[GRASS-SVN] r46167 - grass/trunk/ps/ps.map
Tue May 3 08:39:12 EDT 2011
Author: hamish
Date: 2011-05-03 05:39:12 -0700 (Tue, 03 May 2011)
New Revision: 46167
   grass/trunk/ps/ps.map/do_plt.c
   grass/trunk/ps/ps.map/eps.c
   grass/trunk/ps/ps.map/map_info.c
   grass/trunk/ps/ps.map/r_plt.c
allow spaces in EPS file pathname (merge from devbr6)
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c	2011-05-03 12:35:17 UTC (rev 46166)
+++ grass/trunk/ps/ps.map/do_plt.c	2011-05-03 12:39:12 UTC (rev 46167)
@@ -152,7 +152,7 @@
 	    break;
 	case 'E':		/* EPS file */
-	    if (sscanf(buf, "E %d %lf %lf %lf %lf %s",
+	    if (sscanf(buf, "E %d %lf %lf %lf %lf %[^\n]s",
 		       &masked, &e1, &n1, &scale, &rotate, name) == 6) {
 		if (masked && after_masking)
 		    continue;
Modified: grass/trunk/ps/ps.map/eps.c
--- grass/trunk/ps/ps.map/eps.c	2011-05-03 12:35:17 UTC (rev 46166)
+++ grass/trunk/ps/ps.map/eps.c	2011-05-03 12:39:12 UTC (rev 46167)
@@ -1,5 +1,6 @@
 #include <math.h>
 #include <string.h>
+#include <grass/glocale.h>
 #include "local_proto.h"
 /*  test if file is realy EPS file and find bbox
@@ -14,7 +15,7 @@
     /* test if file is realy eps and find bbox */
     if ((fp = fopen(eps, "r")) == NULL) {
-	fprintf(stderr, "can't open eps file <%s>\n", eps);
+	G_warning(_("Can't open eps file <%s>"), eps);
 	return (0);
     /* test if first row contains '%!PS-Adobe-m.n EPSF-m.n' string */
@@ -33,7 +34,7 @@
 	    return (1);
-    fprintf(stderr, "Bounding box in eps file <%s> was not found\n", eps);
+    G_warning(_("Bounding box in eps file <%s> was not found"), eps);
     fclose(fp);
     return (0);
Modified: grass/trunk/ps/ps.map/map_info.c
--- grass/trunk/ps/ps.map/map_info.c	2011-05-03 12:35:17 UTC (rev 46166)
+++ grass/trunk/ps/ps.map/map_info.c	2011-05-03 12:39:12 UTC (rev 46167)
@@ -25,6 +25,7 @@
     /* get text location */
     dy = fontsize;
     if (m_info.x > 0.0)
 	x = 72.0 * m_info.x;
     else
@@ -33,7 +34,9 @@
 	y = 72.0 * (PS.page_height - m_info.y);
     else
 	y = PS.min_y;
     margin = 0.2 * fontsize;
     if (x < PS.map_left + margin)
 	x = PS.map_left + margin;
Modified: grass/trunk/ps/ps.map/r_plt.c
--- grass/trunk/ps/ps.map/r_plt.c	2011-05-03 12:35:17 UTC (rev 46166)
+++ grass/trunk/ps/ps.map/r_plt.c	2011-05-03 12:39:12 UTC (rev 46167)
@@ -1,6 +1,7 @@
 #include <string.h>
 #include <grass/colors.h>
 #include <grass/raster.h>
 #define KEY(x)(strcmp(key,x)==0)
@@ -155,7 +156,7 @@
 	    /* test if file is accessible */
-		error(key, data, "Can't open eps file");
+		error(key, data, _("Can't open eps file"));
 	    have_eps = 1;
 	    fclose(fp);
