[GRASS-SVN] r46295 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat May 14 19:32:18 EDT 2011
Author: martinl
Date: 2011-05-14 16:32:18 -0700 (Sat, 14 May 2011)
New Revision: 46295
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
mmetz: attempt to fix #1362
(merge r46273, r4627, r46293 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2011-05-14 23:25:02 UTC (rev 46294)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2011-05-14 23:32:18 UTC (rev 46295)
@@ -583,9 +583,11 @@
@return returncode, stdout, messages (read == True and getErrorMsg == True)
@return stdout, stderr
- Debug.msg(1, "gcmd.RunCommand(): %s" % ' '.join(grass.make_command(prog, flags, overwrite,
- quiet, verbose, **kwargs)))
+ cmdString = ' '.join(grass.make_command(prog, flags, overwrite,
+ quiet, verbose, **kwargs))
+ Debug.msg(1, "gcmd.RunCommand(): %s" % cmdString)
kwargs['stderr'] = subprocess.PIPE
if read:
@@ -596,29 +598,48 @@
ps = grass.start_command(prog, flags, overwrite, quiet, verbose, **kwargs)
+ Debug.msg(2, "gcmd.RunCommand(): command started")
if stdin:
ps.stdin.write(stdin)
ps.stdin.close()
ps.stdin = None
+ Debug.msg(3, "gcmd.RunCommand(): decoding string")
stdout, stderr = map(lambda x: utils.DecodeString(x) if type(x) is types.StringType else x, ps.communicate())
ret = ps.returncode
+ Debug.msg(1, "gcmd.RunCommand(): get return code %d" % ret)
- if ret != 0 and parent:
- GError(parent = parent,
- message = stderr)
+ Debug.msg(3, "gcmd.RunCommand(): print error")
+ if ret != 0 and parent:
+ Debug.msg(2, "gcmd.RunCommand(): error %s" % stderr)
+ if (stderr == None):
+ Debug.msg(2, "gcmd.RunCommand(): nothing to print ???")
+ else:
+ GError(parent = parent,
+ message = stderr)
+ if ret != 0:
+ return None
+ Debug.msg(3, "gcmd.RunCommand(): print read error")
if not read:
if not getErrorMsg:
return ret
else:
return ret, _formatMsg(stderr)
+ if stdout:
+ Debug.msg(2, "gcmd.RunCommand(): return stdout\n'%s'" % stdout)
+ else:
+ Debug.msg(2, "gcmd.RunCommand(): return stdout = None")
if not getErrorMsg:
return stdout
+ Debug.msg(2, "gcmd.RunCommand(): return ret, stdout")
if read and getErrorMsg:
return ret, stdout, _formatMsg(stderr)
+ Debug.msg(2, "gcmd.RunCommand(): return result")
return stdout, _formatMsg(stderr)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-05-14 23:25:02 UTC (rev 46294)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-05-14 23:32:18 UTC (rev 46295)
@@ -652,21 +652,21 @@
def InsertLayers(self, vector):
"""!Insert layers for a vector into the layer combobox"""
- layerchoices = utils.GetVectorNumberOfLayers(vector)
+ layerchoices = utils.GetVectorNumberOfLayers(self, vector)
for layer in self.initial:
if layer in layerchoices:
continue
layerchoices.append(layer)
- # sort list of available layers
- utils.ListSortLower(layerchoices)
+ if len(layerchoices) == 0:
+ layerchoices.insert(0, '-1')
if len(layerchoices) > 1:
self.SetItems(layerchoices)
self.SetStringSelection('1')
- else:
- self.SetItems(['1'])
- self.SetStringSelection('1')
+ elif len(layerchoices) == 1:
+ print layerchoices[0]
+ self.SetItems(layerchoices)
+ self.SetStringSelection(layerchoices[0])
if self.default:
self.SetStringSelection(str(self.default))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2011-05-14 23:25:02 UTC (rev 46294)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2011-05-14 23:32:18 UTC (rev 46295)
@@ -272,7 +272,7 @@
"""!Sort list items (not case-sensitive)"""
list.sort(cmp=lambda x, y: cmp(x.lower(), y.lower()))
-def GetVectorNumberOfLayers(vector):
+def GetVectorNumberOfLayers(parent, vector):
"""!Get list of vector layers"""
layers = []
if not vector:
@@ -284,6 +284,7 @@
return layers
ret = gcmd.RunCommand('v.db.connect',
+ parent = parent,
flags = 'g',
read = True,
map = fullname,
@@ -291,6 +292,8 @@
if not ret:
return layers
+ else:
+ Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
for line in ret.splitlines():
try:
