[GRASS-SVN] r46423 - grass-addons/raster/r.viewshed
svn_grass at osgeo.org
Thu May 26 04:30:49 EDT 2011
Author: hamish
Date: 2011-05-26 01:30:49 -0700 (Thu, 26 May 2011)
New Revision: 46423
grass-addons/raster/r.viewshed/grass.cc
grass-addons/raster/r.viewshed/main.cc
grass-addons/raster/r.viewshed/visibility.h
add a flag to allow consideration of atmospheric refraction (thanks for the research Ben)
Modified: grass-addons/raster/r.viewshed/grass.cc
--- grass-addons/raster/r.viewshed/grass.cc 2011-05-26 08:29:16 UTC (rev 46422)
+++ grass-addons/raster/r.viewshed/grass.cc 2011-05-26 08:30:49 UTC (rev 46423)
@@ -54,9 +54,11 @@
-/* if viewOptions.doCurv is on then adjust the passed height for
+/* If viewOptions.doCurv is on then adjust the passed height for
curvature of the earth; otherwise return the passed height
- unchanged.
+ unchanged.
+ If viewOptions.doRefr is on then adjust the curved height for
+ the effect of atmospheric refraction too.
surface_type adjust_for_curvature(Viewpoint vp, double row,
double col, surface_type h,
@@ -73,14 +75,35 @@
G_row_to_northing(vp.row + 0.5, &(hd->window)),
G_col_to_easting(col + 0.5, &(hd->window)),
G_row_to_northing(row + 0.5, &(hd->window)));
- return h - ((dist * dist) / (2.0 * viewOptions.ellps_a));
+ double adjustment = (dist * dist) / (2.0 * viewOptions.ellps_a);
+ if (!viewOptions.doRefr)
+ return h - adjustment;
+ /* in future we should calculate this based on the physics, for now we
+ just fudge by the 1/7th approximation.
+ ?? See ??
+ @article{yoeli1985making,
+ title={The making of intervisibility maps with computer and plotter},
+ author={Yoeli, Pinhas},
+ journal={Cartographica: The International Journal for Geographic Information and Geovisualization},
+ volume={22},
+ number={3},
+ pages={88--103},
+ year={1985},
+ publisher={UT Press}
+ return h - (adjustment * 6.0/7.0);
/*return a GridHeader that has all the relevant data filled in */
GridHeader *read_header(char *rastName, Cell_head * region)
Modified: grass-addons/raster/r.viewshed/main.cc
--- grass-addons/raster/r.viewshed/main.cc 2011-05-26 08:29:16 UTC (rev 46422)
+++ grass-addons/raster/r.viewshed/main.cc 2011-05-26 08:30:49 UTC (rev 46423)
@@ -147,6 +147,7 @@
viewOptions.maxDist = INFINITY_DISTANCE;
viewOptions.outputMode = OUTPUT_ANGLE;
viewOptions.doCurv = 0;
+ viewOptions.doRefr = 0;
parse_args(argc, argv, &vpRow, &vpCol, &viewOptions, &memSizeBytes,
®ion);
@@ -454,7 +455,14 @@
curvature->description =
_("Consider the curvature of the earth (current ellipsoid)");
+ /* atmospheric refraction flag */
+ struct Flag *refractionFlag;
+ refractionFlag = G_define_flag();
+ refractionFlag->key = 'r';
+ refractionFlag->description =
+ _("Consider the effect of atmospheric refraction");
/* boolean output flag */
struct Flag *booleanOutput;
@@ -471,6 +479,7 @@
elevationFlag->description =
_("Output format is invisible = NULL, else current elev - viewpoint_elev");
/* viewpoint coordinates */
struct Option *viewLocOpt;
@@ -568,8 +577,14 @@
G_fatal_error(_("A negative max distance value is not allowed"));
+ viewOptions->doCurv = curvature->answer;
+ viewOptions->doRefr = refractionFlag->answer;
- viewOptions->doCurv = curvature->answer;
+ if (refractionFlag->answer && !curvature->answer)
+ G_fatal_error(_("Atmospheric refraction is only calculated with "
+ "respect to the curvature of the Earth. "
+ "Enable the -c flag as well."));
if (booleanOutput->answer)
viewOptions->outputMode = OUTPUT_BOOL;
else if (elevationFlag->answer)
Modified: grass-addons/raster/r.viewshed/visibility.h
--- grass-addons/raster/r.viewshed/visibility.h 2011-05-26 08:29:16 UTC (rev 46422)
+++ grass-addons/raster/r.viewshed/visibility.h 2011-05-26 08:30:49 UTC (rev 46423)
@@ -112,18 +112,19 @@
OutputMode outputMode;
/* The mode the viewshed is output;
- in angle mode, the values recorded are {NODATA, INVISIBLE, angle}
- in boolean mode, the values recorded are {BOOL_INVISIBLE, BOOL_VISIBLE}
- in elev mode, the values recorded are {NODATA, INVISIBLE, elevation}
+ - in angle mode, the values recorded are {NODATA, INVISIBLE, angle}
+ - in boolean mode, the values recorded are {BOOL_INVISIBLE, BOOL_VISIBLE}
+ - in elev mode, the values recorded are {NODATA, INVISIBLE, elevation}
int doCurv;
/*determines if the curvature of the earth should be considered
when calculating. Only implemented for GRASS version. */
+ int doRefr;
+ /*determines if atmospheric refraction should be considered
+ when calculating. Only implemented for GRASS version. */
double ellps_a; /* the parameter of the ellipsoid */
float cellsize; /* the cell resolution */
char streamdir[GPATH_MAX]; /* directory for tmp files */
