[GRASS-SVN] r46176 - grass/trunk/lib/lidar
svn_grass at osgeo.org
Wed May 4 03:43:01 EDT 2011
Author: mmetz
Date: 2011-05-04 00:43:01 -0700 (Wed, 04 May 2011)
New Revision: 46176
grass/trunk/lib/lidar/lidar.h
grass/trunk/lib/lidar/zones.c
fix bspline raster interpolation (lib)
Modified: grass/trunk/lib/lidar/lidar.h
--- grass/trunk/lib/lidar/lidar.h 2011-05-04 06:56:02 UTC (rev 46175)
+++ grass/trunk/lib/lidar/lidar.h 2011-05-04 07:43:01 UTC (rev 46176)
@@ -113,10 +113,9 @@
int *, /**/ int, /**/ int /**/);
struct Point *P_Read_Raster_Region_Map(double **, /**/
- char **, /**/
struct Cell_head *, /**/
- int *, /**/ int *, /**/ int /**/);
+ int *, /**/ int /**/);
double P_Mean_Calc(struct Cell_head *, /**/ struct Point *, /**/ int /**/);
Modified: grass/trunk/lib/lidar/zones.c
--- grass/trunk/lib/lidar/zones.c 2011-05-04 06:56:02 UTC (rev 46175)
+++ grass/trunk/lib/lidar/zones.c 2011-05-04 07:43:01 UTC (rev 46176)
@@ -118,7 +118,8 @@
int P_set_dim(struct Reg_dimens *dim, double pe, double pn, int *nsplx, int *nsply)
- int total_splines, edge_splines, n_windows, minsplines;
+ int total_splines, edge_splines, n_windows;
+ int lastsplines, lastsplines_min, lastsplines_max;
double E_extension, N_extension, edgeE, edgeN;
struct Cell_head orig;
int ret = 0;
@@ -137,62 +138,49 @@
/* remaining steps must be larger than edge_v + overlap + half of overlap window */
total_splines = ceil(E_extension / pe);
edge_splines = edgeE / pe;
- n_windows = floor(E_extension / edgeE); /* without last one */
+ n_windows = E_extension / edgeE; /* without last one */
if (n_windows > 0) {
- minsplines = ceil((double)(dim->ew_size / 2.0 - dim->edge_v - dim->overlap) / pe);
- while (total_splines - edge_splines * n_windows < minsplines) {
+ /* min size of the last overlap window = half of current overlap window */
+ /* max size of the last overlap window = elaboration - 3 * edge - overlap */
+ lastsplines_min = ceil((dim->ew_size / 2.0 - 2 * (dim->edge_v + dim->overlap)) / pe);
+ lastsplines_max = ceil((dim->ew_size - 3 * dim->edge_v - dim->overlap) / pe);
+ lastsplines = total_splines - edge_splines * n_windows;
+ while (lastsplines > lastsplines_max || lastsplines < lastsplines_min) {
*nsplx -= 1;
dim->ew_size = *nsplx * pe;
edgeE = dim->ew_size - dim->overlap - 2 * dim->edge_v;
if (ret == 0)
ret = 1;
- while (total_splines - edge_splines * n_windows < minsplines * 2 && minsplines > 30) {
- *nsplx -= 1;
- dim->ew_size = *nsplx * pe;
- edgeE = dim->ew_size - dim->overlap - 2 * dim->edge_v;
- edge_splines = edgeE / pe;
- if (ret == 0)
- ret = 1;
total_splines = ceil(N_extension / pn);
edge_splines = edgeN / pn;
- n_windows = floor(N_extension / edgeN); /* without last one */
+ n_windows = N_extension / edgeN; /* without last one */
- minsplines = ceil((double)(dim->sn_size / 2.0 - dim->edge_h - dim->overlap) / pn);
+ lastsplines_min = ceil((dim->sn_size / 2.0 - 2 * (dim->edge_h - dim->overlap)) / pn);
+ lastsplines_max = ceil((dim->sn_size - 3 * dim->edge_h - dim->overlap) / pn);
*nsply -= 1;
dim->sn_size = *nsply * pn;
edgeN = dim->sn_size - dim->overlap - 2 * dim->edge_h;
if (ret < 2)
ret += 2;
- *nsply -= 1;
- dim->sn_size = *nsply * pn;
- edgeN = dim->sn_size - dim->overlap - 2 * dim->edge_h;
- edge_splines = edgeN / pn;
- if (ret < 2)
- ret += 2;
- return 0;
+ return ret;
@@ -385,13 +373,13 @@
return obs;
-struct Point *P_Read_Raster_Region_Map(double **matrix, char **mask_matrix,
+struct Point *P_Read_Raster_Region_Map(double **matrix,
struct Cell_head *Elaboration,
struct Cell_head *Original,
- int *num_points, int *num_nulls, int dim_vect)
+ int *num_points, int dim_vect)
int col, row, startcol, endcol, startrow, endrow, nrows, ncols;
- int pippo, npoints, nnulls, all_masked = 0;
+ int pippo, npoints;
double x, y, z;
struct Point *obs;
struct bound_box elaboration_box;
@@ -402,13 +390,10 @@
/* Reading points inside elaboration zone */
Vect_region_box(Elaboration, &elaboration_box);
- npoints = nnulls = 0;
+ npoints = 0;
nrows = Original->rows;
ncols = Original->cols;
- if (mask_matrix)
- all_masked = 1;
if (Original->north > Elaboration->north)
startrow = (Original->north - Elaboration->north) / Original->ns_res - 1;
else
@@ -439,11 +424,6 @@
if (!Rast_is_d_null_value(&z)) {
- if (mask_matrix && all_masked) {
- if (mask_matrix[row][col])
- all_masked = 0;
x = Rast_col_to_easting((double)(col) + 0.5, Original);
y = Rast_row_to_northing((double)(row) + 0.5, Original);
@@ -463,18 +443,9 @@
obs[npoints - 1].coordZ = z;
- else {
- /* if point in output region */
- nnulls++;
- /* num_nulls indicates how many points to interpolate */
- if (all_masked)
- *num_nulls = 0;
- else
- *num_nulls = nnulls;
*num_points = npoints;
return obs;
