[GRASS-SVN] r45813 - grass/branches/develbranch_6/lib/vector/Vlib
Wed Mar 30 06:58:09 EDT 2011
Author: mmetz
Date: 2011-03-30 03:58:09 -0700 (Wed, 30 Mar 2011)
New Revision: 45813
   grass/branches/develbranch_6/lib/vector/Vlib/buffer.c
fix debug levels
Modified: grass/branches/develbranch_6/lib/vector/Vlib/buffer.c
--- grass/branches/develbranch_6/lib/vector/Vlib/buffer.c	2011-03-30 06:09:40 UTC (rev 45812)
+++ grass/branches/develbranch_6/lib/vector/Vlib/buffer.c	2011-03-30 10:58:09 UTC (rev 45813)
@@ -281,7 +281,7 @@
     while (first < np - 2) {
 	/* find first loop which doesn't contain any other loop */
 	current = first;
-	G_debug(0, "current: %d", current);
+	G_debug(5, "current: %d", current);
 	last = Points->n_points - 2;
 	lcount = 0;
 	sa = current;
@@ -294,7 +294,7 @@
 	    current = sa + 1;
 	    last = sb;
 	    lcount++;
-	    G_debug(0, "  current = %d, last = %d, lcount = %d", current,
+	    G_debug(5, "  current = %d, last = %d, lcount = %d", current,
 		    last, lcount);
 	if (lcount == 0) {
@@ -308,7 +308,7 @@
 	if (sa < sa_max)
 	    break;
-	G_debug(0, "sa: %d", sa);
+	G_debug(4, "sa: %d", sa);
 	/* remove loop if in buffer */
 	if ((sb - sa) == 1) {	/* neighbouring lines overlap */
