[GRASS-SVN] r46442 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Sun May 29 04:59:45 EDT 2011
Author: neteler
Date: 2011-05-29 01:59:45 -0700 (Sun, 29 May 2011)
New Revision: 46442
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
Fred Maranh?\195?\163o: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2011-05-29 08:59:21 UTC (rev 46441)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2011-05-29 08:59:45 UTC (rev 46442)
@@ -12,7 +12,7 @@
"Project-Id-Version: grassmods_pt_br\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-04-19 00:30+0200\n"
-"PO-Revision-Date: 2011-05-15 20:32-0300\n"
+"PO-Revision-Date: 2011-05-29 05:08-0300\n"
"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
"Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -1071,7 +1071,7 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:2
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
msgid "raster, export"
-msgstr ""
+msgstr "raster, exportar"
#: ../raster/r.out.bin/main.c:280
msgid "Exports a GRASS raster map to a binary array."
@@ -1085,7 +1085,7 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
#: ../imagery/i.zc/main.c:69
msgid "Name of input raster map"
-msgstr "Nome do Raster de entrada"
+msgstr "Nome do mapa raster de entrada"
#: ../raster/r.out.bin/main.c:296
msgid "Name for output binary map (use output=- for stdout)"
@@ -1847,12 +1847,12 @@
#: ../raster/r.basins.fill/main.c:55
#, fuzzy
msgid "Generates watershed subbasins raster map."
-msgstr "Gera estatísticas areais para os mapas raster."
+msgstr "Gera mapa raster de subbacias watershed."
#: ../raster/r.basins.fill/main.c:59
#, fuzzy
msgid "Name of input coded stream network raster map"
-msgstr "Nome do novo arquivo raster"
+msgstr "Nome do mapa raster de rede de drenagem coded de entrada"
#: ../raster/r.basins.fill/main.c:63
#, fuzzy
@@ -1943,7 +1943,7 @@
#: ../raster/r.le/r.le.trace/main.c:59
msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr ""
+msgstr "Exibe as fronteiras de cada patch r.le e mostra como a fronteira é traçada, exibe os índices de atributo, tamanho, perímetro e forma para cada patch e grava os dados em um arquivo de saída."
#: ../raster/r.le/r.le.setup/sample.c:1050
msgid "Cannot read vector"
@@ -1954,9 +1954,8 @@
msgstr ""
#: ../raster/r.le/r.le.setup/main.c:67
-#, fuzzy
msgid "Raster map to use to setup sampling"
-msgstr "Mapa raster a ser usado para preparar amostragem"
+msgstr "Mapa raster para usar para ajustar a amostragem"
#: ../raster/r.le/r.le.setup/main.c:71
msgid "Vector map to overlay"
@@ -2027,7 +2026,7 @@
#: ../raster/r.mfilter.fp/getfilt.c:50 ../raster/r.mfilter/getfilt.c:49
#, fuzzy
msgid "Even filter matrix size specified"
-msgstr "Duas camadas devem ser especificadas"
+msgstr "Tamanho da matriz de filtro even especificado"
#: ../raster/r.mfilter.fp/getfilt.c:72 ../raster/r.mfilter/getfilt.c:71
msgid "Illegal filter matrix"
@@ -2157,9 +2156,9 @@
msgstr "Não consegui abrir o arquivo <%s>"
#: ../raster/r.out.ascii/main.c:181
-#, c-format
+#, fuzzy, c-format
msgid "Unable to read fp range for <%s>"
-msgstr "Não consegui ler o intervalo fp para <%s>"
+msgstr "Não consegui ler intervalo fp para <%s>"
#: ../raster/r.out.ascii/main.c:197
#, c-format
@@ -2189,15 +2188,15 @@
#: ../raster/r.out.png/r.out.png.c:112
msgid "Export GRASS raster as non-georeferenced PNG image."
-msgstr "Exportar um raster do GRASS como imagem PNG não-georeferenciada"
+msgstr "Exporta um raster do GRASS para imagem PNG não-georeferenciada"
#: ../raster/r.out.png/r.out.png.c:119
msgid "Name for new PNG file (use out=- for stdout)"
-msgstr "Nome para novo arquivo PNG (use out=- para saída padrão)"
+msgstr "Nome para novo arquivo PNG (out=- para saída padrão)"
#: ../raster/r.out.png/r.out.png.c:127
msgid "Compression level of PNG file"
-msgstr "Nível de compressão do arquivo PNG"
+msgstr "Nível de Compactação do arquivo PNG"
#: ../raster/r.out.png/r.out.png.c:128
msgid "(0 = none, 1 = fastest, 9 = best)"
@@ -2210,7 +2209,7 @@
#: ../raster/r.out.png/r.out.png.c:144
#, fuzzy
msgid "Output world file"
-msgstr "Arquivo KeyFrame de saída"
+msgstr "Arquivo world de saída"
#: ../raster/r.out.png/r.out.png.c:196 ../display/d.text.freetype/main.c:842
#: ../display/d.graph/main.c:103 ../display/d.graph/do_graph.c:112
@@ -2229,7 +2228,7 @@
#: ../raster/r.out.png/r.out.png.c:298 ../raster/r.univar2/r.univar_main.c:183
#, c-format
msgid "Raster <%s> type mismatch"
-msgstr "erro de tipo do raster <%s>"
+msgstr "tipo do raster <%s> não combina"
#: ../raster/r.out.png/r.out.png.c:324 ../raster/r.surf.idw/main.c:690
#: ../raster/r.proj/readcell.c:27 ../raster/r.mapcalc/map.c:234
@@ -2241,16 +2240,16 @@
#: ../imagery/i.maxlik/main.c:117
#, c-format
msgid "Unable to read raster map row %d"
-msgstr "Não consegui ler linha %d do mapa raster"
+msgstr "Não consegui ler linha %d de mapa raster"
#: ../raster/r.out.png/r.out.png.c:455
#, fuzzy
msgid "Writing world file"
-msgstr "Escrevendo dados para o arquivo ..."
+msgstr "Escrevendo arquivo world"
#: ../raster/r.out.png/r.out.png.c:458 ../raster/r.out.tiff/r.out.tiff.c:417
msgid "Got null file name"
-msgstr "Recebi nome do arquivo nulo"
+msgstr "Recebi nome de arquivo nulo"
#: ../raster/r.out.png/r.out.png.c:460 ../raster/r.out.tiff/r.out.tiff.c:419
msgid "Got null region struct"
@@ -2259,12 +2258,12 @@
#: ../raster/r.out.png/r.out.png.c:462
#, fuzzy
msgid "Unable to open world file for writing"
-msgstr "Não consegui abrir o arquivo de células [%s]"
+msgstr "Não consegui abrir o arquivo world para escrita"
#: ../raster/r.walk/main.c:179
#, fuzzy
msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr "Gera uma camada de mapa raster mostrando o custo acumulado anisotrópico de movimento entre diferentes localizações geográficas em uma camada de mapa raster de elevação cujos valores de categoria das células representam a elevação combinada com uma camada de mapa raster de entrada cujos valores das células representam o custo de fricção."
+msgstr "Gera uma camada raster mostrando o custo cumulativo de movimento entre diferentes localizações sobre um mapa raster de entrada cujos valores de célula representam o custo."
#: ../raster/r.walk/main.c:191
msgid "Name of elevation input raster map"
@@ -2273,7 +2272,7 @@
#: ../raster/r.walk/main.c:199
#, fuzzy
msgid "Name of input raster map containing friction costs"
-msgstr "Nome do mapa raster de entrada contendo isolinhas"
+msgstr "Nome do mapa raster de entrada existente contendo isolinhas"
#: ../raster/r.walk/main.c:206
msgid "Name of raster map to contain results"
@@ -2314,8 +2313,9 @@
msgstr "Porcentagem do mapa para manter em memória"
#: ../raster/r.walk/main.c:277
+#, fuzzy
msgid "Number of the segment to create (segment library)"
-msgstr "Número do segmento para criar (biblioteca de segmentos)"
+msgstr "Número de vezes para repetir o filtro"
#: ../raster/r.walk/main.c:287
msgid "Coefficients for walking energy formula parameters a,b,c,d"
@@ -2359,7 +2359,7 @@
#: ../raster/r.walk/main.c:377
#, c-format
msgid "Missing required value: got %d instead of 4"
-msgstr "Faltando valor obrigatório: recebi %d ao invés de 4"
+msgstr "Faltando valor necessário: obtive %d ao invés de 4"
#: ../raster/r.walk/main.c:381
#, c-format
@@ -2370,7 +2370,7 @@
#: ../raster/r.walk/main.c:401
#, c-format
msgid "Missing required value: %d"
-msgstr "Faltando valor obrigatório: %d"
+msgstr "Faltando valor solicitado: %d"
#: ../raster/r.walk/main.c:389
#, c-format
@@ -2380,12 +2380,12 @@
#: ../raster/r.walk/main.c:397
#, c-format
msgid "Slope_factor is %lf"
-msgstr "slope_factor (fator de declividade) é %lf"
+msgstr "Slope_factor (fator de declividade) é %lf"
#: ../raster/r.walk/main.c:404
#, fuzzy, c-format
msgid "Nseg is %d"
-msgstr "é"
+msgstr "Nseg é %d"
#: ../raster/r.walk/main.c:410
msgid "Null cells excluded from cost evaluation."
@@ -2393,42 +2393,45 @@
#: ../raster/r.walk/main.c:414
msgid "Input null cell will be retained into output map"
-msgstr "Células nulas na entrada vão ser preservadas na saída"
+msgstr "células nulas da entrada vão ser mantidas no mapa de saída"
#: ../raster/r.walk/main.c:426
#, c-format
msgid "Unable to find starting vector <%s> "
-msgstr "Não encontrei vetor de inicio <%s>"
+msgstr "Não encontrei vetor inicial <%s>"
#: ../raster/r.walk/main.c:473
#, c-format
msgid "Unable to find stop vector <%s>"
-msgstr "Não encontrei vetor de parada <%s>"
+msgstr "Não encontrei vetor final <%s>"
#: ../raster/r.walk/main.c:512
msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr "Atenção: atribuindo custo negativo a células nulas. Células nulas excluídas."
+msgstr "Atenção: atribuindo custo negativo a células nulas. Células nulas excluídas."
#: ../raster/r.walk/main.c:584 ../raster/r.walk/main.c:586
#, c-format
msgid "Unable to read %s"
-msgstr "Não consegui ler %s"
+msgstr "não consegui ler %s"
#: ../raster/r.walk/main.c:591
msgid "Map with different projection"
msgstr "Mapa com projeção diferente"
#: ../raster/r.walk/main.c:603
+#, fuzzy
msgid "DTM_Source map is: Integer cell type"
-msgstr "Mapa DTM_Source é: tipo de célula inteiro"
+msgstr "DTM_Source map is: Integer cell type"
#: ../raster/r.walk/main.c:606
+#, fuzzy
msgid "DTM_Source map is: Floating point (float) cell type"
-msgstr "mapa DTM_Source é: tipo de célula ponto flutuante (float)"
+msgstr "DTM_Source map is: Floating point (float) cell type"
#: ../raster/r.walk/main.c:609
+#, fuzzy
msgid "DTM_Source map is: Floating point (double) cell type"
-msgstr "Mapa DTM_Source é: tipo de célula ponto flutuante (double)"
+msgstr "DTM_Source map is: Floating point (double) cell type"
#: ../raster/r.walk/main.c:612 ../raster/r.walk/main.c:627
#: ../raster/r.walk/main.c:664
@@ -2437,28 +2440,34 @@
msgstr "%d linhas, %d colunas"
#: ../raster/r.walk/main.c:618
+#, fuzzy
msgid "COST_Source map is: Integer cell type"
-msgstr "Mapa COST_Source é: tipo de célula inteiro"
+msgstr "COST_Source map is: Integer cell type"
#: ../raster/r.walk/main.c:621
+#, fuzzy
msgid "COST_Source map is: Floating point (float) cell type"
-msgstr "mapa COST_Source é: tipo de célula ponto flutuante (float)"
+msgstr "COST_Source map is: Floating point (float) cell type"
#: ../raster/r.walk/main.c:624
+#, fuzzy
msgid "COST_Source map is: Floating point (double) cell type"
-msgstr "mapa COST_Source é: tipo de célula ponto flutuante (double)"
+msgstr "COST_Source map is: Floating point (double) cell type"
#: ../raster/r.walk/main.c:655
+#, fuzzy
msgid "Output map is: Integer cell type"
-msgstr "Mapa de saída é: tipo de célula inteiro"
+msgstr "Output map is: Integer cell type"
#: ../raster/r.walk/main.c:658
+#, fuzzy
msgid "Output map is: Floating point (float) cell type"
-msgstr "Mapa de saída é: tipo de célula ponto flutuante (float)"
+msgstr "Output map is: Floating point (float) cell type"
#: ../raster/r.walk/main.c:661
+#, fuzzy
msgid "Output map is: Floating point (double) cell type"
-msgstr "Mapa de saída é: tipo de célula ponto flutuante (double)"
+msgstr "Output map is: Floating point (double) cell type"
#: ../raster/r.walk/main.c:666
#, c-format
@@ -2505,11 +2514,11 @@
#: ../imagery/i.gensig/get_train.c:32
#, c-format
msgid "Unable to read raster map <%s> row %d"
-msgstr "Não consegui ler mapa raster <%s> linha %d."
+msgstr "Não consegui ler, no mapa raster <%s>, a linha %d"
#: ../raster/r.walk/main.c:852
msgid "Initializing output "
-msgstr "Inicializando saída "
+msgstr "Iniciando saída "
#: ../raster/r.walk/main.c:860 ../raster/r.walk/main.c:889
msgid "Unable to allocate memory for segment fbuff == NULL"
@@ -2521,14 +2530,14 @@
msgstr "Inicializando dados ...\n"
#: ../raster/r.walk/main.c:917
-#, c-format
+#, fuzzy, c-format
msgid "Raster output map <%s> not found (no start_points given)"
-msgstr "Mapa raster de saída <%s> não encontrado (start_points não foi dado)"
+msgstr "Mapa raster de saída <%s> não encontrado (nenhum start_points dado)"
#: ../raster/r.walk/main.c:932
#, c-format
msgid "Memory allocation error on reading start points from raster map %s"
-msgstr "Erro de alocação de memória ao ler pontos iniciais do mapa raster %s"
+msgstr "Erro de alocação de memória ao ler pontos inicias do mapa raster %s"
#: ../raster/r.walk/main.c:935
#, c-format
@@ -2536,9 +2545,8 @@
msgstr "Lendo %s... "
#: ../raster/r.walk/main.c:982 ../raster/r.cost/main.c:717
-#, fuzzy
msgid "Specified starting location outside database window"
-msgstr "localização fora banco de dados"
+msgstr "Locação inicial especificado fora da janela de banco de dados"
#: ../raster/r.walk/main.c:999
msgid "Finding cost path"
@@ -2555,13 +2563,14 @@
#: ../raster/r.walk/main.c:1497
#, c-format
msgid "Writing output raster map %s... "
-msgstr "Escrevendo mapa raster de saída %s... "
+msgstr "Escrevendo mapa raster %s de saída"
#: ../raster/r.walk/main.c:1501
msgid "Will copy input map null values into output map"
-msgstr "Vou copiar valores nulos do mapa de entrada para o mapa de saída"
+msgstr "Vou copiar valores nulos do mapa de entrada em mapa de saída"
#: ../raster/r.walk/main.c:1508
+#, fuzzy
msgid ""
"Integer cell type.\n"
"Writing..."
@@ -2570,11 +2579,12 @@
"Escrevendo..."
#: ../raster/r.walk/main.c:1543
+#, fuzzy
msgid ""
"Float cell type.\n"
"Writing..."
msgstr ""
-"Tipo de célula float.\n"
+"tipo de célula Float.\n"
"Escrevendo..."
#: ../raster/r.walk/main.c:1578
@@ -2582,7 +2592,7 @@
"Double cell type.\n"
"Writing..."
msgstr ""
-"Tipo de célula double.\n"
+"tipo de célula double.\n"
"Escrevendo..."
#: ../raster/r.walk/main.c:1613 ../raster/r.cost/main.c:1117
@@ -2598,12 +2608,12 @@
#: ../raster/r.walk/main.c:1698 ../raster/r.cost/main.c:1192
#, c-format
msgid "Illegal x coordinate <%s>"
-msgstr "Coordenada x ilegal <%s>"
+msgstr "Coordenada x <%s> ilegal"
#: ../raster/r.walk/main.c:1700 ../raster/r.cost/main.c:1194
#, c-format
msgid "Illegal y coordinate <%s>"
-msgstr "Coordenada y ilegal <%s>"
+msgstr "Coordenada y <%s> ilegal"
#: ../raster/r.walk/main.c:1704 ../raster/r.cost/main.c:1198
#, c-format
@@ -2654,7 +2664,7 @@
#: ../raster/r.sun2/main.c:264
msgid "A single value of the orientation (aspect), 270 is south"
-msgstr "Um único valor de orientação (aspecto), 270 é sul"
+msgstr "Um único valor da orientação (aspecto), 270 é sul"
#: ../raster/r.sun2/main.c:273 ../raster/r.sun/main.c:227
msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
@@ -2662,7 +2672,7 @@
#: ../raster/r.sun2/main.c:281
msgid "A single value of inclination (slope)"
-msgstr "Um único valor da inclinação (declividade)"
+msgstr "Um único valor de inclinação (declividade)"
#: ../raster/r.sun2/main.c:290 ../raster/r.sun/main.c:236
msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
@@ -2701,9 +2711,8 @@
msgstr "Nome do mapa raster do coeficiente de radiação difusa de céu real [-]"
#: ../raster/r.sun2/main.c:365
-#, fuzzy
msgid "The horizon information input map prefix"
-msgstr "The horizon information input map prefix"
+msgstr "O prefixo de mapa de entrada de informações do horizonte"
#: ../raster/r.sun2/main.c:373 ../raster/r.horizon/main.c:244
msgid "Angle step size for multidirectional horizon [degrees]"
@@ -2823,9 +2832,8 @@
msgstr "incompatível"
#: ../raster/r.sun2/main.c:599
-#, fuzzy
msgid "Error reading time step size"
-msgstr "Erro lendo intervalo para [%s]"
+msgstr "Erro lendo o tamanho do intervalo de tempo"
#: ../raster/r.sun2/main.c:601
#, fuzzy
@@ -2835,7 +2843,7 @@
#: ../raster/r.sun2/main.c:605
#, fuzzy
msgid "Error reading horizon step size"
-msgstr "Erro lendo arquivo raster [%s]."
+msgstr "Erro lendo o tamanho de passo do horizonte"
#: ../raster/r.sun2/main.c:609
msgid "The horizon step size must be greater than 0."
@@ -2846,9 +2854,8 @@
msgstr ""
#: ../raster/r.sun2/main.c:618
-#, fuzzy
msgid "Time and insol_time are incompatible options"
-msgstr "incompatível"
+msgstr "Tempo e insol_time são opções incompatíveis"
#: ../raster/r.sun2/main.c:620
#, fuzzy
@@ -2910,14 +2917,13 @@
msgstr ""
#: ../raster/r.sun2/main.c:951
-#, fuzzy, c-format
+#, c-format
msgid "Horizon file no. %d <%s> not found"
-msgstr "Arquivo 3dview <%s> não encontrado"
+msgstr "arquivo de horizonte num. %d <%s> não encontrado"
#: ../raster/r.in.gdal/main.c:81
-#, fuzzy
msgid "Import GDAL supported raster file into a binary raster map layer."
-msgstr "Importar raster suportado pela GDAL para uma camada raster binária."
+msgstr "Importa arquivo raster suportado pela GDAL para uma camada raster binária."
#: ../raster/r.in.gdal/main.c:87
msgid "Raster file to be imported"
@@ -2931,26 +2937,24 @@
#: ../vector/v.in.ogr/main.c:120 ../vector/v.select/args.c:50
#: ../vector/v.in.ascii/in.c:57 ../ps/ps.map/main.c:107
#: ../ps/ps.map/main.c:112
-#, fuzzy
msgid "Required"
-msgstr "quieto"
+msgstr "Exigido"
#: ../raster/r.in.gdal/main.c:100
msgid "Band to select (default is all bands)"
msgstr "Banda selecionada (o padrão são todas as bandas)"
#: ../raster/r.in.gdal/main.c:106 ../raster/r.proj.seg/main.c:196
-#, fuzzy
msgid "Cache size (MiB)"
-msgstr "Tamanho do rótulo (pixels)"
+msgstr "Tamanho do cache (MiB)"
#: ../raster/r.in.gdal/main.c:113
msgid "Name of location to read projection from for GCPs transformation"
-msgstr "Nome da locação para leitura da projeção para transformação dos GCPs"
+msgstr "Nome da locação de onde ler a projeção para transformação dos GCPs"
#: ../raster/r.in.gdal/main.c:121 ../raster/r.external/main.c:537
msgid "Metadata"
-msgstr ""
+msgstr "Metadados"
#: ../raster/r.in.gdal/main.c:127 ../vector/v.in.ogr/main.c:183
msgid "Name for new location to create"
@@ -2967,9 +2971,8 @@
#: ../raster/r.in.gdal/main.c:140 ../raster/r.external/main.c:554
#: ../vector/v.in.ogr/main.c:202
-#, fuzzy
msgid "List supported formats and exit"
-msgstr "Mostra oso formatos suportados e encerra"
+msgstr "Mostra os formatos suportados e encerra"
#: ../raster/r.in.gdal/main.c:141 ../raster/r.stats/main.c:147
#: ../raster/r.stats/main.c:152 ../raster/r.stats/main.c:157
@@ -3000,9 +3003,8 @@
msgstr ""
#: ../raster/r.in.gdal/main.c:146
-#, fuzzy
msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr "Coordenadas do mapa"
+msgstr "Força mapas Lat/Lon a se ajustarem em coordenadas geográficas (90N,S; 180E,W)"
#: ../raster/r.in.gdal/main.c:151
#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
@@ -3011,34 +3013,32 @@
#: ../raster/r.in.gdal/main.c:172
msgid "You have to specify a target location different from output location"
-msgstr ""
+msgstr "Você tem que especificar uma locação alvo diferente da locação saída"
#: ../raster/r.in.gdal/main.c:176
msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr ""
+msgstr "A opção '-l' funciona apenas em locações Lat/Lon"
#: ../raster/r.in.gdal/main.c:194
-#, fuzzy
msgid "Available GDAL Drivers:"
-msgstr "Lista formatos disponíveis e finaliza"
+msgstr "Drivers GDAL disponíveis:"
#: ../raster/r.in.gdal/main.c:215 ../raster/r.proj/main.c:264
#: ../raster/r.out.gdal/main.c:230 ../raster/r.proj.seg/main.c:301
#: ../vector/v.in.ogr/main.c:272 ../vector/v.in.ogr/main.c:324
#: ../vector/v.proj/main.c:181 ../vector/v.select/main.c:90
-#, fuzzy, c-format
+#, c-format
msgid "Required parameter <%s> not set"
-msgstr "parâmetro para"
+msgstr "parâmetro <%s> necessário não configurado"
#: ../raster/r.in.gdal/main.c:218 ../raster/r.external/main.c:585
-#, fuzzy
msgid "Name for output raster map not specified"
-msgstr "Nome do Raster de saída"
+msgstr "Nome do mapa raster de saída não especificado"
#: ../raster/r.in.gdal/main.c:226
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "O vetor '%s' já existe."
+msgstr "Mapa raster <%s> já existe e será sobreescrito"
#: ../raster/r.in.gdal/main.c:246
msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
@@ -3057,20 +3057,19 @@
msgstr "Não consegui converter a projeção do mapa de entrada para o formato do GRASS, não posso criar nova locação."
#: ../raster/r.in.gdal/main.c:330
-#, fuzzy, c-format
+#, c-format
msgid "Location <%s> created"
-msgstr "Locação: %s\n"
+msgstr "Locação <%s> criada"
#: ../raster/r.in.gdal/main.c:337 ../raster/r.external/main.c:83
-#, fuzzy
msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr "Não consegui converter a projeção do mapa de entrada para o formato do GRASS para verificação"
+msgstr "Não consegui converter a projeção do mapa raster de entrada para o formato do GRASS para verificação"
#: ../raster/r.in.gdal/main.c:353 ../raster/r.external/main.c:99
#: ../vector/v.in.ogr/main.c:509
#, fuzzy
msgid "Over-riding projection check"
-msgstr "Fonte"
+msgstr "Over-riding projection check"
#: ../raster/r.in.gdal/main.c:364 ../raster/r.external/main.c:107
#: ../vector/v.in.ogr/main.c:518
@@ -3082,9 +3081,8 @@
"\n"
#: ../raster/r.in.gdal/main.c:369 ../raster/r.external/main.c:112
-#, fuzzy
msgid "Location PROJ_INFO is:\n"
+msgstr "Locação PROJ_INFO é:\n"
#: ../raster/r.in.gdal/main.c:380 ../raster/r.external/main.c:123
msgid "Dataset PROJ_INFO is:\n"
@@ -3104,7 +3102,6 @@
"Você pode usar a opção -o para r.in.gdal para ignorar esta verificaçãoe usar a definição de locação para o conjunto de dados.\n"
#: ../raster/r.in.gdal/main.c:432 ../raster/r.external/main.c:175
-#, fuzzy
msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
msgstr "Considere gerar uma nova locação a partir do conjunto de dados de entrada usando o parâmetro 'location'.\n"
@@ -3114,69 +3111,63 @@
msgstr "Projeção do conjunto de dados de entrada e locação atual parecem combinar"
#: ../raster/r.in.gdal/main.c:443 ../raster/r.external/main.c:614
-#, fuzzy
msgid "Proceeding with import..."
-msgstr "criando novo arquivo cats ..."
+msgstr "Seguindo com a importação..."
#: ../raster/r.in.gdal/main.c:469 ../raster/r.external/main.c:629
-#, fuzzy, c-format
+#, c-format
msgid "Selected band (%d) does not exist"
-msgstr "Mapa raster [%s] não encontrado"
+msgstr "Banda selecionada (%d) não existe"
#: ../raster/r.in.gdal/main.c:548
-#, fuzzy, c-format
+#, c-format
msgid "Copying %d GCPS in points file for <%s>"
-msgstr "Erro na leitura do arquivo de categorias para <%s>."
+msgstr "Copiando %d GCPS em arquivo de pontos para <%s>"
#: ../raster/r.in.gdal/main.c:553
msgid "GCPs have the following OpenGIS WKT Coordinate System:"
msgstr ""
#: ../raster/r.in.gdal/main.c:560
-#, fuzzy
msgid "Re-projecting GCPs table:"
+msgstr "Re-projetando tabela GCPs:"
#: ../raster/r.in.gdal/main.c:561
-#, fuzzy, c-format
+#, c-format
msgid "* Input projection for GCP table: %s"
-msgstr "Entrada"
+msgstr "* Projeção de entrada para a tabela GCP: %s"
#: ../raster/r.in.gdal/main.c:563
-#, fuzzy, c-format
+#, c-format
msgid "* Output projection for GCP table: %s"
-msgstr "Gera uma mapa de direções"
+msgstr "* Projeção de saída para a tabela GCP: %s"
#: ../raster/r.in.gdal/main.c:580
-#, fuzzy, c-format
+#, c-format
msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr "Erro em pj_do_proj (projeção das coordenadas de entrada)"
+msgstr "Erro em pj_do_proj (Não posso re-projetar GCP %i)"
#: ../raster/r.in.gdal/main.c:639
-#, fuzzy
msgid "Unable to translate projection key values of input GCPs"
-msgstr "Não obtive os valores de projeção da locação atual"
+msgstr "Não consegui traduzir valores chave de projeção das entradas GCPs"
#: ../raster/r.in.gdal/main.c:655
-#, fuzzy
msgid "Unable to get projection info of target location"
-msgstr "Não consegui informações de projeção da locação atual"
+msgstr "Não consegui informações de projeção da locação destino"
#: ../raster/r.in.gdal/main.c:657
-#, fuzzy
msgid "Unable to get projection units of target location"
-msgstr "Não consegui unidades de projeção da locação atual"
+msgstr "Não consegui unidades de projeção da locação alvo"
#: ../raster/r.in.gdal/main.c:659
-#, fuzzy
msgid "Unable to get projection key values of target location"
+msgstr "Não obtive os valores chave de projeção da locação alvo"
#: ../raster/r.in.gdal/main.c:662 ../imagery/i.rectify/target.c:32
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
-#, fuzzy, c-format
+#, c-format
msgid "Mapset <%s> in target location <%s> - "
-msgstr "Grupo <%s> destinado para locação <%s>, mapset [%s]\n"
+msgstr "conjunto de mapas <%s> na locação destino <%s> - "
#: ../raster/r.in.gdal/main.c:664 ../raster/r.proj/main.c:245
#: ../raster/r.proj.seg/main.c:282 ../imagery/i.rectify/target.c:33
@@ -3187,35 +3178,32 @@
#: ../raster/r.in.gdal/main.c:665 ../raster/r.proj/main.c:246
#: ../raster/r.proj.seg/main.c:283 ../imagery/i.rectify/target.c:33
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:32
-#, fuzzy
msgid "not found"
-msgstr "[%s] não encontrado."
+msgstr "não encontrado"
#: ../raster/r.in.gdal/main.c:932
-#, fuzzy, c-format
+#, c-format
msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr "Criando arquivos de suporte para %s..."
+msgstr "Configurando tabela de cores cinza para <%s> (8bit, intervalo completo)"
#: ../raster/r.in.gdal/main.c:945
-#, fuzzy, c-format
+#, c-format
msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr "Configurando tabela de cores cinza para <%s> (16bit, intervalo de imagem)"
#: ../raster/r.in.gdal/main.c:956 ../raster/r.circle/dist.c:155
#: ../raster/r.surf.fractal/main.c:39 ../raster/r.recode/main.c:110
#: ../raster/r.composite/main.c:273
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> created."
msgstr "Mapa raster <%s> criado."
#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
#: ../raster/r.in.bin/main.c:510
-#, fuzzy
msgid "Error reading data"
-msgstr "Erro na leitura do mapa raster de entrada."
+msgstr "Erro na leitura de dados"
#: ../raster/r.in.bin/main.c:236
-#, fuzzy
msgid "Import a binary raster file into a GRASS raster map."
msgstr "Importar um arquivo raster binário para uma camada raster do GRASS."
@@ -3267,7 +3255,7 @@
#: ../imagery/i.cluster/main.c:138 ../imagery/i.cluster/main.c:146
#: ../imagery/i.cluster/main.c:154
msgid "Settings"
-msgstr "Configurações"
+msgstr ""
#: ../raster/r.in.bin/main.c:255
msgid "Byte Swap the Data During Import"
@@ -3286,12 +3274,11 @@
#: ../general/g.region/main.c:254 ../general/g.region/main.c:263
#: ../general/g.region/main.c:341 ../general/g.region/main.c:352
msgid "Bounds"
-msgstr "Limites"
+msgstr ""
#: ../raster/r.in.bin/main.c:267
-#, fuzzy
msgid "Binary raster file to be imported"
-msgstr "Arquivo raster para importar"
+msgstr "Arquivo raster binário para importar"
#: ../raster/r.in.bin/main.c:300
msgid "Northern limit of geographic region (outer edge)"
@@ -3322,14 +3309,13 @@
msgstr "Definir valor como NULL"
#: ../raster/r.in.bin/main.c:366
-#, fuzzy
msgid "order= and -b are mutually exclusive"
-msgstr "Opções -B e -C são mutuamente exclusivas. Escolha apenas uma."
+msgstr "order= e -b são mutuamente exclusivos"
#: ../raster/r.in.bin/main.c:381
#, fuzzy
msgid "-f and -d are mutually exclusive"
+msgstr "-f e -d são mutuamente exclusivos"
#: ../raster/r.in.bin/main.c:385
#, c-format
@@ -3384,9 +3370,9 @@
msgstr "Coordenada Leste ilegal <%s>"
#: ../raster/r.in.bin/main.c:445
-#, c-format
+#, fuzzy, c-format
msgid "Unable to open <%s>"
-msgstr "Não consegui abrir <%s>"
+msgstr "Não consegui abrir o arquivo de células <%s>"
#: ../raster/r.in.bin/main.c:464
#, c-format
@@ -3714,9 +3700,9 @@
msgstr "Mapa raster do qual copiarei a tabela de cores"
#: ../raster/r.support/front/front.c:125 ../raster/r.cats/main.c:136
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> not found in current mapset"
-msgstr "mapa vetorial <%s> não encontrado"
+msgstr "mapa vetorial <%s> não encontrado no mapset atual"
#: ../raster/r.support/front/front.c:143
msgid "Not enough room in history file"
@@ -4455,9 +4441,8 @@
msgstr "Modo ângulo"
#: ../raster/r.sun/main.c:474 ../raster/r.horizon/main.c:473
-#, fuzzy
msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Não consegui informações de projeção da locação atual: favor ajustar a latitude via opção 'lat' ou 'latin'!"
#: ../raster/r.sun/main.c:529
#, fuzzy, c-format
@@ -4955,9 +4940,8 @@
msgstr ""
#: ../raster/r.cost/main.c:130
-#, fuzzy
msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "Gera uma camada raster mostrando o custo cumulativo de movimento entre diferentes localizações sobre um mapa raster de entrada cujos valores de célula representam o custo."
+msgstr "Gera um mapa raster mostrando o custo acumulado de movimento entre diferentes localizações em um mapa raster de entrada cujos valores de célula representam o custo."
#: ../raster/r.cost/main.c:137
msgid "Name of raster map containing grid cell cost information"
@@ -5774,19 +5758,17 @@
msgstr "Mostra a região atual"
#: ../raster/r.random/main.c:188
-#, fuzzy
msgid "There are no valid locations in the current region"
-msgstr "Não atualizar a região atual"
+msgstr "Não existem locações válidas na região atual"
#: ../raster/r.random/count.c:74
-#, fuzzy
msgid "Collecting Stats..."
-msgstr "Calculando médias das classes ..."
+msgstr "Coletando estatísticas..."
#: ../raster/r.random/count.c:78
-#, fuzzy, c-format
+#, c-format
msgid "Cannot read raster row [%d]"
-msgstr "Não consegui ler arquivo raster agora."
+msgstr "Não consegui ler linha [%d] do raster"
#: ../raster/r.random/count.c:82
#, fuzzy, c-format
@@ -6102,7 +6084,7 @@
#: ../raster/r.gwflow/main.c:61
msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
-msgstr ""
+msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
#: ../raster/r.gwflow/main.c:66
msgid "X-part of the hydraulic conductivity tensor in [m/s]"
@@ -6181,19 +6163,17 @@
msgstr ""
#: ../raster/r.gwflow/main.c:201 ../raster/r.topidx/main.c:50
-#, fuzzy, c-format
+#, c-format
msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "Tipo da coluna não suportado"
+msgstr "Locação Lat/Long não é suportada por %s. Favor reprojetar o mapa primeiro."
#: ../raster/r.gwflow/main.c:215
-#, fuzzy
msgid "Please provide river_head, river_leak and river_bed maps"
-msgstr "RGB"
+msgstr "Favor fornecer os mapas river_head, river_leak e river_bed"
#: ../raster/r.gwflow/main.c:227
-#, fuzzy
msgid "Please provide drain_head and drain_leak maps"
-msgstr "RGB"
+msgstr "Favor forneça os mapas drain_head e drain_leak"
#: ../raster/r.gwflow/main.c:238
msgid "The direct LU solver do not work with sparse matrices"
@@ -6209,15 +6189,14 @@
msgstr ""
#: ../raster/r.gwflow/main.c:379
-#, fuzzy, c-format
+#, c-format
msgid "Maximum difference between this and last increment: %g"
-msgstr "Máxima distância entre pontos (em unidades do mapa)"
+msgstr "Máxima diferença entre este e o próximo incremento: %g"
#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
#: ../raster/r.profile/input.c:59
-#, fuzzy
msgid "One coordinate pair per line, please"
-msgstr "Um par de coordenadas por linha, por favor."
+msgstr "Um par de coordenadas por linha, por favor"
#: ../raster/r.profile/main.c:55
msgid "Outputs the raster map layer values lying on user-defined line(s)."
@@ -7410,8 +7389,9 @@
msgstr "Não consegui alocar memória para 'string'"
#: ../raster/r.surf.fractal/interface.c:36
+#, fuzzy
msgid "raster, DEM, fractal"
-msgstr "raster, MDT, fractal"
+msgstr "Mapa raster a ser amostrado"
#: ../raster/r.surf.fractal/interface.c:38
msgid "Creates a fractal surface of a given fractal dimension."
@@ -7437,7 +7417,7 @@
#: ../raster/r.surf.fractal/spec_syn.c:120
#, fuzzy, c-format
msgid "Calculating surface %d (of %d)..."
-msgstr "Calculando superfície %d (de %d)..."
+msgstr "Calculando sombras a partir do DEM..."
#: ../raster/r.covar/main.c:55
msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
@@ -10156,7 +10136,7 @@
#: ../raster/r.sunmask/main.c:475
msgid "Calculating shadows from DEM..."
-msgstr "Calculando sombras a partir do MDT..."
#: ../raster/r.sunmask/solpos00.c:949
#, c-format
@@ -11674,8 +11654,9 @@
msgstr ""
#: ../raster/r.carve/main.c:79
+#, fuzzy
msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr "Recebe dados de fluxo vetoriais, transforma em raster e subtrai a profundidade do MDT de saída."
+msgstr "fluxo para profundidade"
#: ../raster/r.carve/main.c:84
#, fuzzy
@@ -12504,7 +12485,7 @@
#: ../raster/r.region/main.c:56
msgid "Sets the boundary definitions for a raster map."
-msgstr "Ajusta as definições de limite para um mapa raster"
+msgstr "Ajusta as definições de fronteira para um mapa raster"
#: ../raster/r.region/main.c:66
msgid "Set from current region"
@@ -14280,7 +14261,7 @@
#: ../general/g.region/main.c:72
#, fuzzy
msgid "Manages the boundary definitions for the geographic region."
-msgstr "Programa para gerenciar as definições de limite para a região geográfica."
+msgstr "Gerencia as definições de fronteira para a região geográfica."
#: ../general/g.region/main.c:79 ../general/g.region/main.c:84
#: ../general/g.region/main.c:172 ../general/g.region/main.c:179
@@ -14414,14 +14395,12 @@
msgstr "Resolução vertical da malha 3D"
#: ../general/g.region/main.c:339
-#, fuzzy
msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr "Ajustar a região coincidente com esse mapa raster"
+msgstr "Diminuir região até ter dados não-nulos provenientes do mapa raster"
#: ../general/g.region/main.c:350
-#, fuzzy
msgid "Adjust region cells to cleanly align with this raster map"
+msgstr "Ajustar as células da região para alinharem claramente com este mapa raster"
#: ../general/g.region/main.c:361
#, fuzzy
@@ -14660,7 +14639,7 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:97
#: ../imagery/i.class/main.c:90
msgid "No graphics device selected"
-msgstr "Nenhum dispositivo gráfico selecionado"
+msgstr "Nenhum dispositivo gráfico selecionado."
#: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
msgid "Use 'd.frame -e' to remove left over frames"
@@ -15248,7 +15227,7 @@
#: ../display/d.erase/main.c:34
msgid "Erase the contents of the active display frame with user defined color"
-msgstr "Apaga o conteúdo do quadro ativo com a cor definida pelo usuário"
+msgstr "Substitui o conteúdo do quadro ativo com a cor definida pelo usuário"
#: ../display/d.erase/main.c:42
msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
@@ -15261,7 +15240,7 @@
#: ../display/d.erase/main.c:62 ../display/d.measure/main.c:90
#: ../display/d.colortable/main.c:147
msgid "No current frame"
-msgstr "Nenhum quadro no momento"
+msgstr "Nenhum quadro selecionado"
#: ../display/d.erase/main.c:64 ../display/d.measure/main.c:93
#: ../display/d.colortable/main.c:149
@@ -15950,7 +15929,7 @@
#: ../display/d.barscale/main.c:98
msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-msgstr "Coordenadas em porcentagem do canto esquerdo-acima do rótulo ([0,0] é o canto superior esquerdo)"
+msgstr "Coordenadas em porcentagem do quadro ([0,0] é o canto superior esquerdo)"
#: ../display/d.barscale/main.c:106
#, fuzzy
@@ -16229,9 +16208,8 @@
msgstr "não consegui atualizar limites"
#: ../display/d.thematic.area/main.c:141
-#, fuzzy
msgid "Boundary width"
-msgstr "Largura da linha"
+msgstr "Largura da borda"
#: ../display/d.thematic.area/main.c:147
#, fuzzy
@@ -16561,7 +16539,7 @@
#: ../display/d.histogram/main.c:73
msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
-msgstr "Mostra um histograma em forma de pizza ou barras para um arquivo raster especificado pelo usuário."
+msgstr "Mostra u m histograma em forma de pizza ou barras para um arquivo raster especificado pelo usuário."
#: ../display/d.histogram/main.c:77
msgid "Raster map for which histogram will be displayed"
@@ -16956,9 +16934,9 @@
#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.components/main.c:108
#: ../vector/v.to.3d/main.c:72 ../vector/v.net.spanningtree/main.c:81
#: ../doc/vector/v.example/main.c:85
-#, c-format
+#, fuzzy, c-format
msgid "Unable to open vector map <%s>"
-msgstr "Não consegui abrir mapa vetorial <%s>."
+msgstr "Não consegui abrir mapa raster [%s]."
#: ../display/d.what.vect/main.c:151
#, c-format
@@ -17117,28 +17095,32 @@
msgstr "valor [%.0f,%.0f] fora do limite [0-100]"
#: ../display/d.rast/main.c:52
+#, fuzzy
msgid "Displays user-specified raster map in the active graphics frame."
-msgstr "Exibe mapas raster selecionados pelo usuário no quadro gráfico ativo."
+msgstr "Exibe três mapas raster selecionados pelo usuário como bandas vermelha, verde e azul no quadro gráfico atual"
#: ../display/d.rast/main.c:57 ../imagery/i.class/main.c:62
+#, fuzzy
msgid "Name of raster map to be displayed"
-msgstr "Nome do mapa raster para exibição"
+msgstr "Nome do mapa de orientação para exibição"
#: ../display/d.rast/main.c:65
msgid "List of categories to be displayed (INT maps)"
msgstr "Lista de categorias para exibir (mapas INT)"
#: ../display/d.rast/main.c:74
+#, fuzzy
msgid "List of values to be displayed (FP maps)"
-msgstr "Lista de valores para exibir (mapas FP)"
+msgstr "Lista de valores de célula para mascarar"
#: ../display/d.rast/main.c:83
+#, fuzzy
msgid "Background color (for null)"
-msgstr "Cor de fundo (para nulos)"
+msgstr "Cor de fundo"
#: ../display/d.rast/main.c:84 ../display/d.rast/main.c:89
msgid "Null cells"
-msgstr "Células nulas"
+msgstr ""
#: ../display/d.rast/main.c:93
#, fuzzy
@@ -17146,8 +17128,9 @@
msgstr "Inverter catlist"
#: ../display/d.rast/main.c:99
+#, fuzzy
msgid "Don't add to list of rasters and commands in monitor"
-msgstr "Não adicionar à lista de rasters e comandos no monitor"
+msgstr "Não adicionar á lista de vetores e comandos no monitor"
#: ../display/d.rast/main.c:119
msgid "Ignoring catlist: map is floating point (please use 'val=')"
@@ -18229,7 +18212,7 @@
#: ../vector/v.to.db/parse.c:38
#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "Tipo dos elementos (coor para ponto/centróide válido, lenght para linha/contorno válido)"
+msgstr "Para coord de ponto/centróide válido, comprimento de linha/contorno válido)"
#: ../vector/v.to.db/parse.c:42
#, fuzzy
@@ -18420,7 +18403,7 @@
#: ../vector/lidar/v.outlier/main.c:74
#, fuzzy
msgid "Removes outliers from vector point data."
-msgstr "Remove desvios da informação dos pontos vetoriais"
+msgstr "Remove desvios da informação dos pontos vectoriais"
#: ../vector/lidar/v.outlier/main.c:78
#: ../vector/lidar/v.surf.bspline/main.c:94
@@ -18629,7 +18612,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:172
msgid "Choose either vector or raster output, not both"
-msgstr "Escolher saída vetorial ou raster, não ambas"
+msgstr "Escolher saída vectorial ou raster, não ambas"
#: ../vector/lidar/v.surf.bspline/main.c:175
#, fuzzy
@@ -19337,21 +19320,15 @@
#: ../vector/v.in.ogr/main.c:164
#, fuzzy
msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr ""
-"Alterar os tipos de entrada (opcional):\n"
-"\t ponto -> importar centróides das áreas como pontos\n"
-"\t linha -> importar limites das áreas como centróides\n"
-"\t limite -> importar linhas como limites das áreas\n"
-"\t centróide -> importar pontos como centróides"
+msgstr " ponto;importar centróides das áreas como pontos;linha;importar limites das áreas como linhas;limite;importar linhas como limites das áreas;centróide;importar pontos como centróides"
#: ../vector/v.in.ogr/main.c:175
-#, fuzzy
msgid "Snapping threshold for boundaries"
-msgstr "Limite de 'snap' para contornos. -1 para não haver snap"
+msgstr "Limiar de 'snap' para fronteiras"
#: ../vector/v.in.ogr/main.c:177
msgid "'-1' for no snap"
-msgstr ""
+msgstr "-1 para não haver snap"
#: ../vector/v.in.ogr/main.c:191
msgid "List of column names to be used instead of original names, first is used for category column"
@@ -19503,7 +19480,7 @@
#: ../vector/v.in.ogr/main.c:842
#, fuzzy, c-format
msgid "Boundary splitting distance in map units: %G"
-msgstr "Distância do buffer (em unidades do mapa)"
+msgstr "Distância de separação de fronteiras em unidades do mapa: %G"
#: ../vector/v.in.ogr/main.c:847
#, c-format
@@ -19718,9 +19695,8 @@
msgstr ""
#: ../vector/v.extract/main.c:98
-#, fuzzy
msgid "Dissolve common boundaries (default is no)"
-msgstr "Dissolver limites comuns? (padrão é não)"
+msgstr "Dissolver limites comuns (padrão é não)"
#: ../vector/v.extract/main.c:102
msgid "Do not copy table (see also 'new' parameter)"
@@ -19728,9 +19704,8 @@
#: ../vector/v.extract/main.c:106 ../vector/v.select/args.c:88
#: ../vector/v.edit/args.c:201
-#, fuzzy
msgid "Reverse selection"
-msgstr "Posição de referência"
+msgstr "Seleção invertida"
#: ../vector/v.extract/main.c:116
#, fuzzy
@@ -21884,7 +21859,7 @@
#: ../vector/v.out.ogr/main.c:232
msgid "Skipping all boundaries that are not part of an area."
-msgstr ""
+msgstr "Pulando todas as fronteiras que não são parte de uma área."
#: ../vector/v.out.ogr/main.c:251
#, fuzzy
@@ -21958,7 +21933,7 @@
#: ../vector/v.out.ogr/main.c:395
#, fuzzy
msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-msgstr "%d Fronteiras encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+msgstr "Nenhuma Fronteira encontrada, mas requerida para exportação. Vou pular este tipo de geometria."
#: ../vector/v.out.ogr/main.c:404
#, fuzzy
@@ -23037,7 +23012,7 @@
#: ../vector/v.buffer2/main.c:547 ../vector/v.buffer/main.c:661
#, fuzzy
msgid "Snapping boundaries..."
-msgstr "Rotacionando dados ... "
+msgstr "Fazendo snap de fronteiras..."
#: ../vector/v.buffer2/main.c:550 ../vector/v.buffer/main.c:664
#, fuzzy
@@ -23054,18 +23029,17 @@
#: ../vector/v.buffer2/main.c:557 ../vector/v.buffer/main.c:670
#, fuzzy
msgid "Breaking boundaries..."
-msgstr "Escrevendo [%s]..."
+msgstr "Quebrando fronteiras..."
#: ../vector/v.buffer2/main.c:563
#, fuzzy
msgid "Cleaning boundaries at nodes"
+msgstr "Limpando fronteiras nos vértices"
#: ../vector/v.buffer2/main.c:578 ../vector/v.overlay/area_area.c:55
#: ../vector/v.buffer/main.c:685
-#, fuzzy
msgid "Attaching islands..."
-msgstr "Anexando categorias...\n"
+msgstr "Anexando ilhas..."
#: ../vector/v.buffer2/main.c:584 ../vector/v.buffer2/main.c:677
#: ../vector/v.buffer/main.c:792
@@ -23074,9 +23048,8 @@
#: ../vector/v.buffer2/main.c:615 ../vector/v.buffer/main.c:742
-#, fuzzy
msgid "Generating list of boundaries to be deleted..."
+msgstr "Gerando lista de fronteiras que serão apagadas..."
#: ../vector/v.buffer2/main.c:648 ../vector/v.buffer/main.c:776
#, fuzzy
@@ -23498,7 +23471,9 @@
msgid ""
"\n"
"New vector map <%s> boundary coordinates:"
-msgstr "Novo mapa de vetores <%s> coordenadas dos limites:\n"
+msgstr ""
+"\n"
+"Novas coordendas de fronteira do mapa vetorial <%s>:"
#: ../vector/v.transform/main.c:353
#, fuzzy, c-format
@@ -31590,7 +31565,7 @@
#: ../imagery/i.vpoints/main.c:96
msgid "Set registration points for an imagery group from a vector map or keyboard entry."
-msgstr "Marcar pontos de registo para um grupo de imagem a partir de uma mapa vetorial ou através do teclado."
+msgstr "Marcar pontos de registo para um grupo de imagem a partir de uma mapa vectorial ou através do teclado."
#: ../imagery/i.vpoints/main.c:104 ../imagery/i.points/main.c:105
#, fuzzy
@@ -33356,16 +33331,15 @@
#~ msgid "raster, color transformation"
#~ msgstr "raster, transformação de cor"
-#, fuzzy
#~ msgid "raster, export, png"
-#~ msgstr "raster, export, png"
+#~ msgstr "raster, exportar, png"
#, fuzzy
#~ msgid "raster, sun energy"
#~ msgstr "raster, sun energy"
#~ msgid "Name of the longitude input raster map [decimal degrees]"
-#~ msgstr "Nome do mapa raster de entrada com as longitudes [graus decimais]"
+#~ msgstr "Nome do mapa raster de entrada com as latitudes [graus decimais]"
#, fuzzy
#~ msgid "raster, rescale"
@@ -33782,7 +33756,7 @@
#, fuzzy
#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "Não existe mapa vetorial para interpolar. A interpolação será efetuada utilizando <%s> mapa vetorial"
+#~ msgstr "Não existe mapa vectorial para interpolar. A interpolação será efectuada utilizando <%s> mapa vectorial"
#, fuzzy
#~ msgid "Remove lines and areas smaller than threshold"
@@ -33961,3 +33935,6 @@
#, fuzzy
#~ msgid "imagery, classification"
#~ msgstr "Assinaturas para usar na classificação"
+#~ msgid "%d boundaries were deleted, input areas are not preserved"
+#~ msgstr "%d fronteiras foram apagadas, áreas de entrada não foram preservadas"
