[GRASS-SVN] r46352 -
grass/branches/develbranch_6/visualization/nviz2/cmd
svn_grass at osgeo.org
Sun May 22 06:13:15 EDT 2011
Author: martinl
Date: 2011-05-22 03:13:15 -0700 (Sun, 22 May 2011)
New Revision: 46352
grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
nviz_cmd: remove double parameter & cosmetics in params description
(merge r46349 from trunk)
Modified: grass/branches/develbranch_6/visualization/nviz2/cmd/args.c
--- grass/branches/develbranch_6/visualization/nviz2/cmd/args.c 2011-05-22 10:10:32 UTC (rev 46351)
+++ grass/branches/develbranch_6/visualization/nviz2/cmd/args.c 2011-05-22 10:13:15 UTC (rev 46352)
@@ -277,18 +277,6 @@
params->wire_color->answer = "136:136:136";
params->wire_color->guisection = _("Draw");
- /* shading */
- params->shade = G_define_option();
- params->shade->key = "shading";
- params->shade->key_desc = "string";
- params->shade->type = TYPE_STRING;
- params->shade->required = NO;
- params->shade->multiple = YES;
- params->shade->description = _("Shading");
- params->shade->options = "flat,gouraud";
- params->shade->answer = "gouraud";
- params->shade->guisection = _("Draw");
/* position */
params->surface_pos = G_define_option();
params->surface_pos->key = "surface_position";
@@ -296,7 +284,7 @@
params->surface_pos->type = TYPE_INTEGER;
params->surface_pos->required = NO;
params->surface_pos->multiple = YES;
- params->surface_pos->description = _("Position");
+ params->surface_pos->description = _("Surface position");
params->surface_pos->guisection = _("Draw");
params->surface_pos->answer = "0,0,0";
@@ -364,7 +352,7 @@
params->vline_pos->type = TYPE_INTEGER;
params->vline_pos->required = NO;
params->vline_pos->multiple = YES;
- params->vline_pos->description = _("Position");
+ params->vline_pos->description = _("Vector lines position");
params->vline_pos->guisection = _("Vector lines");
params->vline_pos->answer = "0,0,0";
@@ -433,7 +421,7 @@
params->vpoint_pos->type = TYPE_INTEGER;
params->vpoint_pos->required = NO;
params->vpoint_pos->multiple = YES;
- params->vpoint_pos->description = _("Position");
+ params->vpoint_pos->description = _("Vector points position");
params->vpoint_pos->guisection = _("Vector points");
params->vpoint_pos->answer = "0,0,0";
