[GRASS-SVN] r45779 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Mar 27 02:49:01 EDT 2011
Author: martinl
Date: 2011-03-26 23:49:01 -0700 (Sat, 26 Mar 2011)
New Revision: 45779
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
#1126: 3D view crashing when started with vector data (was: 3D view
crashing)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-03-27 06:10:18 UTC (rev 45778)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-03-27 06:49:01 UTC (rev 45779)
@@ -32,6 +32,8 @@
except ImportError:
import wx.lib.flatnotebook as FN
+import grass.script as grass
import globalvar
import gselect
import gcmd
@@ -2602,34 +2604,23 @@
@return num of points/features (expect of points)
@return None
- vInfo = gcmd.RunCommand('v.info',
- parent = self,
- read = True,
- flags = 't',
- map = layer.GetName())
+ vInfo = grass.vector_info_topo(layer.GetName())
if not vInfo:
return None
- npoints = nlines = nprimitives = 0
- for line in vInfo.splitlines():
- key, value = line.split('=')
- if key == 'map3d':
- mapIs3D = int(value)
- elif key == 'points':
- npoints = int(value)
- nprimitives += npoints
- elif key == 'lines':
- nlines = int(value)
- nprimitives += nlines
- elif key in ('boundaries',
- 'centroids',
- 'faces',
- 'kernels'):
- nprimitives += int(value)
- return (npoints, nlines, nprimitives, mapIs3D)
+ nprimitives = 0
+ for key, value in vInfo.iteritems():
+ if key in ('points',
+ 'lines',
+ 'boundaries',
+ 'centroids',
+ 'faces',
+ 'kernels'):
+ nprimitives += value
+ return (vInfo['points'], vInfo['lines'], nprimitives, vInfo['map3d'])
def UpdateVectorPage(self, layer, data, updateName = True):
"""!Update vector page"""
npoints, nlines, nfeatures, mapIs3D = self.VectorInfo(layer)
