[GRASS-SVN] r46374 - in grass/branches/develbranch_6/gui/wxpython: . docs gui_modules icons
Sun May 22 11:19:00 EDT 2011
Author: martinl
Date: 2011-05-22 08:18:59 -0700 (Sun, 22 May 2011)
New Revision: 46374
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/icons/icon.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: note wx.psmap in the manual
      add help icon to the main toolbar
(merge r46373 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -27,6 +27,7 @@
   <a href="wxGUI.Nviz.html">3D Viewer</a><br>
   <a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
   <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a><br>
+  <a href="wxGUI.PsMap.html">Hardcopy Map Output Utility</a><br>
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -302,6 +302,7 @@
   <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Modeler.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -36,6 +36,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -305,6 +305,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.PsMap.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -1,10 +1,10 @@
 <h2>DESCRIPTION</h2>
-<b>Note:</b> <em>wxGUI Hardcopy Map Utility is currently under
+<b>Note:</b> <em>wxGUI Hardcopy Map Output Utility is currently under
 development.</em>
 <p>
-<b>wxGUI Hardcopy Map Utility</b> also called <em>wx.psmap</em> is
+<b>wxGUI Hardcopy Map Output Utility</b> also called <em>wx.psmap</em> is
 a <em><a href="wxGUI.html">wxGUI</a></em> extension which allows the
 user to create interactively hardcopy map outputs. This tool
 generates <em><a href="ps.map.html">ps.map</a></em> configuration file
@@ -23,7 +23,7 @@
 </ul>
 <p>
-Hardcopy Map Utility enables to load in saved instructions file. It
+Hardcopy Map Output Utility enables to load in saved instructions file. It
 works better with files created by wx.psmap (more tested).</p>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Vector_Digitizer.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -233,6 +233,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2011-05-22 15:18:59 UTC (rev 46374)
@@ -561,6 +561,7 @@
 </em>
 <p>
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2011-05-22 15:18:59 UTC (rev 46374)
@@ -1592,6 +1592,7 @@
         self.delcmd = wx.NewId()
         self.attribute = wx.NewId()
         self.preferences = wx.NewId()
+        self.help = wx.NewId()
         icons = Icons['layerManager']
         return self._getToolbarData(((self.newdisplay, 'newdisplay', icons["newdisplay"],
@@ -1623,7 +1624,9 @@
                                       self.parent.OnShowAttributeTable),
                                      (None, ),
                                      (self.preferences, 'preferences', icons["settings"],
-                                      self.parent.OnPreferences)
+                                      self.parent.OnPreferences),
+                                     (self.help, 'help', Icons["misc"]["help"],
+                                      self.parent.OnHelp),
 class ToolsToolbar(AbstractToolbar):
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-05-22 15:18:59 UTC (rev 46374)
@@ -427,7 +427,7 @@
         'font' : MetaIcon(img = iconSet.get('font', wx.ART_ERROR),
                           label = _('Select font')),
         'help' : MetaIcon(img = iconSet.get('help', wx.ART_ERROR),
-                          label = _('Show help page')),
+                          label = _('Show manual')),
         'quit' : MetaIcon(img = iconSet.get('quit', wx.ART_ERROR),
                           label = _('Quit')),
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-05-22 15:13:56 UTC (rev 46373)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-05-22 15:18:59 UTC (rev 46374)
@@ -1056,7 +1056,8 @@
         win.Show()
     def OnPreferences(self, event):
-        """!General GUI preferences/settings"""
+        """!General GUI preferences/settings
         if not self.dialogs['preferences']:
             dlg = preferences.PreferencesDialog(parent = self)
             self.dialogs['preferences'] = dlg
@@ -1064,6 +1065,11 @@
         self.dialogs['preferences'].ShowModal()
+    def OnHelp(self, event):
+        """!Show help
+        self.goutput.RunCmd(['g.manual','-i'])
     def DispHistogram(self, event):
         Init histogram display canvas and tools
