[GRASS-SVN] r46311 -
grass/branches/releasebranch_6_4/imagery/i.atcorr
svn_grass at osgeo.org
Sun May 15 16:08:03 EDT 2011
Author: neteler
Date: 2011-05-15 13:08:03 -0700 (Sun, 15 May 2011)
New Revision: 46311
grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
aerosol optical depth demystified
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2011-05-15 14:04:50 UTC (rev 46310)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html 2011-05-15 20:08:03 UTC (rev 46311)
@@ -343,15 +343,20 @@
<h3>D. Aerosol concentration model (visibility)</h3>
-<blockquote>If you have an estimate of the meteorological parameter visibility
+If you have an estimate of the meteorological parameter visibility
v, enter directly the value of v [km] (the aerosol optical depth (AOD) will be
computed from a standard aerosol profile).
-<p>If you have an estimate of aerosol optical depth, enter v=0 for the
-visibility and comma-separated enter the aerosol optical depth at 550nm
+<p>If you have an estimate of aerosol optical depth, enter 0 for the
+visibility and in a following line enter the aerosol optical depth at 550nm
(iaer means 'i' for input and 'aer' for aerosol), for example:<br>
-v=0, 0.112
-<p>NOTE: if iaer=0, enter v=-1.</blockquote>
+<div class="code"><pre>
+0 - visibility
+0.112 - aerosol optical depth 550 nm
+</pre></div>
+<p>
+NOTE: if iaer is 0, enter -1 for visibility.
<h3>E. Target altitude (xps), sensor platform (xpp)</h3>
Target altitude (xps, in negative [km]):
