[GRASS-SVN] r46208 - in grass/trunk: gui/wxpython/gui_modules
lib/ogsf
svn_grass at osgeo.org
Sun May 8 16:31:07 EDT 2011
Author: martinl
Date: 2011-05-08 13:31:07 -0700 (Sun, 08 May 2011)
New Revision: 46208
grass/trunk/gui/wxpython/gui_modules/layertree.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/lib/ogsf/GS2.c
annakrat: fix some wxnviz known issues (http://grass.osgeo.org/wiki/WxNviz#Known_issues) - # 5
fix reloading data (check / uncheck data layer)
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-05-08 19:58:37 UTC (rev 46207)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-05-08 20:31:07 UTC (rev 46208)
@@ -231,7 +231,8 @@
if self.rerender:
if self.mapdisplay.statusbarWin['render'].GetValue():
self.mapdisplay.MapWindow.UpdateMap(render = True)
+ self.rerender = False
event.Skip()
def OnKeyUp(self, event):
@@ -1108,11 +1109,13 @@
elif mapLayer.type == '3d-raster':
self.mapdisplay.MapWindow.LoadRaster3d(item)
elif mapLayer.type == 'vector':
- self.mapdisplay.MapWindow.LoadVector(item)
+ npoints, nlines, nfeatures, mapIs3D = self.lmgr.nviz.VectorInfo(mapLayer)
+ if npoints > 0:
+ self.mapdisplay.MapWindow.LoadVector(item, points = True)
+ if nlines > 0:
+ self.mapdisplay.MapWindow.LoadVector(item, points = False)
else: # disable
- data = self.GetPyData(item)[0]['nviz']
if mapLayer.type == 'raster':
self.mapdisplay.MapWindow.UnloadRaster(item)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-05-08 19:58:37 UTC (rev 46207)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-05-08 20:31:07 UTC (rev 46208)
@@ -399,6 +399,8 @@
self.MapWindow = self.MapWindow3D
# add Nviz notebookpage
self._layerManager.AddNviz()
+ self._layerManager.nviz.UpdatePage('view')
+ self._layerManager.nviz.UpdatePage('light')
# switch from MapWindow to MapWindowGL
# add nviz toolbar
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-05-08 19:58:37 UTC (rev 46207)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2011-05-08 20:31:07 UTC (rev 46208)
@@ -117,6 +117,9 @@
self.img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+ # size of MapWindow, to avoid resizing if size is the same
+ self.size = (0,0)
# default values
@@ -148,13 +151,14 @@
def OnSize(self, event):
size = self.GetClientSize()
- if self.GetContext():
+ if self.size != size \
+ and self.GetContext():
Debug.msg(3, "GLCanvas.OnSize(): w = %d, h = %d" % \
(size.width, size.height))
self.SetCurrent()
self._display.ResizeWindow(size.width,
size.height)
+ self.size = size
event.Skip()
def OnPaint(self, event):
@@ -315,7 +319,7 @@
"""!Change light settings"""
data = self.light
self._display.SetLight(x = data['position']['x'], y = data['position']['y'],
- z = data['position']['z'], color = data['color'],
+ z = data['position']['z'] / 100., color = data['color'],
bright = data['bright'] / 100.,
ambient = data['ambient'] / 100.)
self._display.DrawLightingModel()
@@ -473,12 +477,6 @@
elif ltype == '3d-raster':
self.UnloadRaster3d(layer)
elif ltype == 'vector':
- data = self.tree.GetPyData(layer)[0]['nviz']
- vecType = []
- if data and 'vector' in data:
- for v in ('lines', 'points'):
- if data['vector'][v]:
- vecType.append(v)
self.UnloadVector(layer, True)
self.UnloadVector(layer, False)
@@ -950,6 +948,7 @@
self._display.SetSurfacePosition(id, x, y, z)
data['position'].pop('update')
+ data['draw']['all'] = False
def UpdateVolumeProperties(self, id, data, isosurfId = None):
"""!Update volume (isosurface/slice) map object properties"""
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-05-08 19:58:37 UTC (rev 46207)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2011-05-08 20:31:07 UTC (rev 46208)
@@ -1192,6 +1192,7 @@
colour = UserSettings.Get(group = 'nviz', key = 'light',
subkey = 'color'),
size = globalvar.DIALOG_COLOR_SIZE)
+ self.win['light']['color'] = color.GetId()
color.Bind(csel.EVT_COLOURSELECT, self.OnLightColor)
gridSizer.Add(item = color, pos = (0, 2))
@@ -1461,7 +1462,7 @@
return
val = event.GetInt()
- self.mapWindow.light['position']['z'] = val / 100.
+ self.mapWindow.light['position']['z'] = val
for win in self.win['light'][winName].itervalues():
self.FindWindowById(win).SetValue(val)
@@ -1492,6 +1493,7 @@
def OnBgColor(self, event):
"""!Background color changed"""
color = event.GetValue()
+ self.mapWindow.view['background']['color'] = event.GetValue()
color = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
self._display.SetBgColor(str(color))
@@ -1799,7 +1801,7 @@
"""!Draw resolution changed"""
self.SetSurfaceResolution()
- if apply and self.mapDisplay.statusbarWin['render'].IsChecked():
+ if self.mapDisplay.statusbarWin['render'].IsChecked():
self.mapWindow.Refresh(False)
def SetSurfaceResolution(self):
@@ -1817,10 +1819,7 @@
wx.PostEvent(self.mapWindow, event)
def SetSurfaceMode(self):
- """!Set draw mode
- @param apply allow auto-rendering
+ """!Set draw mode"""
mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
if mode == 0: # coarse
self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
@@ -1853,7 +1852,7 @@
event = wxUpdateProperties(data = data)
def OnSurfaceModeAll(self, event):
@@ -1865,10 +1864,12 @@
cvalue = self._getColorString(color)
for name in self.mapWindow.GetLayerNames(type = 'raster'):
- data = self.GetLayerData('surface')
+ data = self.mapWindow.GetLayerByName(name, mapType = 'raster', dataType = 'nviz')
if not data:
continue # shouldy no happen
+ data['surface']['draw']['all'] = True
data['surface']['draw']['mode'] = { 'value' : value,
'desc' : desc,
'update' : None }
@@ -1882,7 +1883,7 @@
def _getColorString(self, color):
@@ -2480,6 +2481,9 @@
zmax)
self.FindWindowById(self.win['view']['z-exag'][control]).SetValue(zval)
+ self.FindWindowById(self.win['view']['bgcolor']).SetColour(\
+ self.mapWindow.view['background']['color'])
elif pageId in ('surface', 'vector', 'volume'):
name = self.FindWindowById(self.win[pageId]['map']).GetValue()
data = self.GetLayerData(pageId)
@@ -2501,6 +2505,7 @@
self.FindWindowById(self.win['light']['z'][control]).SetValue(zval)
self.FindWindowById(self.win['light']['bright'][control]).SetValue(bval)
self.FindWindowById(self.win['light']['ambient'][control]).SetValue(aval)
+ self.FindWindowById(self.win['light']['color']).SetColour(self.mapWindow.light['color'])
elif pageId == 'fringe':
win = self.FindWindowById(self.win['fringe']['map'])
win.SetValue(self.FindWindowById(self.win['surface']['map']).GetValue())
@@ -2593,8 +2598,7 @@
else:
win.SetValue(value)
# enable/disable res widget + set draw mode
- self.SetSurfaceMode()
- color = self.FindWindowById(self.win['surface']['draw']['wire-color'])
+ self.OnSurfaceMode(event = None)
def VectorInfo(self, layer):
"""!Get number of points/lines
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c 2011-05-08 19:58:37 UTC (rev 46207)
+++ grass/trunk/lib/ogsf/GS2.c 2011-05-08 20:31:07 UTC (rev 46208)
@@ -1599,15 +1599,16 @@
unsigned int atty;
const char *mapset;
struct Cell_head rast_head;
- int reuse = 0, begin, hdata, ret, neg = 0, has_null = 0;
+ int reuse, begin, hdata, ret, neg, has_null;
typbuff *tbuff;
G_debug(3, "GS_load_att_map(): map=%s", filename);
+ reuse = ret = neg = has_null = 0;
gs = gs_get_surf(id);
if (NULL == gs) {
- return (-1);
+ return -1;
gs->mask_needupdate = (ATT_MASK == att || ATT_TOPO == att ||
@@ -1647,8 +1648,7 @@
if (0 < (hdata = gsds_findh(filename, &changed, &atty, begin))) {
- G_debug(3,
- "GS_load_att_map(): %s already has data handle %d.CF=%x",
+ G_debug(3, "GS_load_att_map(): %s already has data handle %d.CF=%x",
filename, hdata, changed);
/* handle found */
@@ -1688,8 +1688,7 @@
filename, hdata);
else {
- G_debug(3,
- "GS_load_att_map(): %s not loaded in correct form - loading now",
+ G_debug(3, "GS_load_att_map(): %s not loaded in correct form - loading now",
filename);
/* not loaded - need to get new dataset handle */
@@ -1769,7 +1768,7 @@
if (ret == -1) {
gsds_free_data_buff(gs->att[att].hdata, ATTY_NULL);
- return (-1);
+ return -1;
G_debug(4, " has_null=%d", has_null);
@@ -1841,7 +1840,7 @@
G_warning(_("Error finding range"));
- return (ret);
+ return ret;
