[GRASS-SVN] r46386 -
grass/branches/releasebranch_6_4/display/d.legend
svn_grass at osgeo.org
Mon May 23 08:27:25 EDT 2011
Author: hamish
Date: 2011-05-23 05:27:25 -0700 (Mon, 23 May 2011)
New Revision: 46386
grass/branches/releasebranch_6_4/display/d.legend/main.c
Dylan: pass through format exactly as given by the user in the
use= command line parameter, helps with log scale.
(#1147; merge from devbr6 r45627)
Modified: grass/branches/releasebranch_6_4/display/d.legend/main.c
--- grass/branches/releasebranch_6_4/display/d.legend/main.c 2011-05-23 12:11:48 UTC (rev 46385)
+++ grass/branches/releasebranch_6_4/display/d.legend/main.c 2011-05-23 12:27:25 UTC (rev 46386)
@@ -876,10 +876,21 @@
sprintf(buff + strlen(buff), " %s", cstr);
else { /* is fp */
- if (!flip)
- sprintf(buff, DispFormat, catlist[i]);
- else
- sprintf(buff, DispFormat, catlist[catlistCount - i - 1]);
+ if (!flip) {
+ if(use_catlist)
+ /* pass through format exactly as given by the user in
+ the use= command line parameter (helps with log scale) */
+ sprintf(buff, "%s", opt8->answers[i]);
+ else
+ /* automatically generated/tuned decimal precision format */
+ sprintf(buff, DispFormat, catlist[i]);
+ else {
+ if(use_catlist)
+ sprintf(buff, "%s", opt8->answers[catlistCount - i - 1]);
+ else
+ sprintf(buff, DispFormat, catlist[catlistCount - i - 1]);
R_move_abs((l + 3 + dots_per_line), (cur_dot_row) - 3);
