[GRASS-SVN] r46384 - grass/branches/releasebranch_6_4/ps/ps.map
svn_grass at osgeo.org
Mon May 23 07:35:07 EDT 2011
Author: hamish
Date: 2011-05-23 04:35:07 -0700 (Mon, 23 May 2011)
New Revision: 46384
grass/branches/releasebranch_6_4/ps/ps.map/do_geogrid.c
comment on common semi-bug (merge from devbr6, r45417,23,24)
Modified: grass/branches/releasebranch_6_4/ps/ps.map/do_geogrid.c
--- grass/branches/releasebranch_6_4/ps/ps.map/do_geogrid.c 2011-05-23 11:30:47 UTC (rev 46383)
+++ grass/branches/releasebranch_6_4/ps/ps.map/do_geogrid.c 2011-05-23 11:35:07 UTC (rev 46384)
@@ -170,8 +170,8 @@
set_rgb_color(PS.geogrid_numbers_color);
first = 1;
- /* horizontal grid numbers
- * these numbers only appear on the left edge of the first panel.
+ /* vertical grid numbers
+ * these numbers only appear on the right edge
* center the numbers on each grid line.
* suppress number if it falls off the map or would overlay the previous
* label
@@ -216,7 +216,7 @@
- /* vertical grid numbers
+ /* horizontal grid numbers along the bottom
* suppress number if it falls of the map or would overlay the previous
* label
@@ -373,10 +373,13 @@
* check projected coords to make sure they do not
- * go outside region -- if so re-project
+ * go outside region -- if so re-project
+ * This gets a bit wobbly if the projection does not reverse-project
+ * cleanly, e.g. if the eastern edge of a UTM region is many
+ * degrees east of the end of the zone where things get distorted.
void check_coords(double e, double n, double *lon, double *lat, int par)
double x, y;
