[GRASS-SVN] r46444 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun May 29 05:00:15 EDT 2011
Author: mmetz
Date: 2011-05-29 02:00:15 -0700 (Sun, 29 May 2011)
New Revision: 46444
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/build_nat.c
fix memory leak
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2011-05-29 08:59:57 UTC (rev 46443)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2011-05-29 09:00:15 UTC (rev 46444)
@@ -216,6 +216,8 @@
btype = Vect_read_line(Map, BPoints, BCats, bline);
+ AXLines = NULL;
+ BXLines = NULL;
Vect_line_intersection(APoints, BPoints, &AXLines, &BXLines,
&naxlines, &nbxlines, 0);
G_debug(3, " naxlines = %d nbxlines = %d", naxlines, nbxlines);
@@ -292,9 +294,10 @@
Vect_destroy_line_struct(AXLines[k]);
- G_free(AXLines);
nbreaks += naxlines - 1;
+ if (AXLines)
+ G_free(AXLines);
if (nbxlines > 0) {
if (aline != bline) { /* Self intersection, do not write twice, TODO: is it OK? */
@@ -341,8 +344,9 @@
for (k = 0; k < nbxlines; k++)
Vect_destroy_line_struct(BXLines[k]);
+ if (BXLines)
G_free(BXLines);
if (Err) {
for (l = 0; l < nx; l++) { /* Write out errors */
Vect_reset_line(Points);
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2011-05-29 08:59:57 UTC (rev 46443)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2011-05-29 09:00:15 UTC (rev 46444)
@@ -564,7 +564,7 @@
if (format == G_INFO_FORMAT_PLAIN)
fprintf(stderr, "%d..", i);
else
- fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
+ fprintf(stderr, "%10d\b\b\b\b\b\b\b\b\b\b", i);
i++;
