[GRASS-SVN] r45800 - in grass/trunk: include/Make
scripts/g.extension
svn_grass at osgeo.org
Mon Mar 28 09:47:42 EDT 2011
Author: martinl
Date: 2011-03-28 06:47:42 -0700 (Mon, 28 Mar 2011)
New Revision: 45800
grass/trunk/include/Make/Install.make
grass/trunk/scripts/g.extension/g.extension.py
fix r45796 to install also wxGUI extension
Install.make fixed to set up also grass_home
Modified: grass/trunk/include/Make/Install.make
--- grass/trunk/include/Make/Install.make 2011-03-28 13:30:09 UTC (rev 45799)
+++ grass/trunk/include/Make/Install.make 2011-03-28 13:47:42 UTC (rev 45800)
@@ -132,9 +132,14 @@
sed -e 's#$(GISBASE)#$(INST_DIR)#g' $< > $@
endef
+define fix_grass_home
+sed -e 's#^\(GRASS_HOME.[^=]*\).*#\1= $(INST_DIR)#g' \
+ -e 's#$(GISBASE)#$(INST_DIR)#g' $< > $@
+endef
define fix_grass_arch
-sed -e 's#^ARCH_DISTDIR.*#ARCH_DISTDIR = $(INST_DIR)#g' \
- -e 's#^ARCH_BINDIR.*#ARCH_BINDIR = $(UNIX_BIN)#g' $< > $@
+sed -e 's#^\(ARCH_DISTDIR.[^=]*\).*#\1= $(INST_DIR)#g' \
+ -e 's#^\(ARCH_BINDIR.[^=]*\).*#\1= $(UNIX_BIN)#g' $< > $@
endef
$(INST_DIR)/$(FONTCAP): $(GISBASE)/$(FONTCAP)
@@ -144,7 +149,7 @@
$(call fix_gisbase)
$(INST_DIR)/$(PLATMAKE): $(GISBASE)/$(PLATMAKE)
- $(call fix_gisbase)
+ $(call fix_grass_home)
$(INST_DIR)/$(GRASSMAKE): $(GISBASE)/$(GRASSMAKE)
$(call fix_grass_arch)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-03-28 13:30:09 UTC (rev 45799)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-03-28 13:47:42 UTC (rev 45800)
@@ -306,10 +306,8 @@
else:
url = svnurl + '/gui/wxpython/' + module
if not flags['s']:
- grass.warning(_("Installation of wxGUI extension requires -%s flag. "
- "Trying to use system administrator rights.") % 's')
- flags['s'] = True
+ grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % module)
global tmpdir
os.chdir(tmpdir)
@@ -323,22 +321,29 @@
grass.fatal(_("GRASS Addons '%s' not found in repository") % module)
os.chdir(os.path.join(tmpdir, module))
+ grass.message(_("Compiling '%s'...") % module)
+ if module not in gui_list:
+ bin_dir = os.path.join(tmpdir, module, 'bin')
+ docs_dir = os.path.join(tmpdir, module, 'docs')
+ html_dir = os.path.join(docs_dir, 'html')
+ man_dir = os.path.join(tmpdir, module, 'man')
+ man1_dir = os.path.join(man_dir, 'man1')
+ for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir):
+ os.mkdir(d)
- bin_dir = os.path.join(tmpdir, module, 'bin')
- docs_dir = os.path.join(tmpdir, module, 'docs')
- html_dir = os.path.join(docs_dir, 'html')
- man_dir = os.path.join(tmpdir, module, 'man')
- man1_dir = os.path.join(man_dir, 'man1')
- for d in (bin_dir, docs_dir, html_dir, man_dir, man1_dir):
- os.mkdir(d)
+ ret = grass.call(['make',
+ 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
+ 'BIN=%s' % bin_dir,
+ 'HTMLDIR=%s' % html_dir,
+ 'MANDIR=%s' % man1_dir],
+ stdout = outdev)
+ else:
+ 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ ')],
+ stdout = outdev)
- grass.message(_("Compiling '%s'...") % module)
- if grass.call(['make',
- 'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
- 'BIN=%s' % bin_dir,
- 'HTMLDIR=%s' % html_dir,
- 'MANDIR=%s' % man1_dir],
- stdout = outdev) != 0:
+ if ret != 0:
grass.fatal(_('Compilation failed, sorry. Please check above error messages.'))
if no_install or module in gui_list:
