[GRASS-SVN] r46259 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Fri May 13 06:10:45 EDT 2011
Author: hamish
Date: 2011-05-13 03:10:44 -0700 (Fri, 13 May 2011)
New Revision: 46259
grass/branches/develbranch_6/scripts/g.extension/description.html
grass/branches/develbranch_6/scripts/g.extension/g.extension
add new -u flag to support systems using sudo;
remove do-nothing curly brackets;
add bug warning to man page
Modified: grass/branches/develbranch_6/scripts/g.extension/description.html
--- grass/branches/develbranch_6/scripts/g.extension/description.html 2011-05-13 09:35:51 UTC (rev 46258)
+++ grass/branches/develbranch_6/scripts/g.extension/description.html 2011-05-13 10:10:44 UTC (rev 46259)
@@ -5,7 +5,11 @@
<p>
Re-running the script on an installed GRASS Addon re-installs
the requested extension which may include updates.
+<P>
+If your GRASS_ADDON_PATH contains more than one path, the default
+action is to use the first directory in the list.
<h2>EXAMPLES</h2>
Download and install <em>i.landsat.toar</em> into current GRASS installation:
@@ -13,8 +17,17 @@
g.extension extension=i.landsat.toar
</pre></div>
+<h2>BUGS</h2>
+This is a new module and obtaining successful behavior on all platforms
+is rather tricky. Please report any problems to the GRASS bug tracker.
+If this automatic build fails, instructions for compiling both the GRASS
+source code and GRASS addons by hand can be found in the GRASS wiki.
<h2>AUTHOR</h2>
Markus Neteler
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2011-05-13 09:35:51 UTC (rev 46258)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2011-05-13 10:10:44 UTC (rev 46259)
@@ -62,6 +62,10 @@
#% key: s
#% description: Install system-wide (may need system administrator rights)
#%end
+#%flag
+#% key: u
+#% description: Install system-wide using sudo
+#%end
if [ -z "$GISBASE" ] ; then
@@ -218,9 +222,14 @@
GRASS_ADDON_PATH1=`echo "$GRASS_ADDON_PATH" | cut -f1 -d:`
fi
PREFIX="$GRASS_ADDON_PATH1"
-elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] ; then
+elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] || [ $GIS_FLAG_U -eq 1 ] ; then
SYSADMIN=1
PREFIX="$GISBASE"
+ # just to make later tests happy
+ if [ $GIS_FLAG_S -eq 0 ] && [ $GIS_FLAG_U -eq 1 ] ; then
+ GIS_FLAG_S=1
+ fi
fi
@@ -288,29 +297,39 @@
PROGTYPE=bin
fi
# can we write? Install dir present?
- if test ! -d "${MYINST_DIR}" ; then
- mkdir -p "${MYINST_DIR}"
+ if test ! -d "$MYINST_DIR" ; then
+ mkdir -p "$MYINST_DIR"
fi
- if test ! -d "${MYINST_DIR}/$PROGTYPE" ; then
- mkdir -p "${MYINST_DIR}/$PROGTYPE"
+ if test ! -d "$MYINST_DIR/$PROGTYPE" ; then
+ mkdir -p "$MYINST_DIR/$PROGTYPE"
fi
- if test ! -d "${MYINST_DIR}/docs/html" ; then
- mkdir -p "${MYINST_DIR}/docs/html"
+ if test ! -d "$MYINST_DIR/docs/html" ; then
+ mkdir -p "$MYINST_DIR/docs/html"
fi
- if test ! -d "${MYINST_DIR}/man/man1" ; then
- mkdir -p "${MYINST_DIR}/man/man1"
+ if test ! -d "$MYINST_DIR/man/man1" ; then
+ mkdir -p "$MYINST_DIR/man/man1"
fi
if [ $SYSADMIN -eq 1 ] ; then
- if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
- g.message "You need to enter the root password to remove the previous version of ${MODULE}:"
- su -c "rm -f \"${MYINST_DIR}/$PROGTYPE/${MODULE}\""
+ if test -f "$MYINST_DIR/$PROGTYPE/$MODULE" ; then
+ if [ $GIS_FLAG_U -eq 1 ] ; then
+ g.message "You may need to enter your password to remove an earlier copy of $MODULE:"
+ sudo rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
+ else
+ g.message "You need to enter the root password to remove an earlier copy of $MODULE:"
+ su -c "rm -f \"$MYINST_DIR/$PROGTYPE/$MODULE\""
+ fi
fi
- g.message "You need to enter the root password next to install ${MODULE}:"
- su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
+ g.message "You may need to enter your password to install $MODULE:"
+ sudo make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install
+ else
+ g.message "You need to enter the root password to install $MODULE:"
+ su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
+ fi
else
- rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
+ rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
fi
fi
@@ -321,7 +340,7 @@
exit 1
fi
- if [ ! -x "${MYINST_DIR}/$PROGTYPE/${MODULE}" ] ; then
+ if [ ! -x "$MYINST_DIR/$PROGTYPE/$MODULE" ] ; then
g.message -e "Module did not install properly"
cleanup
exit 1
