[GRASS-SVN] r46356 - in grass/trunk/gui/wxpython: docs gui_modules icons xml
Sun May 22 07:51:32 EDT 2011
Author: martinl
Date: 2011-05-22 04:51:32 -0700 (Sun, 22 May 2011)
New Revision: 46356
Added:
   grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html
   grass/trunk/gui/wxpython/gui_modules/psmap.py
   grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py
   grass/trunk/gui/wxpython/xml/menudata_psmap.xml
   grass/trunk/gui/wxpython/gui_modules/menudata.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/icons/icon.py
wx.psmap moved from addons to the main repo
(author: Anna Kratochvilova)
Copied: grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html (from rev 46349, grass-addons/gui/wxpython/wx.psmap/docs/wxGUI.PsMap.html)
--- grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	                        (rev 0)
+++ grass/trunk/gui/wxpython/docs/wxGUI.PsMap.html	2011-05-22 11:51:32 UTC (rev 46356)
@@ -0,0 +1,207 @@
+<h2>DESCRIPTION</h2>
+<b>Note:</b> <em>wxGUI Hardcopy Map Utility is currently under
+development.</em>
+<p>
+<b>wxGUI Hardcopy Map Utility</b> also called <em>wx.psmap</em> is
+a <em><a href="wxGUI.html">wxGUI</a></em> extension which allows the
+user to create interactively hardcopy map outputs. This tool
+generates <em><a href="ps.map.html">ps.map</a></em> configuration file
+and then runs <em><a href="ps.map.html">ps.map</a></em> to create
+PostScript output. There are two modes - <em>Draft mode</em> for map
+composing and <em>Preview mode</em> to see how the result will look
+like. In draft mode map features (like legend or scalebar) are
+represented by a colored rectangle with a label.</p>
+<p>
+Possible output files:</p>
+<ul>
+  <li> <em><a href="ps.map.html">ps.map</a></em> instructions file
+  <li> PostScript/EPS file
+  <li> PDF (using ps2pdf)
+</ul>
+<p>
+Hardcopy Map Utility enables to load in saved instructions file. It
+works better with files created by wx.psmap (more tested).</p>
+<p>
+Currently supported <em><a href="ps.map.html">ps.map</a></em> instructions:</p>
+<ul>
+  <li> paper
+  <li> maploc
+  <li> scale
+  <li> border
+  <li> raster
+  <li> colortable
+  <li> vpoints
+  <li> vlines
+  <li> vareas
+  <li> vlegend
+  <li> text
+  <li> scalebar
+  <li> mapinfo
+</ul>
+<h3>HARDCOPY MAP UTILITY TOOLBAR</h3>
+<dl>
+  <dt><img src="icons/script-save.png">&nbsp;
+    <em>Generate instructions file</em></dt>
+  <dd>Generates and saves text file with mapping instructions.</dd>
+  <dt><img src="icons/script-load.png">&nbsp;
+    <em>Load instructions file</em></dt>
+  <dd>Load text file with mapping instructions.</dd>
+  <dt><img src="icons/page-settings.png">&nbsp;
+    <em>Page setup</em></dt>
+  <dd>Specify paper size, margins and orientation.</dd>
+  <dt><img src="icons/pointer.png">&nbsp;
+    <em>Pointer</em></dt>
+  <dd>Select object on the paper by clicking, drag the cursor while pressing the left mouse button to move it or resize object (currently only map frame) by clicking on a small black box in its bottom right corner. Double click to show object properties dialog</dd>
+  <dt><img src="icons/pan.png">&nbsp;
+    <em>Pan</em></dt>
+  <dd>Drag the pan cursor while pressing the left mouse button to move your view. </dd>
+  <dt><img src="icons/zoom-in.png">&nbsp;
+    <em>Zoom in</em></dt>
+  <dd>Interactive zooming with the mouse in both draft and preview mode. Drawing a box or just a left click with the mouse and zoom-in cursor causes the display to zoom in so that the area defined by the box fills the display.</dd>
+  <dt><img src="icons/zoom-out.png">&nbsp;
+    <em>Zoom out</em></dt>
+  <dd>Interactive zooming with the mouse in both draft and preview mode. Drawing a box or just a left click with the mouse and zoom-out cursor causes the display to zoom out so that the area displayed shrinks to fill the area defined by the box.</dd>
+  <dt><img src="icons/zoom-extent.png">&nbsp;
+    <em>Zoom to page</em></dt>
+  <dd>Zoom to display the entire page </dd>
+  <dt><img src="icons/layer-add.png">&nbsp;
+    <em>Map frame</em></dt>
+  <dd>Click and drag to place map frame. If map frame is already drawn, open a dialog to set its properties. </dd>
+  <dt><img src="icons/layer-raster-add.png">&nbsp;
+    <em>Raster map</em></dt>
+  <dd>Shows a dialog to add or change the raster map.</dd>
+  <dt><img src="icons/layer-vector-add.png">&nbsp;
+    <em>Vector map</em></dt>
+  <dd>Shows a dialog to add or change current vector maps and their properties:
+    <dl>
+      <dt><em>Data selection</em></dt>
+        <dd>Select data to draw:
+        <dl>
+          <dt><em>Feature type</em></dt>
+            <dd> Select which data type to draw. In case of point data, points or centroids
+            can be drawn, in case of line data, lines or boundaries. </dd>
+          <dt><em>Layer selection</em></dt>
+            <dd>Select layer and limit data by a SQL query or chose only certain categories.</dd>
+          <dt><em>Mask</em></dt>
+            <dd>Whether to use mask or not.</dd>
+        </dl>
+        </dd>
+      <dt><em>Colors</em></dt>
+        <dd>Color settings:
+        <dl>
+          <dt><em>Outline</em></dt>
+            <dd> Select outline color and width in points. In case of lines, outline means highlighting.</dd>
+          <dt><em>Fill</em></dt>
+            <dd>Select fill color, one color for all vector elements or color from rgb column.</dd>
+        </dl>
+      </dd>
+      <dt><em>Size and style</em></dt>
+        <dd>
+        Sets size, style, symbols, pattern; depends on data type:
+        <dl>
+          <dt><em>Symbology</em></dt>
+            <dd> Available for point data. Choose symbol or EPS file to draw points with.</dd>
+          <dt><em>Line style</em></dt>
+            <dd>Available for line data. Select line style (solid, dashed, ...) and the look of the ends of the line (butt, round, ...)</dd>
+          <dt><em>Pattern</em></dt>
+          <dd> Available for areas. Choose pattern file and set the width of the pattern.</dd>
+          <dt><em>Size</em></dt>
+          <dd> Available for point data. Choose size (number of times larger than the size in the icon file) as a single value or take the size from a map table column.</dd>
+          <dt><em>Rotation</em></dt>
+          <dd> Available for point data. Rotate symbols counterclockwise with the given value or with the value from a map table column</dd>
+          <dt><em>Width</em></dt>
+          <dd> Available for line data. Set line width in points or take the value from a map table column.</dd>
+        </dl>
+      </dd>
+    </dl>
+    </dd>
+   <dt><img src="icons/overlay-add.png">&nbsp;
+    <em>Add map elements</em></dt>
+   <dd>Add map elements: legend, scalebar, map info, text
+    <dl>
+      <dt><img src="icons/legend-add.png">&nbsp;
+        <em>Add legend</em></dt>
+      <dd>Add raster or vector legend or edit their properties.</dd>
+      <dt><img src="icons/map-info.png">&nbsp;
+        <em>Add map info</em></dt>
+      <dd>Add information about region, grid and scale or edit map info properties.</dd>
+      <dt><img src="icons/scalebar-add.png">&nbsp;
+        <em>Add scalebar</em></dt>
+      <dd>Add scalebar or edit its properties.</dd>
+      <dt><img src="icons/text-add.png">&nbsp;
+        <em>Add text</em></dt>
+      <dd>Add text label.</dd>
+    </dl>
+    </dd>
+  <dt><img src="icons/layer-remove.png">&nbsp;
+    <em>Remove selected element</em></dt>
+  <dd>Select an object and remove it. Pressing Delete key does the same. </dd>
+  <dt><img src="icons/execute.png">&nbsp;
+    <em>Show preview</em></dt>
+  <dd> Generates output and switches to Preview mode to see the result. Be patient, it can take a while.</dd>
+  <dt><img src="icons/ps-export.png">&nbsp;
+    <em>Generate hardcopy map output in PS</em></dt>
+  <dd> Generates hardcopy map output in PostScript/EPS file.</dd>
+   <dt><img src="icons/pdf-export.png">&nbsp;
+    <em>Generate hardcopy map output in PDF</em></dt>
+  <dd> Generates hardcopy map output in PDF using ps2pdf.</dd>
+</dl>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="wxGUI.html">wxGUI</a>
+</em>
+<p>
+Other wxGUI components:<br>
+<em>
+  <a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
+  <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
+  <a href="wxGUI.Nviz.html">3D Viewer</a><br>
+  <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
+</em>
+</p>
+<p>
+See also <a href="http://grass.osgeo.org/wiki/WxGUI_Hardcopy_Map_Output_Utility">wiki</a> page.
+</p>
+<h2>AUTHORS</h2>
+Anna Kratochvilova, Czech Technical Univesity (CTU) in Prague, Czech Republic (bachelor's final project 2011, mentor: Martin Landa)
+<p>
+<i>$Date$</i></p>
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py	2011-05-22 11:01:04 UTC (rev 46355)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py	2011-05-22 11:51:32 UTC (rev 46356)
@@ -7,6 +7,7 @@
  - MenuData
  - ManagerData
  - ModelerData
+ - PsMapData
 Usage:
 @code
@@ -27,6 +28,7 @@
 @author Yann Chemin <yann.chemin gmail.com>
 @author Martin Landa <landa.martin gmail.com>
 @author Glynn Clements
+ at author Anna Kratochvilova <anna.kratochvilova fsv.cvut.cz>
 import os
@@ -235,6 +237,19 @@
         MenuData.__init__(self, filename)
+class PsMapData(MenuData):
+    def __init__(self, path = None):
+        """!Menu for Hardcopy Map Output Utility (psmap.py)
+        @path path to XML to be read (None for menudata_psmap.xml)
+        if not path:
+            gisbase = os.getenv('GISBASE')
+            global etcwxdir
+        path = os.path.join(etcwxdir, 'xml', 'menudata_psmap.xml')
+        MenuData.__init__(self, path)
 if __name__ == "__main__":
     import sys
Copied: grass/trunk/gui/wxpython/gui_modules/psmap.py (from rev 46349, grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py)
--- grass/trunk/gui/wxpython/gui_modules/psmap.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/psmap.py	2011-05-22 11:51:32 UTC (rev 46356)
@@ -0,0 +1,1654 @@
+ at package psmap
+ at brief GUI for ps.map
+Classes:
+ - PsMapFrame
+ - PsMapBufferedWindow
+(C) 2011 by Anna Kratochvilova, and the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Anna Kratochvilova <anna.kratochvilova fsv.cvut.cz> (bachelor's project)
+ at author Martin Landa <landa.martin gmail.com> (mentor)
+import os
+import sys
+import textwrap
+import Queue
+try:
+    import Image
+    haveImage = True
+except ImportError:
+    haveImage = False
+from math import sin, cos, pi
+import grass.script as grass
+if int(grass.version()['version'].split('.')[0]) > 6:
+    sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython',
+                                 'gui_modules'))
+else:
+    sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'wxpython',
+                                 'gui_modules'))
+import globalvar
+import menu
+from   goutput    import CmdThread, EVT_CMD_DONE
+from   menudata   import PsMapData
+from   toolbars   import PsMapToolbar
+from   icon       import Icons, MetaIcon, iconSet
+from   gcmd       import RunCommand, GError, GMessage
+from psmap_dialogs import *
+import wx
+try:
+    import wx.lib.agw.flatnotebook as fnb
+    import wx.lib.flatnotebook as fnb
+class PsMapFrame(wx.Frame):
+    def __init__(self, parent = None, id = wx.ID_ANY,
+                 title = _("GRASS GIS Hardcopy Map Output Utility"), **kwargs):
+        """!Main window of ps.map GUI
+        @param parent parent window
+        @param id window id
+        @param title window title
+        @param kwargs wx.Frames' arguments
+        self.parent = parent
+        wx.Frame.__init__(self, parent = parent, id = id, title = title, name = "PsMap", **kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        #menubar
+        self.menubar = menu.Menu(parent = self, data = PsMapData())
+        self.SetMenuBar(self.menubar)
+        #toolbar
+        self.toolbar = PsMapToolbar(parent = self)
+        self.SetToolBar(self.toolbar)
+        self.actionOld = self.toolbar.action['id']
+        self.iconsize = (16, 16)
+        #satusbar
+        self.statusbar = self.CreateStatusBar(number = 1)
+        # mouse attributes -- position on the screen, begin and end of
+        # dragging, and type of drawing
+        self.mouse = {
+            'begin': [0, 0], # screen coordinates
+            'end'  : [0, 0],
+            'use'  : "pointer",
+        # available cursors
+        self.cursors = {
+            "default" : wx.StockCursor(wx.CURSOR_ARROW),
+            "cross"   : wx.StockCursor(wx.CURSOR_CROSS),
+            "hand"    : wx.StockCursor(wx.CURSOR_HAND),
+            "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
+        # pen and brush
+        self.pen = {
+            'paper': wx.Pen(colour = "BLACK", width = 1),
+            'margins': wx.Pen(colour = "GREY", width = 1),
+            'map': wx.Pen(colour = wx.Color(86, 122, 17), width = 2),
+            'rasterLegend': wx.Pen(colour = wx.Color(219, 216, 4), width = 2),
+            'vectorLegend': wx.Pen(colour = wx.Color(219, 216, 4), width = 2),
+            'mapinfo': wx.Pen(colour = wx.Color(5, 184, 249), width = 2),
+            'scalebar': wx.Pen(colour = wx.Color(150, 150, 150), width = 2),
+            'box': wx.Pen(colour = 'RED', width = 2, style = wx.SHORT_DASH),
+            'select': wx.Pen(colour = 'BLACK', width = 1, style = wx.SHORT_DASH),
+            'resize': wx.Pen(colour = 'BLACK', width = 1)
+        self.brush = {
+            'paper': wx.WHITE_BRUSH,
+            'margins': wx.TRANSPARENT_BRUSH,
+            'map': wx.Brush(wx.Color(151, 214, 90)),
+            'rasterLegend': wx.Brush(wx.Color(250, 247, 112)),
+            'vectorLegend': wx.Brush(wx.Color(250, 247, 112)),
+            'mapinfo': wx.Brush(wx.Color(127, 222, 252)),
+            'scalebar': wx.Brush(wx.Color(200, 200, 200)),
+            'box': wx.TRANSPARENT_BRUSH,
+            'select':wx.TRANSPARENT_BRUSH,
+            'resize': wx.BLACK_BRUSH
+        # list of objects to draw
+        self.objectId = []
+        # instructions
+        self.instruction = Instruction(parent = self, objectsToDraw = self.objectId)
+        # open dialogs
+        self.openDialogs = dict()
+        self.pageId = wx.NewId()
+        #current page of flatnotebook
+        self.currentPage = 0
+        #canvas for draft mode
+        self.canvas = PsMapBufferedWindow(parent = self, mouse = self.mouse, pen = self.pen,
+                                            brush = self.brush, cursors = self.cursors,
+                                            instruction = self.instruction, openDialogs = self.openDialogs,
+                                            pageId = self.pageId, objectId = self.objectId,
+                                            preview = False)
+        self.canvas.SetCursor(self.cursors["default"])
+        self.getInitMap()
+        # image path
+        env = grass.gisenv()
+        self.imgName = os.path.join( env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], '.tmp', 'tmpImage.png')
+        #canvas for preview
+        self.previewCanvas = PsMapBufferedWindow(parent = self, mouse = self.mouse, cursors = self.cursors,
+                                                    pen = self.pen, brush = self.brush, preview = True)
+        # set WIND_OVERRIDE
+        grass.use_temp_region()
+        # create queues
+        self.requestQ = Queue.Queue()
+        self.resultQ = Queue.Queue()
+        # thread
+        self.cmdThread = CmdThread(self, self.requestQ, self.resultQ)
+        self._layout()
+        self.SetMinSize(wx.Size(750, 600))
+        self.Bind(fnb.EVT_FLATNOTEBOOK_PAGE_CHANGING, self.OnPageChanging)
+        self.Bind(fnb.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
+        self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+        self.Bind(EVT_CMD_DONE, self.OnCmdDone)
+        if not haveImage:
+            wx.CallAfter(self._showErrMsg)
+    def _showErrMsg(self):
+        """!Show error message (missing preview)
+        GError(parent = self,
+               message = _("Python Imaging Library is not available.\n"
+                           "'Preview' functionality won't work."),
+               showTraceback = False)
+    def _layout(self):
+        """!Do layout
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        if globalvar.hasAgw:
+            self.book = fnb.FlatNotebook(parent = self, id = wx.ID_ANY,
+                                            agwStyle = fnb.FNB_FANCY_TABS | fnb.FNB_BOTTOM |
+                                            fnb.FNB_NO_NAV_BUTTONS | fnb.FNB_NO_X_BUTTON)
+        else:
+                                            style = fnb.FNB_FANCY_TABS | fnb.FNB_BOTTOM |
+        #self.book = fnb.FlatNotebook(self, wx.ID_ANY, style = fnb.FNB_BOTTOM)
+        self.book.AddPage(self.canvas, "Draft mode")
+        self.book.AddPage(self.previewCanvas, "Preview")
+        self.book.SetSelection(0)
+        mainSizer.Add(self.book,1, wx.EXPAND)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+    def InstructionFile(self):
+        """!Creates mapping instructions"""
+        return str(self.instruction)
+    def OnPSFile(self, event):
+        """!Generate PostScript"""
+        filename = self.getFile(wildcard = "PostScript (*.ps)|*.ps|Encapsulated PostScript (*.eps)|*.eps")
+        if filename:
+            self.PSFile(filename)
+    def OnPDFFile(self, event):
+        """!Generate PDF from PS with ps2pdf if available"""
+        try:
+            p = grass.Popen(["ps2pdf"], stderr = grass.PIPE)
+            p.stderr.close()
+        except OSError:
+            GMessage(parent = self,
+                    message = _("Program ps2pdf is not available. Please install it first to create PDF."))
+            return
+        filename = self.getFile(wildcard = "PDF (*.pdf)|*.pdf")
+        if filename:
+            self.PSFile(filename, pdf = True)
+    def OnPreview(self, event):
+        """!Run ps.map and show result"""
+        self.PSFile()
+    def PSFile(self, filename = None, pdf = False):
+        """!Create temporary instructions file and run ps.map with output = filename"""
+        instrFile = grass.tempfile()
+        instrFileFd = open(instrFile, mode = 'w')
+        instrFileFd.write(self.InstructionFile())
+        instrFileFd.flush()
+        instrFileFd.close()
+        temp = False
+        regOld = grass.region()
+        if pdf:
+            pdfname = filename
+        else:
+            pdfname = None
+        #preview or pdf
+        if not filename or (filename and pdf):
+            temp = True
+            filename = grass.tempfile()
+            if not pdf: # lower resolution for preview
+                if self.instruction.FindInstructionByType('map'):
+                    mapId = self.instruction.FindInstructionByType('map').id
+                    SetResolution(dpi = 100, width = self.instruction[mapId]['rect'][2],
+                                    height = self.instruction[mapId]['rect'][3])
+        cmd = ['ps.map', '--overwrite']
+        if os.path.splitext(filename)[1] == '.eps':
+            cmd.append('-e')
+        if self.instruction[self.pageId]['Orientation'] == 'Landscape':
+            cmd.append('-r')
+        cmd.append('input=%s' % instrFile)
+        cmd.append('output=%s' % filename)
+        if pdf:
+            self.SetStatusText(_('Generating PDF...'), 0)
+        elif not temp:
+            self.SetStatusText(_('Generating PostScript...'), 0)
+        else:
+            self.SetStatusText(_('Generating preview...'), 0)
+        self.cmdThread.RunCmd(cmd, userData = {'instrFile' : instrFile, 'filename' : filename,
+                                            'pdfname' : pdfname, 'temp' : temp, 'regionOld' : regOld})
+    def OnCmdDone(self, event):
+        """!ps.map process finished"""
+        if event.returncode != 0:
+                   message = _("Ps.map exited with return code %s") % event.returncode)
+            grass.try_remove(event.userData['instrFile'])
+            if event.userData['temp']:
+                grass.try_remove(event.userData['filename'])
+            return
+        if event.userData['pdfname']:
+            try:
+                proc = grass.Popen(['ps2pdf', '-dPDFSETTINGS=/prepress', '-r1200',
+                                    event.userData['filename'], event.userData['pdfname']])
+                ret = proc.wait()
+                if ret > 0:
+                    message = _("ps2pdf exited with return code %s") % ret)
+            except OSError, e:
+                       message = _("Program ps2pdf is not available. Please install it to create PDF.\n\n %s") % e)
+        # show preview only when user doesn't want to create ps or pdf
+        if haveImage and event.userData['temp'] and not event.userData['pdfname']:
+            RunCommand('g.region', cols = event.userData['regionOld']['cols'], rows = event.userData['regionOld']['rows'])
+## wx.BusyInfo does not display the message
+##            busy = wx.BusyInfo(message = "Generating preview, wait please", parent = self)
+            try:
+                im = Image.open(event.userData['filename'])
+                    im = im.rotate(270)
+                im.save(self.imgName, format = 'png')
+            except IOError, e:
+                       message = _("Unable to generate preview. %s") % e)
+            rect = self.previewCanvas.ImageRect()
+            self.previewCanvas.image = wx.Image(self.imgName, wx.BITMAP_TYPE_PNG)
+            self.previewCanvas.DrawImage(rect = rect)
+##            busy.Destroy()
+            self.SetStatusText(_('Preview generated'), 0)
+            self.book.SetSelection(1)
+            self.currentPage = 1
+    def getFile(self, wildcard):
+        suffix = []
+        for filter in wildcard.split('|')[1::2]:
+            s = filter.strip('*').split('.')[1]
+            if s:
+                s = '.' + s
+            suffix.append(s)
+        raster = self.instruction.FindInstructionByType('raster')
+        if raster:
+            rasterId = raster.id
+        else:
+            rasterId = None
+        if rasterId and self.instruction[rasterId]['raster']:
+            mapName = self.instruction[rasterId]['raster'].split('@')[0] + suffix[0]
+        else:
+            mapName = ''
+        filename = ''
+        dlg = wx.FileDialog(self, message = "Save file as", defaultDir = "",
+                            defaultFile = mapName, wildcard = wildcard,
+                            style = wx.CHANGE_DIR|wx.SAVE|wx.OVERWRITE_PROMPT)
+        if dlg.ShowModal() == wx.ID_OK:
+            filename = dlg.GetPath()
+            suffix = suffix[dlg.GetFilterIndex()]
+            if not os.path.splitext(filename)[1]:
+                filename = filename + suffix
+            elif os.path.splitext(filename)[1] != suffix and suffix != '':
+                filename = os.path.splitext(filename)[0] + suffix
+        dlg.Destroy()
+        return filename
+    def OnInstructionFile(self, event):
+        filename = self.getFile(wildcard = "*.psmap|*.psmap|Text file(*.txt)|*.txt|All files(*.*)|*.*")
+        if filename:
+            instrFile = open(filename, "w")
+            instrFile.write(self.InstructionFile())
+            instrFile.close()
+    def OnLoadFile(self, event):
+        """!Load file and read instructions"""
+        #find file
+        filename = ''
+        dlg = wx.FileDialog(self, message = "Find instructions file", defaultDir = "",
+                            defaultFile = '', wildcard = "All files (*.*)|*.*",
+                            style = wx.CHANGE_DIR|wx.OPEN)
+        dlg.Destroy()
+        if not filename:
+            return
+        # load instructions
+        #filename = '/home/anna/Desktop/reading.txt'
+        readObjectId = []
+        readInstruction = Instruction(parent = self, objectsToDraw = readObjectId)
+        ok = readInstruction.Read(filename)
+        if not ok:
+            GMessage(_("Failed to read file %s.") % filename)
+        else:
+            self.instruction = self.canvas.instruction = readInstruction
+            self.objectId = self.canvas.objectId = readObjectId
+            self.pageId = self.canvas.pageId = self.instruction.FindInstructionByType('page').id
+            self.canvas.UpdateMapLabel()
+            self.canvas.dragId = -1
+            self.canvas.Clear()
+            #self.canvas.ZoomAll()
+            self.DialogDataChanged(self.objectId)
+    def OnPageSetup(self, event = None):
+        """!Specify paper size, margins and orientation"""
+        id = self.instruction.FindInstructionByType('page').id
+        dlg = PageSetupDialog(self, id = id, settings = self.instruction)
+        dlg.CenterOnScreen()
+        val = dlg.ShowModal()
+        if val == wx.ID_OK:
+            self.canvas.SetPage()
+            self.canvas.RecalculatePosition(ids = self.objectId)
+        dlg.Destroy()
+    def OnPointer(self, event):
+        self.toolbar.OnTool(event)
+        self.mouse["use"] = "pointer"
+        self.previewCanvas.SetCursor(self.cursors["default"])
+    def OnPan(self, event):
+        self.mouse["use"] = "pan"
+        self.canvas.SetCursor(self.cursors["hand"])
+        self.previewCanvas.SetCursor(self.cursors["hand"])
+    def OnZoomIn(self, event):
+        self.mouse["use"] = "zoomin"
+        self.canvas.SetCursor(self.cursors["cross"])
+        self.previewCanvas.SetCursor(self.cursors["cross"])
+    def OnZoomOut(self, event):
+        self.mouse["use"] = "zoomout"
+    def OnZoomAll(self, event):
+        self.mouseOld = self.mouse['use']
+        if self.currentPage == 0:
+            self.cursorOld = self.canvas.GetCursor()
+        else:
+            self.previewCanvas.GetCursor()
+            self.canvas.ZoomAll()
+        else:
+            self.previewCanvas.ZoomAll()
+        self.mouse["use"] = self.mouseOld
+            self.canvas.SetCursor(self.cursorOld)
+        else:
+            self.previewCanvas.SetCursor(self.cursorOld)
+    def OnAddMap(self, event, notebook = False):
+        """!Add or edit map frame"""
+        if event is not None:
+            if event.GetId() != self.toolbar.action['id']:
+        else: mapId = None
+        id = [mapId, None, None]
+        if notebook:
+            if self.instruction.FindInstructionByType('vector'):
+                vectorId = self.instruction.FindInstructionByType('vector').id
+            else: vectorId = None
+            if self.instruction.FindInstructionByType('raster'):
+                rasterId = self.instruction.FindInstructionByType('raster').id
+            else: rasterId = None
+            id[1] = rasterId
+            id[2] = vectorId
+        if mapId: # map exists
+            self.toolbar.ToggleTool(self.actionOld, True)
+            self.toolbar.ToggleTool(self.toolbar.action['id'], False)
+            self.toolbar.action['id'] = self.actionOld
+            try:
+            except AttributeError:
+                pass
+##            dlg = MapDialog(parent = self, id  = id, settings = self.instruction,
+##                            notebook = notebook)
+##            dlg.ShowModal()
+            if notebook:
+                #check map, raster, vector and save, destroy them
+                if 'map' in self.openDialogs:
+                    self.openDialogs['map'].OnOK(event = None)
+                if 'raster' in self.openDialogs:
+                    self.openDialogs['raster'].OnOK(event = None)
+                if 'vector' in self.openDialogs:
+                    self.openDialogs['vector'].OnOK(event = None)
+                if 'mapNotebook' not in self.openDialogs:
+                    dlg = MapDialog(parent = self, id  = id, settings = self.instruction,
+                                notebook = notebook)
+                    self.openDialogs['mapNotebook'] = dlg
+                self.openDialogs['mapNotebook'].Show()
+            else:
+                if 'mapNotebook' in self.openDialogs:
+                    self.openDialogs['mapNotebook'].notebook.ChangeSelection(0)
+                else:
+                    if 'map' not in self.openDialogs:
+                        self.openDialogs['map'] = dlg
+                    self.openDialogs['map'].Show()
+        else:    # sofar no map
+            self.mouse["use"] = "addMap"
+            if self.currentPage == 1:
+    def OnAddRaster(self, event):
+        """!Add raster map"""
+            id = self.instruction.FindInstructionByType('raster').id
+        else: id = None
+        if not id:
+            if not mapId:
+                GMessage(message = _("Please, create map frame first."))
+                return
+##        dlg = RasterDialog(self, id = id, settings = self.instruction)
+##        dlg.ShowModal()
+            self.openDialogs['mapNotebook'].notebook.ChangeSelection(1)
+        else:
+            if 'raster' not in self.openDialogs:
+                dlg = RasterDialog(self, id = id, settings = self.instruction)
+                self.openDialogs['raster'] = dlg
+            self.openDialogs['raster'].Show()
+    def OnAddVect(self, event):
+        """!Add vector map"""
+            id = self.instruction.FindInstructionByType('vector').id
+        else: id = None
+        if not id:
+            if not mapId:
+                return
+##        dlg = MainVectorDialog(self, id = id, settings = self.instruction)
+##        dlg.ShowModal()
+            self.openDialogs['mapNotebook'].notebook.ChangeSelection(2)
+        else:
+            if 'vector' not in self.openDialogs:
+                dlg =  MainVectorDialog(self, id = id, settings = self.instruction)
+                self.openDialogs['vector'] = dlg
+            self.openDialogs['vector'].Show()
+    def OnDecoration(self, event):
+        """!Decorations overlay menu
+        decmenu = wx.Menu()
+        # legend
+        AddLegend = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addLegend"].GetLabel())
+        AddLegend.SetBitmap(Icons['psMap']["addLegend"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddLegend)
+        self.Bind(wx.EVT_MENU, self.OnAddLegend, AddLegend)
+        # mapinfo
+        AddMapinfo = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addMapinfo"].GetLabel())
+        AddMapinfo.SetBitmap(Icons['psMap']["addMapinfo"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddMapinfo)
+        self.Bind(wx.EVT_MENU, self.OnAddMapinfo, AddMapinfo)
+        # scalebar
+        AddScalebar = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addScalebar"].GetLabel())
+        AddScalebar.SetBitmap(Icons['psMap']["addScalebar"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddScalebar)
+        self.Bind(wx.EVT_MENU, self.OnAddScalebar, AddScalebar)
+        # text
+        AddText = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addText"].GetLabel())
+        AddText.SetBitmap(Icons['psMap']["addText"].GetBitmap(self.iconsize))
+        decmenu.AppendItem(AddText)
+        self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
+        # Popup the menu.  If an item is selected then its handler
+        # will be called before PopupMenu returns.
+        self.PopupMenu(decmenu)
+        decmenu.Destroy()
+    def OnAddScalebar(self, event):
+        """!Add scalebar"""
+        if projInfo()['proj'] == 'll':
+            GMessage(message = _("Scalebar is not appropriate for this projection"))
+            return
+        if self.instruction.FindInstructionByType('scalebar'):
+            id = self.instruction.FindInstructionByType('scalebar').id
+        else: id = None
+        if 'scalebar' not in self.openDialogs:
+            dlg = ScalebarDialog(self, id = id, settings = self.instruction)
+            self.openDialogs['scalebar'] = dlg
+        self.openDialogs['scalebar'].Show()
+    def OnAddLegend(self, event, page = 0):
+        """!Add raster or vector legend"""
+        if self.instruction.FindInstructionByType('rasterLegend'):
+            idR = self.instruction.FindInstructionByType('rasterLegend').id
+        else: idR = None
+        if self.instruction.FindInstructionByType('vectorLegend'):
+            idV = self.instruction.FindInstructionByType('vectorLegend').id
+        else: idV = None
+        if 'rasterLegend' not in self.openDialogs:
+            dlg = LegendDialog(self, id = [idR, idV], settings = self.instruction, page = page)
+            self.openDialogs['rasterLegend'] = dlg
+            self.openDialogs['vectorLegend'] = dlg
+        self.openDialogs['rasterLegend'].notebook.ChangeSelection(page)
+        self.openDialogs['rasterLegend'].Show()
+    def OnAddMapinfo(self, event):
+        if self.instruction.FindInstructionByType('mapinfo'):
+            id = self.instruction.FindInstructionByType('mapinfo').id
+        else: id = None
+        if 'mapinfo' not in self.openDialogs:
+            dlg = MapinfoDialog(self, id = id, settings = self.instruction)
+            self.openDialogs['mapinfo'] = dlg
+        self.openDialogs['mapinfo'].Show()
+    def OnAddText(self, event, id = None):
+        """!Show dialog for text adding and editing"""
+        position = None
+        if 'text' in self.openDialogs:
+            position = self.openDialogs['text'].GetPosition()
+            self.openDialogs['text'].OnApply(event = None)
+            self.openDialogs['text'].Destroy()
+        dlg = TextDialog(self, id = id, settings = self.instruction)
+        self.openDialogs['text'] = dlg
+        if position:
+            dlg.SetPosition(position)
+        dlg.Show()
+    def getModifiedTextBounds(self, x, y, textExtent, rotation):
+        """!computes bounding box of rotated text, not very precisely"""
+        w, h = textExtent
+        rotation = float(rotation)/180*pi
+        H = float(w) * sin(rotation)
+        W = float(w) * cos(rotation)
+        X, Y = x, y
+        if pi/2 < rotation <= 3*pi/2:
+            X = x + W
+        if 0 < rotation < pi:
+            Y = y - H
+        if rotation == 0:
+            return wx.Rect(x,y, *textExtent)
+        else:
+            return wx.Rect(X, Y, abs(W), abs(H)).Inflate(h,h)
+    def getTextExtent(self, textDict):
+        fontsize = str(textDict['fontsize'] * self.canvas.currScale)
+        #fontsize = str(fontsize if fontsize >= 4 else 4)
+        dc = wx.PaintDC(self) # dc created because of method GetTextExtent, which pseudoDC lacks
+        dc.SetFont(wx.FontFromNativeInfoString(textDict['font'] + " " + fontsize))
+        return dc.GetTextExtent(textDict['text'])
+    def getInitMap(self):
+        """!Create default map frame when no map is selected, needed for coordinates in map units"""
+        mapInitRect = GetMapBounds(instrFile)
+        grass.try_remove(instrFile)
+        region = grass.region()
+        units = UnitConversion(self)
+        realWidth = units.convert(value = abs(region['w'] - region['e']), fromUnit = 'meter', toUnit = 'inch')
+        scale = mapInitRect.Get()[2]/realWidth
+        initMap = self.instruction.FindInstructionByType('initMap')
+        if initMap:
+            id = initMap.id
+        else:
+            id = None
+        if not id:
+            id = wx.NewId()
+            initMap = InitMap(id)
+            self.instruction.AddInstruction(initMap)
+        self.instruction[id].SetInstruction(dict(rect = mapInitRect, scale = scale))
+    def OnDelete(self, event):
+        if self.canvas.dragId != -1 and self.currentPage == 0:
+            if self.instruction[self.canvas.dragId].type == 'map':
+                self.deleteObject(self.canvas.dragId)
+                self.getInitMap()
+                self.canvas.RecalculateEN()
+            else:
+    def deleteObject(self, id):
+        """!Deletes object, his id and redraws"""
+        #delete from canvas
+        self.canvas.pdcObj.RemoveId(id)
+        if id == self.canvas.dragId:
+            self.canvas.pdcTmp.RemoveAll()
+        self.canvas.Refresh()
+        # delete from instructions
+        del self.instruction[id]
+    def DialogDataChanged(self, id):
+        ids = id
+        if type(id) == int:
+            ids = [id]
+        for id in ids:
+            itype = self.instruction[id].type
+            if itype in ('scalebar', 'mapinfo'):
+                drawRectangle = self.canvas.CanvasPaperCoordinates(
+                                    rect = self.instruction[id]['rect'], canvasToPaper = False)
+                self.canvas.Draw( pen = self.pen[itype], brush = self.brush[itype],
+                                pdc = self.canvas.pdcObj, drawid = id, pdctype = 'rectText', bb = drawRectangle)
+                self.canvas.RedrawSelectBox(id)
+            if itype == 'text':
+                if self.instruction[id]['rotate']:
+                    rot = float(self.instruction[id]['rotate'])
+                else:
+                    rot = 0
+                extent = self.getTextExtent(textDict = self.instruction[id].GetInstruction())
+                rect = wx.Rect2D(self.instruction[id]['where'][0], self.instruction[id]['where'][1], 0, 0)
+                self.instruction[id]['coords'] = list(self.canvas.CanvasPaperCoordinates(rect = rect, canvasToPaper = False)[:2])
+                #computes text coordinates according to reference point, not precisely
+                if self.instruction[id]['ref'].split()[0] == 'lower':
+                    self.instruction[id]['coords'][1] -= extent[1]
+                elif self.instruction[id]['ref'].split()[0] == 'center':
+                    self.instruction[id]['coords'][1] -= extent[1]/2
+                if self.instruction[id]['ref'].split()[1] == 'right':
+                    self.instruction[id]['coords'][0] -= extent[0] * cos(rot/180*pi)
+                    self.instruction[id]['coords'][1] += extent[0] * sin(rot/180*pi)
+                elif self.instruction[id]['ref'].split()[1] == 'center':
+                    self.instruction[id]['coords'][0] -= extent[0]/2 * cos(rot/180*pi)
+                    self.instruction[id]['coords'][1] += extent[0]/2 * sin(rot/180*pi)
+                self.instruction[id]['coords'][0] += self.instruction[id]['xoffset']
+                self.instruction[id]['coords'][1] -= self.instruction[id]['yoffset']
+                coords = self.instruction[id]['coords']
+                self.instruction[id]['rect'] = bounds = self.getModifiedTextBounds(coords[0], coords[1], extent, rot)
+                self.canvas.DrawRotText(pdc = self.canvas.pdcObj, drawId = id,
+                                        textDict = self.instruction[id].GetInstruction(),
+                                        coords = coords, bounds = bounds)
+            if itype in ('map', 'vector', 'raster'):
+                if itype == 'raster':#set resolution
+                    resol = RunCommand('r.info', read = True, flags = 's', map = self.instruction[id]['raster'])
+                    resol = grass.parse_key_val(resol, val_type = float)
+                    RunCommand('g.region', nsres = resol['nsres'], ewres = resol['ewres'])
+                    # change current raster in raster legend
+                if 'rasterLegend' in self.openDialogs:
+                    self.openDialogs['rasterLegend'].updateDialog()
+                id = self.instruction.FindInstructionByType('map').id
+                #check resolution
+                    SetResolution(dpi = self.instruction[id]['resolution'],
+                                    width = self.instruction[id]['rect'].width,
+                                    height = self.instruction[id]['rect'].height)
+                rectCanvas = self.canvas.CanvasPaperCoordinates(rect = self.instruction[id]['rect'],
+        canvasToPaper = False)
+                self.canvas.Draw( pen = self.pen['map'], brush = self.brush['map'],
+                                pdc = self.canvas.pdcObj, drawid = id, pdctype = 'rectText', bb = rectCanvas)
+                # redraw select box
+                self.canvas.pdcTmp.RemoveId(self.canvas.idZoomBoxTmp)
+                # redraw to get map to the bottom layer
+                #self.canvas.Zoom(zoomFactor = 1, view = (0, 0))
+            if itype == 'rasterLegend':
+                if self.instruction[id]['rLegend']:
+                    drawRectangle = self.canvas.CanvasPaperCoordinates(rect = self.instruction[id]['rect'], canvasToPaper = False)
+                else:
+                    self.deleteObject(id)
+            if itype == 'vectorLegend':
+                if not self.instruction.FindInstructionByType('vector'):
+                elif self.instruction[id]['vLegend']:
+                else:
+    def OnPageChanged(self, event):
+        """!Flatnotebook page has changed"""
+        self.currentPage = self.book.GetPageIndex(self.book.GetCurrentPage())
+    def OnPageChanging(self, event):
+        """!Flatnotebook page is changing"""
+        if self.currentPage == 0 and self.mouse['use'] == 'addMap':
+            event.Veto()
+    def OnHelp(self, event):
+        """!Show help"""
+        if self.parent and self.parent.GetName() == 'LayerManager':
+            log = self.parent.GetLogWindow()
+            log.RunCmd(['g.manual',
+                        'entry=wxGUI.PsMap'])
+        else:
+            RunCommand('g.manual',
+                       quiet = True,
+                       entry = 'wxGUI.PsMap')
+    def OnAbout(self, event):
+        """!Display About window"""
+        info = wx.AboutDialogInfo()
+        info.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        info.SetName(_('wxGUI Hardcopy Map Utility'))
+        info.SetWebSite('http://grass.osgeo.org')
+        info.SetDescription(_('(C) 2011 by the GRASS Development Team\n\n') +
+                            '\n'.join(textwrap.wrap(_('This program is free software under the GNU General Public License'
+                                                      '(>=v2). Read the file COPYING that comes with GRASS for details.'), 75)))
+        wx.AboutBox(info)
+    def OnCloseWindow(self, event):
+        """!Close window"""
+        try:
+            os.remove(self.imgName)
+        except OSError:
+            pass
+        grass.set_raise_on_error(False)
+        self.Destroy()
+class PsMapBufferedWindow(wx.Window):
+    """!A buffered window class.
+    @param kwargs other wx.Window parameters
+    def __init__(self, parent, id =  wx.ID_ANY,
+                 style = wx.NO_FULL_REPAINT_ON_RESIZE,
+                 **kwargs):
+        wx.Window.__init__(self, parent, id = id, style = style)
+        self.FitInside()
+        # store an off screen empty bitmap for saving to file
+        self._buffer = None
+        # indicates whether or not a resize event has taken place
+        self.resize = False
+        self.mouse = kwargs['mouse']
+        self.cursors = kwargs['cursors']
+        self.preview = kwargs['preview']
+        self.pen = kwargs['pen']
+        self.brush = kwargs['brush']
+        if kwargs.has_key('instruction'):
+            self.instruction = kwargs['instruction']
+        if kwargs.has_key('openDialogs'):
+            self.openDialogs = kwargs['openDialogs']
+        if kwargs.has_key('pageId'):
+            self.pageId = kwargs['pageId']
+        if kwargs.has_key('objectId'):
+            self.objectId = kwargs['objectId']
+        #labels
+        self.itemLabels = { 'map': ['MAP FRAME'],
+                            'rasterLegend': ['RASTER LEGEND'],
+                            'vectorLegend': ['VECTOR LEGEND'],
+                            'mapinfo': ['MAP INFO'],
+                            'scalebar': ['SCALE BAR']}
+        # define PseudoDC
+        self.pdc = wx.PseudoDC()
+        self.pdcObj = wx.PseudoDC()
+        self.pdcPaper = wx.PseudoDC()
+        self.pdcTmp = wx.PseudoDC()
+        self.pdcImage = wx.PseudoDC()
+        self.font = dc.GetFont()
+        self.SetClientSize((700,510))#?
+        self._buffer = wx.EmptyBitmap(*self.GetClientSize())
+        self.idBoxTmp = wx.NewId()
+        self.idZoomBoxTmp = wx.NewId()
+        self.idResizeBoxTmp = wx.NewId()
+        self.dragId = -1
+        if self.preview:
+            self.image = None
+            self.imageId = 2000
+            self.imgName = self.parent.imgName
+        self.currScale = None
+        self.Clear()
+        self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
+        self.Bind(wx.EVT_PAINT, self.OnPaint)
+        self.Bind(wx.EVT_SIZE,  self.OnSize)
+        self.Bind(wx.EVT_IDLE,  self.OnIdle)
+        self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouse)
+    def Clear(self):
+        """!Clear canvas and set paper
+        bg = wx.LIGHT_GREY_BRUSH
+        self.pdcPaper.BeginDrawing()
+        self.pdcPaper.SetBackground(bg)
+        self.pdcPaper.Clear()
+        self.pdcPaper.EndDrawing()
+        self.pdcObj.RemoveAll()
+        self.pdcTmp.RemoveAll()
+        if not self.preview:
+            self.SetPage()
+    def CanvasPaperCoordinates(self, rect, canvasToPaper = True):
+        """!Converts canvas (pixel) -> paper (inch) coordinates and size and vice versa"""
+        fromU = 'pixel'
+        toU = 'inch'
+        pRect = self.pdcPaper.GetIdBounds(self.pageId)
+        pRectx, pRecty = pRect.x, pRect.y
+        scale = 1/self.currScale
+        if not canvasToPaper: # paper -> canvas
+            fromU = 'inch'
+            toU = 'pixel'
+            scale = self.currScale
+            pRectx = units.convert(value =  - pRect.x, fromUnit = 'pixel', toUnit = 'inch' ) /scale #inch, real, negative
+            pRecty = units.convert(value =  - pRect.y, fromUnit = 'pixel', toUnit = 'inch' ) /scale
+        Width = units.convert(value = rect.width, fromUnit = fromU, toUnit = toU) * scale
+        Height = units.convert(value = rect.height, fromUnit = fromU, toUnit = toU) * scale
+        X = units.convert(value = (rect.x - pRectx), fromUnit = fromU, toUnit = toU) * scale
+        Y = units.convert(value = (rect.y - pRecty), fromUnit = fromU, toUnit = toU) * scale
+        return wx.Rect2D(X, Y, Width, Height)
+    def SetPage(self):
+        """!Sets and changes page, redraws paper"""
+        page = self.instruction[self.pageId]
+        if not page:
+            page = PageSetup(id = self.pageId)
+            self.instruction.AddInstruction(page)
+        ppi = wx.PaintDC(self).GetPPI()
+        cW, cH = self.GetClientSize()
+        pW, pH = page['Width']*ppi[0], page['Height']*ppi[1]
+        if self.currScale is None:
+            self.currScale = min(cW/pW, cH/pH)
+        pW = pW * self.currScale
+        pH = pH * self.currScale
+        x = cW/2 - pW/2
+        y = cH/2 - pH/2
+        self.DrawPaper(wx.Rect(x, y, pW, pH))
+    def modifyRectangle(self, r):
+        """! Recalculates rectangle not to have negative size"""
+        if r.GetWidth() < 0:
+            r.SetX(r.GetX() + r.GetWidth())
+        if r.GetHeight() < 0:
+            r.SetY(r.GetY() + r.GetHeight())
+        r.SetWidth(abs(r.GetWidth()))
+        r.SetHeight(abs(r.GetHeight()))
+        return r
+    def RecalculateEN(self):
+        """!Recalculate east and north for texts (eps, points) after their or map's movement"""
+        try:
+            mapId = self.instruction.FindInstructionByType('initMap').id
+        texts = self.instruction.FindInstructionByType('text', list = True)
+        for text in texts:
+            e, n = PaperMapCoordinates(map = self.instruction[mapId], x = self.instruction[text.id]['where'][0],
+                                                y = self.instruction[text.id]['where'][1], paperToMap = True)
+            self.instruction[text.id]['east'], self.instruction[text.id]['north'] = e, n
+    def OnPaint(self, event):
+        """!Draw pseudo DC to buffer
+        if not self._buffer:
+            return
+        dc = wx.BufferedPaintDC(self, self._buffer)
+        # use PrepareDC to set position correctly
+        self.PrepareDC(dc)
+        dc.SetBackground(wx.LIGHT_GREY_BRUSH)
+        dc.Clear()
+        # draw paper
+            self.pdcPaper.DrawToDC(dc)
+        # draw to the DC using the calculated clipping rect
+        rgn = self.GetUpdateRegion()
+            self.pdcObj.DrawToDCClipped(dc, rgn.GetBox())
+        else:
+            self.pdcImage.DrawToDCClipped(dc, rgn.GetBox())
+        self.pdcTmp.DrawToDCClipped(dc, rgn.GetBox())
+    def OnMouse(self, event):
+        if event.GetWheelRotation():
+            zoom = event.GetWheelRotation()
+            use = self.mouse['use']
+            self.mouse['begin'] = event.GetPosition()
+            if zoom > 0:
+                self.mouse['use'] = 'zoomin'
+            else:
+                self.mouse['use'] = 'zoomout'
+            zoomFactor, view = self.ComputeZoom(wx.Rect(0,0,0,0))
+            self.Zoom(zoomFactor, view)
+            self.mouse['use'] = use
+        if event.Moving():
+            if self.mouse['use'] in ('pointer', 'resize'):
+                pos = event.GetPosition()
+                foundResize = self.pdcTmp.FindObjects(pos[0], pos[1])
+                if foundResize and foundResize[0] == self.idResizeBoxTmp:
+                    self.SetCursor(self.cursors["sizenwse"])
+                    self.parent.SetStatusText(_('Click and drag to resize object'), 0)
+                else:
+                    self.parent.SetStatusText(_(''), 0)
+                    self.SetCursor(self.cursors["default"])
+        elif event.LeftDown():
+            self.begin = self.mouse['begin']
+            if self.mouse['use'] in ('pan', 'zoomin', 'zoomout', 'addMap'):
+                pass
+            #select
+            if self.mouse['use'] == 'pointer':
+                found = self.pdcObj.FindObjects(self.mouse['begin'][0], self.mouse['begin'][1])
+                foundResize = self.pdcTmp.FindObjects(self.mouse['begin'][0], self.mouse['begin'][1])
+                    self.mouse['use'] = 'resize'
+                    # when resizing, proportions match region
+                    if self.instruction[self.dragId].type == 'map':
+                        self.constraint = False
+                        self.mapBounds = self.pdcObj.GetIdBounds(self.dragId)
+                        if self.instruction[self.dragId]['scaleType'] in (0, 1, 2):
+                            self.constraint = True
+                elif found:
+                    self.dragId = found[0]
+                    self.RedrawSelectBox(self.dragId)
+                    if self.instruction[self.dragId].type != 'map':
+                        self.pdcTmp.RemoveId(self.idResizeBoxTmp)
+                        self.Refresh()
+                else:
+                    self.dragId = -1
+                    self.pdcTmp.RemoveId(self.idBoxTmp)
+                    self.Refresh()
+        elif event.Dragging() and event.LeftIsDown():
+            #draw box when zooming, creating map
+            if self.mouse['use'] in ('zoomin', 'zoomout', 'addMap'):
+                self.mouse['end'] = event.GetPosition()
+                r = wx.Rect(self.mouse['begin'][0], self.mouse['begin'][1],
+                            self.mouse['end'][0]-self.mouse['begin'][0], self.mouse['end'][1]-self.mouse['begin'][1])
+                r = self.modifyRectangle(r)
+                self.Draw(pen = self.pen['box'], brush = self.brush['box'], pdc = self.pdcTmp, drawid = self.idZoomBoxTmp,
+                            pdctype = 'rect', bb = r)
+            # panning
+            if self.mouse["use"] == 'pan':
+                view = self.mouse['begin'][0] - self.mouse['end'][0], self.mouse['begin'][1] - self.mouse['end'][1]
+                zoomFactor = 1
+            #move object
+            if self.mouse['use'] == 'pointer' and self.dragId != -1:
+                dx, dy = self.mouse['end'][0] - self.begin[0], self.mouse['end'][1] - self.begin[1]
+                self.pdcObj.TranslateId(self.dragId, dx, dy)
+                self.pdcTmp.TranslateId(self.idBoxTmp, dx, dy)
+                self.pdcTmp.TranslateId(self.idResizeBoxTmp, dx, dy)
+                if self.instruction[self.dragId].type == 'text':
+                    self.instruction[self.dragId]['coords'] = self.instruction[self.dragId]['coords'][0] + dx,\
+                                                            self.instruction[self.dragId]['coords'][1] + dy
+                self.begin = event.GetPosition()
+                self.Refresh()
+            # resize object
+            if self.mouse['use'] == 'resize':
+                type = self.instruction[self.dragId].type
+                x, y = self.mapBounds.GetX(), self.mapBounds.GetY()
+                width, height = self.mapBounds.GetWidth(), self.mapBounds.GetHeight()
+                diffX = pos[0] - self.mouse['begin'][0]
+                diffY = pos[1] - self.mouse['begin'][1]
+                # match given region
+                if self.constraint:
+                    if width > height:
+                        newWidth = width + diffX
+                        newHeight = height + diffX * (float(height) / width)
+                    else:
+                        newWidth = width + diffY * (float(width) / height)
+                        newHeight = height + diffY
+                else:
+                if newWidth < 10 or newHeight < 10:
+                    return
+                bounds = wx.Rect(x, y, newWidth, newHeight)
+                self.Draw(pen = self.pen[type], brush = self.brush[type], pdc = self.pdcObj, drawid = self.dragId,
+                            pdctype = 'rectText', bb = bounds)
+        elif event.LeftUp():
+            # zoom in, zoom out
+            if self.mouse['use'] in ('zoomin','zoomout'):
+                zoomR = self.pdcTmp.GetIdBounds(self.idZoomBoxTmp)
+                self.pdcTmp.RemoveId(self.idZoomBoxTmp)
+                self.Refresh()
+                zoomFactor, view = self.ComputeZoom(zoomR)
+            # draw map frame
+            if self.mouse['use'] == 'addMap':
+                rectTmp = self.pdcTmp.GetIdBounds(self.idZoomBoxTmp)
+                # too small rectangle, it's usually some mistake
+                if rectTmp.GetWidth() < 20 or rectTmp.GetHeight() < 20:
+                    self.Refresh()
+                    return
+                rectPaper = self.CanvasPaperCoordinates(rect = rectTmp, canvasToPaper = True)
+                dlg = MapDialog(parent = self.parent, id = [None, None, None], settings = self.instruction,
+                                         rect = rectPaper)
+                self.mouse['use'] = self.parent.mouseOld
+                self.SetCursor(self.parent.cursorOld)
+                self.parent.toolbar.ToggleTool(self.parent.actionOld, True)
+                self.parent.toolbar.ToggleTool(self.parent.toolbar.action['id'], False)
+                self.parent.toolbar.action['id'] = self.parent.actionOld
+            # resize resizable objects (only map sofar)
+                if self.dragId == mapId:
+                    # necessary to change either map frame (scaleType 0,1,2) or region (scaletype 3)
+                    newRectCanvas = self.pdcObj.GetIdBounds(mapId)
+                    newRectPaper = self.CanvasPaperCoordinates(rect = newRectCanvas, canvasToPaper = True)
+                    self.instruction[mapId]['rect'] = newRectPaper
+                    if self.instruction[mapId]['scaleType'] in (0, 1, 2):
+                        if self.instruction[mapId]['scaleType'] == 0:
+                            scale, foo, rect = AutoAdjust(self, scaleType = 0,
+                                                        map = self.instruction[mapId]['map'],
+                                                        mapType = self.instruction[mapId]['mapType'],
+                                                        rect = self.instruction[mapId]['rect'])
+                        elif self.instruction[mapId]['scaleType'] == 1:
+                            scale, foo, rect = AutoAdjust(self, scaleType = 1,
+                                                        region = self.instruction[mapId]['region'],
+                        else:
+                            scale, foo, rect = AutoAdjust(self, scaleType = 2,
+                        self.instruction[mapId]['rect'] = rect
+                        self.instruction[mapId]['scale'] = scale
+                        rectCanvas = self.CanvasPaperCoordinates(rect = rect, canvasToPaper = False)
+                        self.Draw(pen = self.pen['map'], brush = self.brush['map'],
+                                    pdc = self.pdcObj, drawid = mapId, pdctype = 'rectText', bb = rectCanvas)
+                    elif self.instruction[mapId]['scaleType'] == 3:
+                        ComputeSetRegion(self, mapDict = self.instruction[mapId].GetInstruction())
+                    #check resolution
+                    SetResolution(dpi = self.instruction[mapId]['resolution'],
+                                    width = self.instruction[mapId]['rect'].width,
+                                    height = self.instruction[mapId]['rect'].height)
+                    self.RedrawSelectBox(mapId)
+                    self.Zoom(zoomFactor = 1, view = (0, 0))
+                self.mouse['use'] = 'pointer'
+            # recalculate the position of objects after dragging
+            if self.mouse['use'] in ('pointer', 'resize') and self.dragId != -1:
+                if self.mouse['begin'] != event.GetPosition(): #for double click
+                    self.RecalculatePosition(ids = [self.dragId])
+                    if self.instruction[self.dragId].type in self.openDialogs:
+                        self.openDialogs[self.instruction[self.dragId].type].updateDialog()
+        # double click launches dialogs
+        elif event.LeftDClick():
+                itemCall = {    'text':self.parent.OnAddText, 'mapinfo': self.parent.OnAddMapinfo,
+                                'scalebar': self.parent.OnAddScalebar,
+                                'rasterLegend': self.parent.OnAddLegend, 'vectorLegend': self.parent.OnAddLegend,
+                                'map': self.parent.OnAddMap}
+                itemArg = { 'text': dict(event = None, id = self.dragId), 'mapinfo': dict(event = None),
+                            'scalebar': dict(event = None),
+                            'rasterLegend': dict(event = None), 'vectorLegend': dict(event = None, page = 1),
+                            'map': dict(event = None, notebook = True)}
+                itemCall[type](**itemArg[type])
+    def RecalculatePosition(self, ids):
+        for id in ids:
+            if itype == 'map':
+                        self.instruction[id]['rect'] = self.CanvasPaperCoordinates(rect = self.pdcObj.GetIdBounds(id),
+        canvasToPaper = True)
+                        self.RecalculateEN()
+            elif itype in ('mapinfo' ,'rasterLegend', 'vectorLegend'):
+                self.instruction[id]['where'] = self.CanvasPaperCoordinates(rect = self.pdcObj.GetIdBounds(id),
+                                                            canvasToPaper = True)[:2]
+            elif  itype == 'scalebar':
+                self.instruction[id]['where'] = self.instruction[id]['rect'].GetCentre()
+            elif  itype == 'text':
+                x, y = self.instruction[id]['coords'][0] - self.instruction[id]['xoffset'],\
+                        self.instruction[id]['coords'][1] + self.instruction[id]['yoffset']
+                extent = self.parent.getTextExtent(textDict = self.instruction[id])
+                if self.instruction[id]['rotate'] is not None:
+                    rot = float(self.instruction[id]['rotate'])/180*pi
+                else:
+                    rot = 0
+                    y += extent[1]
+                    y += extent[1]/2
+                    x += extent[0] * cos(rot)
+                    y -= extent[0] * sin(rot)
+                    x += extent[0]/2 * cos(rot)
+                    y -= extent[0]/2 * sin(rot)
+                self.instruction[id]['where'] = self.CanvasPaperCoordinates(rect = wx.Rect2D(x, y, 0, 0),
+    def ComputeZoom(self, rect):
+        """!Computes zoom factor and scroll view"""
+        zoomFactor = 1
+        cW = float(cW)
+        if rect.IsEmpty(): # clicked on canvas
+            zoomFactor = 1.5
+            if self.mouse['use'] == 'zoomout':
+                zoomFactor = 1./zoomFactor
+            x,y = self.mouse['begin']
+            xView = x - x/zoomFactor#x - cW/(zoomFactor * 2)
+            yView = y - y/zoomFactor#y - cH/(zoomFactor * 2)
+        else:   #dragging
+            rW, rH = float(rect.GetWidth()), float(rect.GetHeight())
+            zoomFactor = 1/max(rW/cW, rH/cH)
+            # when zooming to full extent, in some cases, there was zoom 1.01..., which causes problem
+            if abs(zoomFactor - 1) > 0.01:
+                zoomFactor = zoomFactor
+            else:
+                zoomFactor = 1.
+                zoomFactor = min(rW/cW, rH/cH)
+            if rW/rH > cW/cH:
+                yView = rect.GetY() - (rW*(cH/cW) - rH)/2
+                xView = rect.GetX()
+                    x,y = rect.GetX() + (rW-(cW/cH)*rH)/2, rect.GetY()
+                    xView, yView = -x, -y
+            else:
+                xView = rect.GetX() - (rH*(cW/cH) - rW)/2
+                    x,y = rect.GetX(), rect.GetY() + (rH-(cH/cW)*rW)/2
+        return zoomFactor, (int(xView), int(yView))
+    def Zoom(self, zoomFactor, view):
+        """! Zoom to specified region, scroll view, redraw"""
+        if not self.currScale:
+            return
+        self.currScale = self.currScale*zoomFactor
+        if self.currScale > 10 or self.currScale < 0.1:
+            self.currScale = self.currScale/zoomFactor
+            return
+            # redraw paper
+            pRect.OffsetXY(-view[0], -view[1])
+            pRect = self.ScaleRect(rect = pRect, scale = zoomFactor)
+            self.DrawPaper(pRect)
+            #redraw objects
+            for id in self.objectId:
+                oRect = self.CanvasPaperCoordinates(
+                type = self.instruction[id].type
+                if type == 'text':
+                    coords = self.instruction[id]['coords']# recalculate coordinates, they are not equal to BB
+                    self.instruction[id]['coords'] = coords = [(int(coord) - view[i]) * zoomFactor
+        for i, coord in enumerate(coords)]
+                    self.DrawRotText(pdc = self.pdcObj, drawId = id, textDict = self.instruction[id],
+                     coords = coords, bounds = oRect )
+                    else:
+                        rot = 0
+                    self.instruction[id]['rect'] = bounds = self.parent.getModifiedTextBounds(coords[0], coords[1], extent, rot)
+                    self.pdcObj.SetIdBounds(id, bounds)
+                else:
+                            drawid = id, pdctype = 'rectText', bb = oRect)
+            #redraw tmp objects
+            if self.dragId != -1:
+        #redraw preview
+        else: # preview mode
+            imageRect = self.pdcImage.GetIdBounds(self.imageId)
+            imageRect.OffsetXY(-view[0], -view[1])
+            imageRect = self.ScaleRect(rect = imageRect, scale = zoomFactor)
+            self.DrawImage(imageRect)
+    def ZoomAll(self):
+        """! Zoom to full extent"""
+            bounds = self.pdcPaper.GetIdBounds(self.pageId)
+        else:
+            bounds = self.pdcImage.GetIdBounds(self.imageId)
+        zoomP = bounds.Inflate(bounds.width/20, bounds.height/20)
+        zoomFactor, view = self.ComputeZoom(zoomP)
+    def Draw(self, pen, brush, pdc, drawid = None, pdctype = 'rect', bb = wx.Rect(0,0,0,0)):
+        """! Draw object"""
+        if drawid is None:
+            drawid = wx.NewId()
+        bb = bb.Get()
+        pdc.BeginDrawing()
+        pdc.RemoveId(drawid)
+        pdc.SetId(drawid)
+        pdc.SetPen(pen)
+        pdc.SetBrush(brush)
+        if pdctype in ('rect', 'rectText'):
+            pdc.DrawRectangle(*bb)
+        if pdctype == 'rectText':
+            font = self.font
+            size = 10
+            font.SetPointSize(size)
+            font.SetStyle(wx.ITALIC)
+            dc.SetFont(font)
+            pdc.SetFont(font)
+            text = '\n'.join(self.itemLabels[self.instruction[drawid].type])
+            textExtent = dc.GetTextExtent(text)
+            textRect = wx.Rect(0, 0, *textExtent).CenterIn(bb)
+            r = map(int, bb)
+            while not wx.Rect(*r).ContainsRect(textRect) and size >= 8:
+                size -= 2
+                dc.SetFont(font)
+                pdc.SetFont(font)
+            pdc.SetTextForeground(wx.Color(100,100,100,200))
+            pdc.SetBackgroundMode(wx.TRANSPARENT)
+            pdc.DrawText(text = text, x = textRect.x, y = textRect.y)
+        pdc.SetIdBounds(drawid, bb)
+        pdc.EndDrawing()
+        self.Refresh()
+        return drawid
+    def DrawRotText(self, pdc, drawId, textDict, coords, bounds):
+        if textDict['rotate']:
+            rot = float(textDict['rotate'])
+        else:
+            rot = 0
+        fontsize = str(textDict['fontsize'] * self.currScale)
+        if textDict['background'] != 'none':
+            background = textDict['background']
+        else:
+            background = None
+        pdc.RemoveId(drawId)
+        pdc.SetId(drawId)
+        # doesn't work
+        if background:
+            pdc.SetBackground(wx.Brush(convertRGB(background)))
+            pdc.SetBackgroundMode(wx.SOLID)
+        else:
+            pdc.SetBackground(wx.TRANSPARENT_BRUSH)
+        pdc.SetFont(wx.FontFromNativeInfoString(textDict['font'] + " " + fontsize))
+        pdc.SetTextForeground(convertRGB(textDict['color']))
+        pdc.DrawRotatedText(textDict['text'], coords[0], coords[1], rot)
+        pdc.SetIdBounds(drawId, wx.Rect(*bounds))
+        self.Refresh()
+        pdc.EndDrawing()
+    def DrawImage(self, rect):
+        """!Draw preview image to pseudoDC"""
+        self.pdcImage.ClearId(self.imageId)
+        self.pdcImage.SetId(self.imageId)
+        img = self.image
+        if img.GetWidth() != rect.width or img.GetHeight() != rect.height:
+            img = img.Scale(rect.width, rect.height)
+        bitmap = img.ConvertToBitmap()
+        self.pdcImage.BeginDrawing()
+        self.pdcImage.DrawBitmap(bitmap, rect.x, rect.y)
+        self.pdcImage.SetIdBounds(self.imageId, rect)
+        self.pdcImage.EndDrawing()
+        self.Refresh()
+    def DrawPaper(self, rect):
+        """!Draw paper and margins"""
+        scale = page['Width'] / rect.GetWidth()
+        w = (page['Width'] - page['Right'] - page['Left']) / scale
+        h = (page['Height'] - page['Top'] - page['Bottom']) / scale
+        x = page['Left'] / scale + rect.GetX()
+        y = page['Top'] / scale + rect.GetY()
+        self.pdcPaper.RemoveId(self.pageId)
+        self.pdcPaper.SetId(self.pageId)
+        self.pdcPaper.SetPen(self.pen['paper'])
+        self.pdcPaper.SetBrush(self.brush['paper'])
+        self.pdcPaper.DrawRectangleRect(rect)
+        self.pdcPaper.SetPen(self.pen['margins'])
+        self.pdcPaper.SetBrush(self.brush['margins'])
+        self.pdcPaper.DrawRectangle(x, y, w, h)
+        self.pdcPaper.SetIdBounds(self.pageId, rect)
+        self.Refresh()
+    def ImageRect(self):
+        """!Returns image centered in canvas, computes scale"""
+        img = wx.Image(self.imgName, wx.BITMAP_TYPE_PNG)
+        iW, iH = img.GetWidth(), img.GetHeight()
+        self.currScale = min(float(cW)/iW, float(cH)/iH)
+        iW = iW * self.currScale
+        iH = iH * self.currScale
+        x = cW/2 - iW/2
+        y = cH/2 - iH/2
+        imageRect = wx.Rect(x, y, iW, iH)
+        return imageRect
+    def RedrawSelectBox(self, id):
+        """!Redraws select box when selected object changes its size"""
+        if self.dragId == id:
+            rect = [self.pdcObj.GetIdBounds(id).Inflate(3,3)]
+            type = ['select']
+            ids = [self.idBoxTmp]
+            if self.instruction[id].type == 'map':
+                controlP = self.pdcObj.GetIdBounds(id).GetBottomRight()
+                rect.append(wx.Rect(controlP.x, controlP.y, 10,10))
+                type.append('resize')
+                ids.append(self.idResizeBoxTmp)
+            for id, type, rect in zip(ids, type, rect):
+                self.Draw(pen = self.pen[type], brush = self.brush[type], pdc = self.pdcTmp,
+                            drawid = id, pdctype = 'rect', bb = rect)
+    def UpdateMapLabel(self):
+        """!Updates map frame label"""
+        vector = self.instruction.FindInstructionByType('vector')
+        if vector:
+            vectorId = vector.id
+        else:
+            vectorId = None
+        if raster:
+        else:
+            rasterId = None
+        rasterName = 'None'
+        if rasterId:
+            rasterName = self.instruction[rasterId]['raster'].split('@')[0]
+        self.itemLabels['map'] = self.itemLabels['map'][0:1]
+        self.itemLabels['map'].append("raster: " + rasterName)
+        if vectorId:
+            for map in self.instruction[vectorId]['list']:
+                self.itemLabels['map'].append('vector: ' + map[0].split('@')[0])
+    def OnSize(self, event):
+        """!Init image size to match window size
+        # not zoom all when notebook page is changed
+        if self.preview and self.parent.currentPage == 1 or not self.preview and self.parent.currentPage == 0:
+            self.ZoomAll()
+        self.OnIdle(None)
+        event.Skip()
+    def OnIdle(self, event):
+        """!Only re-render a image during idle time instead of
+        multiple times during resizing.
+        width, height = self.GetClientSize()
+        # Make new off screen bitmap: this bitmap will always have the
+        # current drawing in it, so it can be used to save the image
+        # to a file, or whatever.
+        self._buffer = wx.EmptyBitmap(width, height)
+        # re-render image on idle
+        self.resize = True
+    def ScaleRect(self, rect, scale):
+        """! Scale rectangle"""
+        return wx.Rect(rect.GetLeft()*scale, rect.GetTop()*scale,
+                    rect.GetSize()[0]*scale, rect.GetSize()[1]*scale)
+def main():
+    app = wx.PySimpleApp()
+    wx.InitAllImageHandlers()
+    frame = PsMapFrame()
+    frame.Show()
+    app.MainLoop()
+if __name__ == "__main__":
+    main()
Copied: grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py (from rev 46349, grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py)
--- grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_modules/psmap_dialogs.py	2011-05-22 11:51:32 UTC (rev 46356)
@@ -0,0 +1,5717 @@
+ at package psmap_dialogs
+ at brief map feature objects and dialogs for ps.map
+Classes:
+ - UnitConversion
+ - TCValidator
+ - PenStyleComboBox
+ - CheckListCtrl
+ - Instruction
+ - InstructionObject
+ - InitMap
+ - MapFrame
+ - PageSetup
+ - Mapinfo
+ - Text
+ - Scalebar
+ - RasterLegend
+ - VectorLegend
+ - Raster
+ - Vector
+ - VProperties
+ - PsmapDialog
+ - PageSetupDialog
+ - MapDialog
+ - MapFramePanel
+ - RasterPanel
+ - VectorPanel
+ - RasterDialog
+ - MainVectorDialog
+ - VPropertiesDialog
+ - LegendDialog
+ - MapinfoDialog
+ - ScalebarDialog
+ - TextDialog
+import os
+import sys
+import string
+from math import ceil, floor
+from copy import deepcopy
+from time import strftime, localtime
+                                 'gui_modules'))
+else:
+                                 'gui_modules'))
+import globalvar
+import dbm_base
+from   utils      import CmdToTuple, GetCmdString
+from   gselect    import Select
+from   gcmd       import RunCommand, GError, GMessage, GWarning
+import wx
+import wx.lib.scrolledpanel as scrolled
+import  wx.lib.filebrowsebutton as filebrowse
+from wx.lib.mixins.listctrl import CheckListCtrlMixin, ListCtrlAutoWidthMixin
+from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
+try:
+    import wx.lib.agw.floatspin as fs
+    fs = None
+grass.set_raise_on_error(True)
+PSMAP_COLORS = ['aqua', 'black', 'blue', 'brown', 'cyan', 'gray', 'grey', 'green', 'indigo',
+                'magenta','orange', 'purple', 'red', 'violet', 'white', 'yellow']
+class UnitConversion:
+    """! Class for converting units"""
+    def __init__(self, parent = None):
+        if self.parent:
+            ppi = wx.PaintDC(self.parent).GetPPI()
+        else:
+            ppi = (72, 72)
+        self._unitsPage = { 'inch' : 1.0,
+                            'point' : 72.0,
+                            'centimeter' : 2.54,
+                            'milimeter' : 25.4}
+        self._unitsMap = {  'meters' : 0.0254,
+                            'kilometers' : 2.54e-5,
+                            'feet' : 1./12,
+                            'miles' : 1./63360,
+                            'nautical miles' : 1/72913.44}
+        self._units = { 'pixel': ppi[0],
+                        'meter': 0.0254,
+                        'degrees' : 0.0254  #like 1 meter, incorrect
+        self._units.update(self._unitsPage)
+        self._units.update(self._unitsMap)
+    def getPageUnits(self):
+        return sorted(self._unitsPage.keys())
+    def getMapUnits(self):
+        return sorted(self._unitsMap.keys())
+    def getAllUnits(self):
+        return sorted(self._units.keys())
+    def convert(self, value, fromUnit = None, toUnit = None):
+        return float(value)/self._units[fromUnit]*self._units[toUnit]
+class TCValidator(wx.PyValidator):
+    """!validates input in textctrls, combobox, taken from wxpython demo"""
+    def __init__(self, flag = None):
+        wx.PyValidator.__init__(self)
+        self.flag = flag
+        self.Bind(wx.EVT_CHAR, self.OnChar)
+    def Clone(self):
+        return TCValidator(self.flag)
+    def Validate(self, win):
+        tc = self.GetWindow()
+        val = tc.GetValue()
+        if self.flag == 'DIGIT_ONLY':
+            for x in val:
+                if x not in string.digits:
+                    return False
+        return True
+    def OnChar(self, event):
+        key = event.GetKeyCode()
+        if key < wx.WXK_SPACE or key == wx.WXK_DELETE or key > 255:
+            event.Skip()
+            return
+        if self.flag == 'DIGIT_ONLY' and chr(key) in string.digits + '.':
+            event.Skip()
+            return
+##        if self.flag == 'SCALE' and chr(key) in string.digits + ':':
+##            event.Skip()
+##            return
+        if self.flag == 'ZERO_AND_ONE_ONLY' and chr(key) in '01':
+            event.Skip()
+            return
+        if not wx.Validator_IsSilent():
+            wx.Bell()
+        # Returning without calling even.Skip eats the event before it
+        # gets to the text control
+        return
+class PenStyleComboBox(wx.combo.OwnerDrawnComboBox):
+    """!Combo for selecting line style, taken from wxpython demo"""
+    # Overridden from OwnerDrawnComboBox, called to draw each
+    # item in the list
+    def OnDrawItem(self, dc, rect, item, flags):
+        if item == wx.NOT_FOUND:
+            # painting the control, but there is no valid item selected yet
+            return
+        r = wx.Rect(*rect)  # make a copy
+        r.Deflate(3, 5)
+        penStyle = wx.SOLID
+        if item == 1:
+            penStyle = wx.LONG_DASH
+        elif item == 2:
+            penStyle = wx.DOT
+        elif item == 3:
+            penStyle = wx.DOT_DASH
+        pen = wx.Pen(dc.GetTextForeground(), 3, penStyle)
+        dc.SetPen(pen)
+        # for painting the items in the popup
+        dc.DrawText(self.GetString( item ),
+                    r.x + 3,
+                    (r.y + 0) + ( (r.height/2) - dc.GetCharHeight() )/2
+        dc.DrawLine( r.x+5, r.y+((r.height/4)*3)+1, r.x+r.width - 5, r.y+((r.height/4)*3)+1 )
+    def OnDrawBackground(self, dc, rect, item, flags):
+        """!Overridden from OwnerDrawnComboBox, called for drawing the
+            background area of each item."""
+        # If the item is selected, or its item # iseven, or we are painting the
+        # combo control itself, then use the default rendering.
+        if (item & 1 == 0 or flags & (wx.combo.ODCB_PAINTING_CONTROL |
+                                      wx.combo.ODCB_PAINTING_SELECTED)):
+            wx.combo.OwnerDrawnComboBox.OnDrawBackground(self, dc, rect, item, flags)
+            return
+        # Otherwise, draw every other background with different colour.
+        bgCol = wx.Colour(240,240,250)
+        dc.SetBrush(wx.Brush(bgCol))
+        dc.SetPen(wx.Pen(bgCol))
+        dc.DrawRectangleRect(rect);
+    def OnMeasureItem(self, item):
+        """!Overridden from OwnerDrawnComboBox, should return the height
+            needed to display an item in the popup, or -1 for default"""
+        return 30
+    def OnMeasureItemWidth(self, item):
+        """!Overridden from OwnerDrawnComboBox.  Callback for item width, or
+            -1 for default/undetermined"""
+        return -1; # default - will be measured from text width
+class CheckListCtrl(wx.ListCtrl, CheckListCtrlMixin, ListCtrlAutoWidthMixin):
+    """!List control for managing order and labels of vector maps in legend"""
+    def __init__(self, parent):
+        wx.ListCtrl.__init__(self, parent, id = wx.ID_ANY,
+                style = wx.LC_REPORT|wx.LC_SINGLE_SEL|wx.BORDER_SUNKEN|wx.LC_VRULES|wx.LC_HRULES)
+        CheckListCtrlMixin.__init__(self)
+        ListCtrlAutoWidthMixin.__init__(self)
+class Instruction:
+    """!Class which represents instruction file"""
+    def __init__(self, parent, objectsToDraw):
+        self.objectsToDraw = objectsToDraw
+        #here are kept objects like mapinfo, rasterlegend, etc.
+        self.instruction = list()
+    def __str__(self):
+        """!Returns text for instruction file"""
+        comment = "# timestamp: " + strftime("%Y-%m-%d %H:%M", localtime()) + '\n'
+        comment += "# location: %s\n" % env['LOCATION_NAME']
+        comment += "# mapset: %s\n" % env['MAPSET']
+        border = ''
+        if not self.FindInstructionByType('map'):
+            border = 'border n\n'
+        text = [str(each) for each in self.instruction]
+        return comment + border + '\n'.join(text) + '\nend'
+    def __getitem__(self, id):
+        for each in self.instruction:
+            if each.id == id:
+                return each
+        return None
+    def __contains__(self, id):
+        """!Test if instruction is included"""
+            if each.id == id:
+                return True
+        return False
+    def __delitem__(self, id):
+        """!Delete instruction"""
+            if each.id == id:
+                if each.type == 'map':
+                    #must remove raster, vector layers too
+                    vektor = self.FindInstructionByType('vector', list = True)
+                    vProperties = self.FindInstructionByType('vProperties', list = True)
+                    raster = self.FindInstructionByType('raster', list = True)
+                    for item in vektor + vProperties + raster:
+                        if item in self.instruction:
+                            self.instruction.remove(item)
+                self.instruction.remove(each)
+                if id in self.objectsToDraw:
+                    self.objectsToDraw.remove(id)
+                return
+    def AddInstruction(self, instruction):
+        """!Add instruction"""
+        # add to instructions
+        if instruction.type == 'map':
+            self.instruction.insert(0, instruction)
+        else:
+            self.instruction.append(instruction)
+        # add to drawable objects
+        if instruction.type not in ('page', 'raster', 'vector', 'vProperties', 'initMap'):
+                self.objectsToDraw.insert(0, instruction.id)
+            else:
+                self.objectsToDraw.append(instruction.id)
+    def FindInstructionByType(self, type, list = False):
+        """!Find instruction(s) with the given type"""
+        inst = []
+            if each.type == type:
+                inst.append(each)
+        if len(inst) == 1 and not list:
+            return inst[0]
+        return inst
+    def Read(self, filename):
+        """!Reads instruction file and creates instruction objects"""
+        self.filename = filename
+        # open file
+        try:
+            file = open(filename, 'r')
+        except IOError:
+            GError(message = _("Unable to open file\n%s") % filename)
+            return
+        # first read file to get information about region and scaletype
+        isRegionComment = False
+        for line in file:
+            if '# g.region' in line:
+                self.SetRegion(regionInstruction = line)
+                isRegionComment = True
+                break
+        if not isRegionComment:
+            self.SetRegion(regionInstruction = None)
+        # then run ps.map -b to get information for maploc
+        # compute scale and center
+        map = self.FindInstructionByType('map')
+        map['center'] = (region['n'] + region['s']) / 2, (region['w'] + region['e']) / 2
+        mapRect = GetMapBounds(self.filename)
+        map['rect'] = mapRect
+        proj = projInfo()
+        toM = 1.0
+        if proj['units']:
+            toM = float(proj['meters'])
+        units = UnitConversion(self.parent)
+        w = units.convert(value = mapRect.Get()[2], fromUnit = 'inch', toUnit = 'meter') / toM
+        map['scale'] = w / abs((region['w'] - region['e']))
+        SetResolution(dpi = 300, width = map['rect'].width, height = map['rect'].height)
+        # read file again, now with information about map bounds
+        isBuffer = False
+        buffer = []
+        instruction = None
+        vectorMapNumber = 1
+        file.seek(0)
+        for line in file:
+            if not line.strip():
+                continue
+            line = line.strip()
+            if isBuffer:
+                buffer.append(line)
+                if 'end' in line:
+                    isBuffer = False
+                    kwargs = {}
+                    if instruction == 'scalebar':
+                        kwargs['scale'] = map['scale']
+                    elif instruction == 'text':
+                        kwargs['mapInstruction'] = map
+                    elif instruction in ('vpoints', 'vlines', 'vareas'):
+                        kwargs['id'] = wx.NewId()
+                        kwargs['vectorMapNumber'] = vectorMapNumber
+                        vectorMapNumber += 1
+                    ok = self.SendToRead(instruction, buffer, **kwargs)
+                    if not ok: return False
+                    buffer = []
+                continue
+            elif line.startswith('paper'):
+                instruction = 'paper'
+                isBuffer = True
+            elif line.startswith('border'):
+                if line.split()[1].lower() in ('n', 'no', 'none'):
+                    ok = self.SendToRead('border', [line])
+                elif line.split()[1].lower() in ('y', 'yes'):
+                    instruction = 'border'
+                    isBuffer = True
+            elif line.startswith('scale '):
+                ok = self.SendToRead('scale', line, isRegionComment = isRegionComment)
+            elif line.startswith('maploc'):
+                ok = self.SendToRead(instruction = 'maploc', text = line)
+            elif line.startswith('raster'):
+                ok = self.SendToRead(instruction = 'raster', text = line)
+            elif line.startswith('mapinfo'):
+                instruction = 'mapinfo'
+                isBuffer = True
+            elif line.startswith('scalebar'):
+                instruction = 'scalebar'
+                isBuffer = True
+            elif line.startswith('text'):
+                instruction = 'text'
+                isBuffer = True
+            elif line.startswith('colortable'):
+                if len(line.split()) == 2 and line.split()[1].lower() in ('n', 'no', 'none'):
+                    break
+                instruction = 'colortable'
+                isBuffer = True
+            elif line.startswith('vlegend'):
+                instruction = 'vlegend'
+                isBuffer = True
+            elif line.startswith('vpoints'):
+                instruction = 'vpoints'
+                isBuffer = True
+            elif line.startswith('vlines'):
+                instruction = 'vlines'
+                isBuffer = True
+            elif line.startswith('vareas'):
+                instruction = 'vareas'
+                isBuffer = True
+        rasterLegend = self.FindInstructionByType('rasterLegend')
+        raster = self.FindInstructionByType('raster')
+        page = self.FindInstructionByType('page')
+        vector = self.FindInstructionByType('vector')
+        vectorLegend = self.FindInstructionByType('vectorLegend')
+        vectorMaps = self.FindInstructionByType('vProperties', list = True)
+        # check (in case of scaletype 0) if map is drawn also
+        map['drawMap'] = False
+        if map['scaleType'] == 0:
+            mapForRegion = map['map']
+            if map['mapType'] == 'raster' and raster:
+                if mapForRegion == raster['raster']:
+                    map['drawMap'] = True
+            elif map['mapType'] == 'vector' and vector:
+                for vmap in vector['list']:
+                    if mapForRegion == vmap[0]:
+        # rasterLegend
+        if rasterLegend:
+            if rasterLegend['rasterDefault'] and raster:
+                rasterLegend['raster'] = raster['raster']
+                if not rasterLegend['discrete']:
+                    rasterType = getRasterType(map = rasterLegend['raster'])
+                    if rasterType == 'CELL':
+                        rasterLegend['discrete'] = 'y'
+                    else:
+                        rasterLegend['discrete'] = 'n'
+            #estimate size
+            height = rasterLegend.EstimateHeight(raster = rasterLegend['raster'], discrete = rasterLegend['discrete'],
+                                        fontsize = rasterLegend['fontsize'],
+                                        cols = rasterLegend['cols'],
+                                        height = rasterLegend['height'])
+            width = rasterLegend.EstimateWidth(raster = rasterLegend['raster'], discrete = rasterLegend['discrete'],
+                                        cols = rasterLegend['cols'] ,
+                                        width = rasterLegend['width'],
+                                        paperInstr = page)
+            rasterLegend['rect'] = wx.Rect2D(x = float(rasterLegend['where'][0]), y = float(rasterLegend['where'][1]),
+                                                w = width, h = height)
+        # vectors, vlegend
+        if vector:
+            for vmap in vectorMaps:
+                for i, each in enumerate(vector['list']):
+                    if each[2] == vmap.id:
+                        vector['list'][i][4] = vmap['label']
+                        vector['list'][i][3] = vmap['lpos']
+            if vectorLegend:
+                size = vectorLegend.EstimateSize(vectorInstr = vector, fontsize = vectorLegend['fontsize'],
+                                            width = vectorLegend['width'], cols = vectorLegend['cols'])
+                vectorLegend['rect'] = wx.Rect2D(x = float(vectorLegend['where'][0]), y = float(vectorLegend['where'][1]),
+                                                    w = size[0], h = size[1])
+        if not page:
+            page = PageSetup(wx.NewId())
+            self.AddInstruction(page)
+        return True
+    def SendToRead(self, instruction, text, **kwargs):
+        #print 'send to read', instruction, text
+        psmapInstrDict = dict(  paper = ['page'],
+                                maploc = ['map'],
+                                scale = ['map'],
+                                border = ['map'],
+                                raster = ['raster'],
+                                mapinfo = ['mapinfo'],
+                                scalebar = ['scalebar'],
+                                text = ['text'],
+                                vpoints = ['vector', 'vProperties'],
+                                vlines = ['vector', 'vProperties'],
+                                vareas = ['vector', 'vProperties'],
+                                colortable = ['rasterLegend'],
+                                vlegend = ['vectorLegend']
+        myInstrDict = dict( page = PageSetup,
+                            map = MapFrame,
+                            raster = Raster,
+                            mapinfo = Mapinfo,
+                            scalebar = Scalebar,
+                            text = Text,
+                            rasterLegend = RasterLegend,
+                            vectorLegend = VectorLegend,
+                            vector = Vector,
+                            vProperties = VProperties
+        myInstruction = psmapInstrDict[instruction]
+        for i in myInstruction:
+            instr = self.FindInstructionByType(i)
+            if i in ('text', 'vProperties') or not instr:
+                id = wx.NewId() #!vProperties expect subtype
+                if i == 'vProperties':
+                    id = kwargs['id']
+                    newInstr = myInstrDict[i](id, subType = instruction[1:])
+                else:
+                    newInstr = myInstrDict[i](id)
+                ok = newInstr.Read(instruction, text, **kwargs)
+                if ok:
+                    self.AddInstruction(newInstr)
+                else:
+                    return False
+            else:
+                ok = instr.Read(instruction, text, **kwargs)
+                if not ok:
+                    return False
+        return True
+    def SetRegion(self, regionInstruction):
+        """!Sets region from file comment or sets current region in case of no comment"""
+        map = MapFrame(wx.NewId())
+        self.AddInstruction(map)
+        if regionInstruction:
+            cmd = CmdToTuple(regionInstruction.strip('# ').split())
+            # define scaleType
+            if len(cmd[1]) <= 3:
+                if 'rast' in cmd[1]:
+                    map['scaleType'] = 0
+                    map['mapType'] = 'raster'
+                    map['map'] = cmd[1]['rast']
+                elif 'vect' in cmd[1]:
+                    map['mapType'] = 'vector'
+                    map['map'] = cmd[1]['vect']
+                elif 'region' in cmd[1]:
+                    map['scaleType'] = 1
+                    map['region'] = cmd[1]['region']
+            else:
+                map['scaleType'] = 2
+        else:
+            grass.del_temp_region()
+            cmd = ['g.region', region]
+        cmdString = GetCmdString(cmd).replace('g.region', '')
+        GMessage(_("Instruction file will be loaded with following region: %s\n") % cmdString)
+        try:
+            RunCommand(cmd[0], **cmd[1])
+        except grass.ScriptError, e:
+            GError(_("Region cannot be set\n%s") % e)
+            return False
+class InstructionObject:
+    """!Abtract class representing single instruction"""
+    def __init__(self, id):
+        self.id = id
+        # default values
+        self.defaultInstruction = dict()
+        # current values
+        self.instruction = self.defaultInstruction
+        # converting units
+        self.unitConv = UnitConversion()
+        """!Returns particular part of text instruction"""
+        return ''
+    def __getitem__(self, key):
+        for each in self.instruction.keys():
+            if each == key:
+                return self.instruction[key]
+        return None
+    def __setitem__(self, key, value):
+        self.instruction[key] = value
+    def GetInstruction(self):
+        """!Get current values"""
+    def SetInstruction(self, instruction):
+        """!Set default values"""
+        self.instruction = instruction
+    def Read(self, instruction, text, **kwargs):
+        """!Read instruction and save them"""
+        pass
+class InitMap(InstructionObject):
+    """!Class representing virtual map"""
+        InstructionObject.__init__(self, id = id)
+        self.type = 'initMap'
+        # default values
+        self.defaultInstruction = dict(rect = None, scale =  None)
+        # current values
+        self.instruction = dict(self.defaultInstruction)
+class MapFrame(InstructionObject):
+    """!Class representing map (instructions maploc, scale, border)"""
+        self.type = 'map'
+        # default values
+        self.defaultInstruction = dict( map = None, mapType = None, drawMap = True, region = None,
+                                        rect = wx.Rect2D(), scaleType = 0, scale = None, center = None,
+                                        resolution = 300, border = 'y', width = 1, color = '0:0:0')
+        # current values
+        instr = ''
+        comment = ''
+        #region settings
+        if self.instruction['scaleType'] == 0: #match map
+            map = self.instruction['map']
+            if self.instruction['mapType'] == 'raster':
+                comment = "# g.region rast=%s cols=%s rows=%s\n" % (map, region['cols'], region['rows'])
+            else:
+                comment = "# g.region vect=%s\n" % (map)
+        elif self.instruction['scaleType'] == 1:# saved region
+            region = self.instruction['region']
+            comment = "# g.region region=%s\n" % region
+        elif self.instruction['scaleType'] in (2, 3): #current region, fixed scale
+            comment = string.Template("# g.region n=$n s=$s e=$e w=$w rows=$rows cols=$cols \n").substitute(**region)
+        instr += comment
+        instr += '\n'
+        # maploc
+        maplocInstruction = "maploc %.3f %.3f" % (self.instruction['rect'].x, self.instruction['rect'].y)
+        if self.instruction['scaleType'] != 3:
+            maplocInstruction += "  %.3f %.3f"% (self.instruction['rect'].width, self.instruction['rect'].height)
+        instr += maplocInstruction
+        instr += '\n'
+        # scale
+        if self.instruction['scaleType'] == 3: #fixed scale
+            scaleInstruction = "scale 1:%.0f" % (1/self.instruction['scale'])
+            instr += scaleInstruction
+            instr += '\n'
+        # border
+        borderInstruction = ''
+        if self.instruction['border'] == 'n':
+            borderInstruction = "border n"
+        else:
+            borderInstruction = "border y\n"
+            borderInstruction += string.Template("    width $width\n    color $color\n").substitute(self.instruction)
+            borderInstruction += "    end"
+        instr += borderInstruction
+        instr += '\n'
+        return instr
+        """!Read instruction and save information"""
+        if 'isRegionComment' in kwargs:
+            isRegionComment = kwargs['isRegionComment']
+        instr = {}
+        if instruction == 'border':
+            for line in text:
+                if line.startswith('end'):
+                    break
+                try:
+                        instr['border'] = 'n'
+                        break
+                        instr['border'] = 'y'
+                    elif line.startswith('width'):
+                        instr['width'] = line.split()[1]
+                    elif line.startswith('color'):
+                        instr['color'] = line.split()[1]
+                except IndexError:
+                    GError(_("Failed to read instruction %s") % instruction)
+                    return False
+        elif instruction == 'scale':
+            try:
+                scaleText = text.strip('scale ').split(':')[1]
+                # when scale instruction given and region comment also, then scaletype is fixed scale
+                    instr['scaleType'] = 2
+                else:
+                    instr['scaleType'] = 3
+                scale = 1/float(scaleText)
+                if abs(scale - self.instruction['scale']) > (0.01 * scale):
+                    GWarning(_("Scale has changed, old value: %s\nnew value: %s") % (scale, self.instruction['scale']))
+            except (ValueError, IndexError):
+                GError(_("Failed to read instruction %s.\nUse 1:25000 notation.") % instruction)
+                return False
+        elif instruction == 'maploc':
+            maploc = text.strip('maploc ').split()
+            if len(maploc) >= 2:
+                if  abs(self.instruction['rect'].Get()[0] - float(maploc[0])) > 0.5 or \
+                    abs(self.instruction['rect'].Get()[1] - float(maploc[1])) > 0.5:
+                    GWarning(_("Map frame position changed, old value: %s %s\nnew value: %s %s") % \
+                        (maploc[0], maploc[1], self.instruction['rect'].Get()[0], self.instruction['rect'].Get()[1]))
+                #instr['rect'] = wx.Rect2D(float(maploc[0]), float(maploc[1]), self.instruction['rect'][2], self.instruction['rect'][3])
+            if len(maploc) == 4:
+                if  abs(self.instruction['rect'].Get()[2] - float(maploc[2])) > 0.5 or \
+                    abs(self.instruction['rect'].Get()[3] - float(maploc[3])) > 0.5:
+                    GWarning(_("Map frame size changed, old value: %s %s\nnew value: %s %s") %(
+                                            maploc[2], maploc[3], self.instruction['rect'].Get()[2], self.instruction['rect'].Get()[3]))
+                #instr['rect'] = wx.Rect2D(*map(float, maploc))
+        self.instruction.update(instr)
+        return True
+class PageSetup(InstructionObject):
+    """!Class representing page instruction"""
+        self.type = 'page'
+        # default values
+        self.defaultInstruction = dict(Units = 'inch', Format = 'a4', Orientation = 'Portrait',
+                                        Width = 8.268, Height = 11.693, Left = 0.5, Right = 0.5, Top = 1, Bottom = 1)
+        # current values
+        if self.instruction['Format'] == 'custom':
+            instr = string.Template("paper\n    width $Width\n    height $Height\n").substitute(self.instruction)
+        else:
+            instr = string.Template("paper $Format\n").substitute(self.instruction)
+        instr += string.Template("    left $Left\n    right $Right\n    bottom $Bottom\n    top $Top\n    end").substitute(self.instruction)
+        return instr
+    def Read(self, instruction, text):
+        instr = {}
+        self.cats = ['Width', 'Height', 'Left', 'Right', 'Top', 'Bottom']
+        self.subInstr = dict(zip(['width', 'height', 'left', 'right', 'top', 'bottom'], self.cats))
+        if instruction == 'paper': # just for sure
+            for line in text:
+                if line.startswith('paper'):
+                    if len(line.split()) > 1:
+                        pformat = line.split()[1]
+                        availableFormats = self._toDict(grass.read_command('ps.map', flags = 'p',
+        quiet = True))
+                        # e.g. paper a3
+                        try:
+                            instr['Format'] = pformat
+                            for key, value in availableFormats[pformat].iteritems():
+                                instr[key] = float(value)
+                            break
+                        except KeyError:
+                            GError(_("Failed to read instruction %s.\nUnknown format %s") % (instruction, format))
+                            return False
+                    else:
+                        # paper
+                        # width ...
+                        instr['Format'] = 'custom'
+                # read subinstructions
+                elif instr['Format'] == 'custom' and not line.startswith('end'):
+                    text = line.split()
+                    try:
+                        instr[self.subInstr[text[0]]] = float(text[1])
+                    except  (IndexError, KeyError):
+                        GError(_("Failed to read instruction %s.") % instruction)
+                        return False
+        return True
+    def _toDict(self, paperStr):
+        sizeDict = dict()
+#     cats = self.subInstr[ 'Width', 'Height', 'Left', 'Right', 'Top', 'Bottom']
+        for line in paperStr.strip().split('\n'):
+            d = dict(zip(self.cats, line.split()[1:]))
+            sizeDict[line.split()[0]] = d
+        return sizeDict
+class Mapinfo(InstructionObject):
+    """!Class representing mapinfo instruction"""
+        self.type = 'mapinfo'
+        # default values
+        self.defaultInstruction = dict( unit = 'inch', where = (0, 0),
+                                            font = 'Helvetica', fontsize = 10, color = 'black', background = 'none',
+                                            #font = 'Sans', fontsize = 10, color = '0:0:0', background = 'none',
+                                            border = 'none', rect = None)
+        # current values
+        instr = "mapinfo\n"
+        instr += "    where %.3f %.3f\n" % (self.instruction['where'][0], self.instruction['where'][1])
+        instr += string.Template("    font $font\n    fontsize $fontsize\n    color $color\n").substitute(self.instruction)
+        instr += string.Template("    background $background\n    border $border\n").substitute(self.instruction)
+        instr += "    end"
+        return instr
+        instr = {}
+        try:
+            for line in text:
+                sub = line.split(None,1)
+                if sub[0] == 'font':
+                    instr['font'] = sub[1]
+                elif sub[0] == 'fontsize':
+                    instr['fontsize'] = int(sub[1])
+                elif sub[0] == 'color':
+                    instr['color'] = sub[1]
+                elif sub[0] == 'background':
+                    instr['background'] = sub[1]
+                elif sub[0] == 'border':
+                    instr['border'] = sub[1]
+                elif sub[0] == 'where':
+                    instr['where'] = float(sub[1].split()[0]), float(sub[1].split()[1])
+            return False
+        self.instruction['rect'] = self.EstimateRect(mapinfoDict = self.instruction)
+        return True
+    def EstimateRect(self, mapinfoDict):
+        """!Estimate size to draw mapinfo"""
+        w = mapinfoDict['fontsize'] * 20 # any better estimation?
+        h = mapinfoDict['fontsize'] * 7
+        width = self.unitConv.convert(value = w, fromUnit = 'point', toUnit = 'inch')
+        height = self.unitConv.convert(value = h, fromUnit = 'point', toUnit = 'inch')
+        return wx.Rect2D(x = float(mapinfoDict['where'][0]), y = float(mapinfoDict['where'][1]), w = width, h = height)
+class Text(InstructionObject):
+    """!Class representing text instruction"""
+        self.type = 'text'
+        # default values
+        self.defaultInstruction = dict(text = "", font = "Helvetica", fontsize = 10, color = 'black', background = 'none',
+                                        hcolor = 'none', hwidth = 1, border = 'none', width = '1', XY = True,
+                                        where = (0,0), unit = 'inch', rotate = None,
+                                        ref = "center center", xoffset = 0, yoffset = 0, east = None, north = None)
+        # current values
+        text = self.instruction['text'].replace('\n','\\n')
+        instr = "text %s %s" % (self.instruction['east'], self.instruction['north'])
+        instr += " %s\n" % text
+        instr += string.Template("    hcolor $hcolor\n").substitute(self.instruction)
+        if self.instruction['hcolor'] != 'none':
+            instr += string.Template("    hwidth $hwidth\n").substitute(self.instruction)
+        instr += string.Template("    border $border\n").substitute(self.instruction)
+        if self.instruction['border'] != 'none':
+            instr += string.Template("    width $width\n").substitute(self.instruction)
+        instr += string.Template("    background $background\n").substitute(self.instruction)
+        if self.instruction["ref"] != '0':
+            instr += string.Template("    ref $ref\n").substitute(self.instruction)
+        if self.instruction["rotate"]:
+            instr += string.Template("    rotate $rotate\n").substitute(self.instruction)
+        if float(self.instruction["xoffset"]) or float(self.instruction["yoffset"]):
+            instr += string.Template("    xoffset $xoffset\n    yoffset $yoffset\n").substitute(self.instruction)
+        instr += "    end"
+        return instr
+        map = kwargs['mapInstruction']
+        instr = {}
+        for line in text:
+            try:
+                sub = line.split(None, 1)[0]
+                if sub == 'text':
+                    e, n = line.split(None, 3)[1:3]
+                    if '%' in e and '%' in n:
+                        instr['XY'] = True
+                        instr['east'], instr['north'] = self.PercentToReal(e, n)
+                    else:
+                        instr['XY'] = False
+                        instr['east'], instr['north'] = float(e), float(n)
+                    instr['text'] = line.split(None, 3)[3]
+                elif sub == 'font':
+                    instr['font'] = line.split(None, 1)[1]
+                elif sub == 'fontsize':
+                    instr['fontsize'] = float(line.split(None, 1)[1])
+                elif sub == 'color':
+                    instr['color'] = line.split(None, 1)[1]
+                elif sub == 'width':
+                    instr['width'] = line.split(None, 1)[1]
+                elif sub == 'hcolor':
+                    instr['hcolor'] = line.split(None, 1)[1]
+                elif sub == 'hwidth':
+                    instr['hwidth'] = line.split(None, 1)[1]
+                elif sub == 'background':
+                    instr['background'] = line.split(None, 1)[1]
+                elif sub == 'border':
+                    instr['border'] = line.split(None, 1)[1]
+                elif sub == 'ref':
+                    instr['ref'] = line.split(None, 1)[1]
+                elif sub == 'rotate':
+                    instr['rotate'] = float(line.split(None, 1)[1])
+                elif sub == 'xoffset':
+                    instr['xoffset'] = int(line.split(None, 1)[1])
+                elif sub == 'yoffset':
+                    instr['yoffset'] = int(line.split(None, 1)[1])
+                elif sub == 'opaque':
+                    if line.split(None, 1)[1].lower() in ('n', 'none'):
+                        instr['background'] = 'none'
+            except(IndexError, ValueError):
+                return False
+        instr['where'] = PaperMapCoordinates(map = map, x = instr['east'], y = instr['north'], paperToMap = False)
+        return True
+    def PercentToReal(self, e, n):
+        """!Converts text coordinates from percent of region to map coordinates"""
+        e, n = float(e.strip('%')), float(n.strip('%'))
+        N = region['s'] + (region['n'] - region['s']) / 100 * n
+        E = region['w'] + (region['e'] - region['w']) / 100 * e
+        return E, N
+class Scalebar(InstructionObject):
+    """!Class representing scalebar instruction"""
+        self.type = 'scalebar'
+        # default values
+        self.defaultInstruction = dict( unit = 'inch', where = (1,1),
+                                            unitsLength = 'auto', unitsHeight = 'inch',
+                                            length = None, height = 0.1, rect = None,
+                                            fontsize = 10, background = 'y',
+                                            scalebar = 'f', segment = 4, numbers = 1)
+        # current values
+        instr = string.Template("scalebar $scalebar\n").substitute(self.instruction)
+        instr += string.Template("    length $length\n    units $unitsLength\n").substitute(self.instruction)
+        instr += string.Template("    height $height\n").substitute(self.instruction)
+        instr += string.Template("    segment $segment\n    numbers $numbers\n").substitute(self.instruction)
+        instr += string.Template("    fontsize $fontsize\n    background $background\n").substitute(self.instruction)
+        instr += "    end"
+        return instr
+        scale = kwargs['scale']
+        instr = {}
+        for line in text:
+            try:
+                if line.startswith('scalebar'):
+                    if 'scalebar s' in line:
+                        instr['scalebar'] = 's'
+                    else:
+                        instr['scalebar'] = 'f'
+                elif line.startswith('where'):
+                    instr['where'] = map(float, line.split()[1:3])
+                elif line.startswith('length'):
+                    instr['length'] = float(line.split()[1])
+                elif line.startswith('units'):
+                    if line.split()[1] in ['auto', 'meters', 'kilometers', 'feet', 'miles', 'nautmiles']:
+                        instr['unitsLength'] = line.split()[1]
+                elif line.startswith('height'):
+                    instr['height'] = float(line.split()[1])
+                elif line.startswith('fontsize'):
+                    instr['fontsize'] = float(line.split()[1])
+                elif line.startswith('numbers'):
+                    instr['numbers'] = int(line.split()[1])
+                elif line.startswith('segment'):
+                    instr['segment'] = int(line.split()[1])
+                elif line.startswith('background'):
+                    if line.split()[1].strip().lower() in ('y','yes'):
+                        instr['background'] = 'y'
+                    elif line.split()[1].strip().lower() in ('n','no', 'none'):
+                        instr['background'] = 'n'
+                return False
+        w, h = self.EstimateSize(scalebarDict = self.instruction, scale = scale)
+        x = self.instruction['where'][0] - w / 2
+        y = self.instruction['where'][1] - h / 2
+        self.instruction['rect'] = wx.Rect2D(x, y, w, h)
+        return True
+    def EstimateSize(self, scalebarDict, scale):
+        """!Estimate size to draw scalebar"""
+        units = projInfo()['units']
+        if not units or units not in self.unitConv.getAllUnits():
+            units = 'meters'
+        if scalebarDict['unitsLength'] != 'auto':
+            length = self.unitConv.convert(value = scalebarDict['length'], fromUnit = scalebarDict['unitsLength'], toUnit = 'inch')
+        else:
+            length = self.unitConv.convert(value = scalebarDict['length'], fromUnit = units, toUnit = 'inch')
+        length *= scale
+        length *= 1.1 #for numbers on the edge
+        height = scalebarDict['height'] + 2 * self.unitConv.convert(value = scalebarDict['fontsize'], fromUnit = 'point', toUnit = 'inch')
+        return (length, height)
+class RasterLegend(InstructionObject):
+    """!Class representing colortable instruction"""
+        self.type = 'rasterLegend'
+        # default values
+        self.defaultInstruction = dict(rLegend = False, unit = 'inch', rasterDefault = True, raster = None,
+                                                discrete = None, type = None,
+                                                where = (0, 0),
+                                                width = None, height = None, cols = 1, font = "Helvetica", fontsize = 10,
+                                                #color = '0:0:0', tickbar = False, range = False, min = 0, max = 0,
+                                                color = 'black', tickbar = 'n', range = False, min = 0, max = 0,
+                                                nodata = 'n')
+        # current values
+        instr = "colortable y\n"
+        instr += string.Template("    raster $raster\n").substitute(self.instruction)
+        if self.instruction['width']:
+        instr += string.Template("    discrete $discrete\n").substitute(self.instruction)
+        if self.instruction['discrete'] == 'n':
+            if self.instruction['height']:
+            instr += string.Template("    tickbar $tickbar\n").substitute(self.instruction)
+            if self.instruction['range']:
+                instr += string.Template("    range $min $max\n").substitute(self.instruction)
+        else:
+            instr += string.Template("    cols $cols\n").substitute(self.instruction)
+            instr += string.Template("    nodata $nodata\n").substitute(self.instruction)
+        instr += string.Template("    font $font\n    fontsize $fontsize\n    color $color\n")\
+                                .substitute(self.instruction)
+        instr += "    end"
+        return instr
+        instr = {}
+        instr['rLegend'] = True
+        for line in text:
+            try:
+                if line.startswith('where'):
+                elif line.startswith('font '):
+                    instr['font'] = line.split()[1]
+                elif line.startswith('color '):
+                    instr['raster'] = line.split()[1]
+                    instr['width'] = float(line.split()[1])
+                elif line.startswith('cols'):
+                    instr['cols'] = int(line.split()[1])
+                elif line.startswith('range'):
+                    instr['range'] = True
+                    instr['min'] = float(line.split()[1])
+                    instr['max'] = float(line.split()[2])
+                elif line.startswith('nodata'):
+                        instr['nodata'] = 'y'
+                        instr['nodata'] = 'n'
+                elif line.startswith('tickbar'):
+                        instr['tickbar'] = 'y'
+                        instr['tickbar'] = 'n'
+                elif line.startswith('discrete'):
+                        instr['discrete'] = 'y'
+                        instr['discrete'] = 'n'
+                return False
+        if 'raster' in instr:
+            instr['rasterDefault'] = False
+            if 'discrete' not in instr:
+                rasterType = getRasterType(map = instr['raster'])
+                instr['type'] = rasterType
+                else:
+        else:
+            instr['rasterDefault'] = True
+        # add 'rect' in the end
+        return True
+    def EstimateHeight(self, raster, discrete, fontsize, cols = None,  height = None):
+        """!Estimate height to draw raster legend"""
+        if discrete == 'n':
+            if height:
+                height = height
+            else:
+                height = self.unitConv.convert(value = fontsize * 10,
+                                                    fromUnit = 'point', toUnit = 'inch')
+        if discrete == 'y':
+            if cols:
+                cols = cols
+            else:
+                cols = 1
+            rinfo = grass.raster_info(raster)
+            if rinfo['datatype'] in ('DCELL', 'FCELL'):
+                minim, maxim = rinfo['min'], rinfo['max']
+                rows = ceil( maxim / cols )
+            else:
+                cat = grass.read_command('r.category', map = raster,
+                                    fs = ':').strip().split('\n')
+                rows = ceil( float(len(cat)) / cols )
+            height = self.unitConv.convert(value =  1.5 * rows * fontsize, fromUnit = 'point', toUnit = 'inch')
+        return height
+    def EstimateWidth(self, raster, discrete, fontsize, cols = None, width = None, paperInstr = None):
+        """!Estimate size to draw raster legend"""
+            if width:
+                width = width
+            else:
+                width = self.unitConv.convert(value = fontsize * 2,
+            text = len(max(str(minim), str(maxim), key = len))
+            textPart = self.unitConv.convert(value = text * fontsize / 2,
+            width += textPart
+        elif discrete == 'y':
+            if cols:
+                cols = cols
+            else:
+                cols = 1
+            if width:
+                width = width
+            else:
+                paperWidth = paperInstr['Width'] - paperInstr['Right'] - paperInstr['Left']
+                width = (paperWidth / cols) * (cols - 1) + 1
+        return width
+class VectorLegend(InstructionObject):
+        self.type = 'vectorLegend'
+        # default values
+        self.defaultInstruction = dict(vLegend = False, unit = 'inch', where = (0, 0),
+                                                defaultSize = True, width = 0.4, cols = 1, span = None,
+                                                font = "Helvetica", fontsize = 10,
+                                                border = 'none')
+        # current values
+        instr = "vlegend\n"
+        instr += string.Template("    font $font\n    fontsize $fontsize\n").substitute(self.instruction)
+        instr += string.Template("    width $width\n    cols $cols\n").substitute(self.instruction)
+        if self.instruction['span']:
+            instr += string.Template("    span $span\n").substitute(self.instruction)
+        instr += "    end"
+        return instr
+        instr = {}
+        instr['vLegend'] = True
+        for line in text:
+            try:
+                elif line.startswith('span'):
+                    instr['span'] = float(line.split()[1])
+                    instr['border'] = line.split()[1]
+                return False
+        return True
+    def EstimateSize(self, vectorInstr, fontsize, width = None, cols = None):
+        """!Estimate size to draw vector legend"""
+        if width:
+            width = width
+        else:
+            width = fontsize/24.0
+        if cols:
+            cols = cols
+        else:
+            cols = 1
+        vectors = vectorInstr['list']
+        labels = [vector[4] for vector in vectors if vector[3] != 0]
+        extent = (len(max(labels, key = len)) * fontsize / 2, fontsize)
+        wExtent = self.unitConv.convert(value = extent[0], fromUnit = 'point', toUnit = 'inch')
+        hExtent = self.unitConv.convert(value = extent[1], fromUnit = 'point', toUnit = 'inch')
+        w = (width + wExtent) * cols
+        h = len(labels) * hExtent / cols
+        h *= 1.1
+        return (w, h)
+class Raster(InstructionObject):
+    """!Class representing raster instruction"""
+        self.type = 'raster'
+        # default values
+        self.defaultInstruction = dict(isRaster = False, raster = None)
+        # current values
+        instr = string.Template("raster $raster").substitute(self.instruction)
+        return instr
+        instr = {}
+        instr['isRaster'] = True
+        try:
+            map = text.split()[1]
+            return False
+        try:
+            info = grass.find_file(map, element = 'cell')
+            GError(message = e.value)
+            return False
+        instr['raster'] = info['fullname']
+        return True
+class Vector(InstructionObject):
+    """!Class keeps vector layers"""
+        self.type = 'vector'
+        # default values
+        self.defaultInstruction = dict(list = None)# [vmap, type, id, lpos, label]
+        # current values
+        return ''
+        instr = {}
+        for line in text:
+            if line.startswith('vpoints') or line.startswith('vlines') or line.startswith('vareas'):
+                # subtype
+                if line.startswith('vpoints'):
+                    subType = 'points'
+                    subType = 'lines'
+                    subType = 'areas'
+                # name of vector map
+                vmap = line.split()[1]
+                try:
+                    info = grass.find_file(vmap, element = 'vector')
+                    return False
+                vmap = info['fullname']
+                # id
+                id = kwargs['id']
+                # lpos
+                lpos = kwargs['vectorMapNumber']
+                #label
+                label = '('.join(vmap.split('@')) + ')'
+                break
+        instr = [vmap, subType, id, lpos, label]
+        if not self.instruction['list']:
+            self.instruction['list'] = []
+        self.instruction['list'].append(instr)
+        return True
+class VProperties(InstructionObject):
+    """!Class represents instructions vareas, vlines, vpoints"""
+    def __init__(self, id, subType):
+        self.type = 'vProperties'
+        self.subType = subType
+        # default values
+        if self.subType == 'points':
+            dd = dict(subType  = 'points', name = None, type = 'point or centroid', connection = False, layer = '1',
+                        masked = 'n', color = '0:0:0', width = 1,
+                        fcolor = '255:0:0', rgbcolumn = None, symbol = os.path.join('basic', 'x'), eps = None,
+                        size = 5, sizecolumn = None, scale = None,
+                        rotation = False, rotate = 0, rotatecolumn = None, label = None, lpos = None)
+        elif self.subType == 'lines':
+            dd = dict(subType = 'lines', name = None, type = 'line or boundary', connection = False, layer = '1',
+                        masked = 'n', color = '0:0:0', hwidth = 1,
+                        hcolor = 'none', rgbcolumn = None,
+                        width = 1, cwidth = None,
+                        style = 'solid', linecap = 'butt', label = None, lpos = None)
+        else: # areas
+            dd = dict(subType = 'areas', name = None, connection = False, layer = '1',
+                        fcolor = 'none', rgbcolumn = None,
+                        pat = None, pwidth = 1, scale = 1, label = None, lpos = None)
+        self.defaultInstruction = dd
+        # current values
+        dic = self.instruction
+        vInstruction = string.Template("v$subType $name\n").substitute(dic)
+        #data selection
+        if self.subType in ('points', 'lines'):
+           vInstruction += string.Template("    type $type\n").substitute(dic)
+        if dic['connection']:
+            vInstruction += string.Template("    layer $layer\n").substitute(dic)
+            if dic.has_key('cats'):
+                vInstruction += string.Template("    cats $cats\n").substitute(dic)
+            elif dic.has_key('where'):
+                    vInstruction += string.Template("    where $where\n").substitute(dic)
+        vInstruction += string.Template("    masked $masked\n").substitute(dic)
+        #colors
+        vInstruction += string.Template("    color $color\n").substitute(dic)
+        if self.subType in ('points', 'areas'):
+            if dic['color'] != 'none':
+                vInstruction += string.Template("    width $width\n").substitute(dic)
+            if dic['rgbcolumn']:
+                vInstruction += string.Template("    rgbcolumn $rgbcolumn\n").substitute(dic)
+            vInstruction += string.Template("    fcolor $fcolor\n").substitute(dic)
+        else:
+            elif dic['hcolor'] != 'none':
+                vInstruction += string.Template("    hwidth $hwidth\n").substitute(dic)
+                vInstruction += string.Template("    hcolor $hcolor\n").substitute(dic)
+        # size and style
+            if dic['symbol']:
+                vInstruction += string.Template("    symbol $symbol\n").substitute(dic)
+            else: #eps
+                vInstruction += string.Template("    eps $eps\n").substitute(dic)
+            if dic['size']:
+                vInstruction += string.Template("    size $size\n").substitute(dic)
+            else: # sizecolumn
+                vInstruction += string.Template("    sizecolumn $sizecolumn\n").substitute(dic)
+                vInstruction += string.Template("    scale $scale\n").substitute(dic)
+            if dic['rotation']:
+                if dic['rotate'] is not None:
+                    vInstruction += string.Template("    rotate $rotate\n").substitute(dic)
+                else:
+                    vInstruction += string.Template("    rotatecolumn $rotatecolumn\n").substitute(dic)
+        if self.subType == 'areas':
+            if dic['pat'] is not None:
+                vInstruction += string.Template("    pat $pat\n").substitute(dic)
+                vInstruction += string.Template("    pwidth $pwidth\n").substitute(dic)
+        if self.subType == 'lines':
+            if dic['width'] is not None:
+            else:
+                vInstruction += string.Template("    cwidth $cwidth\n").substitute(dic)
+            vInstruction += string.Template("    style $style\n").substitute(dic)
+            vInstruction += string.Template("    linecap $linecap\n").substitute(dic)
+        #position and label in vlegend
+        vInstruction += string.Template("    label $label\n    lpos $lpos\n").substitute(dic)
+        vInstruction += "    end"
+        return vInstruction
+        instr = {}
+        try:
+            info = grass.find_file(name = text[0].split()[1], element = 'vector')
+            return False
+        instr['name'] = info['fullname']
+        #connection
+        instr['connection'] = True
+        self.mapDBInfo = dbm_base.VectorDBInfo(instr['name'])
+        self.layers = self.mapDBInfo.layers.keys()
+        if not self.layers:
+            instr['connection'] = False
+        # points
+        if text[0].startswith('vpoints'):
+            for line in text[1:]:
+                if line.startswith('type'):
+                    tp = []
+                    if line.find('point') != -1:
+                        tp.append('point')
+                    if line.find('centroid') != -1:
+                        tp.append('centroid')
+                    instr['type'] = ' or '.join(tp)
+                elif line.startswith('fcolor'):
+                    instr['fcolor'] = line.split()[1]
+                elif line.startswith('rgbcolumn'):
+                    instr['rgbcolumn'] = line.split()[1]
+                elif line.startswith('symbol'):
+                    instr['symbol'] = line.split()[1]
+                elif line.startswith('eps'):
+                    instr['eps'] = line.split()[1]
+                elif line.startswith('size '):
+                    instr['size'] = line.split()[1]
+                elif line.startswith('sizecolumn'):
+                    instr['size'] = None
+                    instr['sizecolumn'] = line.split()[1]
+                    instr['scale'] = float(line.split()[1])
+                elif line.startswith('rotate '):
+                    instr['rotation'] = True
+                    instr['rotate'] = line.split()[1]
+                elif line.startswith('rotatecolumn'):
+                    instr['rotatecolumn'] = line.split()[1]
+                    instr['rotate'] = None
+        # lines
+        elif text[0].startswith('vlines'):
+                    tp = []
+                    if line.find('line') != -1:
+                        tp.append('line')
+                    if line.find('boundary') != -1:
+                        tp.append('boundary')
+                elif line.startswith('hwidth'):
+                    instr['hwidth'] = float(line.split()[1])
+                elif line.startswith('hcolor'):
+                    instr['hcolor'] = line.split()[1]
+                elif line.startswith('cwidth'):
+                    instr['cwidth'] = float(line.split()[1])
+                    instr['width'] = None
+                elif line.startswith('style'):
+                    instr['style'] = line.split()[1]
+                elif line.startswith('linecap'):
+                    instr['linecap'] = line.split()[1]
+        elif text[0].startswith('vareas'):
+                if line.startswith('fcolor'):
+                elif line.startswith('pat'):
+                    instr['pat'] = line.split()[1]
+                elif line.startswith('pwidth'):
+                    instr['pwidth'] = float(line.split()[1])
+                elif line.startswith('scale'):
+        # same properties for all
+            if line.startswith('lpos'):
+                instr['lpos'] = int(line.split()[1])
+            elif line.startswith('label'):
+                instr['label'] = line.split(None, 1)[1]
+            elif line.startswith('layer'):
+                instr['layer'] = line.split()[1]
+            elif line.startswith('masked'):
+                if line.split()[1].lower() in ('y', 'yes'):
+                    instr['masked'] = 'y'
+                else:
+                    instr['masked'] = 'n'
+        if 'label' not in instr:
+            instr['label'] = '('.join(instr['name'].split('@')) + ')'
+        if 'lpos' not in instr:
+            instr['lpos'] = kwargs['vectorMapNumber']
+        return True
+class PsmapDialog(wx.Dialog):
+    def __init__(self, parent, id,  title, settings, apply = True):
+        wx.Dialog.__init__(self, parent = parent, id = wx.ID_ANY,
+                            title = title, size = wx.DefaultSize,
+                            style = wx.CAPTION|wx.MINIMIZE_BOX|wx.CLOSE_BOX)
+        self.apply = apply
+        self.id = id
+        self.parent = parent
+        self.instruction = settings
+        self.objectType = None
+        self.unitConv = UnitConversion(self)
+        self.spinCtrlSize = (50, -1)
+        self.Bind(wx.EVT_CLOSE, self.OnClose)
+    def AddUnits(self, parent, dialogDict):
+        parent.units = dict()
+        parent.units['unitsLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Units:"))
+        choices = self.unitConv.getPageUnits()
+        parent.units['unitsCtrl'] = wx.Choice(parent, id = wx.ID_ANY, choices = choices)
+        parent.units['unitsCtrl'].SetStringSelection(dialogDict['unit'])
+    def AddPosition(self, parent, dialogDict):
+        parent.position = dict()
+        parent.position['comment'] = wx.StaticText(parent, id = wx.ID_ANY,\
+                    label = _("Position of the top left corner\nfrom the top left edge of the paper"))
+        parent.position['xLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("X:"))
+        parent.position['yLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Y:"))
+        parent.position['xCtrl'] = wx.TextCtrl(parent, id = wx.ID_ANY, value = str(dialogDict['where'][0]), validator = TCValidator(flag = 'DIGIT_ONLY'))
+        parent.position['yCtrl'] = wx.TextCtrl(parent, id = wx.ID_ANY, value = str(dialogDict['where'][1]), validator = TCValidator(flag = 'DIGIT_ONLY'))
+        if dialogDict.has_key('unit'):
+            x = self.unitConv.convert(value = dialogDict['where'][0], fromUnit = 'inch', toUnit = dialogDict['unit'])
+            y = self.unitConv.convert(value = dialogDict['where'][1], fromUnit = 'inch', toUnit = dialogDict['unit'])
+            parent.position['xCtrl'].SetValue("%5.3f" % x)
+            parent.position['yCtrl'].SetValue("%5.3f" % y)
+    def AddFont(self, parent, dialogDict, color = True):
+        parent.font = dict()
+##        parent.font['fontLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Choose font:"))
+##        parent.font['fontCtrl'] = wx.FontPickerCtrl(parent, id = wx.ID_ANY)
+##        parent.font['fontCtrl'].SetSelectedFont(
+##                        wx.FontFromNativeInfoString(dialogDict['font'] + " " + str(dialogDict['fontsize'])))
+##        parent.font['fontCtrl'].SetMaxPointSize(50)
+##        if color:
+##            parent.font['colorLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Choose color:"))
+##            parent.font['colorCtrl'] = wx.ColourPickerCtrl(parent, id = wx.ID_ANY, style=wx.FNTP_FONTDESC_AS_LABEL)
+##            parent.font['colorCtrl'].SetColour(dialogDict['color'])
+##        parent.font['colorCtrl'].SetColour(convertRGB(dialogDict['color']))
+        parent.font['fontLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Font:"))
+        parent.font['fontSizeLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Font size:"))
+        fontChoices = [ 'Times-Roman', 'Times-Italic', 'Times-Bold', 'Times-BoldItalic', 'Helvetica',\
+                        'Helvetica-Oblique', 'Helvetica-Bold', 'Helvetica-BoldOblique', 'Courier',\
+                        'Courier-Oblique', 'Courier-Bold', 'Courier-BoldOblique']
+        parent.font['fontCtrl'] = wx.Choice(parent, id = wx.ID_ANY, choices = fontChoices)
+        if dialogDict['font'] in fontChoices:
+            parent.font['fontCtrl'].SetStringSelection(dialogDict['font'])
+        else:
+            parent.font['fontCtrl'].SetStringSelection('Helvetica')
+        parent.font['fontSizeCtrl'] = wx.SpinCtrl(parent, id = wx.ID_ANY, min = 4, max = 50, initial = 10)
+        parent.font['fontSizeCtrl'].SetValue(dialogDict['fontsize'])
+        if color:
+            parent.font['colorLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Choose color:"))
+            parent.font['colorCtrl'] = wx.ColourPickerCtrl(parent, id = wx.ID_ANY)
+            parent.font['colorCtrl'].SetColour(convertRGB(dialogDict['color']))
+##            parent.font['colorLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Color:"))
+##            colorChoices = [  'aqua', 'black', 'blue', 'brown', 'cyan', 'gray', 'green', 'indigo', 'magenta',\
+##                                'orange', 'purple', 'red', 'violet', 'white', 'yellow']
+##            parent.colorCtrl = wx.Choice(parent, id = wx.ID_ANY, choices = colorChoices)
+##            parent.colorCtrl.SetStringSelection(parent.rLegendDict['color'])
+##            parent.font['colorCtrl'] = wx.ColourPickerCtrl(parent, id = wx.ID_ANY)
+    def OnApply(self, event):
+        ok = self.update()
+        if ok:
+            self.parent.DialogDataChanged(id = self.id)
+            return True
+        else:
+            return False
+    def OnOK(self, event):
+        """!Apply changes, close dialog"""
+        ok = self.OnApply(event)
+        if ok:
+            self.Close()
+    def OnCancel(self, event):
+        """!Close dialog"""
+        self.Close()
+    def OnClose(self, event):
+        """!Destroy dialog and delete it from open dialogs"""
+        if self.objectType:
+            for each in  self.objectType:
+                if each in self.parent.openDialogs:
+                    del self.parent.openDialogs[each]
+        event.Skip()
+        self.Destroy()
+    def _layout(self, panel):
+        #buttons
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnOK = wx.Button(self, wx.ID_OK)
+        btnOK.SetDefault()
+        if self.apply:
+            btnApply = wx.Button(self, wx.ID_APPLY)
+        # bindigs
+        btnOK.Bind(wx.EVT_BUTTON, self.OnOK)
+        btnOK.SetToolTipString(_("Close dialog and apply changes"))
+        #btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        if self.apply:
+            btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+            btnApply.SetToolTipString(_("Apply changes"))
+        # sizers
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(btnCancel)
+        if self.apply:
+            btnSizer.AddButton(btnApply)
+        btnSizer.AddButton(btnOK)
+        btnSizer.Realize()
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        mainSizer.Add(item = panel, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
+        mainSizer.Add(item = btnSizer, proportion = 0,
+                      flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
+        self.SetSizer(mainSizer)
+        mainSizer.Layout()
+        mainSizer.Fit(self)
+class PageSetupDialog(PsmapDialog):
+    def __init__(self, parent, id, settings):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "Page setup",  settings = settings)
+        self.cat = ['Units', 'Format', 'Orientation', 'Width', 'Height', 'Left', 'Right', 'Top', 'Bottom']
+        paperString = RunCommand('ps.map', flags = 'p', read = True, quiet = True)
+        self.paperTable = self._toList(paperString)
+        self.unitsList = self.unitConv.getPageUnits()
+        self.pageSetupDict = settings[id].GetInstruction()
+        self._layout()
+        if self.pageSetupDict:
+            for item in self.cat[:3]:
+                self.getCtrl(item).SetSelection(self.getCtrl(item).FindString(self.pageSetupDict[item]))
+            for item in self.cat[3:]:
+                self.getCtrl(item).SetValue("%4.3f" % self.pageSetupDict[item])
+        if self.getCtrl('Format').GetString(self.getCtrl('Format').GetSelection()) != 'custom':
+            self.getCtrl('Width').Disable()
+            self.getCtrl('Height').Disable()
+        else:
+            self.getCtrl('Orientation').Disable()
+        # events
+        self.getCtrl('Units').Bind(wx.EVT_CHOICE, self.OnChoice)
+        self.getCtrl('Format').Bind(wx.EVT_CHOICE, self.OnChoice)
+        self.getCtrl('Orientation').Bind(wx.EVT_CHOICE, self.OnChoice)
+        self.btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
+    def update(self):
+        self.pageSetupDict['Units'] = self.getCtrl('Units').GetString(self.getCtrl('Units').GetSelection())
+        self.pageSetupDict['Format'] = self.paperTable[self.getCtrl('Format').GetSelection()]['Format']
+        self.pageSetupDict['Orientation'] = self.getCtrl('Orientation').GetString(self.getCtrl('Orientation').GetSelection())
+            self.pageSetupDict[item] = self.unitConv.convert(value = float(self.getCtrl(item).GetValue()),
+                                        fromUnit = self.pageSetupDict['Units'], toUnit = 'inch')
+        try:
+            self.update()
+        except ValueError:
+                wx.MessageBox(message = _("Literal is not allowed!"), caption = _('Invalid input'),
+                                    style = wx.OK|wx.ICON_ERROR)
+        else:
+            event.Skip()
+    def _layout(self):
+        size = (110,-1)
+        #sizers
+        pageBox = wx.StaticBox(self, id = wx.ID_ANY, label ="  Page size ")
+        pageSizer = wx.StaticBoxSizer(pageBox, wx.VERTICAL)
+        marginBox = wx.StaticBox(self, id = wx.ID_ANY, label = " Margins ")
+        marginSizer = wx.StaticBoxSizer(marginBox, wx.VERTICAL)
+        horSizer = wx.BoxSizer(wx.HORIZONTAL)
+        #staticText + choice
+        choices = [self.unitsList, [item['Format'] for item in self.paperTable], ['Portrait', 'Landscape']]
+        propor = [0,1,1]
+        border = [5,3,3]
+        self.hBoxDict={}
+        for i, item in enumerate(self.cat[:3]):
+            hBox = wx.BoxSizer(wx.HORIZONTAL)
+            stText = wx.StaticText(self, id = wx.ID_ANY, label = item + ':')
+            choice = wx.Choice(self, id = wx.ID_ANY, choices = choices[i], size = size)
+            hBox.Add(stText, proportion = propor[i], flag = wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = border[i])
+            hBox.Add(choice, proportion = 0, flag = wx.ALL, border = border[i])
+            if item == 'Units':
+                hBox.Add(size,1)
+            self.hBoxDict[item] = hBox
+        #staticText + TextCtrl
+            label = wx.StaticText(self, id = wx.ID_ANY, label = item + ':')
+            textctrl = wx.TextCtrl(self, id = wx.ID_ANY, size = size, value = '')
+            hBox.Add(label, proportion = 1, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = 3)
+            hBox.Add(textctrl, proportion = 0, flag = wx.ALIGN_CENTRE|wx.ALL, border = 3)
+        sizer = list([mainSizer] + [pageSizer]*4 + [marginSizer]*4)
+        for i, item in enumerate(self.cat):
+                sizer[i].Add(self.hBoxDict[item], 0, wx.GROW|wx.RIGHT|wx.LEFT,5)
+        # OK button
+        self.btnOk = wx.Button(self, wx.ID_OK)
+        self.btnOk.SetDefault()
+        btnSizer.AddButton(self.btnOk)
+        btn = wx.Button(self, wx.ID_CANCEL)
+        btnSizer.AddButton(btn)
+        horSizer.Add(pageSizer, proportion = 0, flag = wx.LEFT|wx.RIGHT|wx.BOTTOM, border = 10)
+        horSizer.Add(marginSizer, proportion = 0, flag = wx.LEFT|wx.RIGHT|wx.BOTTOM|wx.EXPAND, border = 10)
+        mainSizer.Add(horSizer, proportion = 0, border = 10)
+        mainSizer.Add(btnSizer, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT|wx.ALL,  border = 10)
+    def OnChoice(self, event):
+        currPaper = self.paperTable[self.getCtrl('Format').GetSelection()]
+        currUnit = self.getCtrl('Units').GetString(self.getCtrl('Units').GetSelection())
+        currOrient = self.getCtrl('Orientation').GetString(self.getCtrl('Orientation').GetSelection())
+        newSize = dict()
+            newSize[item] = self.unitConv.convert(float(currPaper[item]), fromUnit = 'inch', toUnit = currUnit)
+        enable = True
+        if currPaper['Format'] != 'custom':
+            if currOrient == 'Landscape':
+                newSize['Width'], newSize['Height'] = newSize['Height'], newSize['Width']
+                self.getCtrl(item).ChangeValue("%4.3f" % newSize[item])
+            enable = False
+        self.getCtrl('Width').Enable(enable)
+        self.getCtrl('Height').Enable(enable)
+        self.getCtrl('Orientation').Enable(not enable)
+    def getCtrl(self, item):
+         return self.hBoxDict[item].GetItem(1).GetWindow()
+    def _toList(self, paperStr):
+        sizeList = list()
+            d = dict(zip([self.cat[1]]+ self.cat[3:],line.split()))
+            sizeList.append(d)
+        d = {}.fromkeys([self.cat[1]]+ self.cat[3:], 100)
+        d.update(Format = 'custom')
+        return sizeList
+class MapDialog(PsmapDialog):
+    """!Dialog for map frame settings and optionally  raster and vector map selection"""
+    def __init__(self, parent, id, settings,  rect = None, notebook = False):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "", settings = settings)
+        self.isNotebook = notebook
+        if self.isNotebook:
+            self.objectType = ('mapNotebook',)
+        else:
+            self.objectType = ('map',)
+        #notebook
+            self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
+            self.mPanel = MapFramePanel(parent = self.notebook, id = self.id[0], settings = self.instruction,
+                                        rect = rect, notebook = True)
+            self.id[0] = self.mPanel.getId()
+            self.rPanel = RasterPanel(parent = self.notebook, id = self.id[1], settings = self.instruction,
+                                        notebook = True)
+            self.id[1] = self.rPanel.getId()
+            self.vPanel = VectorPanel(parent = self.notebook, id = self.id[2], settings = self.instruction,
+                                        notebook = True)
+            self.id[2] = self.vPanel.getId()
+            self._layout(self.notebook)
+            self.SetTitle(_("Map settings"))
+        else:
+            self.mPanel = MapFramePanel(parent = self, id = self.id[0], settings = self.instruction,
+                                        rect = rect, notebook = False)
+            self._layout(self.mPanel)
+            self.SetTitle(_("Map frame settings"))
+        """!Apply changes"""
+            okV = self.vPanel.update()
+            okR = self.rPanel.update()
+            if okV and self.id[2] in self.instruction:
+                self.parent.DialogDataChanged(id = self.id[2])
+            if okR and self.id[1] in self.instruction:
+                self.parent.DialogDataChanged(id = self.id[1])
+            if not okR or not okV:
+                return False
+        ok = self.mPanel.update()
+        if ok:
+            self.parent.DialogDataChanged(id = self.id[0])
+            return True
+        return False
+        """!Close dialog and remove tmp red box"""
+        self.parent.canvas.pdcTmp.RemoveId(self.parent.canvas.idZoomBoxTmp)
+        self.parent.canvas.Refresh()
+        self.Close()
+    def updateDialog(self):
+        """!Update raster and vector information"""
+        if self.mPanel.scaleChoice.GetSelection() == 0:
+            if self.mPanel.rasterTypeRadio.GetValue():
+                if 'raster' in self.parent.openDialogs:
+                    if self.parent.openDialogs['raster'].rPanel.rasterYesRadio.GetValue() and \
+                            self.parent.openDialogs['raster'].rPanel.rasterSelect.GetValue() == self.mPanel.select.GetValue():
+                            self.mPanel.drawMap.SetValue(True)
+                    else:
+                        self.mPanel.drawMap.SetValue(False)
+            else:
+                if 'vector' in self.parent.openDialogs:
+                    found = False
+                    for each in self.parent.openDialogs['vector'].vPanel.vectorList:
+                        if each[0] == self.mPanel.select.GetValue():
+                            found = True
+                    self.mPanel.drawMap.SetValue(found)
+class MapFramePanel(wx.Panel):
+    """!wx.Panel with map (scale, region, border) settings"""
+    def __init__(self, parent, id, settings, rect, notebook = True):
+        wx.Panel.__init__(self, parent, id = wx.ID_ANY, style = wx.TAB_TRAVERSAL)
+        self.id = id
+        if notebook:
+            self.book = parent
+            self.book.AddPage(page = self, text = _("Map frame"))
+            self.mapDialog = self.book.GetParent()
+        else:
+            self.mapDialog = parent
+        if self.id is not None:
+            self.mapFrameDict = self.instruction[self.id].GetInstruction()
+        else:
+            self.id = wx.NewId()
+            mapFrame = MapFrame(self.id)
+            self.mapFrameDict = mapFrame.GetInstruction()
+            self.mapFrameDict['rect'] = rect
+        self._layout()
+        self.scale = [None]*4
+        self.center = [None]*4
+        self.selectedMap = self.mapFrameDict['map']
+        self.selectedRegion = self.mapFrameDict['region']
+        self.scaleType = self.mapFrameDict['scaleType']
+        self.mapType = self.mapFrameDict['mapType']
+        self.scaleChoice.SetSelection(self.mapFrameDict['scaleType'])
+        if self.instruction[self.id]:
+            self.drawMap.SetValue(self.mapFrameDict['drawMap'])
+        else:
+            self.drawMap.SetValue(True)
+        if self.mapFrameDict['scaleType'] == 0 and self.mapFrameDict['map']:
+            self.select.SetValue(self.mapFrameDict['map'])
+            if self.mapFrameDict['mapType'] == 'raster':
+                self.rasterTypeRadio.SetValue(True)
+                self.vectorTypeRadio.SetValue(False)
+            else:
+                self.rasterTypeRadio.SetValue(False)
+                self.vectorTypeRadio.SetValue(True)
+        elif self.mapFrameDict['scaleType'] == 1 and self.mapFrameDict['region']:
+            self.select.SetValue(self.mapFrameDict['region'])
+        self.OnMap(None)
+        self.scale[self.mapFrameDict['scaleType']] = self.mapFrameDict['scale']
+        self.center[self.mapFrameDict['scaleType']] = self.mapFrameDict['center']
+        self.OnScaleChoice(None)
+        self.OnElementType(None)
+        self.OnBorder(None)
+        """!Do layout"""
+        border = wx.BoxSizer(wx.VERTICAL)
+        box   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Map frame"))
+        sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
+        gridBagSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+        #scale options
+        frameText = wx.StaticText(self, id = wx.ID_ANY, label = _("Map frame options:"))
+        scaleChoices = [_("fit frame to match selected map"),
+                        _("fit frame to match saved region"),
+                        _("fit frame to match current computational region"),
+                        _("fixed scale and map center")]
+        self.scaleChoice = wx.Choice(self, id = wx.ID_ANY, choices = scaleChoices)
+        gridBagSizer.Add(frameText, pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.scaleChoice, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #map and region selection
+        self.staticBox = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Map selection"))
+        sizerM = wx.StaticBoxSizer(self.staticBox, wx.HORIZONTAL)
+        self.mapSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+        self.rasterTypeRadio = wx.RadioButton(self, id = wx.ID_ANY, label = " %s " % _("raster"), style = wx.RB_GROUP)
+        self.vectorTypeRadio = wx.RadioButton(self, id = wx.ID_ANY, label = " %s " % _("vector"))
+        self.drawMap = wx.CheckBox(self, id = wx.ID_ANY, label = "add selected map")
+        self.mapOrRegionText = [_("Map:"), _("Region:")]
+        dc = wx.PaintDC(self)# determine size of labels
+        width = max(dc.GetTextExtent(self.mapOrRegionText[0])[0], dc.GetTextExtent(self.mapOrRegionText[1])[0])
+        self.mapText = wx.StaticText(self, id = wx.ID_ANY, label = self.mapOrRegionText[0], size = (width, -1))
+        self.select = Select(self, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+                             type = 'raster', multiple = False,
+                             updateOnPopup = True, onPopup = None)
+        self.mapSizer.Add(self.rasterTypeRadio, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.mapSizer.Add(self.vectorTypeRadio, pos = (0, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.mapSizer.Add(self.drawMap, pos = (0, 3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        self.mapSizer.Add(self.mapText, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.mapSizer.Add(self.select, pos = (1, 1), span = (1, 3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizerM.Add(self.mapSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        gridBagSizer.Add(sizerM, pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #map scale and center
+        boxC   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Map scale and center"))
+        sizerC = wx.StaticBoxSizer(boxC, wx.HORIZONTAL)
+        self.centerSizer = wx.FlexGridSizer(rows = 2, cols = 5, hgap = 5, vgap = 5)
+        centerText = wx.StaticText(self, id = wx.ID_ANY, label = _("Center:"))
+        self.eastingText = wx.StaticText(self, id = wx.ID_ANY, label = _("E:"))
+        self.northingText = wx.StaticText(self, id = wx.ID_ANY, label = _("N:"))
+        self.eastingTextCtrl = wx.TextCtrl(self, id = wx.ID_ANY, style = wx.TE_RIGHT, validator = TCValidator(flag = 'DIGIT_ONLY'))
+        self.northingTextCtrl = wx.TextCtrl(self, id = wx.ID_ANY, style = wx.TE_RIGHT, validator = TCValidator(flag = 'DIGIT_ONLY'))
+        scaleText = wx.StaticText(self, id = wx.ID_ANY, label = _("Scale:"))
+        scalePrefixText = wx.StaticText(self, id = wx.ID_ANY, label = _("1 :"))
+        self.scaleTextCtrl = wx.TextCtrl(self, id = wx.ID_ANY, value = "", style = wx.TE_RIGHT, validator = TCValidator('DIGIT_ONLY'))
+        self.centerSizer.Add(centerText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.RIGHT, border = 10)
+        self.centerSizer.Add(self.eastingText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        self.centerSizer.Add(self.eastingTextCtrl, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.centerSizer.Add(self.northingText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        self.centerSizer.Add(self.northingTextCtrl, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.centerSizer.Add(scaleText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.RIGHT, border = 10)
+        self.centerSizer.Add(scalePrefixText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        self.centerSizer.Add(self.scaleTextCtrl, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizerC.Add(self.centerSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        gridBagSizer.Add(sizerC, pos = (3, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #resolution
+        flexSizer = wx.FlexGridSizer(rows = 1, cols = 2, hgap = 5, vgap = 5)
+        resolutionText = wx.StaticText(self, id = wx.ID_ANY, label = _("Map max resolution (dpi):"))
+        self.resolutionSpin = wx.SpinCtrl(self, id = wx.ID_ANY, min = 1, max = 1000, initial = 300)
+        flexSizer.Add(resolutionText, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.resolutionSpin, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.resolutionSpin.SetValue(self.mapFrameDict['resolution'])
+        gridBagSizer.Add(flexSizer, pos = (4, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        sizer.Add(gridBagSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+        # border
+        box   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Border"))
+        self.borderCheck = wx.CheckBox(self, id = wx.ID_ANY, label = (_("draw border around map frame")))
+        if self.mapFrameDict['border'] == 'y':
+            self.borderCheck.SetValue(True)
+        else:
+            self.borderCheck.SetValue(False)
+        self.borderColorText = wx.StaticText(self, id = wx.ID_ANY, label = _("border color:"))
+        self.borderWidthText = wx.StaticText(self, id = wx.ID_ANY, label = _("border width (pts):"))
+        self.borderColourPicker = wx.ColourPickerCtrl(self, id = wx.ID_ANY)
+        self.borderWidthCtrl = wx.SpinCtrl(self, id = wx.ID_ANY, min = 1, max = 100, initial = 1)
+            self.borderWidthCtrl.SetValue(int(self.mapFrameDict['width']))
+            self.borderColourPicker.SetColour(convertRGB(self.mapFrameDict['color']))
+        gridBagSizer.Add(self.borderCheck, pos = (0, 0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.borderColorText, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.borderWidthText, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.borderColourPicker, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.borderWidthCtrl, pos = (2, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        self.SetSizer(border)
+        self.Fit()
+        if projInfo()['proj'] == 'll':
+            self.scaleChoice.SetItems(self.scaleChoice.GetItems()[0:3])
+            boxC.Hide()
+            for each in self.centerSizer.GetChildren():
+                each.GetWindow().Hide()
+        # bindings
+        self.scaleChoice.Bind(wx.EVT_CHOICE, self.OnScaleChoice)
+        self.select.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnMap)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnElementType, self.vectorTypeRadio)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnElementType, self.rasterTypeRadio)
+        self.Bind(wx.EVT_CHECKBOX, self.OnBorder, self.borderCheck)
+    def OnMap(self, event):
+        """!Selected map or region changing"""
+        if self.select.GetValue():
+            self.selected = self.select.GetValue()
+        else:
+            self.selected = None
+        if self.scaleChoice.GetSelection() == 0:
+            self.selectedMap = self.selected
+            if self.rasterTypeRadio.GetValue():
+                mapType = 'raster'
+            else:
+                mapType = 'vector'
+            self.scale[0], self.center[0], foo = AutoAdjust(self, scaleType = 0, map = self.selected,
+                                                mapType = mapType, rect = self.mapFrameDict['rect'])
+            #self.center[0] = self.RegionCenter(self.RegionDict(scaleType = 0))
+        elif self.scaleChoice.GetSelection() == 1:
+            self.selectedRegion = self.selected
+            self.scale[1], self.center[1],  foo = AutoAdjust(self, scaleType = 1, region = self.selected, rect = self.mapFrameDict['rect'])
+            #self.center[1] = self.RegionCenter(self.RegionDict(scaleType = 1))
+        elif self.scaleChoice.GetSelection() == 2:
+            self.scale[2], self.center[2], foo = AutoAdjust(self, scaleType = 2, rect = self.mapFrameDict['rect'])
+            #self.center[2] = self.RegionCenter(self.RegionDict(scaleType = 2))
+        else:
+            self.scale[3] = None
+            self.center[3] = None
+    def OnScaleChoice(self, event):
+        """!Selected scale type changing"""
+        scaleType = self.scaleChoice.GetSelection()
+        if self.scaleType != scaleType:
+            self.scaleType = scaleType
+            self.select.SetValue("")
+        if scaleType in (0, 1): # automatic - region from raster map, saved region
+            if scaleType == 0:
+                # set map selection
+                self.rasterTypeRadio.Show()
+                self.vectorTypeRadio.Show()
+                self.drawMap.Show()
+                self.staticBox.SetLabel(" %s " % _("Map selection"))
+                    stype = 'raster'
+                else:
+                    stype = 'vector'
+                self.select.SetElementList(type = stype)
+                self.mapText.SetLabel(self.mapOrRegionText[0])
+                self.select.SetToolTipString(_("Region is set to match this map,\nraster or vector map must be added later"))
+            if scaleType == 1:
+                # set region selection
+                self.rasterTypeRadio.Hide()
+                self.vectorTypeRadio.Hide()
+                self.drawMap.Hide()
+                self.staticBox.SetLabel(" %s " % _("Region selection"))
+                stype = 'region'
+                self.mapText.SetLabel(self.mapOrRegionText[1])
+                self.select.SetToolTipString(_(""))
+            for each in self.mapSizer.GetChildren():
+                each.GetWindow().Enable()
+                each.GetWindow().Disable()
+            if self.scale[scaleType]:
+                self.scaleTextCtrl.SetValue("%.0f" % (1/self.scale[scaleType]))
+            if self.center[scaleType]:
+                self.eastingTextCtrl.SetValue(str(self.center[scaleType][0]))
+                self.northingTextCtrl.SetValue(str(self.center[scaleType][1]))
+        elif scaleType == 2:
+        else: # fixed
+    def OnElementType(self, event):
+        """!Changes data in map selection tree ctrl popup"""
+        else:
+        self.select.SetElementList(type  = mapType)
+        if self.mapType != mapType and event is not None:
+            self.mapType = mapType
+            self.select.SetValue('')
+    def OnBorder(self, event):
+        """!Enables/disable the part relating to border of map frame"""
+        for each in (self.borderColorText, self.borderWidthText, self.borderColourPicker, self.borderWidthCtrl):
+            each.Enable(self.borderCheck.GetValue())
+    def getId(self):
+        """!Returns id of raster map"""
+        return self.id
+    def update(self):
+        """!Save changes"""
+        mapFrameDict = dict(self.mapFrameDict)
+        # resolution
+        mapFrameDict['resolution'] = self.resolutionSpin.GetValue()
+        #scale
+        scaleType = self.scaleType
+        mapFrameDict['scaleType'] = scaleType
+        if mapFrameDict['scaleType'] == 0:
+                mapFrameDict['drawMap'] = self.drawMap.GetValue()
+                mapFrameDict['map'] = self.select.GetValue()
+                mapFrameDict['mapType'] = self.mapType
+                mapFrameDict['region'] = None
+                if mapFrameDict['drawMap']:
+                    if mapFrameDict['mapType'] == 'raster':
+                        mapFile = grass.find_file(mapFrameDict['map'], element = 'cell')
+                        if mapFile['file'] == '':
+                            GMessage("Raster %s not found" % mapFrameDict['map'])
+                            return False
+                        raster = self.instruction.FindInstructionByType('raster')
+                        if raster:
+                            raster['raster'] = mapFrameDict['map']
+                        else:
+                            raster = Raster(wx.NewId())
+                            raster['isRaster'] = True
+                            self.instruction.AddInstruction(raster)
+                    elif mapFrameDict['mapType'] == 'vector':
+                        mapFile = grass.find_file(mapFrameDict['map'], element = 'vector')
+                            GMessage("Vector %s not found" % mapFrameDict['map'])
+                            return False
+                        vector = self.instruction.FindInstructionByType('vector')
+                        isAdded = False
+                        if vector:
+                            for each in vector['list']:
+                                if each[0] == mapFrameDict['map']:
+                                    isAdded = True
+                        if not isAdded:
+                            topoInfo = grass.vector_info_topo(map = mapFrameDict['map'])
+                            if topoInfo:
+                                if bool(topoInfo['areas']):
+                                    topoType = 'areas'
+                                elif bool(topoInfo['lines']):
+                                    topoType = 'lines'
+                                else:
+                                    topoType = 'points'
+                                label = '('.join(mapFrameDict['map'].split('@')) + ')'
+                                if not vector:
+                                    vector = Vector(wx.NewId())
+                                    vector['list'] = []
+                                    self.instruction.AddInstruction(vector)
+                                id = wx.NewId()
+                                vector['list'].insert(0, [mapFrameDict['map'], topoType, id, 1, label])
+                                vProp = VProperties(id, topoType)
+                                vProp['name'], vProp['label'], vProp['lpos'] = mapFrameDict['map'], label, 1
+                                self.instruction.AddInstruction(vProp)
+                            else:
+                                return False
+                self.scale[0], self.center[0], self.rectAdjusted = AutoAdjust(self, scaleType = 0, map = mapFrameDict['map'],
+        mapType = self.mapType, rect = self.mapFrameDict['rect'])
+                if self.rectAdjusted:
+                    mapFrameDict['rect'] = self.rectAdjusted
+                else:
+                    mapFrameDict['rect'] = self.mapFrameDict['rect']
+                mapFrameDict['scale'] = self.scale[0]
+                mapFrameDict['center'] = self.center[0]
+                # set region
+                if self.mapType == 'raster':
+                    RunCommand('g.region', rast = mapFrameDict['map'])
+                if self.mapType == 'vector':
+                    if raster:
+                        rasterId = raster.id
+                    else:
+                        rasterId = None
+                    if rasterId:
+                        RunCommand('g.region', vect = mapFrameDict['map'], rast = self.instruction[rasterId]['raster'])
+                    else:
+                        RunCommand('g.region', vect = mapFrameDict['map'])
+            else:
+                wx.MessageBox(message = _("No map selected!"),
+                                    caption = _('Invalid input'), style = wx.OK|wx.ICON_ERROR)
+                return False
+        elif mapFrameDict['scaleType'] == 1:
+                mapFrameDict['drawMap'] = False
+                mapFrameDict['map'] = None
+                mapFrameDict['mapType'] = None
+                mapFrameDict['region'] = self.select.GetValue()
+                self.scale[1], self.center[1], self.rectAdjusted = AutoAdjust(self, scaleType = 1, region = mapFrameDict['region'],
+        rect = self.mapFrameDict['rect'])
+                else:
+                mapFrameDict['scale'] = self.scale[1]
+                mapFrameDict['center'] = self.center[1]
+                # set region
+                RunCommand('g.region', region = mapFrameDict['region'])
+            else:
+                wx.MessageBox(message = _("No region selected!"),
+                return False
+            self.scale[2], self.center[2], self.rectAdjusted = AutoAdjust(self, scaleType = 2, rect = self.mapFrameDict['rect'])
+            else:
+            mapFrameDict['scale'] = self.scale[2]
+            mapFrameDict['center'] = self.center[2]
+            env = grass.gisenv()
+            windFilePath = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], 'WIND')
+            try:
+                windFile = open(windFilePath, 'r').read()
+                region = grass.parse_key_val(windFile, sep = ':', val_type = float)
+            except IOError:
+                region = grass.region()
+            if raster:
+            else:
+                rasterId = None
+            if rasterId: # because of resolution
+                RunCommand('g.region', n = region['north'], s = region['south'],
+                            e = region['east'], w = region['west'], rast = self.instruction[rasterId]['raster'])
+            else:
+                                        e = region['east'], w = region['west'])
+        elif scaleType == 3:
+            try:
+                scaleNumber = float(self.scaleTextCtrl.GetValue())
+                centerE = float(self.eastingTextCtrl.GetValue())
+                centerN = float(self.northingTextCtrl.GetValue())
+            except (ValueError, SyntaxError):
+                wx.MessageBox(message = _("Invalid scale or map center!"),
+                return False
+            mapFrameDict['scale'] = 1/scaleNumber
+            mapFrameDict['center'] = centerE, centerN
+            ComputeSetRegion(self, mapDict = mapFrameDict)
+        # check resolution
+        SetResolution(dpi = mapFrameDict['resolution'], width = mapFrameDict['rect'].width,
+                                                        height = mapFrameDict['rect'].height)
+        # border
+        if self.borderCheck.GetValue():
+            mapFrameDict['border'] = 'y'
+        else:
+            mapFrameDict['border'] = 'n'
+        if mapFrameDict['border'] == 'y':
+            mapFrameDict['width'] = self.borderWidthCtrl.GetValue()
+            mapFrameDict['color'] = convertRGB(self.borderColourPicker.GetColour())
+        if self.id not in self.instruction:
+            self.instruction.AddInstruction(mapFrame)
+        self.instruction[self.id].SetInstruction(mapFrameDict)
+        if self.id not in self.mapDialog.parent.objectId:
+            self.mapDialog.parent.objectId.insert(0, self.id)# map frame is drawn first
+        return True
+class RasterPanel(wx.Panel):
+    """!Panel for raster map settings"""
+    def __init__(self, parent, id, settings,  notebook = True):
+        if notebook:
+            self.book.AddPage(page = self, text = _("Raster map"))
+            self.mainDialog = self.book.GetParent()
+        else:
+            self.mainDialog = parent
+        if id:
+            self.id = id
+            self.rasterDict = self.instruction[self.id].GetInstruction()
+        else:
+            raster = Raster(self.id)
+            self.rasterDict = raster.GetInstruction()
+        self._layout()
+        self.OnRaster(None)
+        """!Do layout"""
+        # choose raster map
+        box   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Choose raster map"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridBagSizer = wx.GridBagSizer (hgap = 5, vgap = 5)
+        self.rasterNoRadio = wx.RadioButton(self, id = wx.ID_ANY, label = _("no raster map"), style = wx.RB_GROUP)
+        self.rasterYesRadio = wx.RadioButton(self, id = wx.ID_ANY, label = _("raster:"))
+        self.rasterSelect = Select(self, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+        if self.rasterDict['isRaster']:
+            self.rasterYesRadio.SetValue(True)
+            self.rasterNoRadio.SetValue(False)
+            self.rasterSelect.SetValue(self.rasterDict['raster'])
+        else:
+            self.rasterYesRadio.SetValue(False)
+            self.rasterNoRadio.SetValue(True)
+            mapId = self.instruction.FindInstructionByType('map').id
+            if self.instruction[mapId]['map'] and self.instruction[mapId]['mapType'] == 'raster':
+                self.rasterSelect.SetValue(self.instruction[mapId]['map'])# raster map from map frame dialog if possible
+            else:
+                self.rasterSelect.SetValue('')
+        gridBagSizer.Add(self.rasterNoRadio, pos = (0, 0), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rasterYesRadio, pos = (1, 0),  flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rasterSelect, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #self.rasterSelect.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnRaster)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRaster, self.rasterNoRadio)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRaster, self.rasterYesRadio)
+        self.Fit()
+    def OnRaster(self, event):
+        """!Enable/disable raster selection"""
+        self.rasterSelect.Enable(self.rasterYesRadio.GetValue())
+    def update(self):
+        #draw raster
+        map = self.instruction.FindInstructionByType('map')
+        if self.rasterNoRadio.GetValue() or not self.rasterSelect.GetValue():
+            self.rasterDict['isRaster'] = False
+            self.rasterDict['raster'] = None
+            map['drawMap'] = False
+            if self.id in self.instruction:
+                del self.instruction[self.id]
+        else:
+            self.rasterDict['isRaster'] = True
+            self.rasterDict['raster'] = self.rasterSelect.GetValue()
+            if self.rasterDict['raster'] != map['drawMap']:
+            self.instruction[self.id].SetInstruction(self.rasterDict)
+        if 'map' in self.mainDialog.parent.openDialogs:
+            self.mainDialog.parent.openDialogs['map'].updateDialog()
+        return True
+    def getId(self):
+        return self.id
+class VectorPanel(wx.Panel):
+    """!Panel for vector maps settings"""
+        self.tmpDialogDict = {}
+        vectors = self.instruction.FindInstructionByType('vProperties', list = True)
+        for vector in vectors:
+            self.tmpDialogDict[vector.id] = dict(self.instruction[vector.id].GetInstruction())
+        if id:
+            self.id = id
+            self.vectorList = deepcopy(self.instruction[id]['list'])
+        else:
+            self.vectorList = []
+        vLegend = self.instruction.FindInstructionByType('vectorLegend')
+        if vLegend:
+            self.vLegendId = vLegend.id
+        else:
+            self.vLegendId = None
+        self._layout()
+        if notebook:
+            self.parent.AddPage(page = self, text = _("Vector maps"))
+            self.parent = self.parent.GetParent()
+        """!Do layout"""
+        # choose vector map
+        box   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Add map"))
+        text = wx.StaticText(self, id = wx.ID_ANY, label = _("Map:"))
+        self.select = Select(self, id = wx.ID_ANY,# size = globalvar.DIALOG_GSELECT_SIZE,
+                             type = 'vector', multiple = False,
+        topologyType = [_("points"), _("lines"), _("areas")]
+        self.vectorType = wx.RadioBox(self, id = wx.ID_ANY, label = " %s " % _("Data Type"), choices = topologyType,
+                                        majorDimension = 3, style = wx.RA_SPECIFY_COLS)
+        self.AddVector = wx.Button(self, id = wx.ID_ANY, label = _("Add"))
+        gridBagSizer.Add(text, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.select, pos = (0,1), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.vectorType, pos = (1,1), flag = wx.ALIGN_CENTER, border = 0)
+        gridBagSizer.Add(self.AddVector, pos = (1,2), flag = wx.ALIGN_BOTTOM|wx.ALIGN_RIGHT, border = 0)
+        # manage vector layers
+        box   = wx.StaticBox (parent = self, id = wx.ID_ANY, label = " %s " % _("Manage vector maps"))
+        gridBagSizer.AddGrowableCol(0,2)
+        gridBagSizer.AddGrowableCol(1,1)
+        text = wx.StaticText(self, id = wx.ID_ANY, label = _("The topmost vector map overlaps the others"))
+        self.listbox = wx.ListBox(self, id = wx.ID_ANY, choices = [], style = wx.LB_SINGLE|wx.LB_NEEDED_SB)
+        self.btnUp = wx.Button(self, id = wx.ID_ANY, label = _("Up"))
+        self.btnDown = wx.Button(self, id = wx.ID_ANY, label = _("Down"))
+        self.btnDel = wx.Button(self, id = wx.ID_ANY, label = _("Delete"))
+        self.btnProp = wx.Button(self, id = wx.ID_ANY, label = _("Properties..."))
+        self.updateListBox(selected = 0)
+        gridBagSizer.Add(self.listbox, pos = (1,0), span = (4, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.btnUp, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.btnDown, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.btnDel, pos = (3,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.btnProp, pos = (4,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        sizer.Add(gridBagSizer, proportion = 0, flag = wx.ALL, border = 5)
+        self.Bind(wx.EVT_BUTTON, self.OnAddVector, self.AddVector)
+        self.Bind(wx.EVT_BUTTON, self.OnDelete, self.btnDel)
+        self.Bind(wx.EVT_BUTTON, self.OnUp, self.btnUp)
+        self.Bind(wx.EVT_BUTTON, self.OnDown, self.btnDown)
+        self.Bind(wx.EVT_BUTTON, self.OnProperties, self.btnProp)
+        self.select.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnVector)
+        self.Fit()
+        self.Bind(wx.EVT_LISTBOX_DCLICK, self.OnProperties, self.listbox)
+    def OnVector(self, event):
+        """!Gets info about toplogy and enables/disables choices point/line/area"""
+        vmap = self.select.GetValue()
+        try:
+            topoInfo = grass.vector_info_topo(map = vmap)
+        except grass.ScriptError:
+            return
+        if topoInfo:
+            self.vectorType.EnableItem(2, bool(topoInfo['areas']))
+            self.vectorType.EnableItem(1, bool(topoInfo['boundaries']) or bool(topoInfo['lines']))
+            self.vectorType.EnableItem(0, bool(topoInfo['centroids'] or bool(topoInfo['points']) ))
+            for item in range(2,-1,-1):
+                if self.vectorType.IsItemEnabled(item):
+                    self.vectorType.SetSelection(item)
+                    break
+            self.AddVector.SetFocus()
+    def OnAddVector(self, event):
+        """!Adds vector map to list"""
+        if vmap:
+            mapname = vmap.split('@')[0]
+            try:
+                mapset = '(' + vmap.split('@')[1] + ')'
+            except IndexError:
+                mapset = ''
+            type = self.vectorType.GetStringSelection()
+            record = "%s - %s" % (vmap,type)
+            id = wx.NewId()
+            lpos = 1
+            label = mapname + mapset
+            self.vectorList.insert(0, [vmap, type, id, lpos, label])
+            self.reposition()
+            self.listbox.InsertItems([record], 0)
+            vector = VProperties(id, type)
+            self.tmpDialogDict[id] = vector.GetInstruction()
+            self.tmpDialogDict[id]['name'] = vmap
+            self.listbox.SetSelection(0)
+            self.listbox.EnsureVisible(0)
+            self.btnProp.SetFocus()
+            self.enableButtons()
+    def OnDelete(self, event):
+        """!Deletes vector map from the list"""
+        if self.listbox.GetSelections():
+            pos = self.listbox.GetSelection()
+            id = self.vectorList[pos][2]
+            del self.vectorList[pos]
+            del self.tmpDialogDict[id]
+            for i in range(pos, len(self.vectorList)):
+                if self.vectorList[i][3]:# can be 0
+                    self.vectorList[i][3] -= 1
+            if pos < len(self.vectorList) -1:
+                selected = pos
+            else:
+                selected = len(self.vectorList) -1
+            self.updateListBox(selected = selected)
+            if self.listbox.IsEmpty():
+                self.enableButtons(False)
+    def OnUp(self, event):
+        """!Moves selected map to top"""
+            if pos:
+                self.vectorList.insert(pos - 1, self.vectorList.pop(pos))
+            if not self.vLegendId:
+                self.reposition()
+            if pos > 0:
+                self.updateListBox(selected = (pos - 1))
+            else:
+    def OnDown(self, event):
+        """!Moves selected map to bottom"""
+            if pos != len(self.vectorList) - 1:
+                self.vectorList.insert(pos + 1, self.vectorList.pop(pos))
+                    self.reposition()
+                self.updateListBox(selected = (pos + 1))
+            else:
+                self.updateListBox(selected = len(self.vectorList) -1)
+    def OnProperties(self, event):
+        """!Opens vector map properties dialog"""
+            dlg = VPropertiesDialog(self, id = id, settings = self.instruction,
+                                    vectors = self.vectorList, tmpSettings = self.tmpDialogDict[id])
+            dlg.ShowModal()
+            self.parent.FindWindowById(wx.ID_OK).SetFocus()
+    def enableButtons(self, enable = True):
+        """!Enable/disable up, down, properties, delete buttons"""
+        self.btnUp.Enable(enable)
+        self.btnDown.Enable(enable)
+        self.btnProp.Enable(enable)
+        self.btnDel.Enable(enable)
+    def updateListBox(self, selected = None):
+        mapList = ["%s - %s" % (item[0], item[1]) for item in self.vectorList]
+        self.listbox.Set(mapList)
+        if selected is not None:
+            self.listbox.SetSelection(selected)
+            self.listbox.EnsureVisible(selected)
+        else:
+            self.enableButtons(True)
+    def reposition(self):
+        """!Update position in legend, used only if there is no vlegend yet"""
+        for i in range(len(self.vectorList)):
+                self.vectorList[i][3] = i + 1
+    def getId(self):
+        return self.id
+    def update(self):
+            del self.instruction[vector.id]
+        if len(self.vectorList) > 0:
+            vector = Vector(self.id)
+            vector.SetInstruction({'list': deepcopy(self.vectorList)})
+            # save new vectors
+            for item in self.vectorList:
+                id = item[2]
+                vLayer = VProperties(id, item[1])
+                self.instruction.AddInstruction(vLayer)
+                vLayer.SetInstruction(self.tmpDialogDict[id])
+                vLayer['name'] = item[0]
+                vLayer['label'] = item[4]
+                vLayer['lpos'] = item[3]
+        else:
+        if 'map' in self.parent.parent.openDialogs:
+            self.parent.parent.openDialogs['map'].updateDialog()
+        return True
+class RasterDialog(PsmapDialog):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = _("Raster map settings"), settings = settings)
+        self.objectType = ('raster',)
+        self.rPanel = RasterPanel(parent = self, id = self.id, settings = self.instruction, notebook = False)
+        self.id = self.rPanel.getId()
+        self._layout(self.rPanel)
+    def update(self):
+        ok = self.rPanel.update()
+        if ok:
+            return True
+        return False
+        if not ok:
+            return False
+        else:
+            self.parent.DialogDataChanged(id = mapId)
+        return True
+        """!Update information (not used)"""
+        pass
+##        if 'map' in self.parent.openDialogs:
+##            if self.parent.openDialogs['map'].mPanel.rasterTypeRadio.GetValue()\
+##                    and self.parent.openDialogs['map'].mPanel.select.GetValue():
+##                if self.parent.openDialogs['map'].mPanel.drawMap.IsChecked():
+##                    self.rPanel.rasterSelect.SetValue(self.parent.openDialogs['map'].mPanel.select.GetValue())
+class MainVectorDialog(PsmapDialog):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = _("Vector maps settings"), settings = settings)
+        self.objectType = ('vector',)
+        self.vPanel = VectorPanel(parent = self, id = self.id, settings = self.instruction, notebook = False)
+        self.id = self.vPanel.getId()
+        self._layout(self.vPanel)
+    def update(self):
+        self.vPanel.update()
+        self.update()
+        else:
+        return True
+        pass
+class VPropertiesDialog(PsmapDialog):
+    def __init__(self, parent, id, settings, vectors, tmpSettings):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "", settings = settings, apply = False)
+        vectorList = vectors
+        self.vPropertiesDict = tmpSettings
+        # determine map and its type
+        for item in vectorList:
+            if id == item[2]:
+                self.vectorName = item[0]
+                self.type = item[1]
+        self.SetTitle(self.vectorName + " "+ _("properties"))
+        #vector map info
+        self.connection = True
+        try:
+            self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
+            self.connection = False
+            self.layers = []
+            self.layers = []
+        self.currLayer = self.vPropertiesDict['layer']
+        #path to symbols, patterns
+        gisbase = os.getenv("GISBASE")
+        self.symbolPath = os.path.join(gisbase, 'etc', 'symbol')
+        self.symbols = []
+        for dir in os.listdir(self.symbolPath):
+            for symbol in os.listdir(os.path.join(self.symbolPath, dir)):
+                self.symbols.append(os.path.join(dir, symbol))
+        self.patternPath = os.path.join(gisbase, 'etc', 'paint', 'patterns')
+        #notebook
+        notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
+        self.DSpanel = self._DataSelectionPanel(notebook)
+        self.EnableLayerSelection(enable = self.connection)
+        selectPanel = { 'points': [self._ColorsPointAreaPanel, self._StylePointPanel],
+                        'lines': [self._ColorsLinePanel, self._StyleLinePanel],
+                        'areas': [self._ColorsPointAreaPanel, self._StyleAreaPanel]}
+        self.ColorsPanel = selectPanel[self.type][0](notebook)
+        self.OnOutline(None)
+        if self.type in ('points', 'areas'):
+            self.OnFill(None)
+        self.OnColor(None)
+        self.StylePanel = selectPanel[self.type][1](notebook)
+        if self.type == 'points':
+            self.OnSize(None)
+            self.OnRotation(None)
+        if self.type == 'areas':
+            self.OnPattern(None)
+        self._layout(notebook)
+    def _DataSelectionPanel(self, notebook):
+        panel = wx.Panel(parent = notebook, id = wx.ID_ANY, size = (-1, -1), style = wx.TAB_TRAVERSAL)
+        notebook.AddPage(page = panel, text = _("Data selection"))
+        # data type
+        self.checkType1 = self.checkType2 = None
+        if self.type in ('lines', 'points'):
+            box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Feature type"))
+                label = (_("points"), _("centroids"))
+            else:
+                label = (_("lines"), _("boundaries"))
+                name = ("point", "centroid")
+            else:
+                name = ("line", "boundary")
+            self.checkType1 = wx.CheckBox(panel, id = wx.ID_ANY, label = label[0], name = name[0])
+            self.checkType2 = wx.CheckBox(panel, id = wx.ID_ANY, label = label[1], name = name[1])
+            self.checkType1.SetValue(self.vPropertiesDict['type'].find(name[0]) >= 0)
+            self.checkType2.SetValue(self.vPropertiesDict['type'].find(name[1]) >= 0)
+            gridBagSizer.Add(self.checkType1, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            gridBagSizer.Add(self.checkType2, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        # layer selection
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Layer selection"))
+        self.gridBagSizerL = wx.GridBagSizer(hgap = 5, vgap = 5)
+        self.warning =  wx.StaticText(panel, id = wx.ID_ANY, label = "")
+        if not self.connection:
+            self.warning = wx.StaticText(panel, id = wx.ID_ANY, label = _("Database connection is not defined in DB file."))
+        text = wx.StaticText(panel, id = wx.ID_ANY, label = _("Select layer:"))
+        self.layerChoice = wx.Choice(panel, id = wx.ID_ANY, choices = map(str, self.layers), size = self.spinCtrlSize)
+        self.layerChoice.SetStringSelection(self.currLayer)
+        if self.connection:
+            table = self.mapDBInfo.layers[int(self.currLayer)]['table']
+        else:
+            table = ""
+        self.radioWhere = wx.RadioButton(panel, id = wx.ID_ANY, label = "SELECT * FROM %s WHERE" % table, style = wx.RB_GROUP)
+        self.textCtrlWhere = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+            cols = self.mapDBInfo.GetColumns(self.mapDBInfo.layers[int(self.currLayer)]['table'])
+        else:
+            cols = []
+        self.choiceColumns = wx.Choice(panel, id = wx.ID_ANY, choices = cols)
+        self.radioCats = wx.RadioButton(panel, id = wx.ID_ANY, label = "Choose categories ")
+        self.textCtrlCats = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+        self.textCtrlCats.SetToolTipString(_("list of categories (e.g. 1,3,5-7)"))
+        if self.vPropertiesDict.has_key('cats'):
+            self.radioCats.SetValue(True)
+            self.textCtrlCats.SetValue(self.vPropertiesDict['cats'])
+        if self.vPropertiesDict.has_key('where'):
+            self.radioWhere.SetValue(True)
+            where = self.vPropertiesDict['where'].strip().split(" ",1)
+            self.choiceColumns.SetStringSelection(where[0])
+            self.textCtrlWhere.SetValue(where[1])
+        row = 0
+            self.gridBagSizerL.Add(self.warning, pos = (0,0), span = (1,3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            row = 1
+        self.gridBagSizerL.Add(text, pos = (0 + row,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerL.Add(self.layerChoice, pos = (0 + row,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        self.gridBagSizerL.Add(self.radioWhere, pos = (1 + row,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerL.Add(self.choiceColumns, pos = (1 + row,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerL.Add(self.textCtrlWhere, pos = (1 + row,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerL.Add(self.radioCats, pos = (2 + row,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerL.Add(self.textCtrlCats, pos = (2 + row,1), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        sizer.Add(self.gridBagSizerL, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        #mask
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Mask"))
+        self.mask = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Use current mask"))
+        if self.vPropertiesDict['masked'] == 'y':
+            self.mask.SetValue(True)
+        else:
+            self.mask.SetValue(False)
+        sizer.Add(self.mask, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        self.Bind(wx.EVT_CHOICE, self.OnLayer, self.layerChoice)
+        panel.SetSizer(border)
+        panel.Fit()
+        return panel
+    def _ColorsPointAreaPanel(self, notebook):
+        notebook.AddPage(page = panel, text = _("Colors"))
+        #colors - outline
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Outline"))
+        self.gridBagSizerO = wx.GridBagSizer(hgap = 5, vgap = 2)
+        self.outlineCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("draw outline"))
+        self.outlineCheck.SetValue(self.vPropertiesDict['color'] != 'none')
+        widthText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
+        if fs:
+            self.widthSpin = fs.FloatSpin(panel, id = wx.ID_ANY, min_val = 0, max_val = 30,
+                                          increment = 0.5, value = 1, extrastyle = fs.FS_RIGHT)
+            self.widthSpin.SetFormat("%f")
+            self.widthSpin.SetDigits(2)
+        else:
+            self.widthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 25, initial = 1,
+                                         size = self.spinCtrlSize)
+        if self.vPropertiesDict['color'] != 'none':
+            self.widthSpin.SetValue(self.vPropertiesDict['width'] )
+        else:
+            self.widthSpin.SetValue(1)
+        colorText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Color:"))
+        self.colorPicker = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+            self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['color']))
+        else:
+            self.colorPicker.SetColour('black')
+        self.gridBagSizerO.Add(self.outlineCheck, pos = (0, 0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerO.Add(widthText, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerO.Add(self.widthSpin, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        self.gridBagSizerO.Add(colorText, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerO.Add(self.colorPicker, pos = (2, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(self.gridBagSizerO, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        self.Bind(wx.EVT_CHECKBOX, self.OnOutline, self.outlineCheck)
+        #colors - fill
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Fill"))
+        self.gridBagSizerF = wx.GridBagSizer(hgap = 5, vgap = 2)
+        self.fillCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("fill color"))
+        self.fillCheck.SetValue(self.vPropertiesDict['fcolor'] != 'none' or self.vPropertiesDict['rgbcolumn'] is not None)
+        self.colorPickerRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("choose color:"), style = wx.RB_GROUP)
+        #set choose color option if there is no db connection
+            self.colorPickerRadio.SetValue(not self.vPropertiesDict['rgbcolumn'])
+        else:
+            self.colorPickerRadio.SetValue(False)
+        self.fillColorPicker = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        if self.vPropertiesDict['fcolor'] != 'none':
+            self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['fcolor']))
+        else:
+            self.fillColorPicker.SetColour('red')
+        self.colorColRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("color from map table column:"))
+        self.colorColChoice = self.getColsChoice(parent = panel)
+            if self.vPropertiesDict['rgbcolumn']:
+                self.colorColRadio.SetValue(True)
+                self.colorColChoice.SetStringSelection(self.vPropertiesDict['rgbcolumn'])
+            else:
+                self.colorColRadio.SetValue(False)
+                self.colorColChoice.SetSelection(0)
+        self.colorColChoice.Enable(self.connection)
+        self.colorColRadio.Enable(self.connection)
+        self.gridBagSizerF.Add(self.fillCheck, pos = (0, 0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerF.Add(self.colorPickerRadio, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerF.Add(self.fillColorPicker, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerF.Add(self.colorColRadio, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerF.Add(self.colorColChoice, pos = (2, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        sizer.Add(self.gridBagSizerF, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        self.Bind(wx.EVT_CHECKBOX, self.OnFill, self.fillCheck)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnColor, self.colorColRadio)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnColor, self.colorPickerRadio)
+        panel.Fit()
+        return panel
+    def _ColorsLinePanel(self, notebook):
+        #colors - outline
+        self.outlineCheck.SetValue(self.vPropertiesDict['hcolor'] != 'none')
+        self.outlineCheck.SetToolTipString(_("No effect for fill color from table column"))
+        if fs:
+            self.outWidthSpin = fs.FloatSpin(panel, id = wx.ID_ANY, min_val = 0, max_val = 30,
+            self.outWidthSpin.SetFormat("%f")
+            self.outWidthSpin.SetDigits(1)
+        else:
+            self.outWidthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 30, initial = 1,
+        if self.vPropertiesDict['hcolor'] != 'none':
+            self.outWidthSpin.SetValue(self.vPropertiesDict['hwidth'] )
+        else:
+            self.outWidthSpin.SetValue(1)
+            self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['hcolor']) )
+        else:
+        self.gridBagSizerO.Add(self.outWidthSpin, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #colors - fill
+        fillText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Color of lines:"))
+        else:
+            self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['color']) )
+        else:
+            self.fillColorPicker.SetColour('black')
+            else:
+        self.gridBagSizerF.Add(fillText, pos = (0, 0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        panel.Fit()
+        return panel
+    def _StylePointPanel(self, notebook):
+        notebook.AddPage(page = panel, text = _("Size and style"))
+        #symbology
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Symbology"))
+        gridBagSizer.AddGrowableCol(1)
+        self.symbolRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("symbol:"), style = wx.RB_GROUP)
+        self.symbolRadio.SetValue(bool(self.vPropertiesDict['symbol']))
+        self.symbolChoice = wx.Choice(panel, id = wx.ID_ANY, choices = self.symbols)
+        self.epsRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("eps file:"))
+        self.epsRadio.SetValue(bool(self.vPropertiesDict['eps']))
+        self.epsFileCtrl = filebrowse.FileBrowseButton(panel, id = wx.ID_ANY, labelText = '',
+                                buttonText =  _("Browse"), toolTip = _("Type filename or click browse to choose file"),
+                                dialogTitle = _("Choose a file"), startDirectory = '', initialValue = '',
+                                fileMask = "Encapsulated PostScript (*.eps)|*.eps|All files (*.*)|*.*", fileMode = wx.OPEN)
+        if self.vPropertiesDict['symbol']:
+            self.symbolChoice.SetStringSelection(self.vPropertiesDict['symbol'])
+            self.epsFileCtrl.SetValue('')
+        else: #eps chosen
+            self.epsFileCtrl.SetValue(self.vPropertiesDict['eps'])
+            self.symbolChoice.SetSelection(0)
+        gridBagSizer.Add(self.symbolRadio, pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.symbolChoice, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.epsRadio, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.epsFileCtrl, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #size
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Size"))
+        gridBagSizer.AddGrowableCol(0)
+        self.sizeRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("size:"), style = wx.RB_GROUP)
+        self.sizeSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 50, initial = 1)
+        self.sizecolumnRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("size from map table column:"))
+        self.sizeColChoice = self.getColsChoice(panel)
+        self.scaleText = wx.StaticText(panel, id = wx.ID_ANY, label = _("scale:"))
+        self.scaleSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 25, initial = 1)
+        self.sizeRadio.SetValue(self.vPropertiesDict['size'] is not None)
+        self.sizecolumnRadio.SetValue(bool(self.vPropertiesDict['sizecolumn']))
+        if self.vPropertiesDict['size']:
+            self.sizeSpin.SetValue(self.vPropertiesDict['size'])
+        else: self.sizeSpin.SetValue(5)
+        if self.vPropertiesDict['sizecolumn']:
+            self.scaleSpin.SetValue(self.vPropertiesDict['scale'])
+            self.sizeColChoice.SetStringSelection(self.vPropertiesDict['sizecolumn'])
+        else:
+            self.scaleSpin.SetValue(1)
+            self.sizeColChoice.SetSelection(0)
+            for each in (self.sizecolumnRadio, self.sizeColChoice, self.scaleSpin, self.scaleText):
+                each.Disable()
+        gridBagSizer.Add(self.sizeRadio, pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sizeSpin, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sizecolumnRadio, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sizeColChoice, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.scaleText, pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        gridBagSizer.Add(self.scaleSpin, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnSize, self.sizeRadio)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnSize, self.sizecolumnRadio)
+        #rotation
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Rotation"))
+        self.rotateCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("rotate symbols:"))
+        self.rotateRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("counterclockwise in degrees:"), style = wx.RB_GROUP)
+        self.rotateSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 0, max = 360, initial = 0)
+        self.rotatecolumnRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("from map table column:"))
+        self.rotateColChoice = self.getColsChoice(panel)
+        self.rotateCheck.SetValue(self.vPropertiesDict['rotation'])
+        self.rotateRadio.SetValue(self.vPropertiesDict['rotate'] is not None)
+        self.rotatecolumnRadio.SetValue(bool(self.vPropertiesDict['rotatecolumn']))
+        if self.vPropertiesDict['rotate']:
+            self.rotateSpin.SetValue(self.vPropertiesDict['rotate'])
+        else:
+            self.rotateSpin.SetValue(0)
+        if self.vPropertiesDict['rotatecolumn']:
+            self.rotateColChoice.SetStringSelection(self.vPropertiesDict['rotatecolumn'])
+        else:
+            self.rotateColChoice.SetSelection(0)
+        gridBagSizer.Add(self.rotateCheck, pos = (0, 0), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rotateRadio, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rotateSpin, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rotatecolumnRadio, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.rotateColChoice, pos = (2, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        self.Bind(wx.EVT_CHECKBOX, self.OnRotation, self.rotateCheck)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRotationType, self.rotateRadio)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRotationType, self.rotatecolumnRadio)
+        panel.Fit()
+        return panel
+    def _StyleLinePanel(self, notebook):
+        #width
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Width"))
+        widthText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Set width (pts):"))
+        if fs:
+            self.widthSpin.SetDigits(1)
+        else:
+            self.widthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 30, initial = 1)
+        self.cwidthCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("multiply width by category value"))
+        if self.vPropertiesDict['width']:
+            self.widthSpin.SetValue(self.vPropertiesDict['width'])
+            self.cwidthCheck.SetValue(False)
+        else:
+            self.widthSpin.SetValue(self.vPropertiesDict['cwidth'])
+            self.cwidthCheck.SetValue(True)
+        gridBagSizer.Add(widthText, pos = (0, 0),  flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.widthSpin, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.cwidthCheck, pos = (1, 0), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        #style
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Line style"))
+        styleText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Choose line style:"))
+        penStyles = ["solid", "dashed", "dotted", "dashdotted"]
+        self.styleCombo = PenStyleComboBox(panel, choices = penStyles, validator = TCValidator(flag = 'ZERO_AND_ONE_ONLY'))
+##        self.styleCombo = wx.ComboBox(panel, id = wx.ID_ANY,
+##                            choices = ["solid", "dashed", "dotted", "dashdotted"],
+##                            validator = TCValidator(flag = 'ZERO_AND_ONE_ONLY'))
+##        self.styleCombo.SetToolTipString(_("It's possible to enter a series of 0's and 1's too. "\
+##                                    "The first block of repeated zeros or ones represents 'draw', "\
+##                                    "the second block represents 'blank'. An even number of blocks "\
+##                                    "will repeat the pattern, an odd number of blocks will alternate the pattern."))
+        linecapText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Choose linecap:"))
+        self.linecapChoice = wx.Choice(panel, id = wx.ID_ANY, choices = ["butt", "round", "extended_butt"])
+        self.styleCombo.SetValue(self.vPropertiesDict['style'])
+        self.linecapChoice.SetStringSelection(self.vPropertiesDict['linecap'])
+        gridBagSizer.Add(styleText, pos = (0, 0),  flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.styleCombo, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(linecapText, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.linecapChoice, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        panel.Fit()
+        return panel
+    def _StyleAreaPanel(self, notebook):
+        #pattern
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Pattern"))
+        self.patternCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("use pattern:"))
+        self.patFileCtrl = filebrowse.FileBrowseButton(panel, id = wx.ID_ANY, labelText = _("Choose pattern file:"),
+                                dialogTitle = _("Choose a file"), startDirectory = self.patternPath, initialValue = '',
+        self.patWidthText = wx.StaticText(panel, id = wx.ID_ANY, label = _("pattern line width (pts):"))
+        self.patWidthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 25, initial = 1)
+        self.patScaleText = wx.StaticText(panel, id = wx.ID_ANY, label = _("pattern scale factor:"))
+        self.patScaleSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 25, initial = 1)
+        self.patternCheck.SetValue(bool(self.vPropertiesDict['pat']))
+        if self.patternCheck.GetValue():
+            self.patFileCtrl.SetValue(self.vPropertiesDict['pat'])
+            self.patWidthSpin.SetValue(self.vPropertiesDict['pwidth'])
+            self.patScaleSpin.SetValue(self.vPropertiesDict['scale'])
+        gridBagSizer.Add(self.patternCheck, pos = (0, 0),  flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.patFileCtrl, pos = (1, 0), span = (1, 2),flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.patWidthText, pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.patWidthSpin, pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.patScaleText, pos = (3, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.patScaleSpin, pos = (3, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.Bind(wx.EVT_CHECKBOX, self.OnPattern, self.patternCheck)
+        panel.Fit()
+        return panel
+    def OnLayer(self, event):
+        """!Change columns on layer change """
+        if self.layerChoice.GetStringSelection() == self.currLayer:
+            return
+        self.currLayer = self.layerChoice.GetStringSelection()
+        else:
+            cols = []
+        self.choiceColumns.SetItems(cols)
+        self.choiceColumns.SetSelection(0)
+        if self.type in ('points', 'lines'):
+            self.colorColChoice.SetItems(cols)
+    def OnOutline(self, event):
+        for widget in self.gridBagSizerO.GetChildren():
+            if widget.GetWindow() != self.outlineCheck:
+                widget.GetWindow().Enable(self.outlineCheck.GetValue())
+    def OnFill(self, event):
+        enable = self.fillCheck.GetValue()
+        self.colorColChoice.Enable(enable)
+        self.colorColRadio.Enable(enable)
+        self.fillColorPicker.Enable(enable)
+        self.colorPickerRadio.Enable(enable)
+        if enable:
+            self.colorColChoice.Disable()
+            self.colorColRadio.Disable()
+    def OnColor(self, event):
+        self.colorColChoice.Enable(self.colorColRadio.GetValue())
+        self.fillColorPicker.Enable(self.colorPickerRadio.GetValue())
+    def OnSize(self, event):
+        self.sizeSpin.Enable(self.sizeRadio.GetValue())
+        self.sizeColChoice.Enable(self.sizecolumnRadio.GetValue())
+        self.scaleText.Enable(self.sizecolumnRadio.GetValue())
+        self.scaleSpin.Enable(self.sizecolumnRadio.GetValue())
+    def OnRotation(self, event):
+        for each in (self.rotateRadio, self.rotatecolumnRadio, self.rotateColChoice, self.rotateSpin):
+            if self.rotateCheck.GetValue():
+                each.Enable()
+                self.OnRotationType(event = None)
+            else:
+                each.Disable()
+    def OnRotationType(self, event):
+        self.rotateSpin.Enable(self.rotateRadio.GetValue())
+        self.rotateColChoice.Enable(self.rotatecolumnRadio.GetValue())
+    def OnPattern(self, event):
+        for each in (self.patFileCtrl, self.patWidthText, self.patWidthSpin, self.patScaleText, self.patScaleSpin):
+            each.Enable(self.patternCheck.GetValue())
+    def EnableLayerSelection(self, enable = True):
+        for widget in self.gridBagSizerL.GetChildren():
+            if widget.GetWindow() != self.warning:
+                widget.GetWindow().Enable(enable)
+    def getColsChoice(self, parent):
+        """!Returns a wx.Choice with table columns"""
+        else:
+            cols = []
+        choice = wx.Choice(parent = parent, id = wx.ID_ANY, choices = cols)
+        return choice
+    def update(self):
+        #feature type
+            featureType = None
+            if self.checkType1.GetValue():
+                featureType = self.checkType1.GetName()
+                if self.checkType2.GetValue():
+                    featureType += " or " + self.checkType2.GetName()
+            elif self.checkType2.GetValue():
+                featureType = self.checkType2.GetName()
+            if featureType:
+                self.vPropertiesDict['type'] = featureType
+        # is connection
+        self.vPropertiesDict['connection'] = self.connection
+            self.vPropertiesDict['layer'] = self.layerChoice.GetStringSelection()
+            if self.radioCats.GetValue() and not self.textCtrlCats.IsEmpty():
+                self.vPropertiesDict['cats'] = self.textCtrlCats.GetValue()
+            elif self.radioWhere.GetValue() and not self.textCtrlWhere.IsEmpty():
+                self.vPropertiesDict['where'] = self.choiceColumns.GetStringSelection() + " " \
+        + self.textCtrlWhere.GetValue()
+        #mask
+        if self.mask.GetValue():
+            self.vPropertiesDict['masked'] = 'y'
+        else:
+            self.vPropertiesDict['masked'] = 'n'
+        #colors
+            if self.outlineCheck.GetValue():
+                self.vPropertiesDict['color'] = convertRGB(self.colorPicker.GetColour())
+                self.vPropertiesDict['width'] = self.widthSpin.GetValue()
+            else:
+                self.vPropertiesDict['color'] = 'none'
+            if self.fillCheck.GetValue():
+                if self.colorPickerRadio.GetValue():
+                    self.vPropertiesDict['fcolor'] = convertRGB(self.fillColorPicker.GetColour())
+                    self.vPropertiesDict['rgbcolumn'] = None
+                if self.colorColRadio.GetValue():
+                    self.vPropertiesDict['fcolor'] = 'none'# this color is taken in case of no record in rgb column
+                    self.vPropertiesDict['rgbcolumn'] = self.colorColChoice.GetStringSelection()
+            else:
+        if self.type == 'lines':
+                #hcolor only when no rgbcolumn
+            if self.outlineCheck.GetValue():# and self.fillCheck.GetValue() and self.colorColRadio.GetValue():
+                self.vPropertiesDict['hcolor'] = convertRGB(self.colorPicker.GetColour())
+                self.vPropertiesDict['hwidth'] = self.outWidthSpin.GetValue()
+            else:
+                self.vPropertiesDict['hcolor'] = 'none'
+                self.vPropertiesDict['color'] = convertRGB(self.fillColorPicker.GetColour())
+                self.vPropertiesDict['color'] = 'none'# this color is taken in case of no record in rgb column
+        #size and style
+            #symbols
+            if self.symbolRadio.GetValue():
+                self.vPropertiesDict['symbol'] = self.symbolChoice.GetStringSelection()
+                self.vPropertiesDict['eps'] = None
+            else:
+                self.vPropertiesDict['eps'] = self.epsFileCtrl.GetValue()
+                self.vPropertiesDict['symbol'] = None
+            #size
+            if self.sizeRadio.GetValue():
+                self.vPropertiesDict['size'] = self.sizeSpin.GetValue()
+                self.vPropertiesDict['sizecolumn'] = None
+                self.vPropertiesDict['scale'] = None
+            else:
+                self.vPropertiesDict['sizecolumn'] = self.sizeColChoice.GetStringSelection()
+                self.vPropertiesDict['scale'] = self.scaleSpin.GetValue()
+                self.vPropertiesDict['size'] = None
+            #rotation
+            self.vPropertiesDict['rotate'] = None
+            self.vPropertiesDict['rotatecolumn'] = None
+            self.vPropertiesDict['rotation'] = False
+                self.vPropertiesDict['rotation'] = True
+            if self.rotateRadio.GetValue():
+                self.vPropertiesDict['rotate'] = self.rotateSpin.GetValue()
+            else:
+                self.vPropertiesDict['rotatecolumn'] = self.rotateColChoice.GetStringSelection()
+            #pattern
+            self.vPropertiesDict['pat'] = None
+            if self.patternCheck.GetValue() and bool(self.patFileCtrl.GetValue()):
+                self.vPropertiesDict['pat'] = self.patFileCtrl.GetValue()
+                self.vPropertiesDict['pwidth'] = self.patWidthSpin.GetValue()
+                self.vPropertiesDict['scale'] = self.patScaleSpin.GetValue()
+            #width
+            if self.cwidthCheck.GetValue():
+                self.vPropertiesDict['cwidth'] = self.widthSpin.GetValue()
+                self.vPropertiesDict['width'] = None
+            else:
+                self.vPropertiesDict['cwidth'] = None
+            #line style
+            if self.styleCombo.GetValue():
+                self.vPropertiesDict['style'] = self.styleCombo.GetValue()
+            else:
+                self.vPropertiesDict['style'] = 'solid'
+            self.vPropertiesDict['linecap'] = self.linecapChoice.GetStringSelection()
+    def OnOK(self, event):
+        self.update()
+        event.Skip()
+class LegendDialog(PsmapDialog):
+    def __init__(self, parent, id, settings, page):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "Legend settings", settings = settings)
+        self.objectType = ('rasterLegend', 'vectorLegend')
+        self.instruction = settings
+        if map:
+            self.mapId = map.id
+        else:
+            self.mapId = None
+        if vector:
+            self.vectorId = vector.id
+        else:
+            self.vectorId = None
+        if raster:
+            self.rasterId = raster.id
+        else:
+            self.rasterId = None
+        self.pageId = self.instruction.FindInstructionByType('page').id
+        currPage = self.instruction[self.pageId].GetInstruction()
+        #raster legend
+        if self.id[0] is not None:
+            self.rasterLegend = self.instruction[self.id[0]]
+            self.rLegendDict = self.rasterLegend.GetInstruction()
+        else:
+            self.id[0] = wx.NewId()
+            self.rasterLegend = RasterLegend(self.id[0])
+            self.rLegendDict['where'] = currPage['Left'], currPage['Top']
+        #vector legend
+        if self.id[1] is not None:
+            self.vLegendDict = self.instruction[self.id[1]].GetInstruction()
+        else:
+            self.id[1] = wx.NewId()
+            vectorLegend = VectorLegend(self.id[1])
+            self.vLegendDict = vectorLegend.GetInstruction()
+            self.vLegendDict['where'] = currPage['Left'], currPage['Top']
+        if self.rasterId:
+            self.currRaster = self.instruction[self.rasterId]['raster']
+        else:
+            self.currRaster = None
+        #notebook
+        self.panelRaster = self._rasterLegend(self.notebook)
+        self.panelVector = self._vectorLegend(self.notebook)
+        self.OnRange(None)
+        self.OnIsLegend(None)
+        self.OnSpan(None)
+        self.notebook.ChangeSelection(page)
+    def _rasterLegend(self, notebook):
+        panel = scrolled.ScrolledPanel(parent = notebook, id = wx.ID_ANY, size = (-1, 500), style = wx.TAB_TRAVERSAL)
+        panel.SetupScrolling(scroll_x = False, scroll_y = True)
+        notebook.AddPage(page = panel, text = _("Raster legend"))
+        # is legend
+        self.isRLegend = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Show raster legend"))
+        self.isRLegend.SetValue(self.rLegendDict['rLegend'])
+        border.Add(item = self.isRLegend, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+        # choose raster
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Source raster"))
+        flexSizer = wx.FlexGridSizer (cols = 2, hgap = 5, vgap = 5)
+        flexSizer.AddGrowableCol(1)
+        self.rasterDefault = wx.RadioButton(panel, id = wx.ID_ANY, label = _("current raster"), style = wx.RB_GROUP)
+        self.rasterOther = wx.RadioButton(panel, id = wx.ID_ANY, label = _("select raster"))
+        self.rasterDefault.SetValue(self.rLegendDict['rasterDefault'])#
+        self.rasterOther.SetValue(not self.rLegendDict['rasterDefault'])#
+        rasterType = getRasterType(map = self.currRaster)
+        self.rasterCurrent = wx.StaticText(panel, id = wx.ID_ANY,
+                                label = _("%s: type %s" % (self.currRaster, rasterType)))
+        self.rasterSelect = Select( panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+        if not self.rLegendDict['rasterDefault']:
+            self.rasterSelect.SetValue(self.rLegendDict['raster'])
+        else:
+        flexSizer.Add(self.rasterDefault, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.rasterCurrent, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT, border = 10)
+        flexSizer.Add(self.rasterOther, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.rasterSelect, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        sizer.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        # type of legend
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Type of legend"))
+        vbox = wx.BoxSizer(wx.VERTICAL)
+        self.discrete = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+                        label = " %s " % _("discrete legend (categorical maps)"), style = wx.RB_GROUP)
+        self.continuous = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+                        label = " %s " % _("continuous color gradient legend (floating point map)"))
+        vbox.Add(self.discrete, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 0)
+        vbox.Add(self.continuous, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 0)
+        sizer.Add(item = vbox, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        # size, position and font
+        self.sizePositionFont(legendType = 'raster', parent = panel, mainSizer = border)
+        # advanced settings
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Advanced legend settings"))
+        # no data
+        self.nodata = wx.CheckBox(panel, id = wx.ID_ANY, label = _('draw "no data" box'))
+        if self.rLegendDict['nodata'] == 'y':
+            self.nodata.SetValue(True)
+        else:
+            self.nodata.SetValue(False)
+        #tickbar
+        self.ticks = wx.CheckBox(panel, id = wx.ID_ANY, label = _("draw ticks across color table"))
+        if self.rLegendDict['tickbar'] == 'y':
+            self.ticks.SetValue(True)
+        else:
+            self.ticks.SetValue(False)
+        # range
+        if self.rasterId and self.instruction[self.rasterId]['raster']:
+            rinfo = grass.raster_info(self.instruction[self.rasterId]['raster'])
+            self.minim, self.maxim = rinfo['min'], rinfo['max']
+        else:
+            self.minim, self.maxim = 0,0
+        self.range = wx.CheckBox(panel, id = wx.ID_ANY, label = _("range"))
+        self.range.SetValue(self.rLegendDict['range'])
+        self.minText =  wx.StaticText(panel, id = wx.ID_ANY, label = "min (%s)" % self.minim)
+        self.maxText =  wx.StaticText(panel, id = wx.ID_ANY, label = "max (%s)" % self.maxim)
+        self.min = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(self.rLegendDict['min']))
+        self.max = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(self.rLegendDict['max']))
+        gridBagSizer.Add(self.nodata, pos = (0,0), span = (1,5), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.ticks, pos = (1,0), span = (1,5), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.range, pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.minText, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        gridBagSizer.Add(self.min, pos = (2,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.maxText, pos = (2,3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT, border = 0)
+        gridBagSizer.Add(self.max, pos = (2,4), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(gridBagSizer, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        panel.Fit()
+        # bindings
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRaster, self.rasterDefault)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnRaster, self.rasterOther)
+        self.Bind(wx.EVT_CHECKBOX, self.OnIsLegend, self.isRLegend)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnDiscrete, self.discrete)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnDiscrete, self.continuous)
+##        self.Bind(wx.EVT_CHECKBOX, self.OnDefaultSize, panel.defaultSize)
+        self.Bind(wx.EVT_CHECKBOX, self.OnRange, self.range)
+        self.rasterSelect.GetTextCtrl().Bind(wx.EVT_TEXT, self.OnRaster)
+        return panel
+    def _vectorLegend(self, notebook):
+        notebook.AddPage(page = panel, text = _("Vector legend"))
+        border = wx.BoxSizer(wx.VERTICAL)
+        # is legend
+        self.isVLegend = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Show vector legend"))
+        self.isVLegend.SetValue(self.vLegendDict['vLegend'])
+        border.Add(item = self.isVLegend, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+        #vector maps, their order, labels
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Source vector maps"))
+        gridBagSizer.AddGrowableCol(0,3)
+        vectorText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Choose vector maps and their order in legend"))
+        self.vectorListCtrl = CheckListCtrl(panel)
+        self.vectorListCtrl.InsertColumn(0, _("Vector map"))
+        self.vectorListCtrl.InsertColumn(1, _("Label"))
+        if self.vectorId:
+            vectors = sorted(self.instruction[self.vectorId]['list'], key = lambda x: x[3])
+                index = self.vectorListCtrl.InsertStringItem(sys.maxint, vector[0].split('@')[0])
+                self.vectorListCtrl.SetStringItem(index, 1, vector[4])
+                self.vectorListCtrl.SetItemData(index, index)
+                self.vectorListCtrl.CheckItem(index, True)
+                if vector[3] == 0:
+                    self.vectorListCtrl.CheckItem(index, False)
+        if not self.vectorId:
+            self.vectorListCtrl.SetColumnWidth(0, 100)
+        else:
+            self.vectorListCtrl.SetColumnWidth(0, wx.LIST_AUTOSIZE)
+        self.vectorListCtrl.SetColumnWidth(1, wx.LIST_AUTOSIZE)
+        self.btnUp = wx.Button(panel, id = wx.ID_ANY, label = _("Up"))
+        self.btnDown = wx.Button(panel, id = wx.ID_ANY, label = _("Down"))
+        self.btnLabel = wx.Button(panel, id = wx.ID_ANY, label = _("Edit label"))
+        gridBagSizer.Add(vectorText, pos = (0,0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.vectorListCtrl, pos = (1,0), span = (3,1), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(self.btnUp, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.btnDown, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.btnLabel, pos = (3,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(gridBagSizer, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        self.sizePositionFont(legendType = 'vector', parent = panel, mainSizer = border)
+        # border
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Border"))
+        flexGridSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
+        self.borderCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("draw border around legend"))
+        self.borderColorCtrl = wx.ColourPickerCtrl(panel, id = wx.ID_ANY, style = wx.FNTP_FONTDESC_AS_LABEL)
+        if self.vLegendDict['border'] == 'none':
+            self.borderColorCtrl.SetColour('black')
+        else:
+            self.borderColorCtrl.SetColour(convertRGB(self.vLegendDict['border']))
+        flexGridSizer.Add(self.borderCheck, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(self.borderColorCtrl, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(item = flexGridSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        self.Bind(wx.EVT_BUTTON, self.OnEditLabel, self.btnLabel)
+        self.Bind(wx.EVT_CHECKBOX, self.OnIsLegend, self.isVLegend)
+        self.Bind(wx.EVT_CHECKBOX, self.OnSpan, panel.spanRadio)
+        self.Bind(wx.EVT_FONTPICKER_CHANGED, self.OnFont, panel.font['fontCtrl'])
+        panel.Fit()
+        return panel
+    def sizePositionFont(self, legendType, parent, mainSizer):
+        """!Insert widgets for size, position and font control"""
+        if legendType == 'raster':
+            legendDict = self.rLegendDict
+        else:
+            legendDict = self.vLegendDict
+        panel = parent
+        border = mainSizer
+        # size and position
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Size and position"))
+        #unit
+        self.AddUnits(parent = panel, dialogDict = legendDict)
+        unitBox = wx.BoxSizer(wx.HORIZONTAL)
+        unitBox.Add(panel.units['unitsLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT, border = 10)
+        unitBox.Add(panel.units['unitsCtrl'], proportion = 1, flag = wx.ALL, border = 5)
+        sizer.Add(unitBox, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        hBox = wx.BoxSizer(wx.HORIZONTAL)
+        posBox = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " %_("Position"))
+        posSizer = wx.StaticBoxSizer(posBox, wx.VERTICAL)
+        sizeBox = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Size"))
+        sizeSizer = wx.StaticBoxSizer(sizeBox, wx.VERTICAL)
+        posGridBagSizer = wx.GridBagSizer(hgap = 10, vgap = 5)
+        posGridBagSizer.AddGrowableRow(2)
+        #position
+        self.AddPosition(parent = panel, dialogDict = legendDict)
+        posGridBagSizer.Add(panel.position['xLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        posGridBagSizer.Add(panel.position['xCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        posGridBagSizer.Add(panel.position['yLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        posGridBagSizer.Add(panel.position['yCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        posGridBagSizer.Add(panel.position['comment'], pos = (2,0), span = (1,2), flag =wx.ALIGN_BOTTOM, border = 0)
+        posSizer.Add(posGridBagSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        #size
+        width = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width:"))
+        if legendDict['width']:
+            w = self.unitConv.convert(value = float(legendDict['width']), fromUnit = 'inch', toUnit = legendDict['unit'])
+        else:
+            w = ''
+        panel.widthCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(w), validator = TCValidator("DIGIT_ONLY"))
+        panel.widthCtrl.SetToolTipString(_("Leave the edit field empty, to use default values."))
+##            panel.defaultSize = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Use default size"))
+##            panel.defaultSize.SetValue(legendDict['defaultSize'])
+            panel.heightOrColumnsLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Height:"))
+            if legendDict['height']:
+                h = self.unitConv.convert(value = float(legendDict['height']), fromUnit = 'inch', toUnit = legendDict['unit'])
+            else:
+                h = ''
+            panel.heightOrColumnsCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = str(h), validator = TCValidator("DIGIT_ONLY"))
+            self.rSizeGBSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+##            self.rSizeGBSizer.Add(panel.defaultSize, pos = (0,0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.rSizeGBSizer.Add(width, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.rSizeGBSizer.Add(panel.widthCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.rSizeGBSizer.Add(panel.heightOrColumnsLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.rSizeGBSizer.Add(panel.heightOrColumnsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            sizeSizer.Add(self.rSizeGBSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        if legendType == 'vector':
+            panel.widthCtrl.SetToolTipString(_("Width of the color symbol (for lines)\nin front of the legend text"))
+            #columns
+            minVect, maxVect = 0, 0
+            if self.vectorId:
+                minVect = 1
+                maxVect = min(10, len(self.instruction[self.vectorId]['list']))
+            cols = wx.StaticText(panel, id = wx.ID_ANY, label = _("Columns:"))
+            panel.colsCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, value = "",
+                                        min = minVect, max = maxVect, initial = legendDict['cols'])
+            #span
+            panel.spanRadio = wx.CheckBox(panel, id = wx.ID_ANY, label = _("column span:"))
+            panel.spanTextCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = '')
+            panel.spanTextCtrl.SetToolTipString(_("Column separation distance between the left edges\n"\
+                                                "of two columns in a multicolumn legend"))
+            if legendDict['span']:
+                panel.spanRadio.SetValue(True)
+                s = self.unitConv.convert(value = float(legendDict['span']), fromUnit = 'inch', toUnit = legendDict['unit'])
+                panel.spanTextCtrl.SetValue(str(s))
+            else:
+                panel.spanRadio.SetValue(False)
+            self.vSizeGBSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+            self.vSizeGBSizer.AddGrowableCol(1)
+            self.vSizeGBSizer.Add(width, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.vSizeGBSizer.Add(panel.widthCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.vSizeGBSizer.Add(cols, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.vSizeGBSizer.Add(panel.colsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.vSizeGBSizer.Add(panel.spanRadio, pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            self.vSizeGBSizer.Add(panel.spanTextCtrl, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            sizeSizer.Add(self.vSizeGBSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        hBox.Add(posSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 3)
+        hBox.Add(sizeSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 3)
+        sizer.Add(hBox, proportion = 0, flag = wx.EXPAND, border = 0)
+        border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+        # font
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Font settings"))
+        fontSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+            self.AddFont(parent = panel, dialogDict = legendDict, color = True)
+        else:
+            self.AddFont(parent = panel, dialogDict = legendDict, color = False)
+        flexSizer.Add(panel.font['fontLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(panel.font['fontCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(panel.font['fontSizeLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(panel.font['fontSizeCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            flexSizer.Add(panel.font['colorLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+            flexSizer.Add(panel.font['colorCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        fontSizer.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        border.Add(item = fontSizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+    #   some enable/disable methods
+    def OnIsLegend(self, event):
+        """!Enables and disables controls, it depends if raster or vector legend is checked"""
+        page = self.notebook.GetSelection()
+        if page == 0 or event is None:
+            children = self.panelRaster.GetChildren()
+            if self.isRLegend.GetValue():
+                for i,widget in enumerate(children):
+                        widget.Enable()
+                self.OnDiscrete(None)
+            else:
+                    if i != 0:
+                        widget.Disable()
+        if page == 1 or event is None:
+            children = self.panelVector.GetChildren()
+            if self.isVLegend.GetValue():
+                for i, widget in enumerate(children):
+                        widget.Enable()
+                self.OnSpan(None)
+                self.OnBorder(None)
+            else:
+                    if i != 0:
+                        widget.Disable()
+        if self.rasterDefault.GetValue():#default
+            self.rasterSelect.Disable()
+            type = getRasterType(self.currRaster)
+        else:#select raster
+            self.rasterSelect.Enable()
+            map = self.rasterSelect.GetValue()
+            type = getRasterType(map)
+        if type == 'CELL':
+            self.discrete.SetValue(True)
+        elif type in ('FCELL', 'DCELL'):
+            self.continuous.SetValue(True)
+        if event is None:
+            if self.rLegendDict['discrete'] == 'y':
+            elif self.rLegendDict['discrete'] == 'n':
+    def OnDiscrete(self, event):
+        """! Change control according to the type of legend"""
+        enabledSize = self.panelRaster.heightOrColumnsCtrl.IsEnabled()
+        self.panelRaster.heightOrColumnsCtrl.Destroy()
+        if self.discrete.GetValue():
+            self.panelRaster.heightOrColumnsLabel.SetLabel(_("Columns:"))
+            self.panelRaster.heightOrColumnsCtrl = wx.SpinCtrl(self.panelRaster, id = wx.ID_ANY, value = "", min = 1, max = 10, initial = self.rLegendDict['cols'])
+            self.panelRaster.heightOrColumnsCtrl.Enable(enabledSize)
+            self.nodata.Enable()
+            self.range.Disable()
+            self.min.Disable()
+            self.max.Disable()
+            self.minText.Disable()
+            self.maxText.Disable()
+            self.ticks.Disable()
+        else:
+            self.panelRaster.heightOrColumnsLabel.SetLabel(_("Height:"))
+            if self.rLegendDict['height']:
+                h = self.unitConv.convert(value = float(self.rLegendDict['height']), fromUnit = 'inch', toUnit = self.rLegendDict['unit'])
+            else:
+                h = ''
+            self.panelRaster.heightOrColumnsCtrl = wx.TextCtrl(self.panelRaster, id = wx.ID_ANY,
+                                                    value = str(h), validator = TCValidator("DIGIT_ONLY"))
+            self.nodata.Disable()
+            self.range.Enable()
+            if self.range.GetValue():
+                self.minText.Enable()
+                self.maxText.Enable()
+                self.min.Enable()
+                self.max.Enable()
+            self.ticks.Enable()
+        self.rSizeGBSizer.Add(self.panelRaster.heightOrColumnsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.panelRaster.Layout()
+        self.panelRaster.Fit()
+    def OnRange(self, event):
+        if not self.range.GetValue():
+        else:
+            self.min.Enable()
+            self.max.Enable()
+        """!Moves selected map up, changes order in vector legend"""
+        if self.vectorListCtrl.GetFirstSelected() != -1:
+            pos = self.vectorListCtrl.GetFirstSelected()
+            if pos:
+                idx1 = self.vectorListCtrl.GetItemData(pos) - 1
+                idx2 = self.vectorListCtrl.GetItemData(pos - 1) + 1
+                self.vectorListCtrl.SetItemData(pos, idx1)
+                self.vectorListCtrl.SetItemData(pos - 1, idx2)
+                self.vectorListCtrl.SortItems(cmp)
+                if pos > 0:
+                    selected = (pos - 1)
+                else:
+                    selected = 0
+                self.vectorListCtrl.Select(selected)
+        """!Moves selected map down, changes order in vector legend"""
+            if pos != self.vectorListCtrl.GetItemCount() - 1:
+                idx1 = self.vectorListCtrl.GetItemData(pos) + 1
+                idx2 = self.vectorListCtrl.GetItemData(pos + 1) - 1
+                self.vectorListCtrl.SetItemData(pos + 1, idx2)
+                if pos < self.vectorListCtrl.GetItemCount() -1:
+                    selected = (pos + 1)
+                else:
+                    selected = self.vectorListCtrl.GetItemCount() -1
+    def OnEditLabel(self, event):
+        """!Change legend label of vector map"""
+            idx = self.vectorListCtrl.GetFirstSelected()
+            default = self.vectorListCtrl.GetItem(idx, 1).GetText()
+            dlg = wx.TextEntryDialog(self, message = _("Edit legend label:"), caption = _("Edit label"),
+                                    defaultValue = default, style = wx.OK|wx.CANCEL|wx.CENTRE)
+            if dlg.ShowModal() == wx.ID_OK:
+                new = dlg.GetValue()
+                self.vectorListCtrl.SetStringItem(idx, 1, new)
+            dlg.Destroy()
+    def OnSpan(self, event):
+        self.panelVector.spanTextCtrl.Enable(self.panelVector.spanRadio.GetValue())
+    def OnFont(self, event):
+        """!Changes default width according to fontsize, width [inch] = fontsize[pt]/24"""
+##        fontsize = self.panelVector.font['fontCtrl'].GetSelectedFont().GetPointSize()
+        fontsize = self.panelVector.font['fontSizeCtrl'].GetValue()
+        unit = self.panelVector.units['unitsCtrl'].GetStringSelection()
+        w = fontsize/24.
+        width = self.unitConv.convert(value = w, fromUnit = 'inch', toUnit = unit)
+        self.panelVector.widthCtrl.SetValue("%3.2f" % width)
+    def OnBorder(self, event):
+        """!Enables/disables colorPickerCtrl for border"""
+        self.borderColorCtrl.Enable(self.borderCheck.GetValue())
+    def updateRasterLegend(self):
+        """!Save information from raster legend dialog to dictionary"""
+        #is raster legend
+        if not self.isRLegend.GetValue():
+            self.rLegendDict['rLegend'] = False
+        else:
+            self.rLegendDict['rLegend'] = True
+        #units
+        currUnit = self.panelRaster.units['unitsCtrl'].GetStringSelection()
+        self.rLegendDict['unit'] = currUnit
+        # raster
+            self.rLegendDict['rasterDefault'] = True
+            self.rLegendDict['raster'] = self.currRaster
+        else:
+            self.rLegendDict['rasterDefault'] = False
+            self.rLegendDict['raster'] = self.rasterSelect.GetValue()
+        if self.rLegendDict['rLegend'] and not self.rLegendDict['raster']:
+            wx.MessageBox(message = _("No raster map selected!"),
+                                    caption = _('No raster'), style = wx.OK|wx.ICON_ERROR)
+            return False
+        if self.rLegendDict['raster']:
+            # type and range of map
+            rasterType = getRasterType(self.rLegendDict['raster'])
+            if rasterType is None:
+                return False
+            self.rLegendDict['type'] = rasterType
+            #discrete
+                self.rLegendDict['discrete'] = 'y'
+            else:
+                self.rLegendDict['discrete'] = 'n'
+            # font
+            self.rLegendDict['font'] = self.panelRaster.font['fontCtrl'].GetStringSelection()
+            self.rLegendDict['fontsize'] = self.panelRaster.font['fontSizeCtrl'].GetValue()
+##            font = self.panelRaster.font['fontCtrl'].GetSelectedFont()
+##            self.rLegendDict['font'] = font.GetFaceName()
+##            self.rLegendDict['fontsize'] = font.GetPointSize()
+            color = self.panelRaster.font['colorCtrl'].GetColour()
+##            if color.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
+##                self.rLegendDict['color'] = color.GetAsString(wx.C2S_NAME)
+##            else:
+            self.rLegendDict['color'] = convertRGB(color)
+            # position
+            x = self.unitConv.convert(value = float(self.panelRaster.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
+            y = self.unitConv.convert(value = float(self.panelRaster.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
+            self.rLegendDict['where'] = (x, y)
+            # estimated size
+            width = self.panelRaster.widthCtrl.GetValue()
+            try:
+                width = float(width)
+                width = self.unitConv.convert(value = width, fromUnit = currUnit, toUnit = 'inch')
+            except ValueError:
+                width = None
+            self.rLegendDict['width'] = width
+            if self.rLegendDict['discrete'] == 'n':
+                height = self.panelRaster.heightOrColumnsCtrl.GetValue()
+                try:
+                    height = float(height)
+                    height = self.unitConv.convert(value = height, fromUnit = currUnit, toUnit = 'inch')
+                    height = None
+                self.rLegendDict['height'] = height
+            else:
+                cols = self.panelRaster.heightOrColumnsCtrl.GetValue()
+                self.rLegendDict['cols'] = cols
+            drawHeight = self.rasterLegend.EstimateHeight(raster = self.rLegendDict['raster'], discrete = self.rLegendDict['discrete'],
+                                            fontsize = self.rLegendDict['fontsize'], cols = self.rLegendDict['cols'],
+                                            height = self.rLegendDict['height'])
+            drawWidth = self.rasterLegend.EstimateWidth(raster = self.rLegendDict['raster'], discrete = self.rLegendDict['discrete'],
+                                            width = self.rLegendDict['width'], paperInstr = self.instruction[self.pageId])
+            self.rLegendDict['rect'] = wx.Rect2D(x = x, y = y, w = drawWidth, h = drawHeight)
+            # no data
+                if self.nodata.GetValue():
+                    self.rLegendDict['nodata'] = 'y'
+                else:
+                    self.rLegendDict['nodata'] = 'n'
+            # tickbar
+                if self.ticks.GetValue():
+                    self.rLegendDict['tickbar'] = 'y'
+                else:
+                    self.rLegendDict['tickbar'] = 'n'
+            # range
+                    self.rLegendDict['range'] = True
+                    self.rLegendDict['min'] = self.min.GetValue()
+                    self.rLegendDict['max'] = self.max.GetValue()
+                else:
+                    self.rLegendDict['range'] = False
+        if not self.id[0] in self.instruction:
+            rasterLegend = RasterLegend(self.id[0])
+            self.instruction.AddInstruction(rasterLegend)
+        self.instruction[self.id[0]].SetInstruction(self.rLegendDict)
+        if self.id[0] not in self.parent.objectId:
+            self.parent.objectId.append(self.id[0])
+        return True
+    def updateVectorLegend(self):
+        """!Save information from vector legend dialog to dictionary"""
+        vector = self.instruction.FindInstructionByType('vector')
+        if vector:
+        else:
+        #is vector legend
+        if not self.isVLegend.GetValue():
+            self.vLegendDict['vLegend'] = False
+        else:
+            self.vLegendDict['vLegend'] = True
+        if self.vLegendDict['vLegend'] == True and self.vectorId is not None:
+            # labels
+            #reindex order
+            idx = 1
+            for item in range(self.vectorListCtrl.GetItemCount()):
+                if self.vectorListCtrl.IsChecked(item):
+                    self.vectorListCtrl.SetItemData(item, idx)
+                    idx += 1
+                else:
+                    self.vectorListCtrl.SetItemData(item, 0)
+            if idx == 1:
+            else:
+                vList = self.instruction[self.vectorId]['list']
+                for i, vector in enumerate(vList):
+                    item = self.vectorListCtrl.FindItem(start = -1, str = vector[0].split('@')[0])
+                    vList[i][3] = self.vectorListCtrl.GetItemData(item)
+                    vList[i][4] = self.vectorListCtrl.GetItem(item, 1).GetText()
+                vmaps = self.instruction.FindInstructionByType('vProperties', list = True)
+                for vmap, vector in zip(vmaps, vList):
+                    self.instruction[vmap.id]['lpos'] = vector[3]
+                    self.instruction[vmap.id]['label'] = vector[4]
+                #units
+                currUnit = self.panelVector.units['unitsCtrl'].GetStringSelection()
+                self.vLegendDict['unit'] = currUnit
+                # position
+                x = self.unitConv.convert(value = float(self.panelVector.position['xCtrl'].GetValue()),
+        fromUnit = currUnit, toUnit = 'inch')
+                y = self.unitConv.convert(value = float(self.panelVector.position['yCtrl'].GetValue()),
+                self.vLegendDict['where'] = (x, y)
+                # font
+                self.vLegendDict['font'] = self.panelVector.font['fontCtrl'].GetStringSelection()
+                self.vLegendDict['fontsize'] = self.panelVector.font['fontSizeCtrl'].GetValue()
+##                self.vLegendDict['font'] = font.GetFaceName()
+##                self.vLegendDict['fontsize'] = font.GetPointSize()
+                dc = wx.PaintDC(self)
+                font = dc.GetFont()
+                dc.SetFont(wx.Font(   pointSize = self.vLegendDict['fontsize'], family = font.GetFamily(),
+                                                style = font.GetStyle(), weight = wx.FONTWEIGHT_NORMAL))
+                #size
+                width = self.unitConv.convert(value = float(self.panelVector.widthCtrl.GetValue()),
+                self.vLegendDict['width'] = width
+                self.vLegendDict['cols'] = self.panelVector.colsCtrl.GetValue()
+                if self.panelVector.spanRadio.GetValue() and self.panelVector.spanTextCtrl.GetValue():
+                    self.vLegendDict['span'] = self.panelVector.spanTextCtrl.GetValue()
+                else:
+                    self.vLegendDict['span'] = None
+                # size estimation
+                vectors = self.instruction[self.vectorId]['list']
+                labels = [vector[4] for vector in vectors if vector[3] != 0]
+                extent = dc.GetTextExtent(max(labels, key = len))
+                wExtent = self.unitConv.convert(value = extent[0], fromUnit = 'pixel', toUnit = 'inch')
+                hExtent = self.unitConv.convert(value = extent[1], fromUnit = 'pixel', toUnit = 'inch')
+                w = (width + wExtent) * self.vLegendDict['cols']
+                h = len(labels) * hExtent / self.vLegendDict['cols']
+                h *= 1.1
+                self.vLegendDict['rect'] = wx.Rect2D(x, y, w, h)
+                #border
+                if self.borderCheck.GetValue():
+                    color = self.borderColorCtrl.GetColour()
+##                        self.vLegendDict['border'] = color.GetAsString(wx.C2S_NAME)
+##                    else:
+                    self.vLegendDict['border'] = convertRGB(color)
+                else:
+                    self.vLegendDict['border'] = 'none'
+        if not self.id[1] in self.instruction:
+            self.instruction.AddInstruction(vectorLegend)
+        self.instruction[self.id[1]].SetInstruction(self.vLegendDict)
+        if self.id[1] not in self.parent.objectId:
+            self.parent.objectId.append(self.id[1])
+        return True
+    def update(self):
+        okR = self.updateRasterLegend()
+        okV = self.updateVectorLegend()
+        if okR and okV:
+            return True
+        return False
+    def updateDialog(self):
+        """!Update legend coordinates after moving"""
+        # raster legend
+        if 'rect' in self.rLegendDict:
+            x, y = self.rLegendDict['rect'][:2]
+            x = self.unitConv.convert(value = x, fromUnit = 'inch', toUnit = currUnit)
+            y = self.unitConv.convert(value = y, fromUnit = 'inch', toUnit = currUnit)
+            self.panelRaster.position['xCtrl'].SetValue("%5.3f" % x)
+            self.panelRaster.position['yCtrl'].SetValue("%5.3f" % y)
+        #update name and type of raster
+        raster = self.instruction.FindInstructionByType('raster')
+        if raster:
+        else:
+        if raster:
+            currRaster = raster['raster']
+        else:
+            currRaster = None
+        rasterType = getRasterType(map = currRaster)
+        self.rasterCurrent.SetLabel( _("%s: type %s") % (currRaster, str(rasterType)))
+        # vector legend
+        if 'rect' in self.vLegendDict:
+            x, y = self.vLegendDict['rect'][:2]
+            self.panelVector.position['xCtrl'].SetValue("%5.3f" % x)
+            self.panelVector.position['yCtrl'].SetValue("%5.3f" % y)
+        # update vector maps
+        if self.instruction.FindInstructionByType('vector'):
+            vectors = sorted(self.instruction.FindInstructionByType('vector')['list'], key = lambda x: x[3])
+            self.vectorListCtrl.DeleteAllItems()
+            for vector in vectors:
+            self.panelVector.colsCtrl.SetRange(1, min(10, len(self.instruction.FindInstructionByType('vector')['list'])))
+            self.panelVector.colsCtrl.SetValue(1)
+        else:
+            self.panelVector.colsCtrl.SetRange(0,0)
+            self.panelVector.colsCtrl.SetValue(0)
+class MapinfoDialog(PsmapDialog):
+    def __init__(self, parent, id, settings):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "Mapinfo settings", settings = settings)
+        self.objectType = ('mapinfo',)
+        if self.id is not None:
+            self.mapinfo = self.instruction[self.id]
+            self.mapinfoDict = self.mapinfo.GetInstruction()
+        else:
+            self.id = wx.NewId()
+            self.mapinfo = Mapinfo(self.id)
+            page = self.instruction.FindInstructionByType('page').GetInstruction()
+            self.mapinfoDict['where'] = page['Left'], page['Top']
+        self.panel = self._mapinfoPanel()
+        self._layout(self.panel)
+        self.OnIsBackground(None)
+        self.OnIsBorder(None)
+    def _mapinfoPanel(self):
+        panel = wx.Panel(parent = self, id = wx.ID_ANY, size = (-1, -1), style = wx.TAB_TRAVERSAL)
+        #panel.SetupScrolling(scroll_x = False, scroll_y = True)
+        # position
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Position"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridBagSizer = wx.GridBagSizer (hgap = 5, vgap = 5)
+        self.AddPosition(parent = panel, dialogDict = self.mapinfoDict)
+        self.AddUnits(parent = panel, dialogDict = self.mapinfoDict)
+        gridBagSizer.Add(panel.units['unitsLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.units['unitsCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.position['xLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.position['xCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.position['yLabel'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.position['yCtrl'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.position['comment'], pos = (3,0), span = (1,2), flag =wx.ALIGN_BOTTOM, border = 0)
+        sizer.Add(gridBagSizer, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        # font
+        self.AddFont(parent = panel, dialogDict = self.mapinfoDict)#creates font color too, used below
+##        gridBagSizer.Add(panel.font['fontLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+##        gridBagSizer.Add(panel.font['fontCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+##        gridBagSizer.Add(panel.font['colorLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+##        gridBagSizer.Add(panel.font['colorCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['fontLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['fontCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['fontSizeLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['fontSizeCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['colorLabel'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(panel.font['colorCtrl'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(item = gridBagSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        # colors
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " %_("Color settings"))
+        self.colors = {}
+        self.colors['borderCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("use border color:"))
+        self.colors['backgroundCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("use background color:"))
+        self.colors['borderColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        self.colors['backgroundColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        if self.mapinfoDict['border'] != 'none':
+            self.colors['borderCtrl'].SetValue(True)
+        else:
+            self.colors['borderCtrl'].SetValue(False)
+        if self.mapinfoDict['background'] != 'none':
+            self.colors['backgroundCtrl'].SetValue(True)
+        else:
+            self.colors['backgroundCtrl'].SetValue(False)
+            self.colors['borderColor'].SetColour(convertRGB(self.mapinfoDict['border']))
+        else:
+            self.colors['borderColor'].SetColour('black')
+            self.colors['backgroundColor'].SetColour(convertRGB(self.mapinfoDict['background']))
+        else:
+            self.colors['backgroundColor'].SetColour('black')
+        flexSizer.Add(self.colors['borderCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.colors['borderColor'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.colors['backgroundCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexSizer.Add(self.colors['backgroundColor'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.Bind(wx.EVT_CHECKBOX, self.OnIsBorder, self.colors['borderCtrl'])
+        self.Bind(wx.EVT_CHECKBOX, self.OnIsBackground, self.colors['backgroundCtrl'])
+        return panel
+    def OnIsBackground(self, event):
+        if self.colors['backgroundCtrl'].GetValue():
+            self.colors['backgroundColor'].Enable()
+        else:
+            self.colors['backgroundColor'].Disable()
+    def OnIsBorder(self, event):
+        if self.colors['borderCtrl'].GetValue():
+            self.colors['borderColor'].Enable()
+        else:
+            self.colors['borderColor'].Disable()
+    def update(self):
+        #units
+        currUnit = self.panel.units['unitsCtrl'].GetStringSelection()
+        self.mapinfoDict['unit'] = currUnit
+        # position
+        if self.panel.position['xCtrl'].GetValue():
+            x = self.panel.position['xCtrl'].GetValue()
+        else:
+            x = self.mapinfoDict['where'][0]
+        if self.panel.position['yCtrl'].GetValue():
+            y = self.panel.position['yCtrl'].GetValue()
+        else:
+            y = self.mapinfoDict['where'][1]
+        x = self.unitConv.convert(value = float(self.panel.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
+        y = self.unitConv.convert(value = float(self.panel.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
+        self.mapinfoDict['where'] = (x, y)
+        # font
+        self.mapinfoDict['font'] =  self.panel.font['fontCtrl'].GetStringSelection()
+        self.mapinfoDict['fontsize'] = self.panel.font['fontSizeCtrl'].GetValue()
+##        font = self.panel.font['fontCtrl'].GetSelectedFont()
+##        self.mapinfoDict['font'] = font.GetFaceName()
+##        self.mapinfoDict['fontsize'] = font.GetPointSize()
+        #colors
+        color = self.panel.font['colorCtrl'].GetColour()
+##            self.mapinfoDict['color'] = color.GetAsString(wx.C2S_NAME)
+##        else:
+        self.mapinfoDict['color'] = convertRGB(color)
+            background = self.colors['backgroundColor'].GetColour()
+##            if background.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
+##                self.mapinfoDict['background'] = background.GetAsString(wx.C2S_NAME)
+##            else:
+            self.mapinfoDict['background'] = convertRGB(background)
+        else:
+            self.mapinfoDict['background'] = 'none'
+            border = self.colors['borderColor'].GetColour()
+##            if border.GetAsString(wx.C2S_NAME) in PSMAP_COLORS:
+##                self.mapinfoDict['border'] = border.GetAsString(wx.C2S_NAME)
+##            else:
+            self.mapinfoDict['border'] = convertRGB(border)
+        else:
+            self.mapinfoDict['border'] = 'none'
+        # estimation of size
+        self.mapinfoDict['rect'] = self.mapinfo.EstimateRect(self.mapinfoDict)
+        if self.id not in self.instruction:
+            mapinfo = Mapinfo(self.id)
+            self.instruction.AddInstruction(mapinfo)
+        self.instruction[self.id].SetInstruction(self.mapinfoDict)
+        if self.id not in self.parent.objectId:
+            self.parent.objectId.append(self.id)
+        return True
+        """!Update mapinfo coordinates, after moving"""
+        x, y = self.mapinfoDict['where']
+        self.panel.position['xCtrl'].SetValue("%5.3f" % x)
+        self.panel.position['yCtrl'].SetValue("%5.3f" % y)
+class ScalebarDialog(PsmapDialog):
+    """!Dialog for scale bar"""
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "Scale bar settings", settings = settings)
+        self.objectType = ('scalebar',)
+            self.scalebar = self.instruction[id]
+            self.scalebarDict = self.scalebar.GetInstruction()
+        else:
+            self.scalebar = Scalebar(self.id)
+            self.scalebarDict['where'] = page['Left'], page['Top']
+        self.panel = self._scalebarPanel()
+        self.mapUnit = projInfo()['units'].lower()
+        if projInfo()['proj'] == 'xy':
+            self.mapUnit = 'meters'
+        if self.mapUnit not in self.unitConv.getAllUnits():
+            wx.MessageBox(message = _("Units of current projection are not supported,\n meters will be used!"),
+                            caption = _('Unsupported units'),
+                                    style = wx.OK|wx.ICON_ERROR)
+    def _scalebarPanel(self):
+        panel = wx.Panel(parent = self, id = wx.ID_ANY, style = wx.TAB_TRAVERSAL)
+        # position
+        self.AddUnits(parent = panel, dialogDict = self.scalebarDict)
+        self.AddPosition(parent = panel, dialogDict = self.scalebarDict)
+        if self.scalebarDict['rect']: # set position, ref point is center and not left top corner
+            x = self.unitConv.convert(value = self.scalebarDict['where'][0] - self.scalebarDict['rect'].Get()[2]/2,
+                                                    fromUnit = 'inch', toUnit = self.scalebarDict['unit'])
+            y = self.unitConv.convert(value = self.scalebarDict['where'][1] - self.scalebarDict['rect'].Get()[3]/2,
+            panel.position['xCtrl'].SetValue("%5.3f" % x)
+            panel.position['yCtrl'].SetValue("%5.3f" % y)
+        # size
+        lengthText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Length:"))
+        heightText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Height:"))
+        self.lengthTextCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, validator = TCValidator('DIGIT_ONLY'))
+        self.lengthTextCtrl.SetToolTipString(_("Scalebar length is given in map units"))
+        self.heightTextCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, validator = TCValidator('DIGIT_ONLY'))
+        self.heightTextCtrl.SetToolTipString(_("Scalebar height is real height on paper"))
+        choices = ['default'] + self.unitConv.getMapUnits()
+        self.unitsLength = wx.Choice(panel, id = wx.ID_ANY, choices = choices)
+        choices = self.unitConv.getPageUnits()
+        self.unitsHeight = wx.Choice(panel, id = wx.ID_ANY, choices = choices)
+        # set values
+        ok = self.unitsLength.SetStringSelection(self.scalebarDict['unitsLength'])
+        if not ok:
+            if self.scalebarDict['unitsLength'] == 'auto':
+                 self.unitsLength.SetSelection(0)
+            elif self.scalebarDict['unitsLength'] == 'nautmiles':
+                 self.unitsLength.SetStringSelection("nautical miles")
+        self.unitsHeight.SetStringSelection(self.scalebarDict['unitsHeight'])
+        if self.scalebarDict['length']:
+            self.lengthTextCtrl.SetValue(str(self.scalebarDict['length']))
+        else: #estimate default
+            reg = grass.region()
+            w = int((reg['e'] - reg['w'])/3)
+            w = round(w, -len(str(w)) + 2) #12345 -> 12000
+            self.lengthTextCtrl.SetValue(str(w))
+        h = self.unitConv.convert(value = self.scalebarDict['height'], fromUnit = 'inch',
+                                                toUnit =  self.scalebarDict['unitsHeight'])
+        self.heightTextCtrl.SetValue(str(h))
+        gridBagSizer.Add(lengthText, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.lengthTextCtrl, pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.unitsLength, pos = (0, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(heightText, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.heightTextCtrl, pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.unitsHeight, pos = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        #style
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Style"))
+        sbTypeText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Type:"))
+        self.sbCombo = wx.combo.BitmapComboBox(panel, style = wx.CB_READONLY)
+        # only temporary, images must be moved away
+        imagePath = os.path.join(globalvar.ETCIMGDIR, "scalebar-fancy.png"), os.path.join(globalvar.ETCIMGDIR, "scalebar-simple.png")
+        for item, path in zip(['fancy', 'simple'], imagePath):
+            if not os.path.exists(path):
+                bitmap = wx.EmptyBitmap(0,0)
+            else:
+                bitmap = wx.Bitmap(path)
+            self.sbCombo.Append(item = '', bitmap = bitmap, clientData = item[0])
+        #self.sbCombo.Append(item = 'simple', bitmap = wx.Bitmap("./images/scalebar-simple.png"), clientData = 's')
+        if self.scalebarDict['scalebar'] == 'f':
+            self.sbCombo.SetSelection(0)
+        elif self.scalebarDict['scalebar'] == 's':
+            self.sbCombo.SetSelection(1)
+        sbSegmentsText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Number of segments:"))
+        self.sbSegmentsCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 30, initial = 4)
+        self.sbSegmentsCtrl.SetValue(self.scalebarDict['segment'])
+        sbLabelsText1 = wx.StaticText(panel, id = wx.ID_ANY, label = _("Label every "))
+        sbLabelsText2 = wx.StaticText(panel, id = wx.ID_ANY, label = _("segments"))
+        self.sbLabelsCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 30, initial = 1)
+        self.sbLabelsCtrl.SetValue(self.scalebarDict['numbers'])
+        #font
+        fontsizeText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Font size:"))
+        self.fontsizeCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 4, max = 30, initial = 10)
+        self.fontsizeCtrl.SetValue(self.scalebarDict['fontsize'])
+        self.backgroundCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("transparent text background"))
+        if self.scalebarDict['background'] == 'y':
+            self.backgroundCheck.SetValue(False)
+        else:
+            self.backgroundCheck.SetValue(True)
+        gridBagSizer.Add(sbTypeText, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sbCombo, pos = (0,1), span = (1, 2), flag = wx.ALIGN_CENTER_VERTICAL|wx.EXPAND, border = 0)
+        gridBagSizer.Add(sbSegmentsText, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sbSegmentsCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(sbLabelsText1, pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.sbLabelsCtrl, pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(sbLabelsText2, pos = (2,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(fontsizeText, pos = (3,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.fontsizeCtrl, pos = (3,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.backgroundCheck, pos = (4, 0), span = (1,3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizer.Add(gridBagSizer, proportion = 1, flag = wx.ALIGN_CENTER_VERTICAL, border = 5)
+        panel.SetSizer(border)
+        return panel
+    def update(self):
+        """!Save information from dialog"""
+        #units
+        self.scalebarDict['unit'] = currUnit
+        # position
+        else:
+            x = self.scalebarDict['where'][0]
+        else:
+            y = self.scalebarDict['where'][1]
+        #style
+        self.scalebarDict['scalebar'] = self.sbCombo.GetClientData(self.sbCombo.GetSelection())
+        self.scalebarDict['segment'] = self.sbSegmentsCtrl.GetValue()
+        self.scalebarDict['numbers'] = self.sbLabelsCtrl.GetValue()
+        self.scalebarDict['fontsize'] = self.fontsizeCtrl.GetValue()
+        if self.backgroundCheck.GetValue():
+            self.scalebarDict['background'] = 'n'
+        else:
+            self.scalebarDict['background'] = 'y'
+        # size
+        # height
+        self.scalebarDict['unitsHeight'] = self.unitsHeight.GetStringSelection()
+        try:
+            height = float(self.heightTextCtrl.GetValue())
+            height = self.unitConv.convert(value = height, fromUnit = self.scalebarDict['unitsHeight'], toUnit = 'inch')
+        except (ValueError, SyntaxError):
+            height = 0.1 #default in inch
+        self.scalebarDict['height'] = height
+        #length
+        selected = self.unitsLength.GetStringSelection()
+        if selected == 'default':
+            selected = 'auto'
+        elif selected == 'nautical miles':
+            selected = 'nautmiles'
+        self.scalebarDict['unitsLength'] = selected
+        try:
+            length = float(self.lengthTextCtrl.GetValue())
+            wx.MessageBox(message = _("Length of scale bar is not defined"),
+                                    caption = _('Invalid input'), style = wx.OK|wx.ICON_ERROR)
+            return False
+        self.scalebarDict['length'] = length
+        map = self.instruction.FindInstructionByType('map')
+        if not map:
+            map = self.instruction.FindInstructionByType('initMap')
+        mapId = map.id
+        rectSize = self.scalebar.EstimateSize( scalebarDict = self.scalebarDict,
+        scale = self.instruction[mapId]['scale'])
+        self.scalebarDict['rect'] = wx.Rect2D(x = x, y = y, w = rectSize[0], h = rectSize[1])
+        self.scalebarDict['where'] = self.scalebarDict['rect'].GetCentre()
+            scalebar = Scalebar(self.id)
+            self.instruction.AddInstruction(scalebar)
+        self.instruction[self.id].SetInstruction(self.scalebarDict)
+        return True
+        """!Update scalebar coordinates, after moving"""
+        x, y = self.scalebarDict['rect'][:2]
+class TextDialog(PsmapDialog):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = "Text settings", settings = settings)
+        self.objectType = ('text',)
+            self.textDict = self.instruction[id].GetInstruction()
+        else:
+            text = Text(self.id)
+            self.textDict = text.GetInstruction()
+            self.textDict['where'] = page['Left'], page['Top']
+        if not map:
+        self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(map = map, x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
+        notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
+        self.textPanel = self._textPanel(notebook)
+        self.positionPanel = self._positionPanel(notebook)
+        self.OnBackground(None)
+        self.OnHighlight(None)
+        self.OnPositionType(None)
+        self.OnRotation(None)
+        self._layout(notebook)
+    def _textPanel(self, notebook):
+        panel = wx.Panel(parent = notebook, id = wx.ID_ANY, style = wx.TAB_TRAVERSAL)
+        notebook.AddPage(page = panel, text = _("Text"))
+        # text entry
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Text"))
+        sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
+        textLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Enter text:"))
+        self.textCtrl = ExpandoTextCtrl(panel, id = wx.ID_ANY, value = self.textDict['text'])
+        sizer.Add(textLabel, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = 5)
+        sizer.Add(self.textCtrl, proportion = 1, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = 5)
+        #font
+        flexGridSizer = wx.FlexGridSizer (rows = 3, cols = 2, hgap = 5, vgap = 5)
+        flexGridSizer.AddGrowableCol(1)
+        self.AddFont(parent = panel, dialogDict = self.textDict)
+        flexGridSizer.Add(panel.font['fontLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(panel.font['fontCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(panel.font['fontSizeLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(panel.font['fontSizeCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(panel.font['colorLabel'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        flexGridSizer.Add(panel.font['colorCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        #text effects
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Text effects"))
+        self.effect = {}
+        self.effect['backgroundCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("text background"))
+        self.effect['backgroundColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        self.effect['highlightCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("highlight"))
+        self.effect['highlightColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        self.effect['highlightWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, min = 0, max = 5, initial = 1)
+        self.effect['highlightWidthLabel'] = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
+        self.effect['borderCtrl'] = wx.CheckBox(panel, id = wx.ID_ANY, label = _("text border"))
+        self.effect['borderColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
+        self.effect['borderWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, min = 1, max = 25, initial = 1)
+        self.effect['borderWidthLabel'] = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
+        #set values
+        if self.textDict['background'] != 'none':
+            self.effect['backgroundCtrl'].SetValue(True)
+        else:
+            self.effect['backgroundCtrl'].SetValue(False)
+            self.effect['backgroundColor'].SetColour(convertRGB(self.textDict['background']))
+        else:
+            self.effect['backgroundColor'].SetColour('white')
+        if self.textDict['hcolor'] != 'none':
+            self.effect['highlightCtrl'].SetValue(True)
+        else:
+            self.effect['highlightCtrl'].SetValue(False)
+            self.effect['highlightColor'].SetColour(convertRGB(self.textDict['hcolor']))
+        else:
+            self.effect['highlightColor'].SetColour(convertRGB('grey'))
+        self.effect['highlightWidth'].SetValue(float(self.textDict['hwidth']))
+        if self.textDict['border'] != 'none':
+            self.effect['borderCtrl'].SetValue(True)
+        else:
+            self.effect['borderCtrl'].SetValue(False)
+            self.effect['borderColor'].SetColour(convertRGB(self.textDict['border']))
+        else:
+            self.effect['borderColor'].SetColour('black')
+        self.effect['borderWidth'].SetValue(float(self.textDict['width']))
+        gridBagSizer.Add(self.effect['backgroundCtrl'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['backgroundColor'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['highlightCtrl'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['highlightColor'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['highlightWidthLabel'], pos = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['highlightWidth'], pos = (1,3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['borderCtrl'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['borderColor'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['borderWidthLabel'], pos = (2,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizer.Add(self.effect['borderWidth'], pos = (2,3), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.Bind(EVT_ETC_LAYOUT_NEEDED, self.OnRefit, self.textCtrl)
+        self.Bind(wx.EVT_CHECKBOX, self.OnBackground, self.effect['backgroundCtrl'])
+        self.Bind(wx.EVT_CHECKBOX, self.OnHighlight, self.effect['highlightCtrl'])
+        self.Bind(wx.EVT_CHECKBOX, self.OnBorder, self.effect['borderCtrl'])
+        panel.Fit()
+        return panel
+    def _positionPanel(self, notebook):
+        notebook.AddPage(page = panel, text = _("Position"))
+        #Position
+        gridBagSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+        gridBagSizer.AddGrowableCol(0)
+        gridBagSizer.AddGrowableCol(1)
+        self.positionLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Position is given:"))
+        self.paperPositionCtrl = wx.RadioButton(panel, id = wx.ID_ANY, label = _("relatively to paper"), style = wx.RB_GROUP)
+        self.mapPositionCtrl = wx.RadioButton(panel, id = wx.ID_ANY, label = _("by map coordinates"))
+        self.paperPositionCtrl.SetValue(self.textDict['XY'])
+        self.mapPositionCtrl.SetValue(not self.textDict['XY'])
+        gridBagSizer.Add(self.positionLabel, pos = (0,0), span = (1,3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+        gridBagSizer.Add(self.paperPositionCtrl, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+        gridBagSizer.Add(self.mapPositionCtrl, pos = (1,1),flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+        # first box - paper coordinates
+        box1   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
+        sizerP = wx.StaticBoxSizer(box1, wx.VERTICAL)
+        self.gridBagSizerP = wx.GridBagSizer (hgap = 5, vgap = 5)
+        self.gridBagSizerP.AddGrowableCol(1)
+        self.gridBagSizerP.AddGrowableRow(3)
+        self.AddPosition(parent = panel, dialogDict = self.textDict)
+        panel.position['comment'].SetLabel(_("Position from the top left\nedge of the paper"))
+        self.AddUnits(parent = panel, dialogDict = self.textDict)
+        self.gridBagSizerP.Add(panel.units['unitsLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.units['unitsCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.position['xLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.position['xCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.position['yLabel'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.position['yCtrl'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerP.Add(panel.position['comment'], pos = (3,0), span = (1,2), flag = wx.ALIGN_BOTTOM, border = 0)
+        sizerP.Add(self.gridBagSizerP, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        gridBagSizer.Add(sizerP, pos = (2,0),span = (1,1), flag = wx.ALIGN_CENTER_HORIZONTAL|wx.EXPAND, border = 0)
+        # second box - map coordinates
+        box2   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
+        sizerM = wx.StaticBoxSizer(box2, wx.VERTICAL)
+        self.gridBagSizerM = wx.GridBagSizer (hgap = 5, vgap = 5)
+        self.gridBagSizerM.AddGrowableCol(0)
+        self.gridBagSizerM.AddGrowableCol(1)
+        self.eastingLabel  = wx.StaticText(panel, id = wx.ID_ANY, label = "E:")
+        self.northingLabel  = wx.StaticText(panel, id = wx.ID_ANY, label = "N:")
+        self.eastingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+        self.northingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+        east, north = PaperMapCoordinates(map = self.instruction[self.mapId], x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
+        self.eastingCtrl.SetValue(str(east))
+        self.northingCtrl.SetValue(str(north))
+        self.gridBagSizerM.Add(self.eastingLabel, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerM.Add(self.northingLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerM.Add(self.eastingCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        self.gridBagSizerM.Add(self.northingCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizerM.Add(self.gridBagSizerM, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        gridBagSizer.Add(sizerM, pos = (2,1), flag = wx.ALIGN_LEFT|wx.EXPAND, border = 0)
+        #offset
+        box3   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " %_("Offset"))
+        sizerO = wx.StaticBoxSizer(box3, wx.VERTICAL)
+        gridBagSizerO = wx.GridBagSizer (hgap = 5, vgap = 5)
+        self.xoffLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("horizontal (pts):"))
+        self.yoffLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("vertical (pts):"))
+        self.xoffCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, size = (50, -1), min = -50, max = 50, initial = 0)
+        self.yoffCtrl = wx.SpinCtrl(panel, id = wx.ID_ANY, size = (50, -1), min = -50, max = 50, initial = 0)
+        self.xoffCtrl.SetValue(self.textDict['xoffset'])
+        self.yoffCtrl.SetValue(self.textDict['yoffset'])
+        gridBagSizerO.Add(self.xoffLabel, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizerO.Add(self.yoffLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizerO.Add(self.xoffCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        gridBagSizerO.Add(self.yoffCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+        sizerO.Add(gridBagSizerO, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+        gridBagSizer.Add(sizerO, pos = (3,0), flag = wx.ALIGN_CENTER_HORIZONTAL|wx.EXPAND, border = 0)
+        # reference point
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " %_(" Reference point"))
+        sizerR = wx.StaticBoxSizer(box, wx.VERTICAL)
+        flexSizer = wx.FlexGridSizer(rows = 3, cols = 3, hgap = 5, vgap = 5)
+        flexSizer.AddGrowableCol(0)
+        flexSizer.AddGrowableCol(2)
+        ref = []
+        for row in ["upper", "center", "lower"]:
+            for col in ["left", "center", "right"]:
+                ref.append(row + " " + col)
+        self.radio = [wx.RadioButton(panel, id = wx.ID_ANY, label = '', style = wx.RB_GROUP, name = ref[0])]
+        self.radio[0].SetValue(False)
+        flexSizer.Add(self.radio[0], proportion = 0, flag = wx.ALIGN_CENTER, border = 0)
+        for i in range(1,9):
+            self.radio.append(wx.RadioButton(panel, id = wx.ID_ANY, label = '', name = ref[i]))
+            self.radio[-1].SetValue(False)
+            flexSizer.Add(self.radio[-1], proportion = 0, flag = wx.ALIGN_CENTER, border = 0)
+        self.FindWindowByName(self.textDict['ref']).SetValue(True)
+        sizerR.Add(flexSizer, proportion = 1, flag = wx.EXPAND, border = 0)
+        gridBagSizer.Add(sizerR, pos = (3,1), flag = wx.ALIGN_LEFT|wx.EXPAND, border = 0)
+        sizer.Add(gridBagSizer, proportion = 1, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALL, border = 5)
+        #rotation
+        box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Text rotation"))
+        self.rotCtrl = wx.CheckBox(panel, id = wx.ID_ANY, label = _("rotate text (counterclockwise)"))
+        self.rotValue = wx.SpinCtrl(panel, wx.ID_ANY, size = (50, -1), min = 0, max = 360, initial = 0)
+        if self.textDict['rotate']:
+            self.rotValue.SetValue(int(self.textDict['rotate']))
+            self.rotCtrl.SetValue(True)
+        else:
+            self.rotValue.SetValue(0)
+            self.rotCtrl.SetValue(False)
+        sizer.Add(self.rotCtrl, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT|wx.ALL, border = 5)
+        sizer.Add(self.rotValue, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT|wx.ALL, border = 5)
+        panel.Fit()
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, self.paperPositionCtrl)
+        self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, self.mapPositionCtrl)
+        self.Bind(wx.EVT_CHECKBOX, self.OnRotation, self.rotCtrl)
+        return panel
+    def OnRefit(self, event):
+        self.Fit()
+    def OnRotation(self, event):
+        if self.rotCtrl.GetValue():
+            self.rotValue.Enable()
+        else:
+            self.rotValue.Disable()
+    def OnPositionType(self, event):
+        if self.paperPositionCtrl.GetValue():
+            for widget in self.gridBagSizerP.GetChildren():
+                widget.GetWindow().Enable()
+            for widget in self.gridBagSizerM.GetChildren():
+                widget.GetWindow().Disable()
+        else:
+    def OnBackground(self, event):
+        if self.effect['backgroundCtrl'].GetValue():
+            self.effect['backgroundColor'].Enable()
+        else:
+            self.effect['backgroundColor'].Disable()
+    def OnHighlight(self, event):
+        if self.effect['highlightCtrl'].GetValue():
+            self.effect['highlightColor'].Enable()
+            self.effect['highlightWidth'].Enable()
+            self.effect['highlightWidthLabel'].Enable()
+        else:
+            self.effect['highlightColor'].Disable()
+            self.effect['highlightWidth'].Disable()
+            self.effect['highlightWidthLabel'].Disable()
+        if self.effect['borderCtrl'].GetValue():
+            self.effect['borderColor'].Enable()
+            self.effect['borderWidth'].Enable()
+            self.effect['borderWidthLabel'].Enable()
+        else:
+            self.effect['borderColor'].Disable()
+            self.effect['borderWidth'].Disable()
+            self.effect['borderWidthLabel'].Disable()
+    def update(self):
+        #text
+        self.textDict['text'] = self.textCtrl.GetValue()
+        if not self.textDict['text']:
+            wx.MessageBox(_("No text entered!"), _("Error"))
+            return False
+        #font
+        self.textDict['font'] = self.textPanel.font['fontCtrl'].GetStringSelection()
+        self.textDict['fontsize'] = self.textPanel.font['fontSizeCtrl'].GetValue()
+##        font = self.textPanel.font['fontCtrl'].GetSelectedFont()
+##        self.textDict['font'] = font.GetFaceName()
+##        self.textDict['fontsize'] = font.GetPointSize()
+        color = self.textPanel.font['colorCtrl'].GetColour()
+##            self.textDict['color'] = color.GetAsString(wx.C2S_NAME)
+##        else:
+        self.textDict['color'] = convertRGB(color)
+        #effects
+            background = self.effect['backgroundColor'].GetColour()
+            self.textDict['background'] = convertRGB(background)
+        else:
+            self.textDict['background'] = 'none'
+            border = self.effect['borderColor'].GetColour()
+            self.textDict['border'] = convertRGB(border)
+        else:
+            self.textDict['border'] = 'none'
+        self.textDict['width'] = self.effect['borderWidth'].GetValue()
+            highlight = self.effect['highlightColor'].GetColour()
+            self.textDict['hcolor'] = convertRGB(highlight)
+        else:
+            self.textDict['hcolor'] = 'none'
+        self.textDict['hwidth'] = self.effect['highlightWidth'].GetValue()
+        #offset
+        self.textDict['xoffset'] = self.xoffCtrl.GetValue()
+        self.textDict['yoffset'] = self.yoffCtrl.GetValue()
+        #position
+            self.textDict['XY'] = True
+            currUnit = self.positionPanel.units['unitsCtrl'].GetStringSelection()
+            self.textDict['unit'] = currUnit
+            if self.positionPanel.position['xCtrl'].GetValue():
+                x = self.positionPanel.position['xCtrl'].GetValue()
+            else:
+                x = self.textDict['where'][0]
+            if self.positionPanel.position['yCtrl'].GetValue():
+                y = self.positionPanel.position['yCtrl'].GetValue()
+            else:
+                y = self.textDict['where'][1]
+            x = self.unitConv.convert(value = float(x), fromUnit = currUnit, toUnit = 'inch')
+            y = self.unitConv.convert(value = float(y), fromUnit = currUnit, toUnit = 'inch')
+            self.textDict['where'] = x, y
+            self.textDict['east'], self.textDict['north'] = PaperMapCoordinates( self.instruction[self.mapId], x, y, paperToMap = True)
+        else:
+            self.textDict['XY'] = False
+            if self.eastingCtrl.GetValue():
+                self.textDict['east'] = self.eastingCtrl.GetValue()
+            else:
+                self.textDict['east'] = self.textDict['east']
+            if self.northingCtrl.GetValue():
+                self.textDict['north'] = self.northingCtrl.GetValue()
+            else:
+                self.textDict['north'] = self.textDict['north']
+            self.textDict['where'] = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.textDict['east']),
+                                                            y = float(self.textDict['north']), paperToMap = False)
+        #rotation
+            self.textDict['rotate'] = self.rotValue.GetValue()
+        else:
+            self.textDict['rotate'] = None
+        #reference point
+        for radio in self.radio:
+            if radio.GetValue() == True:
+                self.textDict['ref'] = radio.GetName()
+            self.instruction.AddInstruction(text)
+        self.instruction[self.id].SetInstruction(self.textDict)
+        return True
+        """!Update text coordinates, after moving"""
+        # XY coordinates
+        x, y = self.textDict['where'][:2]
+        self.positionPanel.position['xCtrl'].SetValue("%5.3f" % x)
+        self.positionPanel.position['yCtrl'].SetValue("%5.3f" % y)
+        # EN coordinates
+        e, n = self.textDict['east'], self.textDict['north']
+        self.eastingCtrl.SetValue(str(self.textDict['east']))
+        self.northingCtrl.SetValue(str(self.textDict['north']))
+def convertRGB(rgb):
+    """!Converts wx.Colour(255,255,255,255) and string '255:255:255',
+            depends on input"""
+    psmapColors = { "white" : (1.00, 1.00, 1.00),
+                    "black" : (0.00, 0.00, 0.00),
+                    "red" : (1.00, 0.00, 0.00),
+                    "green" : (0.00, 1.00, 0.00),
+                    "blue" : (0.00, 0.00, 1.00),
+                    "yellow" : (1.00, 1.00, 0.00),
+                    "magenta" : (1.00, 0.00, 1.00),
+                    "cyan" : (0.00, 1.00, 1.00),
+                    "aqua" : (0.00, 0.75, 0.75),
+                    "grey" : (0.75, 0.75, 0.75),
+                    "gray" : (0.75, 0.75, 0.75),
+                    "orange" : (1.00, 0.50, 0.00),
+                    "brown" : (0.75, 0.50, 0.25),
+                    "purple" : (0.50, 0.00, 1.00),
+                    "violet" : (0.50, 0.00, 1.00),
+                    "indigo" : (0.00, 0.50, 1.00)}
+    if type(rgb) == wx.Colour:
+        for name, color in psmapColors.items():
+            if  rgb.Red() == int(color[0] * 255) and\
+                rgb.Green() == int(color[1] * 255) and\
+                rgb.Blue() == int(color[2] * 255):
+                return name
+        return str(rgb.Red()) + ':' + str(rgb.Green()) + ':' + str(rgb.Blue())
+    elif type(rgb) == str or type(rgb) == unicode:
+        if ':' in rgb:
+            return wx.Colour(*map(int, rgb.split(':')))
+        else:
+            color = map(lambda x: int(x * 255), psmapColors[rgb])
+            color = wx.Color(*color)
+            if color.IsOk():
+                return color
+            return None
+def PaperMapCoordinates(map, x, y, paperToMap = True):
+    """!Converts paper (inch) coordinates -> map coordinates"""
+    unitConv = UnitConversion()
+    currRegionDict = grass.region()
+    cornerEasting, cornerNorthing = currRegionDict['w'], currRegionDict['n']
+    xMap = map['rect'][0]
+    yMap = map['rect'][1]
+    widthMap = map['rect'][2] * 0.0254 # to meter
+    heightMap = map['rect'][3] * 0.0254
+    xScale = widthMap / abs(currRegionDict['w'] - currRegionDict['e'])
+    yScale = heightMap / abs(currRegionDict['n'] - currRegionDict['s'])
+    currScale = (xScale + yScale) / 2
+    if not paperToMap:
+        textEasting, textNorthing = x, y
+        eastingDiff = textEasting - cornerEasting
+        if currRegionDict['w'] > currRegionDict['e']:
+            eastingDiff = - eastingDiff
+        else:
+            eastingDiff = eastingDiff
+        northingDiff = textNorthing - cornerNorthing
+        if currRegionDict['n'] > currRegionDict['s']:
+            northingDiff = - northingDiff
+        else:
+            northingDiff = northingDiff
+        xPaper = xMap + unitConv.convert(value = eastingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
+        yPaper = yMap + unitConv.convert(value = northingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
+        return xPaper, yPaper
+    else:
+        if currRegionDict['w'] < currRegionDict['e']:
+            eastingDiff = (x - xMap)
+        else:
+            eastingDiff = (xMap - x)
+        if currRegionDict['n'] < currRegionDict['s']:
+            northingDiff = (y - yMap)
+        else:
+            northingDiff = (yMap - y)
+        textEasting = cornerEasting + unitConv.convert(value = eastingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
+        textNorthing = cornerNorthing + unitConv.convert(value = northingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
+        return int(textEasting), int(textNorthing)
+def AutoAdjust(self, scaleType,  rect, map = None, mapType = None, region = None):
+    """!Computes map scale, center and map frame rectangle to fit region (scale is not fixed)"""
+    currRegionDict = {}
+    if scaleType == 0 and map:# automatic, region from raster or vector
+        res = ''
+        if mapType == 'raster':
+            try:
+                res = grass.read_command("g.region", flags = 'gu', rast = map)
+            except grass.ScriptError:
+                pass
+        elif mapType == 'vector':
+            res = grass.read_command("g.region", flags = 'gu', vect = map)
+        currRegionDict = grass.parse_key_val(res, val_type = float)
+    elif scaleType == 1 and region: # saved region
+        res = grass.read_command("g.region", flags = 'gu', region = region)
+    elif scaleType == 2: # current region
+        env = grass.gisenv()
+        windFilePath = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], 'WIND')
+        try:
+            windFile = open(windFilePath, 'r').read()
+        except IOError:
+        regionDict = grass.parse_key_val(windFile, sep = ':', val_type = float)
+        region = grass.read_command("g.region", flags = 'gu', n = regionDict['north'], s = regionDict['south'],
+        e = regionDict['east'], w = regionDict['west'])
+        currRegionDict = grass.parse_key_val(region, val_type = float)
+    else:
+        return None, None, None
+    if not currRegionDict:
+    rX = rect.x
+    rY = rect.y
+    rW = rect.width
+    rH = rect.height
+    if not hasattr(self, 'unitConv'):
+        self.unitConv = UnitConversion(self)
+    toM = 1
+    if projInfo()['proj'] != 'xy':
+        toM = float(projInfo()['meters'])
+    mW = self.unitConv.convert(value = (currRegionDict['e'] - currRegionDict['w']) * toM, fromUnit = 'meter', toUnit = 'inch')
+    mH = self.unitConv.convert(value = (currRegionDict['n'] - currRegionDict['s']) * toM, fromUnit = 'meter', toUnit = 'inch')
+    scale = min(rW/mW, rH/mH)
+    if rW/rH > mW/mH:
+        x = rX - (rH*(mW/mH) - rW)/2
+        y = rY
+        rWNew = rH*(mW/mH)
+        rHNew = rH
+    else:
+        x = rX
+        y = rY - (rW*(mH/mW) - rH)/2
+        rHNew = rW*(mH/mW)
+        rWNew = rW
+    # center
+    cE = (currRegionDict['w'] + currRegionDict['e'])/2
+    cN = (currRegionDict['n'] + currRegionDict['s'])/2
+    return scale, (cE, cN), wx.Rect2D(x, y, rWNew, rHNew) #inch
+def SetResolution(dpi, width, height):
+    """!If resolution is too high, lower it
+    @param dpi max DPI
+    @param width map frame width
+    @param height map frame height
+    region = grass.region()
+    if region['cols'] > width * dpi or region['rows'] > height * dpi:
+        rows = height * dpi
+        cols = width * dpi
+        RunCommand('g.region', rows = rows, cols = cols)
+def ComputeSetRegion(self, mapDict):
+    """!Computes and sets region from current scale, map center coordinates and map rectangle"""
+    if mapDict['scaleType'] == 3: # fixed scale
+        scale = mapDict['scale']
+        fromM = 1
+            fromM = float(projInfo()['meters'])
+        rectHalfInch = ( mapDict['rect'].width/2, mapDict['rect'].height/2)
+        rectHalfMeter = ( self.unitConv.convert(value = rectHalfInch[0], fromUnit = 'inch', toUnit = 'meter')/ fromM /scale,
+                                self.unitConv.convert(value = rectHalfInch[1], fromUnit = 'inch', toUnit = 'meter')/ fromM /scale)
+        centerE = mapDict['center'][0]
+        centerN = mapDict['center'][1]
+        if raster:
+            rasterId = raster.id
+        else:
+            rasterId = None
+        if rasterId:
+            RunCommand('g.region', n = ceil(centerN + rectHalfMeter[1]),
+                           s = floor(centerN - rectHalfMeter[1]),
+                           e = ceil(centerE + rectHalfMeter[0]),
+                           w = floor(centerE - rectHalfMeter[0]),
+                           rast = self.instruction[rasterId]['raster'])
+        else:
+                           w = floor(centerE - rectHalfMeter[0]))
+def projInfo():
+    """!Return region projection and map units information,
+    taken from render.py"""
+    projinfo = dict()
+    ret = RunCommand('g.proj', read = True, flags = 'p')
+    if not ret:
+        return projinfo
+    for line in ret.splitlines():
+        if ':' in line:
+            key, val = line.split(':')
+            projinfo[key.strip()] = val.strip()
+        elif "XY location (unprojected)" in line:
+            projinfo['proj'] = 'xy'
+            projinfo['units'] = ''
+            break
+    return projinfo
+def GetMapBounds(filename):
+    """!Run ps.map -b to get information about map bounding box"""
+    try:
+        bb = map(float, grass.read_command('ps.map',
+                                           flags = 'b',
+                                           quiet = True,
+                                           input = filename).strip().split('=')[1].split(','))
+    except (grass.ScriptError, IndexError):
+        GError(message = _("Unable to run `ps.map -b`"))
+        return None
+    return wx.Rect2D(bb[0], bb[3], bb[2] - bb[0], bb[1] - bb[3])
+def getRasterType(map):
+    """!Returns type of raster map (CELL, FCELL, DCELL)"""
+    if map is None:
+        map = ''
+    file = grass.find_file(name = map, element = 'cell')
+    if file['file']:
+        rasterType = grass.raster_info(map)['datatype']
+        return rasterType
+    else:
+        return None
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-05-22 11:01:04 UTC (rev 46355)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-05-22 11:51:32 UTC (rev 46356)
@@ -15,6 +15,7 @@
  - HistogramToolbar
  - LayerManagerToolbar
  - ToolsToolbar
+ - PsMapToolbar
 (C) 2007-2011 by the GRASS Development Team
 This program is free software under the GNU General Public License
@@ -23,6 +24,7 @@
 @author Michael Barton
 @author Jachym Cepicky
 @author Martin Landa <landa.martin gmail.com>
+ at author Anna Kratochvilova <anna.kratochvilova fsv.cvut.cz>
 import os
@@ -1645,3 +1647,89 @@
                                       self.parent.OnPsMap)
+class PsMapToolbar(AbstractToolbar):
+    def __init__(self, parent):
+        """!Toolbar Hardcopy Map Output Utility (psmap.py)
+        @param parent parent window
+        AbstractToolbar.__init__(self, parent)
+        self.InitToolbar(self._toolbarData())
+        self.Realize()
+        self.action = { 'id' : self.pointer }
+        self.defaultAction = { 'id' : self.pointer,
+                               'bind' : self.parent.OnPointer }
+        self.OnTool(None)
+        from psmap import haveImage
+        if not haveImage:
+            self.EnableTool(self.preview, False)
+    def _toolbarData(self):
+        """!Toolbar data
+        self.quit = wx.NewId()
+        self.pagesetup = wx.NewId()
+        self.pointer = wx.NewId()
+        self.zoomIn = wx.NewId()
+        self.zoomOut = wx.NewId()
+        self.zoomAll = wx.NewId()
+        self.addMap = wx.NewId()
+        self.addRaster = wx.NewId()
+        self.addVector = wx.NewId()
+        self.dec = wx.NewId()
+        self.delete = wx.NewId()
+        self.preview = wx.NewId()
+        self.instructionFile = wx.NewId()
+        self.generatePS = wx.NewId()
+        self.generatePDF = wx.NewId()
+        self.loadFile = wx.NewId()
+        self.pan = wx.NewId()
+        self.help = wx.NewId()
+        icons = Icons['psMap']
+        return self._getToolbarData(((self.loadFile, 'loadFile', icons['scriptLoad'],
+                                      self.parent.OnLoadFile),
+                                     (self.instructionFile, 'psScript', icons['scriptSave'],
+                                      self.parent.OnInstructionFile),
+                                     (None, ),
+                                     (self.pagesetup, 'page setup', icons['pageSetup'],
+                                      self.parent.OnPageSetup),
+                                     (None, ),
+                                     (self.pointer, "pointer", Icons["displayWindow"]["pointer"],
+                                      self.parent.OnPointer, wx.ITEM_CHECK),
+                                     (self.pan, 'pan', Icons["displayWindow"]['pan'],
+                                      self.parent.OnPan, wx.ITEM_CHECK),
+                                     (self.zoomIn, "zoomin", Icons["displayWindow"]["zoomIn"],
+                                      self.parent.OnZoomIn, wx.ITEM_CHECK),
+                                     (self.zoomOut, "zoomout", Icons["displayWindow"]["zoomOut"],
+                                      self.parent.OnZoomOut, wx.ITEM_CHECK),
+                                     (self.zoomAll, 'full extent', icons['fullExtent'],
+                                      self.parent.OnZoomAll),
+                                     (None, ),
+                                     (self.addMap, 'add map', icons['addMap'],
+                                      self.parent.OnAddMap, wx.ITEM_CHECK),
+                                     (self.addRaster, 'add raster', icons['addRast'],
+                                      self.parent.OnAddRaster),
+                                     (self.addVector, 'add vect', icons['addVect'],
+                                      self.parent.OnAddVect),
+                                     (self.dec, "overlay", Icons["displayWindow"]["overlay"],
+                                      self.parent.OnDecoration),
+                                     (self.delete, "delete", icons["deleteObj"],
+                                      self.parent.OnDelete),
+                                     (None, ),
+                                     (self.preview, "preview", icons["preview"],
+                                      self.parent.OnPreview),
+                                     (self.generatePS, 'generatePS', icons['psExport'],
+                                      self.parent.OnPSFile),
+                                    ( self.generatePDF, 'generatePDF', icons['pdfExport'],
+                                      self.parent.OnPDFFile),
+                                     (None, ),
+                                     (self.help, "help", Icons['misc']['help'],
+                                      self.parent.OnHelp),
+                                     (self.quit, 'quit', icons['quit'],
+                                      self.parent.OnCloseWindow))
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2011-05-22 11:01:04 UTC (rev 46355)
+++ grass/trunk/gui/wxpython/icons/icon.py	2011-05-22 11:51:32 UTC (rev 46356)
@@ -16,6 +16,7 @@
 for details.
 import os
@@ -396,6 +397,45 @@
                           label = _('Show help page')),
         'quit' : MetaIcon(img = iconSet.get('quit', wx.ART_ERROR),
                           label = _('Quit')),
+    'psMap' : {
+        'scriptSave' : MetaIcon(img = iconSet['script-save'],
+                                label = _('Generate text file with mapping instructions')),
+        'scriptLoad' : MetaIcon(img = iconSet['script-load'],
+                                label = _('Load text file with mapping instructions')),
+        'psExport'   : MetaIcon(img = iconSet['ps-export'],
+                                label = _('Generate PostScript output')),
+        'pdfExport'  : MetaIcon(img = iconSet['pdf-export'],
+                                label = _('Generate PDF output')),
+        'pageSetup'  : MetaIcon(img = iconSet['page-settings'],
+                                label = _('Page setup'),
+                                desc = _('Specify paper size, margins and orientation')),
+        'fullExtent' : MetaIcon(img = iconSet['zoom-extent'],
+                                label = _("Full extent"),
+                                desc = _("Zoom to full extent")),
+        'addMap'     : MetaIcon(img = iconSet['layer-add'],
+                                label = _("Map frame"),
+                                desc = _("Click and drag to place map frame")),
+        'addRast'    : MetaIcon(img = iconSet['layer-raster-add'],
+                                label = _("Raster map"),
+                                desc = _("Add raster map")),
+        'addVect'    : MetaIcon(img = iconSet['layer-vector-add'],
+                                label = _("Vector map"),
+                                desc = _("Add vector map")),
+        'deleteObj'  : MetaIcon(img = iconSet['layer-remove'],
+                                label = _("Delete selected object")),
+        'preview'    : MetaIcon(img = iconSet['execute'],
+                                label = _("Show preview")),
+        'quit'       : MetaIcon(img = iconSet['quit'],
+                                label = _('Quit Hardcopy Map Utility')),
+        'addText'    : MetaIcon(img = iconSet['text-add'],
+                                label = _('Add text')),
+        'addMapinfo' : MetaIcon(img = iconSet['map-info'],
+                                label = _('Add map info')),
+        'addLegend'  : MetaIcon(img = iconSet['legend-add'],
+                                label = _('Add legend')),
+        'addScalebar' : MetaIcon(img = iconSet['scalebar-add'],
+                                 label = _('Add scale bar')),
Copied: grass/trunk/gui/wxpython/xml/menudata_psmap.xml (from rev 46349, grass-addons/gui/wxpython/wx.psmap/xml/menudata_psmap.xml)
--- grass/trunk/gui/wxpython/xml/menudata_psmap.xml	                        (rev 0)
+++ grass/trunk/gui/wxpython/xml/menudata_psmap.xml	2011-05-22 11:51:32 UTC (rev 46356)
@@ -0,0 +1,117 @@
+<menudata>
+  <menubar>
+    <menu>
+      <label>&amp;File</label>
+      <items>
+      	<menuitem>
+	  <label>Page setup</label>
+	  <help>Specify paper size, margins and orientation</help>
+	  <handler>OnPageSetup</handler>
+	  <shortcut>Ctrl+P</shortcut>
+	</menuitem>
+	<separator/>
+	<menuitem>
+	  <label>Load instruction file</label>
+	  <help>Load text file with mapping instructions</help>
+	  <handler>OnLoadFile</handler>
+	  <shortcut>Ctrl+O</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Export instruction file</label>
+	  <help>Generate text file with mapping instructions</help>
+	  <handler>OnInstructionFile</handler>
+	  <shortcut>Ctrl+Shift+E</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Export to PostScript</label>
+	  <help>Generate PostScript output</help>
+	  <handler>OnPSFile</handler>
+	  <shortcut>Ctrl+E</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Export to PDF</label>
+	  <help>Generate PDF output</help>
+	  <handler>OnPDFFile</handler>
+	  <shortcut>Ctrl+F</shortcut>
+	</menuitem>
+	<separator/>
+	<menuitem>
+	  <label>Quit</label>
+	  <help>Close Hardcopy Map Output Utility</help>
+	  <handler>OnCloseWindow</handler>
+	  <shortcut>Ctrl+W</shortcut>
+	</menuitem>
+      </items>
+    </menu>
+    <menu>
+      <label>&amp;Insert</label>
+      <items>
+	<menuitem>
+	  <label>Map frame</label>
+	  <help>Add or edit map frame</help>
+	  <handler>OnAddMap</handler>
+	  <shortcut>Ctrl+M</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Raster map</label>
+	  <help>Add or edit raster map</help>
+	  <handler>OnAddRaster</handler>
+	  <shortcut>Ctrl+R</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Vector map</label>
+	  <help>Add or edit vector map</help>
+	  <handler>OnAddVect</handler>
+	  <shortcut>Ctrl+V</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Map legend</label>
+	  <help>Add or edit raster and vector legend</help>
+	  <handler>OnAddLegend</handler>
+	  <shortcut>Ctrl+L</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Map info</label>
+	  <help>Add or edit map info</help>
+	  <handler>OnAddMapinfo</handler>
+	  <shortcut>Ctrl+I</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Scale bar</label>
+	  <help>Add or edit scale bar</help>
+	  <handler>OnAddScalebar</handler>
+	  <shortcut>Ctrl+B</shortcut>
+	</menuitem>
+	<menuitem>
+	  <label>Text</label>
+	  <help>Add text</help>
+	  <handler>OnAddText</handler>
+	  <shortcut>Ctrl+T</shortcut>
+	</menuitem>
+	<separator/>
+	<menuitem>
+	  <label>Delete</label>
+	  <help>Delete selected object</help>
+	  <handler>OnDelete</handler>
+	  <shortcut>Delete</shortcut>
+	</menuitem>
+      </items>
+    </menu>
+    <menu>
+      <label>&amp;Help</label>
+      <items>
+	<menuitem>
+	  <label>Help</label>
+	  <help>Display the HTML man pages of Hardcopy Map Output Utility</help>
+	  <handler>OnHelp</handler>
+	</menuitem>
+	<separator />
+	<menuitem>
+	  <label>About Hardcopy Map Output Utility</label>
+	  <help>Display information about Hardcopy Map Output Utility</help>
+	  <handler>OnAbout</handler>
+	</menuitem>
+      </items>
+    </menu>
+  </menubar>
+</menudata>
