[GRASS-SVN] r46363 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sun May 22 09:18:47 EDT 2011
Author: martinl
Date: 2011-05-22 06:18:47 -0700 (Sun, 22 May 2011)
New Revision: 46363
grass/branches/develbranch_6/SUBMITTING_PYTHON
sync SUBMITTING_PYTHON with trunk
Modified: grass/branches/develbranch_6/SUBMITTING_PYTHON
--- grass/branches/develbranch_6/SUBMITTING_PYTHON 2011-05-22 13:11:18 UTC (rev 46362)
+++ grass/branches/develbranch_6/SUBMITTING_PYTHON 2011-05-22 13:18:47 UTC (rev 46363)
@@ -1,114 +1,203 @@
-$Date$
NOTE: Please improve this list!
-Dear (new) GRASS Developer,
+Dear (new) GRASS developer,
-When submitting Python code to GRASS SVN repository, please take
+when submitting Python code to GRASS SVN repository, please take
care of following rules:
-[ see SUBMITTING for C hints ]
+[ see SUBMITTING for C hints ]
+[ see SUBMITTING_DOCS for documentation ]
[ see SUBMITTING_SCRIPTS for shell script hints ]
[ see SUBMITTING_TCLTK for tcl and tk hints ]
-[ see SUBMITTING_DOCS for documentation ]
+0. Indentation
-1. Indentation
+ As Python determines nesting based upon indentation, it isn't just
+ a stylistic issue.
- As Python determines nesting based upon indentation, it
- isn't just a stylistic issue.
Please use 4-space indentation (GNU Emacs python-mode default).
See also "Python Style Guide" by Guido van Rossum
http://www.python.org/doc/essays/styleguide.html
+1. Instructions for the GRASS script parser can be found in the g.parser
+ module's help page.
+ http://grass.osgeo.org/grass70/manuals/html70_user/g.parser.html
-2. Add a header section to the script you submit and make sure you
+2. Use the directory structure to place your script appropriately into
+ the source tree
+ - scripts go into scripts/
+ Also add a Makefile and a <module>.html file into this directory.
+ See existing Python scripts for examples.
+3. Add a header section to the script you submit and make sure you
include the copyright. The purpose section is meant to contain a
general over view of the code in the file to assist other
programmers that will need to make changes to your code. For this
purpose use Python Docstring, see
http://epydoc.sourceforge.net/docstrings.html
- Example (fictitious header for a script called r.myscript):
+ Example (fictitious header for a script called g.myscript):
-MODULE: r.myscript
+MODULE: g.myscript
-AUTHOR(S): Me <email AT some domain>
+AUTHOR(S): John Doe <email AT some domain>
-PURPOSE: Calculates univariate statistics from a GRASS raster map
+PURPOSE: Describe your script here...
-COPYRIGHT: (C) 2007 by the GRASS Development Team
+COPYRIGHT: (C) 2007 John Doe, and by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
- The copyright protects your rights according to GNU General Public
- License (www.gnu.org).
+ The copyright protects your rights according to GNU General Public
+ License (www.gnu.org).
+ You can easily autogenerate the header and parameters from an existing
+ module using the --script flag. Example:
-3. - deleted.
- We don't want the $ ID $ in source code any more as it causes problems
+ d.rast --script
+ Just select an existing module which is close to your application to save
+ efforts.
+4. We don't want the $ ID $ in source code any more as it causes problems
for the branches.
+5. Create and use secure temporary files and directories. Use the
+ grass.tempfile() or grass.tempdir() functions to do this. e.g.
-4. PLEASE take the time to add comments throughout your code explaining what
+ # setup temporary file
+ TMP = grass.tempfile()
+ if TMP is None:
+ grass.fatal("Unable to create temporary files")
+6. Use grass.findfile() when there is a need to test if a map exists.
+ # test for input raster map
+ result = grass.find_file(name = map_name, element = 'cell', quiet = True)
+ if not result['file']
+ grass.fatal("Raster map <%s> not found" % map_name)
+ # test for input vector map
+ result = grass.find_file(name = map_name, element = 'vector', quiet = True)
+ grass.fatal("Vector map <%s> not found" % map_name)
+ ... and so forth. See 'g.manual g.findfile' for details.
+7. For any informational output, use the grass.message()
+ function. For error messages should be used grass.fatal_error() or
+ grass.error() and for warnings grass.warning(). For debugging
+ purposes grass.debug().
+ #normal message:
+ grass.message("Done")
+ # warning:
+ grass.warning("No input values found, using default values")
+ # error:
+ grass.error("No map found")
+ # fatal error:
+ grass.fatal_error("No map found, exiting")
+ # debug output (use g.gisenv to enable/disable)
+ grass.debug("Our calculated value is: %d" % value)
+ Try to omit any usage of the 'print' command for informational output.
+8. PLEASE take the time to add comments throughout your code explaining what
the code is doing. It will save a HUGE amount of time and frustration for
other programmers that may have to change your code in the future.
-5. Make sure a new line is at the end of each file.
+9. Make sure a new line is at the end of each file.
-6. For consistency, use README rather than README.txt for any README files.
+10. For consistency, use README rather than README.txt for any README files.
-7. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
- You can re-check before submission with 'svn diff':
+11. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
+ You can re-check before submission with 'svn diff':
- Be sure to create unified ("diff -u") format. "Plain" diffs (the default
- format) are risky, because they will apply without warning to code which
- has been substantially changed; they are also harder to read than unified.
+ Be sure to create unified ("diff -u") format. "Plain" diffs (the default
+ format) are risky, because they will apply without warning to code which
+ has been substantially changed; they are also harder to read than unified.
- Such diffs should be made from the top-level directory, e.g.
- "svn diff gui/wxpython/wxgui.py"; that way, the diff will
- include the pathname rather than just "wxgui.py".
+ Such diffs should be made from the top-level directory, e.g.
+ "svn diff gui/wxpython/wxgui.py"; that way, the diff will
+ include the pathname rather than just "wxgui.py".
-8. When submitting new files to the repository set SVN properties,
- usually for directory
+12. When submitting new files to the repository set SVN properties,
+ usually for directory
svn:ignore : *.pyc
- or e.g. for Python file
+ or e.g. for Python file
svn:mime-type : text/python
svn:keywords : Author Date Id
svn:eol-style : native
- See
- http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
+ See
+ http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
-9. wxGUI (gui/wxpython)
+13. wxGUI (gui/wxpython)
- See http://wiki.wxpython.org/wxPython_Style_Guide
+ See http://wiki.wxpython.org/wxPython_Style_Guide
+ Major rules:
-10. Tell the other developers about the new code using the following e-mail:
- grass-dev at lists.osgeo.org
+ - use named parameters in functions, e.g.
+ dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
+ wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
+ instead of
+ dlg = wx.FileDialog(self, _("Choose file to save current workspace"),
+ _("GRASS Workspace File (*.gxw)|*.gxw"), wx.FD_SAVE)
+ - use wx.ID_ANY instead of `-1`
+ - use gcmd.GError(), gcmd.GWarning and gcmd.GMessage instead of wx.MessageBox()
+ - use gcmd.RunCommand() instead of grass.run_command() or grass.read_command()
+ - use full strings, eg.
+ if ...:
+ win.SetLabel(_('Name for new 3D raster map to create'))
+ else:
+ win.SetLabel(_('Name for new raster map to create'))
+ instead of
+ _('Name for new %s to create') % maplabel
+ where `maplabel` can be 'raster map' or '3D raster map'
+14. Tell the other developers about the new code using the following e-mail:
+ grass-dev at lists.osgeo.org
- To subscribe to this mailing list, see
- http://lists.osgeo.org/mailman/listinfo/grass-dev
+ To subscribe to this mailing list, see
+ http://lists.osgeo.org/mailman/listinfo/grass-dev
-11. In case of questions feel free to contact the developers at the above
- mailing list.
- http://www.grass-gis.org/devel/index.php#submission
+15. In case of questions feel free to contact the developers at the above
+ mailing list.
+ http://grass.osgeo.org/devel/index.php#submission
[please add further hints if required]
+"Your attention to detail is appreciated."
