[GRASS-SVN] r46195 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed May 4 18:23:05 EDT 2011
Author: martinl
Date: 2011-05-04 15:23:05 -0700 (Wed, 04 May 2011)
New Revision: 46195
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: fix settings dialog
(merge r46194 from relbr64)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2011-05-04 22:20:28 UTC (rev 46194)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2011-05-04 22:23:05 UTC (rev 46195)
@@ -65,12 +65,13 @@
wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY, title = title, style = style)
- self.parent = parent # mapdisplay.BufferedWindow class instance
+ self.parent = parent # mapdisplay.MapFrame class instance
+ self.digit = self.parent.MapWindow.digit
# notebook
notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
self._createSymbologyPage(notebook)
- self.parent.digit.SetCategory()
+ self.digit.SetCategory()
self._createGeneralPage(notebook)
self._createAttributesPage(notebook)
self._createQueryPage(notebook)
@@ -205,7 +206,7 @@
self.mapUnits = self.parent.MapWindow.Map.GetProjInfo()['units']
self.snappingInfo = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = _("Snapping threshold is %(value).1f %(units)s") % \
- {'value' : self.parent.digit.GetDisplay().GetThreshold(),
+ {'value' : self.digit.GetDisplay().GetThreshold(),
'units' : self.mapUnits})
vertexSizer.Add(item = self.snappingInfo, proportion = 0,
flag = wx.ALL | wx.EXPAND, border = 1)
@@ -588,7 +589,7 @@
if mode == 2 and self.addRecord.IsChecked(): # no category
self.addRecord.SetValue(False)
self.category.SetValue(UserSettings.Get(group = 'vdigit', key = 'category', subkey = 'value'))
def OnChangeLayer(self, event):
@@ -597,7 +598,7 @@
layer = event.GetInt()
if layer > 0:
UserSettings.Set(group = 'vdigit', key = 'layer', subkey = 'value', value = layer)
event.Skip()
@@ -605,7 +606,7 @@
def OnChangeAddRecord(self, event):
"""!Checkbox 'Add new record' status changed
- self.category.SetValue(self.parent.digit.SetCategory())
+ self.category.SetValue(self.digit.SetCategory())
def OnChangeSnappingValue(self, event):
"""!Change snapping value - update static text
@@ -615,12 +616,12 @@
if value < 0:
region = self.parent.MapWindow.Map.GetRegion()
res = (region['nsres'] + region['ewres']) / 2.
- threshold = self.parent.digit.GetDisplay().GetThreshold(value = res)
+ threshold = self.digit.GetDisplay().GetThreshold(value = res)
else:
if self.snappingUnit.GetStringSelection() == "map units":
threshold = value
else:
- threshold = self.parent.digit.GetDisplay().GetThreshold(value = value)
+ threshold = self.digit.GetDisplay().GetThreshold(value = value)
if value == 0:
self.snappingInfo.SetLabel(_("Snapping disabled"))
@@ -641,7 +642,7 @@
value = self.snappingValue.GetValue()
units = self.snappingUnit.GetStringSelection()
- threshold = self.parent.digit.GetDisplay().GetThreshold(value = value, units = units)
+ threshold = self.digit.GetDisplay().GetThreshold(value = value, units = units)
if units == "map units":
self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
@@ -807,7 +808,7 @@
UserSettings.Set(group = 'vdigit', key = "breakLines", subkey = 'enabled',
value = self.intersect.IsChecked())
- self.parent.digit.UpdateSettings()
+ self.digit.UpdateSettings()
# redraw map if auto-rendering is enabled
if self.parent.statusbarWin['render'].GetValue():
