[GRASS-SVN] r46416 - grass/trunk
svn_grass at osgeo.org
Wed May 25 03:47:44 EDT 2011
Author: mmetz
Date: 2011-05-25 00:47:44 -0700 (Wed, 25 May 2011)
New Revision: 46416
grass/trunk/configure
grass/trunk/configure.in
configure: add check for libLAS
Modified: grass/trunk/configure
--- grass/trunk/configure 2011-05-25 05:52:44 UTC (rev 46415)
+++ grass/trunk/configure 2011-05-25 07:47:44 UTC (rev 46416)
@@ -73,6 +73,11 @@
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
ac_help="$ac_help
+ --with-liblas[=path/liblas-config]
+ enable libLAS support (liblas-config with path,
+ e.g. '--with-liblas=/usr/local/bin/liblas-config',
+ default: no)"
+ac_help="$ac_help
--with-wxwidgets[=path/wx-config]
enable wxWidgets support (wx-config with path,
e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
@@ -740,7 +745,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:744: checking host system type" >&5
+echo "configure:748: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -763,7 +768,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:767: checking for $ac_word" >&5
+echo "configure:771: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -790,7 +795,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:794: checking for $ac_word" >&5
+echo "configure:798: checking for $ac_word" >&5
@@ -838,7 +843,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:842: checking for $ac_word" >&5
+echo "configure:846: checking for $ac_word" >&5
@@ -867,7 +872,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:871: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:875: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -878,12 +883,12 @@
cat > conftest.$ac_ext << EOF
-#line 882 "configure"
+#line 886 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -909,19 +914,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:913: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:917: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:918: checking whether we are using GNU C" >&5
+echo "configure:922: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:929: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -939,7 +944,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:943: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:947: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -968,10 +973,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:972: checking for Cygwin environment" >&5
+echo "configure:976: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 975 "configure"
+#line 979 "configure"
int main() {
@@ -982,7 +987,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -998,17 +1003,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1002: checking for mingw32 environment" >&5
+echo "configure:1006: checking for mingw32 environment" >&5
-#line 1005 "configure"
+#line 1009 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1016: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1026,7 +1031,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1030: checking for executable suffix" >&5
+echo "configure:1034: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1045,23 +1050,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1049: checking for full floating-point support" >&5
+echo "configure:1053: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1054: checking whether "cc -mieee" works" >&5
+echo "configure:1058: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1058 "configure"
+#line 1062 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1069: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1077,7 +1082,7 @@
else
-#line 1081 "configure"
+#line 1085 "configure"
#include <float.h>
@@ -1091,7 +1096,7 @@
EOF
-if { (eval echo configure:1095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1104,14 +1109,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1108: checking for full floating-point support with -mieee" >&5
+echo "configure:1112: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1115 "configure"
+#line 1119 "configure"
#include <float.h>
@@ -1125,7 +1130,7 @@
EOF
-if { (eval echo configure:1129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1162,7 +1167,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1166: checking for $ac_word" >&5
+echo "configure:1170: checking for $ac_word" >&5
case "$pwd" in
@@ -1200,7 +1205,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1204: checking for source directory" >&5
+echo "configure:1208: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1211,7 +1216,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1215: checking for build directory" >&5
+echo "configure:1219: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1279,7 +1284,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1283: checking for $ac_word" >&5
+echo "configure:1287: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1335,7 +1340,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1339: checking for MacOSX App" >&5
+echo "configure:1343: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1347,7 +1352,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1351: checking for MacOSX architectures" >&5
+echo "configure:1355: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1376,7 +1381,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1380: checking for MacOSX SDK" >&5
+echo "configure:1384: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1386,7 +1391,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1390: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1394: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1430,7 +1435,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1434: checking how to build libraries" >&5
+echo "configure:1438: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1815,6 +1820,15 @@
fi
+# Check whether --with-liblas or --without-liblas was given.
+if test "${with_liblas+set}" = set; then
+ withval="$with_liblas"
+else
+ with_liblas="no"
+fi
# Check whether --with-wxwidgets or --without-wxwidgets was given.
if test "${with_wxwidgets+set}" = set; then
withval="$with_wxwidgets"
@@ -2239,7 +2253,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2243: checking for additional include dirs" >&5
+echo "configure:2254: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2262,7 +2276,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2266: checking for additional library dirs" >&5
+echo "configure:2277: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2296,7 +2310,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2300: checking for a BSD compatible install" >&5
+echo "configure:2311: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2349,7 +2363,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2353: checking for $ac_word" >&5
+echo "configure:2364: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2380,13 +2394,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2384: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2395: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2390 "configure"
+#line 2401 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2397,7 +2411,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2422,7 +2436,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2426: checking for $ac_word" >&5
+echo "configure:2437: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2462,7 +2476,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2466: checking for $ac_word" >&5
+echo "configure:2477: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2493,7 +2507,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2497: checking for $ac_word" >&5
+echo "configure:2508: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2531,7 +2545,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2535: checking for $ac_word" >&5
+echo "configure:2546: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2560,7 +2574,7 @@
-echo "configure:2564: checking for $ac_word" >&5
+echo "configure:2575: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2591,7 +2605,7 @@
-echo "configure:2595: checking for $ac_word" >&5
+echo "configure:2606: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2620,7 +2634,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2624: checking for $ac_word" >&5
+echo "configure:2635: checking for $ac_word" >&5
case "$PERL" in
@@ -2651,7 +2665,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2655: checking how to run the C preprocessor" >&5
+echo "configure:2666: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2664,13 +2678,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2668 "configure"
+#line 2679 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2674: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2681,13 +2695,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2685 "configure"
+#line 2696 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2691: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2698,13 +2712,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2702 "configure"
+#line 2713 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2728,10 +2742,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2732: checking for ANSI C header files" >&5
+echo "configure:2743: checking for ANSI C header files" >&5
-#line 2735 "configure"
+#line 2746 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2739,7 +2753,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2756,7 +2770,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2760 "configure"
+#line 2771 "configure"
#include <string.h>
EOF
@@ -2774,7 +2788,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2778 "configure"
+#line 2789 "configure"
#include <stdlib.h>
EOF
@@ -2795,7 +2809,7 @@
else
-#line 2799 "configure"
+#line 2810 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2806,7 +2820,7 @@
exit (0); }
EOF
-if { (eval echo configure:2810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2833,15 +2847,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2837: checking for $ac_hdr" >&5
+echo "configure:2848: checking for $ac_hdr" >&5
-#line 2840 "configure"
+#line 2851 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2845: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2870,15 +2884,15 @@
do
-echo "configure:2874: checking for $ac_hdr" >&5
+echo "configure:2885: checking for $ac_hdr" >&5
-#line 2877 "configure"
+#line 2888 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2907,15 +2921,15 @@
do
-echo "configure:2911: checking for $ac_hdr" >&5
+echo "configure:2922: checking for $ac_hdr" >&5
-#line 2914 "configure"
+#line 2925 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2944,15 +2958,15 @@
do
-echo "configure:2948: checking for $ac_hdr" >&5
+echo "configure:2959: checking for $ac_hdr" >&5
-#line 2951 "configure"
+#line 2962 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2956: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2967: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2981,15 +2995,15 @@
do
-echo "configure:2985: checking for $ac_hdr" >&5
+echo "configure:2996: checking for $ac_hdr" >&5
-#line 2988 "configure"
+#line 2999 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3015,10 +3029,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3019: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3030: checking whether time.h and sys/time.h may both be included" >&5
-#line 3022 "configure"
+#line 3033 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3027,7 +3041,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3031: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3047,10 +3061,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3051: checking for off_t" >&5
+echo "configure:3062: checking for off_t" >&5
-#line 3054 "configure"
+#line 3065 "configure"
#if STDC_HEADERS
@@ -3077,10 +3091,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3081: checking for uid_t in sys/types.h" >&5
+echo "configure:3092: checking for uid_t in sys/types.h" >&5
-#line 3084 "configure"
+#line 3095 "configure"
EOF
@@ -3108,10 +3122,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3112: checking return type of signal handlers" >&5
+echo "configure:3123: checking return type of signal handlers" >&5
-#line 3115 "configure"
+#line 3126 "configure"
#include <signal.h>
@@ -3128,7 +3142,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3143: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3146,10 +3160,10 @@
-echo "configure:3150: checking for Cygwin environment" >&5
+echo "configure:3161: checking for Cygwin environment" >&5
-#line 3153 "configure"
+#line 3164 "configure"
int main() {
@@ -3160,7 +3174,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3164: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3178,10 +3192,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3182: checking for $ac_func" >&5
+echo "configure:3193: checking for $ac_func" >&5
-#line 3185 "configure"
+#line 3196 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3204,7 +3218,7 @@
; return 0; }
EOF
-if { (eval echo configure:3208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3230,10 +3244,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3234: checking for $ac_func" >&5
+echo "configure:3245: checking for $ac_func" >&5
-#line 3237 "configure"
+#line 3248 "configure"
@@ -3256,7 +3270,7 @@
; return 0; }
EOF
-if { (eval echo configure:3260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3282,10 +3296,10 @@
for ac_func in drand48
do
-echo "configure:3286: checking for $ac_func" >&5
+echo "configure:3297: checking for $ac_func" >&5
-#line 3289 "configure"
+#line 3300 "configure"
@@ -3308,7 +3322,7 @@
; return 0; }
EOF
-if { (eval echo configure:3312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3334,10 +3348,10 @@
for ac_func in putenv setenv
do
-echo "configure:3338: checking for $ac_func" >&5
+echo "configure:3349: checking for $ac_func" >&5
-#line 3341 "configure"
+#line 3352 "configure"
@@ -3360,7 +3374,7 @@
; return 0; }
EOF
-if { (eval echo configure:3364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3386,10 +3400,10 @@
for ac_func in nanosleep
do
-echo "configure:3390: checking for $ac_func" >&5
+echo "configure:3401: checking for $ac_func" >&5
-#line 3393 "configure"
+#line 3404 "configure"
@@ -3412,7 +3426,7 @@
; return 0; }
EOF
-if { (eval echo configure:3416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3437,13 +3451,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3441: checking whether setpgrp takes no argument" >&5
+echo "configure:3452: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3447 "configure"
+#line 3458 "configure"
#ifdef HAVE_UNISTD_H
@@ -3463,7 +3477,7 @@
EOF
-if { (eval echo configure:3467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3491,16 +3505,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3495: checking for long long int" >&5
+echo "configure:3506: checking for long long int" >&5
-#line 3497 "configure"
+#line 3508 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3504: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3520,7 +3534,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3524: checking for W11" >&5
+echo "configure:3535: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3548,7 +3562,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3552: checking for X" >&5
+echo "configure:3563: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3608,12 +3622,12 @@
# First, try using that file with no special directory specified.
-#line 3612 "configure"
+#line 3623 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3628: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3682,14 +3696,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3686 "configure"
+#line 3697 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3794,17 +3808,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3798: checking whether -R must be followed by a space" >&5
+echo "configure:3809: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3801 "configure"
+#line 3812 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3820,14 +3834,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3824 "configure"
+#line 3835 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3859,13 +3873,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3863: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3874: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3869 "configure"
+#line 3880 "configure"
@@ -3876,7 +3890,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3897,13 +3911,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3901: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3912: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3907 "configure"
+#line 3918 "configure"
@@ -3914,7 +3928,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3942,10 +3956,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3946: checking for gethostbyname" >&5
+echo "configure:3957: checking for gethostbyname" >&5
-#line 3949 "configure"
+#line 3960 "configure"
which can conflict with char gethostbyname(); below. */
@@ -3968,7 +3982,7 @@
; return 0; }
EOF
-if { (eval echo configure:3972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -3988,13 +4002,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:3992: checking for gethostbyname in -lnsl" >&5
+echo "configure:4003: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 3998 "configure"
+#line 4009 "configure"
@@ -4005,7 +4019,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4034,10 +4048,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4038: checking for connect" >&5
+echo "configure:4049: checking for connect" >&5
-#line 4041 "configure"
+#line 4052 "configure"
which can conflict with char connect(); below. */
@@ -4060,7 +4074,7 @@
; return 0; }
EOF
-if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4080,13 +4094,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4084: checking for connect in -lsocket" >&5
+echo "configure:4095: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4090 "configure"
+#line 4101 "configure"
@@ -4097,7 +4111,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4120,10 +4134,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4124: checking for remove" >&5
+echo "configure:4135: checking for remove" >&5
-#line 4127 "configure"
+#line 4138 "configure"
which can conflict with char remove(); below. */
@@ -4146,7 +4160,7 @@
; return 0; }
EOF
-if { (eval echo configure:4150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4166,13 +4180,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4170: checking for remove in -lposix" >&5
+echo "configure:4181: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4176 "configure"
+#line 4187 "configure"
@@ -4183,7 +4197,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4206,10 +4220,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4210: checking for shmat" >&5
+echo "configure:4221: checking for shmat" >&5
-#line 4213 "configure"
+#line 4224 "configure"
which can conflict with char shmat(); below. */
@@ -4232,7 +4246,7 @@
; return 0; }
EOF
-if { (eval echo configure:4236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4252,13 +4266,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4256: checking for shmat in -lipc" >&5
+echo "configure:4267: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4262 "configure"
+#line 4273 "configure"
@@ -4269,7 +4283,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4301,13 +4315,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4305: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4316: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4311 "configure"
+#line 4322 "configure"
@@ -4318,7 +4332,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4358,12 +4372,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4362: checking for library containing cuserid" >&5
+echo "configure:4373: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4367 "configure"
+#line 4378 "configure"
@@ -4374,7 +4388,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4385,7 +4399,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4389 "configure"
+#line 4400 "configure"
@@ -4396,7 +4410,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4422,10 +4436,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4426: checking for xdrmem_create" >&5
+echo "configure:4437: checking for xdrmem_create" >&5
-#line 4429 "configure"
+#line 4440 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -4448,7 +4462,7 @@
; return 0; }
EOF
-if { (eval echo configure:4452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -4466,13 +4480,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4470: checking for xdrmem_create in -lsun" >&5
+echo "configure:4481: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 4476 "configure"
+#line 4487 "configure"
@@ -4483,7 +4497,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4502,13 +4516,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4506: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4517: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4512 "configure"
+#line 4523 "configure"
@@ -4519,7 +4533,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4538,13 +4552,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4542: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4553: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 4548 "configure"
+#line 4559 "configure"
@@ -4555,7 +4569,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4574,13 +4588,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4578: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4589: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 4584 "configure"
+#line 4595 "configure"
@@ -4591,7 +4605,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4625,10 +4639,10 @@
for ac_func in asprintf
do
-echo "configure:4629: checking for $ac_func" >&5
+echo "configure:4640: checking for $ac_func" >&5
-#line 4632 "configure"
+#line 4643 "configure"
@@ -4651,7 +4665,7 @@
; return 0; }
EOF
-if { (eval echo configure:4655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4678,10 +4692,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4682: checking for atan" >&5
+echo "configure:4693: checking for atan" >&5
-#line 4685 "configure"
+#line 4696 "configure"
which can conflict with char atan(); below. */
@@ -4704,7 +4718,7 @@
; return 0; }
EOF
-if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4722,13 +4736,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4726: checking for atan in -lm" >&5
+echo "configure:4737: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4732 "configure"
+#line 4743 "configure"
@@ -4739,7 +4753,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4766,10 +4780,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4770: checking for dlsym" >&5
+echo "configure:4781: checking for dlsym" >&5
-#line 4773 "configure"
+#line 4784 "configure"
which can conflict with char dlsym(); below. */
@@ -4792,7 +4806,7 @@
; return 0; }
EOF
-if { (eval echo configure:4796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4810,13 +4824,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4814: checking for dlsym in -ldl" >&5
+echo "configure:4825: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4820 "configure"
+#line 4831 "configure"
@@ -4827,7 +4841,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4854,10 +4868,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4858: checking for iconv" >&5
+echo "configure:4869: checking for iconv" >&5
-#line 4861 "configure"
+#line 4872 "configure"
which can conflict with char iconv(); below. */
@@ -4880,7 +4894,7 @@
; return 0; }
EOF
-if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4898,13 +4912,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4902: checking for iconv in -liconv" >&5
+echo "configure:4913: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4908 "configure"
+#line 4919 "configure"
@@ -4915,7 +4929,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4934,13 +4948,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4938: checking for iconv in -lgiconv" >&5
+echo "configure:4949: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4944 "configure"
+#line 4955 "configure"
@@ -4951,7 +4965,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4970,10 +4984,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4974: checking for libiconv" >&5
+echo "configure:4985: checking for libiconv" >&5
-#line 4977 "configure"
+#line 4988 "configure"
which can conflict with char libiconv(); below. */
@@ -4996,7 +5010,7 @@
; return 0; }
EOF
-if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -5014,13 +5028,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5018: checking for libiconv in -liconv" >&5
+echo "configure:5029: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5024 "configure"
+#line 5035 "configure"
@@ -5031,7 +5045,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5050,13 +5064,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5054: checking for libiconv in -lgiconv" >&5
+echo "configure:5065: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5060 "configure"
+#line 5071 "configure"
@@ -5067,7 +5081,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5104,10 +5118,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5108: checking for socket" >&5
+echo "configure:5119: checking for socket" >&5
-#line 5111 "configure"
+#line 5122 "configure"
which can conflict with char socket(); below. */
@@ -5130,7 +5144,7 @@
; return 0; }
EOF
-if { (eval echo configure:5134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5148,13 +5162,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5152: checking for socket in -lsocket" >&5
+echo "configure:5163: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5158 "configure"
+#line 5169 "configure"
@@ -5165,7 +5179,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5213,7 +5227,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5217: checking for location of zlib includes" >&5
+echo "configure:5228: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5239,15 +5253,15 @@
do
-echo "configure:5243: checking for $ac_hdr" >&5
+echo "configure:5254: checking for $ac_hdr" >&5
-#line 5246 "configure"
+#line 5257 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5251: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5281,7 +5295,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5285: checking for location of zlib library" >&5
+echo "configure:5296: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5306,13 +5320,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5310: checking for deflate in -lz" >&5
+echo "configure:5321: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5316 "configure"
+#line 5327 "configure"
@@ -5323,7 +5337,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5371,7 +5385,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5375: checking for location of External PROJ.4 includes" >&5
+echo "configure:5386: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5397,15 +5411,15 @@
do
-echo "configure:5401: checking for $ac_hdr" >&5
+echo "configure:5412: checking for $ac_hdr" >&5
-#line 5404 "configure"
+#line 5415 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5409: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5442,7 +5456,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5446: checking External PROJ.4 version" >&5
+echo "configure:5457: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5450,7 +5464,7 @@
else
-#line 5454 "configure"
+#line 5465 "configure"
#include <stdio.h>
@@ -5462,7 +5476,7 @@
EOF
-if { (eval echo configure:5466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5487,7 +5501,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5491: checking for location of External PROJ.4 library" >&5
+echo "configure:5502: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5512,13 +5526,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5516: checking for pj_get_def in -lproj" >&5
+echo "configure:5527: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5522 "configure"
+#line 5533 "configure"
@@ -5529,7 +5543,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5563,7 +5577,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5567: checking for location of External PROJ.4 data files" >&5
+echo "configure:5578: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5587,14 +5601,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5591: checking for epsg" >&5
+echo "configure:5602: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5598: checking for $PROJSHARE/epsg" >&5
+echo "configure:5609: checking for $PROJSHARE/epsg" >&5
@@ -5626,7 +5640,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5630: checking for $ac_word" >&5
+echo "configure:5641: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5666,7 +5680,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5670: checking whether to use regex" >&5
+echo "configure:5681: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5686,7 +5700,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5690: checking for location of regex includes" >&5
+echo "configure:5701: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5712,15 +5726,15 @@
do
-echo "configure:5716: checking for $ac_hdr" >&5
+echo "configure:5727: checking for $ac_hdr" >&5
-#line 5719 "configure"
+#line 5730 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5724: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5754,7 +5768,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5758: checking for location of regex library" >&5
+echo "configure:5769: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5779,10 +5793,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5783: checking for regcomp" >&5
+echo "configure:5794: checking for regcomp" >&5
-#line 5786 "configure"
+#line 5797 "configure"
which can conflict with char regcomp(); below. */
@@ -5805,7 +5819,7 @@
; return 0; }
EOF
-if { (eval echo configure:5809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5832,13 +5846,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5836: checking for regcomp in -lregex" >&5
+echo "configure:5847: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5842 "configure"
+#line 5853 "configure"
@@ -5849,7 +5863,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5899,7 +5913,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5903: checking whether to use Readline" >&5
+echo "configure:5914: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5920,7 +5934,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5924: checking for location of Readline includes" >&5
+echo "configure:5935: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5946,15 +5960,15 @@
do
-echo "configure:5950: checking for $ac_hdr" >&5
+echo "configure:5961: checking for $ac_hdr" >&5
-#line 5953 "configure"
+#line 5964 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5958: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5990,15 +6004,15 @@
do
-echo "configure:5994: checking for $ac_hdr" >&5
+echo "configure:6005: checking for $ac_hdr" >&5
-#line 5997 "configure"
+#line 6008 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6032,7 +6046,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6036: checking for location of Readline library" >&5
+echo "configure:6047: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6057,13 +6071,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6061: checking for readline in -lreadline" >&5
+echo "configure:6072: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6067 "configure"
+#line 6078 "configure"
@@ -6074,7 +6088,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6109,13 +6123,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6113: checking for add_history in -lhistory" >&5
+echo "configure:6124: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6119 "configure"
+#line 6130 "configure"
@@ -6126,7 +6140,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6169,7 +6183,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6173: checking whether to use JPEG" >&5
+echo "configure:6184: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -6189,7 +6203,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6193: checking for location of JPEG includes" >&5
+echo "configure:6204: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -6215,15 +6229,15 @@
do
-echo "configure:6219: checking for $ac_hdr" >&5
+echo "configure:6230: checking for $ac_hdr" >&5
-#line 6222 "configure"
+#line 6233 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6227: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6238: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6257,7 +6271,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6261: checking for location of JPEG library" >&5
+echo "configure:6272: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -6284,13 +6298,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6288: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6299: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 6294 "configure"
+#line 6305 "configure"
@@ -6301,7 +6315,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:6305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6320,13 +6334,13 @@
-echo "configure:6324: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6335: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 6330 "configure"
+#line 6341 "configure"
@@ -6337,7 +6351,7 @@
; return 0; }
EOF
-if { (eval echo configure:6341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6386,7 +6400,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6390: checking whether to use GDAL" >&5
+echo "configure:6401: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6404,7 +6418,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6408: checking for $ac_word" >&5
+echo "configure:6419: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6459,14 +6473,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6463 "configure"
+#line 6474 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6475,14 +6489,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6479 "configure"
+#line 6490 "configure"
#include "confdefs.h"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6508,13 +6522,105 @@
+# libLAS option
+echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
+echo "configure:6526: checking whether to use libLAS" >&5
+LIBLAS_LIBS=
+LIBLAS_CFLAGS=
+LIBLAS_INC=
+USE_LIBLAS=
+if test "`basename xx/$with_liblas`" = "liblas-config" ; then
+ LIBLAS_CONFIG="$with_liblas"
+fi
+if test "$with_liblas" = "no" ; then
+ echo "$ac_t""no" 1>&6
+else
+ echo "$ac_t""yes" 1>&6
+ # Extract the first word of "liblas-config", so it can be a program name with args.
+set dummy liblas-config; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:6544: checking for $ac_word" >&5
+case "$LIBLAS_CONFIG" in
+ ac_cv_path_LIBLAS_CONFIG="$LIBLAS_CONFIG" # Let the user override the test with a path.
+ ac_cv_path_LIBLAS_CONFIG="$LIBLAS_CONFIG" # Let the user override the test with a dos path.
+ IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
+ ac_dummy="$PATH"
+ for ac_dir in $ac_dummy; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f $ac_dir/$ac_word; then
+ ac_cv_path_LIBLAS_CONFIG="$ac_dir/$ac_word"
+ break
+ fi
+ done
+ IFS="$ac_save_ifs"
+ test -z "$ac_cv_path_LIBLAS_CONFIG" && ac_cv_path_LIBLAS_CONFIG="no"
+esac
+LIBLAS_CONFIG="$ac_cv_path_LIBLAS_CONFIG"
+if test -n "$LIBLAS_CONFIG"; then
+ echo "$ac_t""$LIBLAS_CONFIG" 1>&6
+else
+fi
+ if test "$LIBLAS_CONFIG" = "no" ; then
+ { echo "configure: error: *** couldn't find liblas-config" 1>&2; exit 1; }
+ fi
+ if test "$LIBLAS_CONFIG" != "" ; then
+ LIBLAS_LIBS=`"$LIBLAS_CONFIG" --libs`
+ LIBLAS_CFLAGS=`"$LIBLAS_CONFIG" --cflags`
+ LIBLAS_INC=`"$LIBLAS_CONFIG" --includes`
+ USE_LIBLAS=1
+ fi
+ LIBLAS=
+ ac_save_libs="$LIBS"
+ ac_save_cflags="$CFLAGS"
+ LIBS="$LIBS $LIBLAS_LIBS"
+ CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
+ cat > conftest.$ac_ext <<EOF
+#line 6592 "configure"
+#include "confdefs.h"
+#include <liblas/capi/liblas.h>
+int main() {
+LASReader_Create("foo");
+; return 0; }
+EOF
+if { (eval echo configure:6599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ { echo "configure: error: *** Unable to locate libLAS library." 1>&2; exit 1; }
+fi
+rm -f conftest*
+ LIBS=${ac_save_libs}
+ CFLAGS=${ac_save_cflags}
+fi
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6518: checking whether to use GEOS" >&5
+echo "configure:6621: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -6532,7 +6638,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6536: checking for $ac_word" >&5
+echo "configure:6639: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6580,15 +6686,15 @@
do
-echo "configure:6584: checking for $ac_hdr" >&5
+echo "configure:6687: checking for $ac_hdr" >&5
-#line 6587 "configure"
+#line 6690 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6592: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6624,13 +6730,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6628: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6731: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 6634 "configure"
+#line 6737 "configure"
@@ -6641,7 +6747,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6677,13 +6783,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6681: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6784: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6687 "configure"
+#line 6790 "configure"
@@ -6694,7 +6800,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6738,7 +6844,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6742: checking whether to use TIFF" >&5
+echo "configure:6845: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6758,7 +6864,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6762: checking for location of TIFF includes" >&5
+echo "configure:6865: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6784,15 +6890,15 @@
do
-echo "configure:6788: checking for $ac_hdr" >&5
+echo "configure:6891: checking for $ac_hdr" >&5
-#line 6791 "configure"
+#line 6894 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6826,7 +6932,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6830: checking for location of TIFF library" >&5
+echo "configure:6933: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6857,13 +6963,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6861: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6964: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6867 "configure"
+#line 6970 "configure"
@@ -6874,7 +6980,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6893,13 +6999,13 @@
-echo "configure:6897: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7000: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6903 "configure"
+#line 7006 "configure"
@@ -6910,7 +7016,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6929,13 +7035,13 @@
-echo "configure:6933: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7036: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6939 "configure"
+#line 7042 "configure"
@@ -6946,7 +7052,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6965,13 +7071,13 @@
-echo "configure:6969: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7072: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6975 "configure"
+#line 7078 "configure"
@@ -6982,7 +7088,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7001,13 +7107,13 @@
-echo "configure:7005: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7108: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7011 "configure"
+#line 7114 "configure"
@@ -7018,7 +7124,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7037,13 +7143,13 @@
-echo "configure:7041: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7144: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7047 "configure"
+#line 7150 "configure"
@@ -7054,7 +7160,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7073,13 +7179,13 @@
-echo "configure:7077: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7180: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7083 "configure"
+#line 7186 "configure"
@@ -7090,7 +7196,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7109,13 +7215,13 @@
-echo "configure:7113: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7216: checking for TIFFOpen in -ltiff" >&5
ac_save_LIBS="$LIBS"
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7119 "configure"
+#line 7222 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7126,7 +7232,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7224,7 +7330,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7228: checking whether to use PNG" >&5
+echo "configure:7331: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7243,7 +7349,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7247: checking for location of PNG includes" >&5
+echo "configure:7350: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7269,15 +7375,15 @@
do
-echo "configure:7273: checking for $ac_hdr" >&5
+echo "configure:7376: checking for $ac_hdr" >&5
-#line 7276 "configure"
+#line 7379 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7311,7 +7417,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7315: checking for location of PNG library" >&5
+echo "configure:7418: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7336,13 +7442,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7340: checking for png_read_image in -lpng" >&5
+echo "configure:7443: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7346 "configure"
+#line 7449 "configure"
@@ -7353,7 +7459,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7395,7 +7501,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7399: checking whether to use PostgreSQL" >&5
+echo "configure:7502: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7422,7 +7528,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7426: checking for location of PostgreSQL includes" >&5
+echo "configure:7529: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7448,15 +7554,15 @@
do
-echo "configure:7452: checking for $ac_hdr" >&5
+echo "configure:7555: checking for $ac_hdr" >&5
-#line 7455 "configure"
+#line 7558 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7494,7 +7600,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7498: checking for location of PostgreSQL library" >&5
+echo "configure:7601: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7523,13 +7629,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7527: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7630: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7533 "configure"
+#line 7636 "configure"
@@ -7540,7 +7646,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7559,13 +7665,13 @@
-echo "configure:7563: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7666: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7569 "configure"
+#line 7672 "configure"
@@ -7576,7 +7682,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7595,13 +7701,13 @@
-echo "configure:7599: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7702: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7605 "configure"
+#line 7708 "configure"
@@ -7612,7 +7718,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7631,13 +7737,13 @@
-echo "configure:7635: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7738: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7641 "configure"
+#line 7744 "configure"
@@ -7648,7 +7754,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7705,13 +7811,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7709: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7812: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7715 "configure"
+#line 7818 "configure"
@@ -7722,7 +7828,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7744,13 +7850,13 @@
-echo "configure:7748: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7851: checking for PQcmdTuples in -lpq" >&5
-#line 7754 "configure"
+#line 7857 "configure"
@@ -7761,7 +7867,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7804,7 +7910,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7808: checking whether to use MySQL" >&5
+echo "configure:7911: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7824,7 +7930,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7828: checking for location of MySQL includes" >&5
+echo "configure:7931: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7850,15 +7956,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7854: checking for $ac_hdr" >&5
+echo "configure:7957: checking for $ac_hdr" >&5
-#line 7857 "configure"
+#line 7960 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7862: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7895,7 +8001,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7899: checking for location of MySQL library" >&5
+echo "configure:8002: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7926,13 +8032,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7930: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8033: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7936 "configure"
+#line 8039 "configure"
@@ -7943,7 +8049,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7962,13 +8068,13 @@
-echo "configure:7966: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8069: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7972 "configure"
+#line 8075 "configure"
@@ -7979,7 +8085,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7998,13 +8104,13 @@
-echo "configure:8002: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8105: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8008 "configure"
+#line 8111 "configure"
@@ -8015,7 +8121,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8034,13 +8140,13 @@
-echo "configure:8038: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8141: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8044 "configure"
+#line 8147 "configure"
@@ -8051,7 +8157,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8070,13 +8176,13 @@
-echo "configure:8074: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8177: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8080 "configure"
+#line 8183 "configure"
@@ -8087,7 +8193,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8106,13 +8212,13 @@
-echo "configure:8110: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8213: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8116 "configure"
+#line 8219 "configure"
@@ -8123,7 +8229,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8142,13 +8248,13 @@
-echo "configure:8146: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8249: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8152 "configure"
+#line 8255 "configure"
@@ -8159,7 +8265,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8178,13 +8284,13 @@
-echo "configure:8182: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8285: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8188 "configure"
+#line 8291 "configure"
@@ -8195,7 +8301,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8285,7 +8391,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:8289: checking for $ac_word" >&5
+echo "configure:8392: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8334,10 +8440,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8338: checking for mysql_server_init" >&5
+echo "configure:8441: checking for mysql_server_init" >&5
-#line 8341 "configure"
+#line 8444 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8363,7 +8469,7 @@
; return 0; }
EOF
-if { (eval echo configure:8367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8415,7 +8521,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8419: checking whether to use SQLite" >&5
+echo "configure:8522: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8435,7 +8541,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8439: checking for location of SQLite includes" >&5
+echo "configure:8542: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8461,15 +8567,15 @@
do
-echo "configure:8465: checking for $ac_hdr" >&5
+echo "configure:8568: checking for $ac_hdr" >&5
-#line 8468 "configure"
+#line 8571 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8473: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8512,7 +8618,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8516: checking for location of SQLite library" >&5
+echo "configure:8619: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8541,13 +8647,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8545: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8648: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8551 "configure"
+#line 8654 "configure"
@@ -8558,7 +8664,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8577,13 +8683,13 @@
-echo "configure:8581: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8684: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8587 "configure"
+#line 8690 "configure"
@@ -8594,7 +8700,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8613,13 +8719,13 @@
-echo "configure:8617: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8720: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8623 "configure"
+#line 8726 "configure"
@@ -8630,7 +8736,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8649,13 +8755,13 @@
-echo "configure:8653: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8756: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8659 "configure"
+#line 8762 "configure"
@@ -8666,7 +8772,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8670: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8735,7 +8841,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8739: checking whether to use FFMPEG" >&5
+echo "configure:8842: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8755,7 +8861,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8759: checking for location of FFMPEG includes" >&5
+echo "configure:8862: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8781,15 +8887,15 @@
do
-echo "configure:8785: checking for $ac_hdr" >&5
+echo "configure:8888: checking for $ac_hdr" >&5
-#line 8788 "configure"
+#line 8891 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8825,15 +8931,15 @@
do
-echo "configure:8829: checking for $ac_hdr" >&5
+echo "configure:8932: checking for $ac_hdr" >&5
-#line 8832 "configure"
+#line 8935 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8869,15 +8975,15 @@
do
-echo "configure:8873: checking for $ac_hdr" >&5
+echo "configure:8976: checking for $ac_hdr" >&5
-#line 8876 "configure"
+#line 8979 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8881: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8920,7 +9026,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8924: checking for location of FFMPEG library" >&5
+echo "configure:9027: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8947,13 +9053,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8951: checking for av_free in -lavutil" >&5
+echo "configure:9054: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8957 "configure"
+#line 9060 "configure"
@@ -8964,7 +9070,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8983,13 +9089,13 @@
-echo "configure:8987: checking for av_free in -lavutil" >&5
+echo "configure:9090: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8993 "configure"
+#line 9096 "configure"
@@ -9000,7 +9106,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9045,13 +9151,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9049: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9152: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 9055 "configure"
+#line 9158 "configure"
@@ -9062,7 +9168,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9081,13 +9187,13 @@
-echo "configure:9085: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9188: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9091 "configure"
+#line 9194 "configure"
@@ -9098,7 +9204,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9143,13 +9249,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9147: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9250: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9153 "configure"
+#line 9256 "configure"
@@ -9160,7 +9266,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9179,13 +9285,13 @@
-echo "configure:9183: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9286: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9189 "configure"
+#line 9292 "configure"
@@ -9196,7 +9302,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9255,7 +9361,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9259: checking whether to use OpenGL" >&5
+echo "configure:9362: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9289,7 +9395,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9293: checking for location of OpenGL includes" >&5
+echo "configure:9396: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9315,15 +9421,15 @@
do
-echo "configure:9319: checking for $ac_hdr" >&5
+echo "configure:9422: checking for $ac_hdr" >&5
-#line 9322 "configure"
+#line 9425 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9357,7 +9463,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9361: checking for location of OpenGL library" >&5
+echo "configure:9464: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9386,13 +9492,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9390: checking for glBegin in -lGL" >&5
+echo "configure:9493: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9396 "configure"
+#line 9499 "configure"
@@ -9403,7 +9509,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9422,13 +9528,13 @@
-echo "configure:9426: checking for glBegin in -lGL" >&5
+echo "configure:9529: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9432 "configure"
+#line 9535 "configure"
@@ -9439,7 +9545,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9458,13 +9564,13 @@
-echo "configure:9462: checking for glBegin in -lGL" >&5
+echo "configure:9565: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9468 "configure"
+#line 9571 "configure"
@@ -9475,7 +9581,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9494,13 +9600,13 @@
-echo "configure:9498: checking for glBegin in -lGL" >&5
+echo "configure:9601: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9504 "configure"
+#line 9607 "configure"
@@ -9511,7 +9617,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9573,13 +9679,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9577: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9680: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9583 "configure"
+#line 9686 "configure"
@@ -9590,7 +9696,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9609,13 +9715,13 @@
-echo "configure:9613: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9716: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9619 "configure"
+#line 9722 "configure"
@@ -9626,7 +9732,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9673,10 +9779,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9677: checking for glXCreatePbuffer" >&5
+echo "configure:9780: checking for glXCreatePbuffer" >&5
-#line 9680 "configure"
+#line 9783 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9699,7 +9805,7 @@
; return 0; }
EOF
-if { (eval echo configure:9703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9736,10 +9842,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9740: checking for glXCreateGLXPixmap" >&5
+echo "configure:9843: checking for glXCreateGLXPixmap" >&5
-#line 9743 "configure"
+#line 9846 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9762,7 +9868,7 @@
; return 0; }
EOF
-if { (eval echo configure:9766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9805,7 +9911,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9809: checking for location of OpenGL framework" >&5
+echo "configure:9912: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9829,15 +9935,15 @@
do
-echo "configure:9833: checking for $ac_hdr" >&5
+echo "configure:9936: checking for $ac_hdr" >&5
-#line 9836 "configure"
+#line 9939 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9873,10 +9979,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9877: checking for glBegin" >&5
+echo "configure:9980: checking for glBegin" >&5
-#line 9880 "configure"
+#line 9983 "configure"
which can conflict with char glBegin(); below. */
@@ -9899,7 +10005,7 @@
; return 0; }
EOF
-if { (eval echo configure:9903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9936,10 +10042,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9940: checking for gluBeginCurve" >&5
+echo "configure:10043: checking for gluBeginCurve" >&5
-#line 9943 "configure"
+#line 10046 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9962,7 +10068,7 @@
; return 0; }
EOF
-if { (eval echo configure:9966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -10010,7 +10116,7 @@
-echo "configure:10014: checking for location of OpenGL includes" >&5
+echo "configure:10117: checking for location of OpenGL includes" >&5
@@ -10036,15 +10142,15 @@
do
-echo "configure:10040: checking for $ac_hdr" >&5
+echo "configure:10143: checking for $ac_hdr" >&5
-#line 10043 "configure"
+#line 10146 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10078,7 +10184,7 @@
-echo "configure:10082: checking for location of OpenGL library" >&5
+echo "configure:10185: checking for location of OpenGL library" >&5
@@ -10103,18 +10209,18 @@
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10107: checking for OpenGL library" >&5
+echo "configure:10210: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 10111 "configure"
+#line 10214 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:10118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10138,18 +10244,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10142: checking for GLU library" >&5
+echo "configure:10245: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10146 "configure"
+#line 10249 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10198,7 +10304,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10202: checking whether to use Tcl/Tk" >&5
+echo "configure:10305: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -10218,7 +10324,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10222: checking for location of Tcl/Tk includes" >&5
+echo "configure:10325: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10244,15 +10350,15 @@
do
-echo "configure:10248: checking for $ac_hdr" >&5
+echo "configure:10351: checking for $ac_hdr" >&5
-#line 10251 "configure"
+#line 10354 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10256: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10359: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10289,15 +10395,15 @@
do
-echo "configure:10293: checking for $ac_hdr" >&5
+echo "configure:10396: checking for $ac_hdr" >&5
-#line 10296 "configure"
+#line 10399 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10331,7 +10437,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10335: checking Tcl version" >&5
+echo "configure:10438: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -10339,7 +10445,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 10343 "configure"
+#line 10446 "configure"
#include <stdio.h>
@@ -10351,7 +10457,7 @@
EOF
-if { (eval echo configure:10355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -10369,7 +10475,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10373: checking Tk version" >&5
+echo "configure:10476: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10377,7 +10483,7 @@
else
-#line 10381 "configure"
+#line 10484 "configure"
#include <stdio.h>
@@ -10389,7 +10495,7 @@
EOF
-if { (eval echo configure:10393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -10418,7 +10524,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10422: checking for location of Tcl/Tk library" >&5
+echo "configure:10525: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10458,13 +10564,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10462: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10565: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 10468 "configure"
+#line 10571 "configure"
@@ -10475,7 +10581,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10494,13 +10600,13 @@
-echo "configure:10498: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10601: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10504 "configure"
+#line 10607 "configure"
@@ -10511,7 +10617,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10538,13 +10644,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10542: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10645: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10548 "configure"
+#line 10651 "configure"
@@ -10555,7 +10661,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10574,13 +10680,13 @@
-echo "configure:10578: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10681: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10584 "configure"
+#line 10687 "configure"
@@ -10591,7 +10697,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10618,13 +10724,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10622: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10725: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10628 "configure"
+#line 10731 "configure"
@@ -10635,7 +10741,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10654,13 +10760,13 @@
-echo "configure:10658: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10761: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10664 "configure"
+#line 10767 "configure"
@@ -10671,7 +10777,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10749,13 +10855,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10753: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10856: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10759 "configure"
+#line 10862 "configure"
@@ -10766,7 +10872,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10785,13 +10891,13 @@
-echo "configure:10789: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10892: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10795 "configure"
+#line 10898 "configure"
@@ -10802,7 +10908,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10829,13 +10935,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10833: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10936: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10839 "configure"
+#line 10942 "configure"
@@ -10846,7 +10952,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10865,13 +10971,13 @@
-echo "configure:10869: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10972: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10875 "configure"
+#line 10978 "configure"
@@ -10882,7 +10988,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10909,13 +11015,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10913: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11016: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10919 "configure"
+#line 11022 "configure"
@@ -10926,7 +11032,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10945,13 +11051,13 @@
-echo "configure:10949: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11052: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10955 "configure"
+#line 11058 "configure"
@@ -10962,7 +11068,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11052,13 +11158,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11056: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11159: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11062 "configure"
+#line 11165 "configure"
@@ -11069,7 +11175,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11119,7 +11225,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11123: checking whether to use ODBC" >&5
+echo "configure:11226: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11138,7 +11244,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11142: checking for location of ODBC includes" >&5
+echo "configure:11245: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11164,15 +11270,15 @@
do
-echo "configure:11168: checking for $ac_hdr" >&5
+echo "configure:11271: checking for $ac_hdr" >&5
-#line 11171 "configure"
+#line 11274 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11176: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11206,7 +11312,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11210: checking for location of ODBC library" >&5
+echo "configure:11313: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11231,13 +11337,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11235: checking for SQLConnect in -lodbc" >&5
+echo "configure:11338: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11241 "configure"
+#line 11344 "configure"
@@ -11248,7 +11354,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11273,13 +11379,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11277: checking for SQLConnect in -liodbc" >&5
+echo "configure:11380: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11283 "configure"
+#line 11386 "configure"
@@ -11290,7 +11396,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11315,11 +11421,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11319: checking for ODBC library" >&5
+echo "configure:11422: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11323 "configure"
+#line 11426 "configure"
#include <windows.h>
#include <sql.h>
@@ -11327,7 +11433,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11376,7 +11482,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11380: checking whether to use FFTW" >&5
+echo "configure:11483: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11395,7 +11501,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11399: checking for location of FFTW includes" >&5
+echo "configure:11502: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11421,15 +11527,15 @@
do
-echo "configure:11425: checking for $ac_hdr" >&5
+echo "configure:11528: checking for $ac_hdr" >&5
-#line 11428 "configure"
+#line 11531 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11457,15 +11563,15 @@
do
-echo "configure:11461: checking for $ac_hdr" >&5
+echo "configure:11564: checking for $ac_hdr" >&5
-#line 11464 "configure"
+#line 11567 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11572: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11493,15 +11599,15 @@
do
-echo "configure:11497: checking for $ac_hdr" >&5
+echo "configure:11600: checking for $ac_hdr" >&5
-#line 11500 "configure"
+#line 11603 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11547,7 +11653,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11551: checking for location of FFTW library" >&5
+echo "configure:11654: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11572,13 +11678,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11576: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11679: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11582 "configure"
+#line 11685 "configure"
@@ -11589,7 +11695,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11614,13 +11720,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11618: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11721: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 11624 "configure"
+#line 11727 "configure"
#include "confdefs.h"
@@ -11631,7 +11737,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11656,13 +11762,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11660: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11763: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11666 "configure"
+#line 11769 "configure"
@@ -11673,7 +11779,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11730,7 +11836,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11734: checking whether to use BLAS" >&5
+echo "configure:11837: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11751,7 +11857,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11755: checking for location of BLAS includes" >&5
+echo "configure:11858: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11771,7 +11877,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11775: checking for location of BLAS library" >&5
+echo "configure:11878: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11797,15 +11903,15 @@
do
-echo "configure:11801: checking for $ac_hdr" >&5
+echo "configure:11904: checking for $ac_hdr" >&5
-#line 11804 "configure"
+#line 11907 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11840,13 +11946,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11844: checking for dnrm2_ in -lblas" >&5
+echo "configure:11947: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11850 "configure"
+#line 11953 "configure"
@@ -11857,7 +11963,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11876,13 +11982,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:11880: checking for dnrm2_ in -lblas" >&5
+echo "configure:11983: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11886 "configure"
+#line 11989 "configure"
@@ -11893,7 +11999,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11937,13 +12043,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11941: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12044: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 11947 "configure"
+#line 12050 "configure"
@@ -11954,7 +12060,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:11958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11969,13 +12075,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11973: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12076: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 11979 "configure"
+#line 12082 "configure"
@@ -11986,7 +12092,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12001,13 +12107,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12005: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12108: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12011 "configure"
+#line 12114 "configure"
@@ -12018,7 +12124,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12064,16 +12170,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12068: checking for sgemm in $vlib_flags" >&5
+echo "configure:12171: checking for sgemm in $vlib_flags" >&5
-#line 12070 "configure"
+#line 12173 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12091,13 +12197,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12095: checking for sgemm_ in -lblas" >&5
+echo "configure:12198: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12101 "configure"
+#line 12204 "configure"
@@ -12108,7 +12214,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12123,13 +12229,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12127: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12230: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12133 "configure"
+#line 12236 "configure"
@@ -12140,7 +12246,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12155,13 +12261,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12159: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12262: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsgemm -lblas $LIBS"
-#line 12165 "configure"
+#line 12268 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12172,7 +12278,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12206,13 +12312,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12210: checking for acosp in -lsunmath" >&5
+echo "configure:12313: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12216 "configure"
+#line 12319 "configure"
@@ -12223,7 +12329,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12238,13 +12344,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12242: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12345: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12248 "configure"
+#line 12351 "configure"
@@ -12255,7 +12361,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12285,13 +12391,13 @@
# Generic BLAS library
-echo "configure:12289: checking for sgemm_ in -lblas" >&5
+echo "configure:12392: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12295 "configure"
+#line 12398 "configure"
@@ -12302,7 +12408,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12341,7 +12447,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12345: checking whether to use LAPACK" >&5
+echo "configure:12448: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12366,7 +12472,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12370: checking for location of LAPACK includes" >&5
+echo "configure:12473: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12386,7 +12492,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12390: checking for location of LAPACK library" >&5
+echo "configure:12493: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12412,15 +12518,15 @@
do
-echo "configure:12416: checking for $ac_hdr" >&5
+echo "configure:12519: checking for $ac_hdr" >&5
-#line 12419 "configure"
+#line 12522 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12452,10 +12558,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12456: checking for dsegv_" >&5
+echo "configure:12559: checking for dsegv_" >&5
-#line 12459 "configure"
+#line 12562 "configure"
which can conflict with char dsegv_(); below. */
@@ -12478,7 +12584,7 @@
; return 0; }
EOF
-if { (eval echo configure:12482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12505,13 +12611,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12509: checking for desgv_ in -llapack" >&5
+echo "configure:12612: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12515 "configure"
+#line 12618 "configure"
@@ -12522,7 +12628,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12554,13 +12660,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12558: checking for dgesv_ in -llapack" >&5
+echo "configure:12661: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12564 "configure"
+#line 12667 "configure"
@@ -12571,7 +12677,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12590,13 +12696,13 @@
-echo "configure:12594: checking for dgesv_ in -llapack" >&5
+echo "configure:12697: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12600 "configure"
+#line 12703 "configure"
@@ -12607,7 +12713,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12663,7 +12769,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12667: checking whether to use Cairo" >&5
+echo "configure:12770: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12695,7 +12801,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12699: checking for location of cairo includes" >&5
+echo "configure:12802: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12721,15 +12827,15 @@
do
-echo "configure:12725: checking for $ac_hdr" >&5
+echo "configure:12828: checking for $ac_hdr" >&5
-#line 12728 "configure"
+#line 12831 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12765,7 +12871,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12769: checking for location of cairo library" >&5
+echo "configure:12872: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12785,7 +12891,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12789: checking for cairo linking flags" >&5
+echo "configure:12892: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12801,10 +12907,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12805: checking for cairo_create" >&5
+echo "configure:12908: checking for cairo_create" >&5
-#line 12808 "configure"
+#line 12911 "configure"
which can conflict with char cairo_create(); below. */
@@ -12827,7 +12933,7 @@
; return 0; }
EOF
-if { (eval echo configure:12831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12861,10 +12967,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12865: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12968: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12868 "configure"
+#line 12971 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12887,7 +12993,7 @@
; return 0; }
EOF
-if { (eval echo configure:12891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -12920,10 +13026,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12924: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13027: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12927 "configure"
+#line 13030 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -12946,7 +13052,7 @@
; return 0; }
EOF
-if { (eval echo configure:12950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -12988,7 +13094,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12992: checking whether to use FreeType" >&5
+echo "configure:13095: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13007,7 +13113,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13011: checking for location of FreeType includes" >&5
+echo "configure:13114: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13033,15 +13139,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13037: checking for $ac_hdr" >&5
+echo "configure:13140: checking for $ac_hdr" >&5
-#line 13040 "configure"
+#line 13143 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13045: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13075,7 +13181,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13079: checking for location of FreeType library" >&5
+echo "configure:13182: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13100,13 +13206,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13104: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13207: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13110 "configure"
+#line 13213 "configure"
@@ -13117,7 +13223,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13158,7 +13264,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13162: checking whether to use NLS" >&5
+echo "configure:13265: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13178,10 +13284,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13182: checking for gettext" >&5
+echo "configure:13285: checking for gettext" >&5
-#line 13185 "configure"
+#line 13288 "configure"
which can conflict with char gettext(); below. */
@@ -13204,7 +13310,7 @@
; return 0; }
EOF
-if { (eval echo configure:13208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13222,13 +13328,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13226: checking for gettext in -lintl" >&5
+echo "configure:13329: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13232 "configure"
+#line 13335 "configure"
@@ -13239,7 +13345,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13274,7 +13380,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13278: checking whether to use C++" >&5
+echo "configure:13381: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13290,7 +13396,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13294: checking for $ac_word" >&5
+echo "configure:13397: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13319,7 +13425,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13323: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13426: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13330,12 +13436,12 @@
cat > conftest.$ac_ext << EOF
-#line 13334 "configure"
+#line 13437 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13361,19 +13467,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13365: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13468: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13370: checking whether we are using GNU C++" >&5
+echo "configure:13473: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13391,7 +13497,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13395: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13498: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13432,7 +13538,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13436: checking whether to use openDWG" >&5
+echo "configure:13539: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13452,7 +13558,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13456: checking for location of openDGW includes" >&5
+echo "configure:13559: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13478,15 +13584,15 @@
do
-echo "configure:13482: checking for $ac_hdr" >&5
+echo "configure:13585: checking for $ac_hdr" >&5
-#line 13485 "configure"
+#line 13588 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13520,7 +13626,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13524: checking for location of openDWG library" >&5
+echo "configure:13627: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13561,7 +13667,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13565: checking whether to use POSIX threads" >&5
+echo "configure:13668: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13581,7 +13687,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13585: checking for location of POSIX threads includes" >&5
+echo "configure:13688: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13607,15 +13713,15 @@
do
-echo "configure:13611: checking for $ac_hdr" >&5
+echo "configure:13714: checking for $ac_hdr" >&5
-#line 13614 "configure"
+#line 13717 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13649,7 +13755,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13653: checking for location of POSIX threads library" >&5
+echo "configure:13756: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13674,10 +13780,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13678: checking for pthread_create" >&5
+echo "configure:13781: checking for pthread_create" >&5
-#line 13681 "configure"
+#line 13784 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -13700,7 +13806,7 @@
; return 0; }
EOF
-if { (eval echo configure:13704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13727,13 +13833,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13731: checking for pthread_create in -lpthread" >&5
+echo "configure:13834: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 13737 "configure"
+#line 13840 "configure"
@@ -13744,7 +13850,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13800,7 +13906,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13804: checking for special C compiler options needed for large files" >&5
+echo "configure:13907: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13808,7 +13914,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13812 "configure"
+#line 13915 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13824,7 +13930,7 @@
; return 0; }
EOF
-if { (eval echo configure:13828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13931: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13833,7 +13939,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13837 "configure"
+#line 13940 "configure"
@@ -13849,7 +13955,7 @@
; return 0; }
EOF
-if { (eval echo configure:13853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13956: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13869,11 +13975,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13873: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13976: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13877 "configure"
+#line 13980 "configure"
@@ -13889,14 +13995,14 @@
; return 0; }
EOF
-if { (eval echo configure:13893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13900 "configure"
+#line 14003 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13914,7 +14020,7 @@
; return 0; }
EOF
-if { (eval echo configure:13918: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14021: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13933,11 +14039,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13937: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14040: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13941 "configure"
+#line 14044 "configure"
@@ -13953,14 +14059,14 @@
; return 0; }
EOF
-if { (eval echo configure:13957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13964 "configure"
+#line 14067 "configure"
#define _LARGE_FILES 1
@@ -13978,7 +14084,7 @@
; return 0; }
EOF
-if { (eval echo configure:13982: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14085: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13997,25 +14103,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14001: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14104: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14005 "configure"
+#line 14108 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14115: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14019 "configure"
+#line 14122 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14024,7 +14130,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14028: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14131: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14045,25 +14151,25 @@
fi
-echo "configure:14049: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14152: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14053 "configure"
+#line 14156 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14163: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14067 "configure"
+#line 14170 "configure"
#include <stdio.h>
@@ -14072,7 +14178,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14076: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14179: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14095,18 +14201,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14099: checking for fseeko" >&5
+echo "configure:14202: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14103 "configure"
+#line 14206 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14123,10 +14229,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14127: checking if system supports Large Files at all" >&5
+echo "configure:14230: checking if system supports Large Files at all" >&5
-#line 14130 "configure"
+#line 14233 "configure"
#include <stdio.h>
@@ -14158,7 +14264,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14162: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14187,7 +14293,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14191: checking whether to use wxWidgets" >&5
+echo "configure:14294: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14208,7 +14314,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14212: checking for $ac_word" >&5
+echo "configure:14315: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14256,7 +14362,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14260: checking wxWidgets version" >&5
+echo "configure:14363: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14279,15 +14385,15 @@
do
-echo "configure:14283: checking for $ac_hdr" >&5
+echo "configure:14386: checking for $ac_hdr" >&5
-#line 14286 "configure"
+#line 14389 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14291: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14548,6 +14654,11 @@
s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
s%@USE_GDAL@%$USE_GDAL%g
s%@USE_OGR@%$USE_OGR%g
+s%@LIBLAS_CONFIG@%$LIBLAS_CONFIG%g
+s%@LIBLAS_LIBS@%$LIBLAS_LIBS%g
+s%@LIBLAS_CFLAGS@%$LIBLAS_CFLAGS%g
+s%@LIBLAS_INC@%$LIBLAS_INC%g
+s%@USE_LIBLAS@%$USE_LIBLAS%g
s%@GEOS_CONFIG@%$GEOS_CONFIG%g
s%@GEOS_LIBS@%$GEOS_LIBS%g
s%@GEOS_CFLAGS@%$GEOS_CFLAGS%g
@@ -14939,6 +15050,8 @@
echo " Large File support (LFS): `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
+echo " libLAS support: `if test -n "${USE_LIBLAS}" ; then echo yes ; else echo no ; fi`"
echo " MySQL support: `if test -n "${USE_MYSQL}" ; then echo yes ; else echo no ; fi`"
echo " NLS support: `if test -n "${USE_NLS}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2011-05-25 05:52:44 UTC (rev 46415)
+++ grass/trunk/configure.in 2011-05-25 07:47:44 UTC (rev 46416)
@@ -267,6 +267,12 @@
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')])
+AC_ARG_WITH(liblas,
+[ --with-liblas[=path/liblas-config]
+ enable libLAS support (liblas-config with path,
+ e.g. '--with-liblas=/usr/local/bin/liblas-config',
+ default: no)],, with_liblas="no")
AC_ARG_WITH(wxwidgets,
[ --with-wxwidgets[=path/wx-config]
enable wxWidgets support (wx-config with path,
@@ -797,6 +803,56 @@
AC_SUBST(USE_GDAL)
AC_SUBST(USE_OGR)
+# libLAS option
+AC_MSG_CHECKING(whether to use libLAS)
+LIBLAS_LIBS=
+LIBLAS_CFLAGS=
+USE_LIBLAS=
+if test "`basename xx/$with_liblas`" = "liblas-config" ; then
+ LIBLAS_CONFIG="$with_liblas"
+fi
+if test "$with_liblas" = "no" ; then
+ AC_MSG_RESULT(no)
+else
+ AC_MSG_RESULT(yes)
+ AC_PATH_PROG(LIBLAS_CONFIG, liblas-config, no)
+ if test "$LIBLAS_CONFIG" = "no" ; then
+ AC_MSG_ERROR([*** couldn't find liblas-config])
+ fi
+ if test "$LIBLAS_CONFIG" != "" ; then
+ LIBLAS_LIBS=`"$LIBLAS_CONFIG" --libs`
+ LIBLAS_CFLAGS=`"$LIBLAS_CONFIG" --cflags`
+ LIBLAS_INC=`"$LIBLAS_CONFIG" --includes`
+ USE_LIBLAS=1
+ fi
+ LIBLAS=
+ ac_save_libs="$LIBS"
+ ac_save_cflags="$CFLAGS"
+ LIBS="$LIBS $LIBLAS_LIBS"
+ CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
+ AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],,[
+ AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],LAS_LIBS="$LAS_LIBS",[
+ AC_MSG_ERROR([*** Unable to locate libLAS library.])
+ LIBS=${ac_save_libs}
+ CFLAGS=${ac_save_cflags}
+ AC_DEFINE(HAVE_LIBLAS)
+fi
+AC_SUBST(LIBLAS_LIBS)
+AC_SUBST(LIBLAS_CFLAGS)
+AC_SUBST(LIBLAS_INC)
+AC_SUBST(USE_LIBLAS)
# GEOS option
AC_MSG_CHECKING(whether to use GEOS)
@@ -1890,6 +1946,7 @@
LOC_MSG_USE(JPEG support,USE_JPEG)
LOC_MSG_USE(LAPACK support,USE_LAPACK)
LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
+LOC_MSG_USE(LIBLAS support,USE_LIBLAS)
LOC_MSG_USE(MySQL support,USE_MYSQL)
LOC_MSG_USE(NLS support,USE_NLS)
LOC_MSG_USE(ODBC support,USE_ODBC)
