[GRASS-SVN] r46278 - grass/trunk/vector/v.surf.bspline
svn_grass at osgeo.org
Sat May 14 13:39:53 EDT 2011
Author: mmetz
Date: 2011-05-14 10:39:52 -0700 (Sat, 14 May 2011)
New Revision: 46278
Added:
grass/trunk/vector/v.surf.bspline/resamp.c
v.surf.bspline: add raster interpolation routines
Added: grass/trunk/vector/v.surf.bspline/resamp.c
--- grass/trunk/vector/v.surf.bspline/resamp.c (rev 0)
+++ grass/trunk/vector/v.surf.bspline/resamp.c 2011-05-14 17:39:52 UTC (rev 46278)
@@ -0,0 +1,399 @@
+ * MODULE: v.surf.bspline
+ * AUTHOR(S): Roberto Antolin & Gonzalo Moreno
+ * update for grass7 by Markus Metz
+ * PURPOSE: Spline Interpolation
+ * COPYRIGHT: (C) 2006 by Politecnico di Milano -
+ * Polo Regionale di Como
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
+#include <grass/config.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include "bspline.h"
+struct Point *P_Read_Raster_Region_masked(SEGMENT *mask_seg,
+ struct Cell_head *Original,
+ struct bound_box output_box,
+ struct bound_box General,
+ int *num_points, int dim_vect,
+ double mean)
+ int col, row, startcol, endcol, startrow, endrow, nrows, ncols;
+ int pippo, npoints;
+ double X, Y;
+ struct Point *obs;
+ char mask_val;
+ pippo = dim_vect;
+ obs = (struct Point *)G_calloc(pippo, sizeof(struct Point));
+ /* Reading points inside output box and inside General box */
+ npoints = 0;
+ nrows = Original->rows;
+ ncols = Original->cols;
+ /* original region = output region
+ * -> General box is somewhere inside output region */
+ if (Original->north > General.N) {
+ startrow = (double)((Original->north - General.N) / Original->ns_res - 1);
+ if (startrow < 0)
+ startrow = 0;
+ else
+ startrow = 0;
+ if (Original->south < General.S) {
+ endrow = (double)((Original->north - General.S) / Original->ns_res + 1);
+ if (endrow > nrows)
+ endrow = nrows;
+ else
+ endrow = nrows;
+ if (General.W > Original->west) {
+ startcol = (double)((General.W - Original->west) / Original->ew_res - 1);
+ if (startcol < 0)
+ startcol = 0;
+ else
+ startcol = 0;
+ if (General.E < Original->east) {
+ endcol = (double)((General.E - Original->west) / Original->ew_res + 1);
+ if (endcol > ncols)
+ endcol = ncols;
+ else
+ endcol = ncols;
+ for (row = startrow; row < endrow; row++) {
+ for (col = startcol; col < endcol; col++) {
+ segment_get(mask_seg, &mask_val, row, col);
+ if (!mask_val)
+ continue;
+ X = Rast_col_to_easting((double)(col) + 0.5, Original);
+ Y = Rast_row_to_northing((double)(row) + 0.5, Original);
+ /* Here, mean is just for asking if obs point is in box */
+ if (Vect_point_in_box(X, Y, mean, &General)) { /* General */
+ if (npoints >= pippo) {
+ pippo += dim_vect;
+ obs =
+ (struct Point *)G_realloc((void *)obs,
+ (signed int)pippo *
+ sizeof(struct Point));
+ /* Storing observation vector */
+ obs[npoints].coordX = X;
+ obs[npoints].coordY = Y;
+ obs[npoints].coordZ = 0;
+ npoints++;
+ *num_points = npoints;
+ return obs;
+int P_Sparse_Raster_Points(SEGMENT *out_seg, struct Cell_head *Elaboration,
+ struct Cell_head *Original, struct bound_box General, struct bound_box Overlap,
+ struct Point *obs, double *param, double pe, double pn,
+ double overlap, int nsplx, int nsply, int num_points,
+ int bilin, double mean)
+ int i, row, col;
+ double X, Y, interpolation, csi, eta, weight, dval;
+ int points_in_box = 0;
+ /* Reading points inside output region and inside general box */
+ /* all points available here are inside the output box,
+ * selected by P_Read_Raster_Region_Nulls(), no check needed */
+ for (i = 0; i < num_points; i++) {
+ X = obs[i].coordX;
+ Y = obs[i].coordY;
+ /* X,Y are cell center cordinates, MUST be inside General box */
+ row = (int) (floor(Rast_northing_to_row(Y, Original)) + 0.1);
+ col = (int) (floor((X - Original->west) / Original->ew_res) + 0.1);
+ if (row < 0 || row >= Original->rows) {
+ G_fatal_error("row index out of range");
+ continue;
+ if (col < 0 || col >= Original->cols) {
+ G_fatal_error("col index out of range");
+ continue;
+ points_in_box++;
+ G_debug(3, "P_Sparse_Raster_Points: interpolate point %d...", i);
+ if (bilin)
+ interpolation =
+ dataInterpolateBilin(X, Y, pe, pn, nsplx,
+ nsply, Elaboration->west,
+ Elaboration->south, param);
+ else
+ interpolation =
+ dataInterpolateBicubic(X, Y, pe, pn, nsplx,
+ interpolation += mean;
+ if (Vect_point_in_box(X, Y, interpolation, &Overlap)) { /* (5) */
+ dval = interpolation;
+ else {
+ segment_get(out_seg, &dval, row, col);
+ if ((X > Overlap.E) && (X < General.E)) {
+ if ((Y > Overlap.N) && (Y < General.N)) { /* (3) */
+ csi = (General.E - X) / overlap;
+ eta = (General.N - Y) / overlap;
+ weight = csi * eta;
+ interpolation *= weight;
+ dval += interpolation;
+ else if ((Y < Overlap.S) && (Y > General.S)) { /* (1) */
+ eta = (Y - General.S) / overlap;
+ else if ((Y >= Overlap.S) && (Y <= Overlap.N)) { /* (1) */
+ weight = (General.E - X ) / overlap;
+ else if ((X < Overlap.W) && (X > General.W)) {
+ if ((Y > Overlap.N) && (Y < General.N)) { /* (4) */
+ csi = (X - General.W) / overlap;
+ weight = eta * csi;
+ else if ((Y < Overlap.S) && (Y > General.S)) { /* (2) */
+ else if ((Y >= Overlap.S) && (Y <= Overlap.N)) { /* (2) */
+ weight = (X - General.W) / overlap;
+ else if ((X >= Overlap.W) && (X <= Overlap.E)) {
+ weight = (General.N - Y) / overlap;
+ weight = (Y - General.S) / overlap;
+ } /* end not in overlap */
+ segment_put(out_seg, &dval, row, col);
+ } /* for num_points */
+ return 1;
+/* align elaboration box to source region
+ * grow each side */
+int align_elaboration_box(struct Cell_head *elaboration, struct Cell_head *original, int type)
+ int row, col;
+ switch (type) {
+ case GENERAL_ROW: /* General case N-S direction */
+ /* northern edge */
+ row = (int)((original->north - elaboration->north) / original->ns_res);
+ if (row < 0)
+ row = 0;
+ elaboration->north = original->north - original->ns_res * row;
+ /* southern edge */
+ row = (int)((original->north - elaboration->south) / original->ns_res) + 1;
+ if (row > original->rows + 1)
+ row = original->rows + 1;
+ elaboration->south = original->north - original->ns_res * row;
+ return 1;
+ case GENERAL_COLUMN: /* General case E-W direction */
+ /* eastern edge */
+ col = (int)((elaboration->east - original->west) / original->ew_res) + 1;
+ if (col > original->cols + 1)
+ col = original->cols + 1;
+ elaboration->east = original->west + original->ew_res * col;
+ /* western edge */
+ col = (int)((elaboration->west - original->west) / original->ew_res);
+ if (col < 0)
+ col = 0;
+ elaboration->west = original->west + original->ew_res * col;
+ return 1;
+ return 0;
+/* align interpolation boxes to destination region
+ * return 1 on success, 0 on failure */
+int align_interp_boxes(struct bound_box *general, struct bound_box *overlap,
+ struct Cell_head *original, struct bound_box last_general,
+ struct bound_box last_overlap, int type)
+ int row, col;
+ switch (type) {
+ /* general box */
+ /* grow north */
+ general->N = last_overlap.S;
+ /* shrink south */
+ row = (int)((original->north - general->S) / original->ns_res);
+ general->S = original->north - original->ns_res * row;
+ /* overlap box */
+ /* grow north */
+ overlap->N = last_general.S;
+ row = (int)((original->north - overlap->S) / original->ns_res);
+ overlap->S = original->north - original->ns_res * row;
+ return 1;
+ /* general box */
+ /* grow west */
+ general->W = last_overlap.E;
+ /* shrink east */
+ col = (int)((general->E - original->west) / original->ew_res);
+ general->E = original->west + original->ew_res * col;
+ /* overlap box */
+ /* grow west */
+ overlap->W = last_general.E;
+ /* shrink east */
+ col = (int)((overlap->E - original->west) / original->ew_res);
+ overlap->E = original->west + original->ew_res * col;
+ return 1;
+ case FIRST_ROW: /* Just started with first row */
+ general->N = original->north;
+ overlap->N = original->north;
+ if (row > original->rows)
+ row = original->rows;
+ return 1;
+ case LAST_ROW: /* Reached last row */
+ general->S = original->south;
+ overlap->S = original->south;
+ return 1;
+ case FIRST_COLUMN: /* Just started with first column */
+ general->W = original->west;
+ overlap->W = original->west;
+ /* shrink east */
+ return 1;
+ case LAST_COLUMN: /* Reached last column */
+ general->E = original->east;
+ overlap->E = original->east;
+ return 1;
+ return 0;
Property changes on: grass/trunk/vector/v.surf.bspline/resamp.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
