[GRASS-SVN] r46266 - grass/trunk/lib/lidar
svn_grass at osgeo.org
Sat May 14 09:09:50 EDT 2011
Author: mmetz
Date: 2011-05-14 06:09:50 -0700 (Sat, 14 May 2011)
New Revision: 46266
grass/trunk/lib/lidar/lidar.h
grass/trunk/lib/lidar/raster.c
grass/trunk/lib/lidar/zones.c
lidarlib: use segmentlib
Modified: grass/trunk/lib/lidar/lidar.h
--- grass/trunk/lib/lidar/lidar.h 2011-05-14 08:01:55 UTC (rev 46265)
+++ grass/trunk/lib/lidar/lidar.h 2011-05-14 13:09:50 UTC (rev 46266)
@@ -25,6 +25,7 @@
#include <grass/vector.h>
#include <grass/dbmi.h>
#include <grass/raster.h>
+#include <grass/segment.h>
#include <grass/glocale.h>
@@ -112,7 +113,7 @@
struct Cell_head *, /**/
int *, /**/ int, /**/ int /**/);
-struct Point *P_Read_Raster_Region_Map(double **, /**/
+struct Point *P_Read_Raster_Region_Map(SEGMENT *, /**/
int *, /**/ int /**/);
@@ -138,12 +139,11 @@
struct line_cats *, /**/
dbDriver *, /**/ double, /**/ char * /**/);
-double **P_Regular_Points(struct Cell_head *, /**/
+int P_Regular_Points(struct Cell_head *, /**/
struct bound_box, /**/
- double **, /**/
- char **, /**/
+ SEGMENT *, /**/
double *, /**/
double, /**/
double, /**/
Modified: grass/trunk/lib/lidar/raster.c
--- grass/trunk/lib/lidar/raster.c 2011-05-14 08:01:55 UTC (rev 46265)
+++ grass/trunk/lib/lidar/raster.c 2011-05-14 13:09:50 UTC (rev 46266)
@@ -187,16 +187,16 @@
-double **P_Regular_Points(struct Cell_head *Elaboration, struct Cell_head *Original,
+int P_Regular_Points(struct Cell_head *Elaboration, struct Cell_head *Original,
struct bound_box General, struct bound_box Overlap,
- double **matrix, char **mask_matrix, double *param,
+ SEGMENT *out_seg, double *param,
double passoN, double passoE, double overlap,
double mean, int nsplx, int nsply,
int nrows, int ncols, int bilin)
int col, row, startcol, endcol, startrow, endrow;
- double X, Y, interpolation, weight, csi, eta;
+ double X, Y, interpolation, weight, csi, eta, dval;
/* G_get_window(&Original); */
if (Original->north > General.N)
@@ -225,11 +225,6 @@
for (row = startrow; row < endrow; row++) {
for (col = startcol; col < endcol; col++) {
- if (mask_matrix) {
- if (!mask_matrix[row][col])
- continue;
X = Rast_col_to_easting((double)(col) + 0.5, Original);
Y = Rast_row_to_northing((double)(row) + 0.5, Original);
@@ -249,28 +244,29 @@
interpolation += mean;
if (Vect_point_in_box(X, Y, interpolation, &Overlap)) { /* (5) */
- matrix[row][col] = interpolation;
+ dval = interpolation;
else {
+ segment_get(out_seg, &dval, row, col);
if ((X > Overlap.E) && (X < General.E)) {
if ((Y > Overlap.N) && (Y < General.N)) { /* (3) */
csi = (General.E - X) / overlap;
eta = (General.N - Y) / overlap;
weight = csi * eta;
interpolation *= weight;
- matrix[row][col] += interpolation;
+ dval += interpolation;
else if ((Y < Overlap.S) && (Y > General.S)) { /* (1) */
eta = (Y - General.S) / overlap;
weight = csi * eta;
else if ((Y >= Overlap.S) && (Y <= Overlap.N)) { /* (1) */
weight = (General.E - X ) / overlap;
else if ((X < Overlap.W) && (X > General.W)) {
@@ -279,36 +275,37 @@
weight = eta * csi;
else if ((Y < Overlap.S) && (Y > General.S)) { /* (2) */
csi = (X - General.W) / overlap;
weight = csi * eta;
else if ((Y >= Overlap.S) && (Y <= Overlap.N)) { /* (2) */
weight = (X - General.W) / overlap;
else if ((X >= Overlap.W) && (X <= Overlap.E)) {
weight = (General.N - Y) / overlap;
weight = (Y - General.S) / overlap;
+ segment_put(out_seg, &dval, row, col);
} /* END COL */
} /* END ROW */
- return matrix;
+ return 1;
Modified: grass/trunk/lib/lidar/zones.c
--- grass/trunk/lib/lidar/zones.c 2011-05-14 08:01:55 UTC (rev 46265)
+++ grass/trunk/lib/lidar/zones.c 2011-05-14 13:09:50 UTC (rev 46266)
@@ -373,7 +373,7 @@
return obs;
-struct Point *P_Read_Raster_Region_Map(double **matrix,
+struct Point *P_Read_Raster_Region_Map(SEGMENT *in_seg,
int *num_points, int dim_vect)
@@ -420,7 +420,7 @@
- z = matrix[row][col];
+ segment_get(in_seg, &z, row, col);
if (!Rast_is_d_null_value(&z)) {
