[GRASS-SVN] r46376 - grass/branches/releasebranch_6_4/ps/ps.map
svn_grass at osgeo.org
Mon May 23 03:22:55 EDT 2011
Author: hamish
Date: 2011-05-23 00:22:55 -0700 (Mon, 23 May 2011)
New Revision: 46376
grass/branches/releasebranch_6_4/ps/ps.map/main.c
backport -b flag from trunk (see #153)
Modified: grass/branches/releasebranch_6_4/ps/ps.map/main.c
--- grass/branches/releasebranch_6_4/ps/ps.map/main.c 2011-05-22 15:20:03 UTC (rev 46375)
+++ grass/branches/releasebranch_6_4/ps/ps.map/main.c 2011-05-23 07:22:55 UTC (rev 46376)
@@ -10,7 +10,7 @@
* Markus Neteler <neteler itc.it>,
* Alessandro Frigeri <afrigeri unipg.it>
* PURPOSE: This is an enhanced PostScript version of the p.map program
- * COPYRIGHT: (C) 2003-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2011 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -82,7 +82,7 @@
struct Option *input_file;
struct Option *output_file;
struct Option *copies;
- struct Flag *rflag, *pflag, *eflag;
+ struct Flag *rflag, *pflag, *eflag, *bflag;
struct GModule *module;
static char *def_font = "Helvetica";
@@ -114,6 +114,11 @@
eflag->description =
_("Create EPS (Encapsulated PostScript) instead of PostScript file");
+ bflag = G_define_flag();
+ bflag->key = 'b';
+ bflag->description =
+ _("Describe map-box's position on the page and exit (inches from top-left of paper)");
input_file = G_define_option();
input_file->key = "input";
input_file->type = TYPE_STRING;
@@ -148,7 +153,7 @@
if (G_parser(argc, argv))
usage(0);
- /* Print papers */
+ /* Print paper sizes to stdout */
if (pflag->answer) {
print_papers();
exit(EXIT_SUCCESS);
@@ -265,6 +270,7 @@
usage(1);
/* get current mapset */
PS.cell_mapset = G_mapset();
@@ -718,6 +724,16 @@
/* reset map location base on 'paper' on 'location' */
reset_map_location();
+ if (bflag->answer) {
+ map_setup();
+ fprintf(stdout, "bbox=%.3f,%.3f,%.3f,%.3f\n", PS.map_left / 72.0,
+ PS.page_height - (PS.map_bot / 72.0), PS.map_right / 72.0,
+ PS.page_height - (PS.map_top / 72.0));
+ /* +/- 0.5 ? see ps.map.c brd.* */
+ unlink(output_file->answer); /* fixme: don't open it in the first place */
+ exit(EXIT_SUCCESS);
/* write the PostScript output file */
ps_mask_file = G_tempfile();
ps_map();
