[GRASS-SVN] r46306 - grass-addons/imagery/i.topo.corr
svn_grass at osgeo.org
Sun May 15 05:08:59 EDT 2011
Author: neteler
Date: 2011-05-15 02:08:59 -0700 (Sun, 15 May 2011)
New Revision: 46306
grass-addons/imagery/i.topo.corr/correction.c
grass-addons/imagery/i.topo.corr/illumination.c
grass-addons/imagery/i.topo.corr/main.c
minor code cleanup
Modified: grass-addons/imagery/i.topo.corr/correction.c
--- grass-addons/imagery/i.topo.corr/correction.c 2011-05-15 08:47:02 UTC (rev 46305)
+++ grass-addons/imagery/i.topo.corr/correction.c 2011-05-15 09:08:59 UTC (rev 46306)
@@ -8,9 +8,9 @@
* for details.
-#include<stdio.h>
-#include<stdlib.h>
-#include<math.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
#include <unistd.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -20,7 +20,7 @@
void eval_tcor(int method, Gfile * out, Gfile * cosi, Gfile * band,
double zenith)
- int i, row, col, nrows, ncols;
+ int row, col, nrows, ncols;
void *pref, *pcos;
double cos_z, cos_i, ref_i;
Modified: grass-addons/imagery/i.topo.corr/illumination.c
--- grass-addons/imagery/i.topo.corr/illumination.c 2011-05-15 08:47:02 UTC (rev 46305)
+++ grass-addons/imagery/i.topo.corr/illumination.c 2011-05-15 09:08:59 UTC (rev 46306)
@@ -8,9 +8,9 @@
* for details.
-#include<stdio.h>
-#include<stdlib.h>
-#include<math.h>
+#include <stdio.h>
+#include <math.h>
#include <unistd.h>
@@ -21,7 +21,7 @@
struct Cell_head window;
CELL *cell[3], *temp;
CELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
double H, V, dx, dy, key, north, east, south, west, center;
@@ -114,7 +114,7 @@
FCELL *cell[3], *temp;
FCELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
@@ -207,7 +207,7 @@
DCELL *cell[3], *temp;
DCELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
Modified: grass-addons/imagery/i.topo.corr/main.c
--- grass-addons/imagery/i.topo.corr/main.c 2011-05-15 08:47:02 UTC (rev 46305)
+++ grass-addons/imagery/i.topo.corr/main.c 2011-05-15 09:08:59 UTC (rev 46306)
@@ -7,7 +7,7 @@
* PURPOSE: Topographic corrections
- * COPYRIGHT: (C) 2002, 2005 2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002, 2005, 2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -48,13 +48,13 @@
snprintf(gf->name, 127, "%s", fname);
if (G_legal_filename(gf->name) < 0)
- G_fatal_error("[%s] is an illegal name", gf->name);
+ G_fatal_error(_("<%s> is an illegal name"), gf->name);
gf->type = ftype;
gf->mapset = G_mapset();
gf->fd = G_open_raster_new(gf->name, gf->type);
if (gf->fd < 0)
- G_fatal_error(_("Cannot create file [%s] in mapset [%s]"), gf->name,
+ G_fatal_error(_("Cannot create file <%s> in mapset <%s>"), gf->name,
gf->mapset);
return gf->fd;
@@ -66,8 +66,7 @@
struct GModule *module;
struct Cell_head hd_band, hd_dem, window;
- char bufname[128];
- int nrows, ncols, row, col;
+ char bufname[128]; /* TODO: use GNAME_MAX? */
int i;
struct Option *base, *output, *input, *zeni, *azim, *metho;
@@ -95,7 +94,7 @@
input->multiple = YES;
input->gisprompt = _("input,cell,raster");
input->description =
- _("List of reflectance band files to correct topographically");
+ _("List of reflectance band maps to correct topographically");
output = G_define_option();
output->key = _("output");
@@ -144,17 +143,16 @@
exit(EXIT_FAILURE);
if (ilum->answer && azim->answer == NULL)
- G_fatal_error
- ("Solar azimuth is necessary to calculate ilumination terrain model.");
+ G_fatal_error(_("Solar azimuth is necessary to calculate ilumination terrain model"));
if (!ilum->answer && input->answer == NULL)
G_fatal_error
- ("Reflectance files are necessary to make topographic correction.");
+ (_("Reflectance maps are necessary to make topographic correction"));
zenith = atof(zeni->answer);
/* Evaluate only cos_i raster file */
- // i.topo.corr -i out=cosi.on07 base=SRTM_v2 zenith=33.3631 azimuth=59.8897
+ /* i.topo.corr -i out=cosi.on07 base=SRTM_v2 zenith=33.3631 azimuth=59.8897 */
if (ilum->answer) {
azimuth = atof(azim->answer);
/* Warning: make buffers and output after set window */
@@ -193,13 +191,14 @@
G_write_history(out.name, &history);
/* Evaluate topographic correction for all bands */
- // i.topo.corr input=on07.toar.1 out=tcor base=cosi.on07 zenith=33.3631 method=c-factor
+ /* i.topo.corr input=on07.toar.1 out=tcor base=cosi.on07 zenith=33.3631 method=c-factor */
else {
- // if (G_strcasecmp(metho->answer, "cosine") == 0) method = COSINE;
- // else if (G_strcasecmp(metho->answer, "percent") == 0) method = PERCENT;
- // else if (G_strcasecmp(metho->answer, "minnaert") == 0) method = MINNAERT;
- // else if (G_strcasecmp(metho->answer, "c-factor") == 0) method = C_CORRECT;
- // else G_fatal_error(_("Invalid method: %s"), metho->answer);
+ /* if (G_strcasecmp(metho->answer, "cosine") == 0) method = COSINE;
+ * else if (G_strcasecmp(metho->answer, "percent") == 0) method = PERCENT;
+ * else if (G_strcasecmp(metho->answer, "minnaert") == 0) method = MINNAERT;
+ * else if (G_strcasecmp(metho->answer, "c-factor") == 0) method = C_CORRECT;
+ * else G_fatal_error(_("Invalid method: %s"), metho->answer);
if (metho->answer[1] == 'o')
method = COSINE;
@@ -214,14 +213,14 @@
full_open_old(&dem, base->answer);
if (dem.type == CELL_TYPE)
- G_fatal_error(_("Illumination model is CELL"));
+ G_fatal_error(_("Illumination model is of CELL type"));
for (i = 0; input->answers[i] != NULL; i++) {
G_message("\nBand %s: ", input->answers[i]);
/* Abre fichero de bandas y el de salida */
full_open_old(&band, input->answers[i]);
if (band.type != DCELL_TYPE) {
- G_warning(_("Reflectance of <%s> is not DCELL - ignored."),
+ G_warning(_("Reflectance of <%s> is not of DCELL type - ignored."),
input->answers[i]);
G_close_cell(band.fd);
continue;
@@ -249,6 +248,7 @@
char command[300];
+ /* TODO: better avoid system() */
sprintf(command, "r.colors map=%s color=grey", out.name);
system(command);
