)
New Revision: 45764
Added:
grass/branches/develbranch_6/gui/scripts/g.extension.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: backport python g.extepsion script from trunk
enable install extension window
Copied: grass/branches/develbranch_6/gui/scripts/g.extension.py (from rev 45759, grass/trunk/scripts/g.extension/g.extension.py)
--- grass/branches/develbranch_6/gui/scripts/g.extension.py (rev 0)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-03-26 16:09:43 UTC (rev 45764)
@@ -0,0 +1,431 @@
+#!/usr/bin/env python
+# MODULE: g.extension
+# AUTHOR(S): Markus Neteler
+# Pythonized by Martin Landa
+# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
+# local GRASS installation
+# COPYRIGHT: (C) 2009-2011 by Markus Neteler, and the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+# TODO: add sudo support where needed (i.e. check first permission to write into
+# $GISBASE directory)
+#%module
+#% label: Tool to maintain the extensions in local GRASS installation.
+#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
+#% keywords: general
+#% keywords: installation
+#% keywords: extensions
+#%end
+#%option
+#% key: extension
+#% type: string
+#% key_desc: name
+#% description: Name of extension to install/remove
+#% required: no
+#%end
+#%option
+#% key: operation
+#% type: string
+#% description: Operation to be performed
+#% required: no
+#% options: add,remove
+#% answer: add
+#%end
+#%option
+#% key: svnurl
+#% type: string
+#% key_desc: url
+#% description: SVN Addons repository URL
+#% required: yes
+#% answer: https://svn.osgeo.org/grass/grass-addons/grass7
+#%end
+#%option
+#% key: prefix
+#% type: string
+#% key_desc: path
+#% description: Prefix where to install extension (ignored when flag -s is given)
+#% answer: $GRASS_ADDON_PATH
+#% required: yes
+#%end
+#%flag
+#% key: l
+#% description: List available modules in the GRASS Addons SVN repository
+#% guisection: Print
+#%end
+#%flag
+#% key: f
+#% description: List available modules in the GRASS Addons SVN repository including modules description
+#%end
+#%flag
+#% key: g
+#% description: List available modules in the GRASS Addons SVN repository (shell script style)
+#%end
+#%flag
+#% key: s
+#% description: Install system-wide (may need system administrator rights)
+#%end
+#%flag
+#% key: d
+#% description: Don't delete downloaded source code when installing new extension
+#%end
+#%flag
+#% key: i
+#% description: Don't install new extension, just compile it
+#%end
+import os
+import sys
+import re
+import atexit
+import urllib
+from grass.script import core as grass
+# temp dir
+remove_tmpdir = True
+tmpdir = grass.tempfile()
+grass.try_remove(tmpdir)
+os.mkdir(tmpdir)
+def check():
+ for prog in ('svn', 'make', 'install', 'gcc'):
+ if not grass.find_program(prog, ['--help']):
+ grass.fatal(_("%s required. Please install '%s' first.") % (prog, prog))
+def expand_module_class_name(c):
+ name = { 'd' : 'display',
+ 'db' : 'database',
+ 'g' : 'general',
+ 'i' : 'imagery',
+ 'm' : 'misc',
+ 'ps' : 'postscript',
+ 'p' : 'paint',
+ 'r' : 'raster',
+ 'r3' : 'raster3D',
+ 's' : 'sites',
+ 'v' : 'vector',
+ 'gui' : 'gui/wxpython' }
+ if name.has_key(c):
+ return name[c]
+ return c
+def list_available_modules(svnurl, full = False, shell = False):
+ mlist = list()
+ grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
+ pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
+ i = 0
+ prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
+ 'p', 'r', 'r3', 's', 'v']
+ nprefix = len(prefix)
+ for d in prefix:
+ if shell:
+ grass.percent(i, nprefix, 1)
+ i += 1
+ modclass = expand_module_class_name(d)
+ grass.verbose(_("Checking for '%s' modules...") % modclass)
+ url = '%s/%s' % (svnurl, modclass)
+ grass.debug("url = %s" % url, debug = 2)
+ f = urllib.urlopen(url)
+ if not f:
+ grass.warning(_("Unable to fetch '%s'") % url)
+ continue
+ for line in f.readlines():
+ # list modules
+ sline = pattern.search(line)
+ if not sline:
+ continue
+ name = sline.group(2).rstrip('/')
+ if name.split('.', 1)[0] == d:
+ print_module_desc(name, url, full, shell)
+ mlist.append(name)
+ mlist += list_wxgui_extensions(svnurl, full, shell)
+ if shell:
+ grass.percent(1, 1, 1)
+ return mlist
+def list_wxgui_extensions(svnurl, full = False, shell = False, print_module = True):
+ mlist = list()
+ grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
+ grass.verbose(_("Checking for '%s' modules...") % 'gui/wxpython')
+ url = '%s/%s' % (svnurl, 'gui/wxpython')
+ if not f:
+ return
+ # list modules
+ if not sline:
+ continue
+ if name not in ('..', 'Makefile'):
+ if print_module:
+ return mlist
+def print_module_desc(name, url, full = False, shell = False):
+ if not full and not shell:
+ print name
+ return
+ if shell:
+ print 'name=' + name
+ # check main.c first
+ desc = get_module_desc(url + '/' + name + '/' + name)
+ if not desc:
+ desc = get_module_desc(url + '/' + name + '/main.c', script = False)
+ if not desc:
+ if not shell:
+ print name + '-'
+ return
+ if shell:
+ print 'description=' + desc.get('description', '')
+ print 'keywords=' + ','.join(desc.get('keywords', list()))
+ else:
+ print name + ' - ' + desc.get('description', '')
+def get_module_desc(url, script = True):
+ grass.debug('url=%s' % url)
+ if script:
+ ret = get_module_script(f)
+ else:
+ ret = get_module_main(f)
+ return ret
+def get_module_main(f):
+ if not f:
+ return dict()
+ ret = { 'keyword' : list() }
+ pattern = re.compile(r'(module.*->)(.+)(=)(.*)', re.IGNORECASE)
+ keyword = re.compile(r'(G_add_keyword\()(.+)(\);)', re.IGNORECASE)
+ key = ''
+ value = ''
+ line = line.strip()
+ find = pattern.search(line)
+ if find:
+ key = find.group(2).strip()
+ line = find.group(4).strip()
+ else:
+ find = keyword.search(line)
+ if find:
+ ret['keyword'].append(find.group(2).replace('"', '').replace('_(', '').replace(')', ''))
+ if key:
+ value += line
+ if line[-2:] == ');':
+ value = value.replace('"', '').replace('_(', '').replace(');', '')
+ if key == 'keywords':
+ ret[key] = map(lambda x: x.strip(), value.split(','))
+ else:
+ ret[key] = value
+ key = value = ''
+ return ret
+def get_module_script(f):
+ ret = dict()
+ if not f:
+ return ret
+ begin = re.compile(r'#%.*module', re.IGNORECASE)
+ end = re.compile(r'#%.*end', re.IGNORECASE)
+ mline = None
+ if not mline:
+ mline = begin.search(line)
+ if mline:
+ if end.search(line):
+ break
+ try:
+ key, value = line.split(':', 1)
+ key = key.replace('#%', '').strip()
+ value = value.strip()
+ else:
+ ret[key] = value
+ except ValueError:
+ pass
+ return ret
+def cleanup():
+ global tmpdir, remove_tmpdir
+ if remove_tmpdir:
+ grass.try_rmdir(tmpdir)
+ else:
+ grass.info(_("Path to the source code: '%s'") % tmpdir)
+def install_extension(svnurl, prefix, module, no_install):
+ gisbase = os.getenv('GISBASE')
+ if not gisbase:
+ grass.fatal(_('$GISBASE not defined'))
+ if grass.find_program(module):
+ grass.warning(_("Extension '%s' already installed. Will be updated...") % module)
+ gui_list = list_wxgui_extensions(svnurl, print_module = False)
+ if module not in gui_list:
+ classchar = module.split('.', 1)[0]
+ moduleclass = expand_module_class_name(classchar)
+ url = svnurl + '/' + moduleclass + '/' + module
+ else:
+ url = svnurl + '/gui/wxpython/' + module
+ if not flags['s']:
+ grass.fatal(_("Installation of wxGUI extension requires -%s flag") % 's')
+ grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
+ global tmpdir
+ os.chdir(tmpdir)
+ if grass.verbosity() == 0:
+ outdev = open(os.devnull, 'w')
+ else:
+ outdev = sys.stdout
+ if grass.call(['svn', 'checkout',
+ url], stdout = outdev) != 0:
+ grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
+ os.chdir(os.path.join(tmpdir, module))
+ grass.message(_("Compiling '%s'...") % module)
+ if grass.call(['make',
+ 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ ')],
+ stdout = outdev) != 0:
+ grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
+ if no_install or module in gui_list:
+ return
+ grass.message(_("Installing '%s'...") % module)
+ # replace with something better
+ file = os.path.join(prefix, 'test')
+ f = open(file, "w")
+ f.close()
+ os.remove(file)
+ ret = grass.call(['make',
+ 'MODULE_TOPDIR=%s' % gisbase,
+ 'INST_DIR=%s' % prefix,
+ 'install'],
+ stdout = outdev)
+ else:
+ ret = grass.call(['sudo', 'make',
+ 'install'],
+ stdout = outdev)
+ if ret != 0:
+ grass.warning(_('Installation failed, sorry. Please check above error messages.'))
+ else:
+ grass.message(_("Installation of '%s' successfully finished.") % module)
+def remove_extension(prefix, module):
+ # is module available?
+ if not os.path.exists(os.path.join(prefix, 'bin', module)):
+ grass.fatal(_("Module '%s' not found") % module)
+ for file in [os.path.join(prefix, 'bin', module),
+ os.path.join(prefix, 'scripts', module),
+ os.path.join(prefix, 'docs', 'html', module + '.html')]:
+ if os.path.isfile(file):
+ os.remove(file)
+ grass.message(_("'%s' successfully uninstalled.") % module)
+def create_dir(path):
+ if os.path.isdir(path):
+ return
+ try:
+ os.makedirs(path)
+ except OSError, e:
+ grass.fatal(_("Unable to create '%s': %s") % (path, e))
+ grass.debug("'%s' created" % path)
+def check_dirs():
+ create_dir(os.path.join(options['prefix'], 'bin'))
+ create_dir(os.path.join(options['prefix'], 'docs', 'html'))
+ create_dir(os.path.join(options['prefix'], 'man', 'man1'))
+def main():
+ # check dependecies
+ check()
+ # list available modules
+ if flags['l'] or flags['f'] or flags['g']:
+ list_available_modules(options['svnurl'], full = flags['f'], shell = flags['g'])
+ return 0
+ else:
+ if not options['extension']:
+ grass.fatal(_('You need to define an extension name or use -l'))
+ # define path
+ if flags['s']:
+ options['prefix'] = os.environ['GISBASE']
+ if options['prefix'] == '$GRASS_ADDON_PATH':
+ if not os.environ.has_key('GRASS_ADDON_PATH') or \
+ not os.environ['GRASS_ADDON_PATH']:
+ grass.warning(_("GRASS_ADDON_PATH is not defined, installing to ~/.grass7/addons/"))
+ options['prefix'] = os.path.join(os.environ['HOME'], '.grass7', 'addons')
+ # check dirs
+ check_dirs()
+ if flags['d']:
+ if options['operation'] != 'add':
+ grass.warning(_("Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."))
+ else:
+ global remove_tmpdir
+ remove_tmpdir = False
+ if options['operation'] == 'add':
+ install_extension(options['svnurl'], options['prefix'], options['extension'], flags['i'])
+ else: # remove
+ remove_extension(options['prefix'], options['extension'])
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-03-26 15:27:58 UTC (rev 45763)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-03-26 16:09:43 UTC (rev 45764)
@@ -871,7 +871,7 @@
if not name:
return
log = self.parent.GetLogWindow()
- log.RunCmd(['g.extension', 'extension=' + name,
+ log.RunCmd(['g.extension.py', 'extension=' + name,
'svnurl=' + self.repo.GetValue().strip()])
self.OnCloseWindow(None)
@@ -997,7 +997,7 @@
flags = 'g'
else:
flags = 'l'
- ret = gcmd.RunCommand('g.extension', read = True,
+ ret = gcmd.RunCommand('g.extension.py', read = True,
svnurl = url,
flags = flags, quiet = True)
if not ret:
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-03-26 15:27:58 UTC (rev 45763)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-03-26 16:09:43 UTC (rev 45764)
@@ -89,6 +89,7 @@
from gui_modules.debug import Debug
from gui_modules.ghelp import MenuTreeWindow
from gui_modules.ghelp import AboutWindow
+from gui_modules.ghelp import InstallExtensionWindow
from gui_modules.toolbars import LayerManagerToolbar
from icons.icon import Icons
@@ -1038,6 +1039,12 @@
# reset display mode
os.environ['GRASS_RENDER_IMMEDIATE'] = 'TRUE'
+ def OnInstallExtension(self, event):
+ """!Install extension from GRASS Addons SVN repository"""
+ win = InstallExtensionWindow(self, size = (550, 400))
+ win.CentreOnScreen()
+ win.Show()
def OnPreferences(self, event):
"""!General GUI preferences/settings"""
if not self.dialogs['preferences']:
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-03-26 15:27:58 UTC (rev 45763)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-03-26 16:09:43 UTC (rev 45764)
@@ -842,6 +842,11 @@
</menu>
<separator />
<menuitem>
+ <label>Install new extension from add-ons</label>
+ <help>Install new extension from GRASS AddOns SVN repository.</help>
+ <handler>OnInstallExtension</handler>
+ </menuitem>
+ <menuitem>
<label>Manage add-ons extensions</label>
<help>Tool to maintain GRASS extensions in local GRASS installation.</help>
<keywords>general,extensions</keywords>
