[GRASS-SVN] r46381 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Mon May 23 06:13:13 EDT 2011
Author: hamish
Date: 2011-05-23 03:13:13 -0700 (Mon, 23 May 2011)
New Revision: 46381
grass/trunk/ps/ps.map/box.c
grass/trunk/ps/ps.map/do_scalebar.c
grass/trunk/ps/ps.map/main.c
grass/trunk/ps/ps.map/map_setup.c
grass/trunk/ps/ps.map/ps.map.html
merge -b flag fixes from relbr4:
- explicitly zero the output file pointer (if only for clarity's sake);
- don't try to remove an output file we never created;
- jump out of map_setup() before trying to write anything.
minor cosmetics to code comment and man page.
Modified: grass/trunk/ps/ps.map/box.c
--- grass/trunk/ps/ps.map/box.c 2011-05-23 10:09:40 UTC (rev 46380)
+++ grass/trunk/ps/ps.map/box.c 2011-05-23 10:13:13 UTC (rev 46381)
@@ -7,8 +7,7 @@
int box_path(double t, double b, double l, double r)
- if (PS.fp)
- fprintf(PS.fp, "%.1f %.1f %.1f %.1f B ", l, b, r, t);
+ fprintf(PS.fp, "%.1f %.1f %.1f %.1f B ", l, b, r, t);
return 0;
@@ -16,8 +15,7 @@
int box_clip(double t, double b, double l, double r)
box_path(t, b, l, r);
- if (PS.fp)
- fprintf(PS.fp, "clip newpath\n");
+ fprintf(PS.fp, "clip newpath\n");
return 0;
Modified: grass/trunk/ps/ps.map/do_scalebar.c
--- grass/trunk/ps/ps.map/do_scalebar.c 2011-05-23 10:09:40 UTC (rev 46380)
+++ grass/trunk/ps/ps.map/do_scalebar.c 2011-05-23 10:13:13 UTC (rev 46381)
@@ -1,6 +1,4 @@
-/* Function to draw scalebar on page
+/* Function to draw scalebar on page */
#include <string.h>
#include <math.h>
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2011-05-23 10:09:40 UTC (rev 46380)
+++ grass/trunk/ps/ps.map/main.c 2011-05-23 10:13:13 UTC (rev 46381)
@@ -235,7 +235,9 @@
output_file->key, output_file->description);
+ else
+ PS.fp = NULL;
/* get current mapset */
PS.cell_mapset = G_mapset();
@@ -255,7 +257,6 @@
PS.page_height - (PS.map_bot / 72.0), PS.map_right / 72.0,
PS.page_height - (PS.map_top / 72.0));
/* +/- 0.5 ? see ps.map.c brd.* */
- unlink(output_file->answer); /* fixme: don't open it in the first place */
exit(EXIT_SUCCESS);
Modified: grass/trunk/ps/ps.map/map_setup.c
--- grass/trunk/ps/ps.map/map_setup.c 2011-05-23 10:09:40 UTC (rev 46380)
+++ grass/trunk/ps/ps.map/map_setup.c 2011-05-23 10:13:13 UTC (rev 46381)
@@ -103,9 +103,13 @@
PS.map_bot, PS.map_left, PS.map_right);
+ /* no need to go on if we're just here for a look-see. (-b flag) */
+ if (!PS.fp)
+ return 0;
/* save original graphics state */
- if (PS.fp)
- fprintf(PS.fp, "gsave ");
+ fprintf(PS.fp, "gsave ");
/* compute conversion factor from meters to PostScript window coordinates */
Modified: grass/trunk/ps/ps.map/ps.map.html
--- grass/trunk/ps/ps.map/ps.map.html 2011-05-23 10:09:40 UTC (rev 46380)
+++ grass/trunk/ps/ps.map/ps.map.html 2011-05-23 10:13:13 UTC (rev 46381)
@@ -1229,7 +1229,7 @@
part of the text should be placed on the location specified by the map
coordinates. Reference points can refer to:
[lower|upper|center] [left|right|center] of the text to be printed;
-The default is center center, i.e the text is centered on the reference point.
+The default is center center, i.e. the text is centered on the reference point.
<P>
<B>rotate</B>
sets the text rotation angle, measured in degrees counter-clockwise.
