[GRASS-SVN] r46344 - grass/trunk
Sat May 21 11:33:59 EDT 2011
Author: glynn
Date: 2011-05-21 08:33:59 -0700 (Sat, 21 May 2011)
New Revision: 46344
   grass/trunk/configure
   grass/trunk/configure.in
Fix cairo checks
Modified: grass/trunk/configure
--- grass/trunk/configure	2011-05-21 13:51:24 UTC (rev 46343)
+++ grass/trunk/configure	2011-05-21 15:33:59 UTC (rev 46344)
@@ -12678,10 +12678,16 @@
 if test -n "$USE_CAIRO"; then
-cairo="cairo cairo-ft cairo-fc"
+cairo="cairo"
+pkgs="cairo-ft cairo-fc"
 if test -n "$USE_X11"; then
-	cairo="$cairo cairo-xlib-xrender"
+	pkgs="$pkgs cairo-xlib-xrender"
 fi
+for pkg in $pkgs ; do
+    if pkg-config --exists $pkg ; then
+        cairo="$cairo $pkg"
+    fi
+done
 # With Cairo includes directory
 #FIXME: somehow quote dirs with spaces in $cairo ?
@@ -12689,7 +12695,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12693: checking for location of cairo includes" >&5
+echo "configure:12699: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12715,15 +12721,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12719: checking for $ac_hdr" >&5
+echo "configure:12725: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12722 "configure"
+#line 12728 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12727: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12759,7 +12765,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12763: checking for location of cairo library" >&5
+echo "configure:12769: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12779,7 +12785,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12783: checking for cairo linking flags" >&5
+echo "configure:12789: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12795,10 +12801,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12799: checking for cairo_create" >&5
+echo "configure:12805: checking for cairo_create" >&5
-#line 12802 "configure"
+#line 12808 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char cairo_create(); below.  */
@@ -12821,7 +12827,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -12855,10 +12861,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12859: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12865: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12862 "configure"
+#line 12868 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -12881,7 +12887,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -12914,10 +12920,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12918: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12924: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12921 "configure"
+#line 12927 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -12940,7 +12946,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -12982,7 +12988,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12986: checking whether to use FreeType" >&5
+echo "configure:12992: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13001,7 +13007,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13005: checking for location of FreeType includes" >&5
+echo "configure:13011: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13027,15 +13033,15 @@
 do
-echo "configure:13031: checking for $ac_hdr" >&5
+echo "configure:13037: checking for $ac_hdr" >&5
-#line 13034 "configure"
+#line 13040 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13069,7 +13075,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13073: checking for location of FreeType library" >&5
+echo "configure:13079: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13094,13 +13100,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13098: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13104: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfreetype  $LIBS"
-#line 13104 "configure"
+#line 13110 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13111,7 +13117,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13152,7 +13158,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13156: checking whether to use NLS" >&5
+echo "configure:13162: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13172,10 +13178,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13176: checking for gettext" >&5
+echo "configure:13182: checking for gettext" >&5
-#line 13179 "configure"
+#line 13185 "configure"
     which can conflict with char gettext(); below.  */
@@ -13198,7 +13204,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13216,13 +13222,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13220: checking for gettext in -lintl" >&5
+echo "configure:13226: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13226 "configure"
+#line 13232 "configure"
@@ -13233,7 +13239,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13268,7 +13274,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13272: checking whether to use C++" >&5
+echo "configure:13278: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13284,7 +13290,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13288: checking for $ac_word" >&5
+echo "configure:13294: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13313,7 +13319,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13317: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13323: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13324,12 +13330,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13328 "configure"
+#line 13334 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13355,19 +13361,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13359: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13365: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13364: checking whether we are using GNU C++" >&5
+echo "configure:13370: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13371: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13385,7 +13391,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13389: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13395: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13426,7 +13432,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13430: checking whether to use openDWG" >&5
+echo "configure:13436: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13446,7 +13452,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13450: checking for location of openDGW includes" >&5
+echo "configure:13456: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13472,15 +13478,15 @@
 do
-echo "configure:13476: checking for $ac_hdr" >&5
+echo "configure:13482: checking for $ac_hdr" >&5
-#line 13479 "configure"
+#line 13485 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13514,7 +13520,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13518: checking for location of openDWG library" >&5
+echo "configure:13524: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13555,7 +13561,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13559: checking whether to use POSIX threads" >&5
+echo "configure:13565: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13575,7 +13581,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13579: checking for location of POSIX threads includes" >&5
+echo "configure:13585: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13601,15 +13607,15 @@
 do
-echo "configure:13605: checking for $ac_hdr" >&5
+echo "configure:13611: checking for $ac_hdr" >&5
-#line 13608 "configure"
+#line 13614 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13643,7 +13649,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13647: checking for location of POSIX threads library" >&5
+echo "configure:13653: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13668,10 +13674,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13672: checking for pthread_create" >&5
+echo "configure:13678: checking for pthread_create" >&5
-#line 13675 "configure"
+#line 13681 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -13694,7 +13700,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13721,13 +13727,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13725: checking for pthread_create in -lpthread" >&5
+echo "configure:13731: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13731 "configure"
+#line 13737 "configure"
@@ -13738,7 +13744,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13794,7 +13800,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13798: checking for special C compiler options needed for large files" >&5
+echo "configure:13804: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13802,7 +13808,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13806 "configure"
+#line 13812 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13818,7 +13824,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -13827,7 +13833,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13831 "configure"
+#line 13837 "configure"
@@ -13843,7 +13849,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13847: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13863,11 +13869,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13867: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13873: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13871 "configure"
+#line 13877 "configure"
@@ -13883,14 +13889,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13887: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13894 "configure"
+#line 13900 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13908,7 +13914,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13912: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13918: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13927,11 +13933,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13931: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13937: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13935 "configure"
+#line 13941 "configure"
@@ -13947,14 +13953,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13951: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13958 "configure"
+#line 13964 "configure"
 #define _LARGE_FILES 1
@@ -13972,7 +13978,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13982: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13991,25 +13997,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13995: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14001: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13999 "configure"
+#line 14005 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14013 "configure"
+#line 14019 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14018,7 +14024,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14028: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14039,25 +14045,25 @@
    fi
-echo "configure:14043: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14049: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14047 "configure"
+#line 14053 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14061 "configure"
+#line 14067 "configure"
 #include <stdio.h>
@@ -14066,7 +14072,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14076: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -14089,18 +14095,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14093: checking for fseeko" >&5
+echo "configure:14099: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 14097 "configure"
+#line 14103 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14117,10 +14123,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14121: checking if system supports Large Files at all" >&5
+echo "configure:14127: checking if system supports Large Files at all" >&5
-#line 14124 "configure"
+#line 14130 "configure"
 #include <stdio.h>
@@ -14152,7 +14158,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14162: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14181,7 +14187,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14185: checking whether to use wxWidgets" >&5
+echo "configure:14191: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14202,7 +14208,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14206: checking for $ac_word" >&5
+echo "configure:14212: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14250,7 +14256,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14254: checking wxWidgets version" >&5
+echo "configure:14260: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14273,15 +14279,15 @@
 do
-echo "configure:14277: checking for $ac_hdr" >&5
+echo "configure:14283: checking for $ac_hdr" >&5
-#line 14280 "configure"
+#line 14286 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14285: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14291: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2011-05-21 13:51:24 UTC (rev 46343)
+++ grass/trunk/configure.in	2011-05-21 15:33:59 UTC (rev 46344)
@@ -1545,10 +1545,16 @@
+cairo="cairo"
 fi
+    fi
+done
