[GRASS-SVN] r46214 - grass-addons/raster/r.stream.extract
    svn_grass at osgeo.org
    Mon May  9 08:22:33 EDT 2011
Author: neteler
Date: 2011-05-09 05:22:33 -0700 (Mon, 09 May 2011)
New Revision: 46214
   grass-addons/raster/r.stream.extract/local_proto.h
   grass-addons/raster/r.stream.extract/main.c
compilation fix
Modified: grass-addons/raster/r.stream.extract/local_proto.h
--- grass-addons/raster/r.stream.extract/local_proto.h	2011-05-09 12:02:05 UTC (rev 46213)
+++ grass-addons/raster/r.stream.extract/local_proto.h	2011-05-09 12:22:33 UTC (rev 46214)
@@ -19,7 +19,14 @@
     int r, c;
-struct snode
+/* global variables */
+#ifdef MAIN
+#       define GLOBAL
+#else
+#       define GLOBAL extern
+#endif
+GLOBAL struct snode
     int r, c;
     int id;
@@ -31,25 +38,25 @@
 } *stream_node;
-extern int nrows, ncols;
-extern unsigned int *astar_pts;
-extern unsigned int n_search_points, n_points, nxt_avail_pt;
-extern unsigned int heap_size, *astar_added;
-extern unsigned int n_stream_nodes, n_alloc_nodes;
-extern struct point *outlets;
-extern unsigned int n_outlets, n_alloc_outlets;
-extern DCELL *acc;
-extern CELL *ele;
-extern char *asp;
-extern CELL *stream;
-extern FLAG *worked, *in_list;
-extern char drain[3][3];
-extern unsigned int first_cum;
-extern char sides;
-extern int c_fac;
-extern int ele_scale;
-extern int have_depressions;
-extern struct RB_TREE *draintree;
+GLOBAL int nrows, ncols;
+GLOBAL unsigned int *astar_pts;
+GLOBAL unsigned int n_search_points, n_points, nxt_avail_pt;
+GLOBAL unsigned int heap_size, *astar_added;
+GLOBAL unsigned int n_stream_nodes, n_alloc_nodes;
+GLOBAL struct point *outlets;
+GLOBAL unsigned int n_outlets, n_alloc_outlets;
+GLOBAL DCELL *acc;
+GLOBAL CELL *ele;
+GLOBAL char *asp;
+GLOBAL CELL *stream;
+GLOBAL FLAG *worked, *in_list;
+GLOBAL char drain[3][3];
+GLOBAL unsigned int first_cum;
+GLOBAL char sides;
+GLOBAL int c_fac;
+GLOBAL int ele_scale;
+GLOBAL int have_depressions;
+GLOBAL struct RB_TREE *draintree;
 /* load.c */
 int load_maps(int, int, int);
Modified: grass-addons/raster/r.stream.extract/main.c
--- grass-addons/raster/r.stream.extract/main.c	2011-05-09 12:02:05 UTC (rev 46213)
+++ grass-addons/raster/r.stream.extract/main.c	2011-05-09 12:22:33 UTC (rev 46214)
@@ -18,6 +18,7 @@
 #include <float.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
+#define MAIN
 #include "local_proto.h"
