[GRASS-SVN] r46465 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules icons
svn_grass at osgeo.org
Tue May 31 05:26:53 EDT 2011
Author: martinl
Date: 2011-05-31 02:26:52 -0700 (Tue, 31 May 2011)
New Revision: 46465
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/icons/icon.py
wxGUI: update preferences.py to follow wxGUI coding standards
re-orgranize preferences dialog tabs (move 'workspace' to 'general')
various minor fixes
(merge r46430 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2011-05-31 08:35:54 UTC (rev 46464)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2011-05-31 09:26:52 UTC (rev 46465)
@@ -999,13 +999,15 @@
settings = preferences.Settings()
- typeface = settings.Get(group='appearance', key='outputfont', subkey='type')
- if typeface == "": typeface = "Courier New"
- typesize = settings.Get(group='appearance', key='outputfont', subkey='size')
- if typesize == None or typesize <= 0: typesize = 10
+ typeface = settings.Get(group = 'appearance', key = 'outputfont', subkey = 'type')
+ if typeface == "":
+ typeface = "Courier New"
+ typesize = settings.Get(group = 'appearance', key = 'outputfont', subkey = 'size')
+ if typesize == None or typesize <= 0:
+ typesize = 10
typesize = float(typesize)
self.StyleDefault = 0
self.StyleDefaultSpec = "face:%s,size:%d,fore:#000000,back:#FFFFFF" % (typeface, typesize)
self.StyleCommand = 1
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2011-05-31 08:35:54 UTC (rev 46464)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2011-05-31 09:26:52 UTC (rev 46465)
@@ -16,7 +16,7 @@
- MapsetAccess
- NvizPreferencesDialog
-(C) 2007-2010 by the GRASS Development Team
+(C) 2007-2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -39,7 +39,7 @@
### i18N
import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
import wx
import wx.lib.filebrowsebutton as filebrowse
@@ -60,15 +60,10 @@
class Settings:
"""!Generic class where to store settings"""
def __init__(self):
- # settings filename
- self.fileName = ".grasswx6"
- self.filePath = None
+ # settings file
+ self.filePath = os.path.join(os.path.expanduser("~"), '.grasswx6')
# key/value separator
self.sep = ';'
try:
@@ -98,6 +93,15 @@
'elementListExpand' : {
'selection' : 0
+ # workspace
+ 'workspace' : {
+ 'posDisplay' : {
+ 'enabled' : False
+ 'posManager' : {
+ 'enabled' : False
'manager' : {
# show opacity level widget
@@ -243,17 +247,6 @@
- # Workspace
- 'workspace' : {
- 'posDisplay' : {
- 'enabled' : False
- 'posManager' : {
- 'enabled' : False
# vdigit
'vdigit' : {
@@ -678,41 +671,20 @@
self.internalSettings['vdigit']['bgmap'] = {}
self.internalSettings['vdigit']['bgmap']['value'] = ''
- def ReadSettingsFile(self, settings=None):
+ def ReadSettingsFile(self, settings = None):
"""!Reads settings file (mapset, location, gisdbase)"""
if settings is None:
settings = self.userSettings
- # look for settings file
- gisenv = grass.gisenv()
- gisdbase = gisenv['GISDBASE']
- location_name = gisenv['LOCATION_NAME']
- mapset_name = gisenv['MAPSET']
- mapset_file = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
- location_file = os.path.join(gisdbase, location_name, self.fileName)
- gisdbase_file = os.path.join(gisdbase, self.fileName)
- home_file = os.path.join(os.path.expanduser("~"), self.fileName) # MS Windows fix ?
+ self._readFile(self.filePath, settings)
- if os.path.isfile(mapset_file):
- self.filePath = mapset_file
- elif os.path.isfile(location_file):
- self.filePath = location_file
- elif os.path.isfile(gisdbase_file):
- self.filePath = gisdbase_file
- elif os.path.isfile(home_file):
- self.filePath = home_file
- if self.filePath:
- self.__ReadFile(self.filePath, settings)
# set environment variables
- os.environ["GRASS_FONT"] = self.Get(group='display',
- key='font', subkey='type')
- os.environ["GRASS_ENCODING"] = self.Get(group='display',
- key='font', subkey='encoding')
+ os.environ["GRASS_FONT"] = self.Get(group = 'display',
+ key = 'font', subkey = 'type')
+ os.environ["GRASS_ENCODING"] = self.Get(group = 'display',
+ key = 'font', subkey = 'encoding')
- def __ReadFile(self, filename, settings=None):
+ def _readFile(self, filename, settings = None):
"""!Read settings from file to dict"""
@@ -735,7 +707,7 @@
else:
subkey = kv[idx]
value = kv[idx+1]
- value = self.__parseValue(value, read=True)
+ value = self._parseValue(value, read = True)
self.Append(settings, group, key, subkey, value)
idx += 2
except ValueError, e:
@@ -748,21 +720,17 @@
file.close()
- def SaveToFile(self, settings=None):
+ def SaveToFile(self, settings = None):
"""!Save settings to the file"""
- home = os.path.expanduser("~") # MS Windows fix ?
- filePath = os.path.join(home, self.fileName)
try:
- file = open(filePath, "w")
+ file = open(self.filePath, "w")
for group in settings.keys():
for key in settings[group].keys():
- file.write('%s%s%s%s' % (group, self.sep, key, self.sep))
subkeys = settings[group][key].keys()
+ file.write('%s%s%s%s' % (group, self.sep, key, self.sep))
for idx in range(len(subkeys)):
value = settings[group][key][subkeys[idx]]
if type(value) == types.DictType:
@@ -772,15 +740,15 @@
kvalues = settings[group][key][subkeys[idx]].keys()
srange = range(len(kvalues))
for sidx in srange:
- svalue = self.__parseValue(settings[group][key][subkeys[idx]][kvalues[sidx]])
+ svalue = self._parseValue(settings[group][key][subkeys[idx]][kvalues[sidx]])
file.write('%s%s%s' % (kvalues[sidx], self.sep,
svalue))
if sidx < len(kvalues) - 1:
file.write('%s' % self.sep)
- if idx < len(subkeys) - 1:
- file.write('%s%s%s%s%s' % (os.linesep, group, self.sep, key, self.sep))
+# if len(subkeys) > 4 and idx < len(subkeys) - 1:
+# file.write('%s%s%s%s%s' % (os.linesep, group, self.sep, key, self.sep))
else:
- value = self.__parseValue(settings[group][key][subkeys[idx]])
+ value = self._parseValue(settings[group][key][subkeys[idx]])
file.write('%s%s%s' % (subkeys[idx], self.sep, value))
if idx < len(subkeys) - 1 and \
type(settings[group][key][subkeys[idx + 1]]) != types.DictType:
@@ -790,14 +758,12 @@
raise gcmd.GException(e)
except StandardError, e:
raise gcmd.GException(_('Writing settings to file <%(file)s> failed.'
- '\n\nDetails: %(detail)s') % { 'file' : filePath,
+ '\n\nDetails: %(detail)s') % { 'file' : self.filePath,
'detail' : e })
file.close()
- return filePath
- def __parseValue(self, value, read=False):
+ def _parseValue(self, value, read = False):
"""!Parse value to be store in settings file"""
if read: # -> read settings (cast values)
if value == 'True':
@@ -827,7 +793,7 @@
return value
- def Get(self, group, key=None, subkey=None, internal=False):
+ def Get(self, group, key = None, subkey = None, internal = False):
"""!Get value by key/subkey
Raise KeyError if key is not found
@@ -945,7 +911,7 @@
style = style)
# notebook
- self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+ self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
# dict for window ids
self.winId = {}
@@ -978,8 +944,8 @@
"""!Layout window"""
# sizers
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(item=self.btnDefault, proportion=1,
- flag=wx.ALL, border=5)
+ btnSizer.Add(item = self.btnDefault, proportion = 1,
+ flag = wx.ALL, border = 5)
btnStdSizer = wx.StdDialogButtonSizer()
btnStdSizer.AddButton(self.btnCancel)
btnStdSizer.AddButton(self.btnSave)
@@ -987,11 +953,11 @@
btnStdSizer.Realize()
mainSizer = wx.BoxSizer(wx.VERTICAL)
- mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
- mainSizer.Add(item=btnSizer, proportion=0,
- flag=wx.EXPAND, border=0)
- mainSizer.Add(item=btnStdSizer, proportion=0,
- flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT, border=5)
+ mainSizer.Add(item = self.notebook, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 5)
+ mainSizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.EXPAND, border = 0)
+ mainSizer.Add(item = btnStdSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT, border = 5)
self.SetSizer(mainSizer)
mainSizer.Fit(self)
@@ -1040,8 +1006,8 @@
Posts event EVT_SETTINGS_CHANGED.
if self._updateSettings():
- file = self.settings.SaveToFile()
- self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % file)
+ self.settings.SaveToFile()
+ self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % self.settings.filePath)
event = wxSettingsChanged()
wx.PostEvent(self, event)
self.Close()
@@ -1071,10 +1037,10 @@
value = win.GetValue()
if key == 'keycolumn' and value == '':
- wx.MessageBox(parent=self,
- message=_("Key column cannot be empty string."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
- win.SetValue(self.settings.Get(group='atm', key='keycolumn', subkey='value'))
+ wx.MessageBox(parent = self,
+ message = _("Key column cannot be empty string."),
+ caption = _("Error"), style = wx.OK | wx.ICON_ERROR)
+ win.SetValue(self.settings.Get(group = 'atm', key = 'keycolumn', subkey = 'value'))
return False
if subkey1:
@@ -1093,150 +1059,187 @@
settings = settings)
# create notebook pages
- self._CreateGeneralPage(self.notebook)
- self._CreateAppearancePage(self.notebook)
- self._CreateDisplayPage(self.notebook)
- self._CreateCmdPage(self.notebook)
- self._CreateAttributeManagerPage(self.notebook)
- self._CreateProjectionPage(self.notebook)
- self._CreateWorkspacePage(self.notebook)
+ self._createGeneralPage(self.notebook)
+ self._createAppearancePage(self.notebook)
+ self._createDisplayPage(self.notebook)
+ self._createCmdPage(self.notebook)
+ self._createAttributeManagerPage(self.notebook)
+ self._createProjectionPage(self.notebook)
self.SetMinSize(self.GetBestSize())
self.SetSize(self.size)
- def _CreateGeneralPage(self, notebook):
+ def _createGeneralPage(self, notebook):
"""!Create notebook page for general settings"""
- panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
- notebook.AddPage(page=panel, text=_("General"))
+ panel = wx.Panel(parent = notebook, id = wx.ID_ANY)
+ notebook.AddPage(page = panel, text = _("General"))
border = wx.BoxSizer(wx.VERTICAL)
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("General settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("General settings"))
sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
+ gridSizer = wx.GridBagSizer (hgap = 3, vgap = 3)
gridSizer.AddGrowableCol(0)
# expand element list
row = 0
- gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Element list:")),
- flag=wx.ALIGN_LEFT |
+ gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = _("Element list:")),
+ flag = wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL,
- pos=(row, 0))
- elementList = wx.Choice(parent=panel, id=wx.ID_ANY,
- choices=self.settings.Get(group='general', key='elementListExpand',
- subkey='choices', internal=True),
- name="GetSelection")
- elementList.SetSelection(self.settings.Get(group='general', key='elementListExpand',
- subkey='selection'))
+ pos = (row, 0))
+ elementList = wx.Choice(parent = panel, id = wx.ID_ANY,
+ choices = self.settings.Get(group = 'general', key = 'elementListExpand',
+ subkey = 'choices', internal = True),
+ name = "GetSelection")
+ elementList.SetSelection(self.settings.Get(group = 'general', key = 'elementListExpand',
+ subkey = 'selection'))
self.winId['general:elementListExpand:selection'] = elementList.GetId()
- gridSizer.Add(item=elementList,
- flag=wx.ALIGN_RIGHT |
+ gridSizer.Add(item = elementList,
+ flag = wx.ALIGN_RIGHT |
- pos=(row, 1))
+ pos = (row, 1))
# default window layout
row += 1
- defaultPos = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Save current window layout as default"),
- name='IsChecked')
- defaultPos.SetValue(self.settings.Get(group='general', key='defWindowPos', subkey='enabled'))
+ defaultPos = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Save current window layout as default"),
+ name = 'IsChecked')
+ defaultPos.SetValue(self.settings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled'))
defaultPos.SetToolTip(wx.ToolTip (_("Save current position and size of Layer Manager window and opened "
"Map Display window(s) and use as default for next sessions.")))
self.winId['general:defWindowPos:enabled'] = defaultPos.GetId()
- gridSizer.Add(item=defaultPos,
- pos=(row, 0), span=(1, 2))
+ gridSizer.Add(item = defaultPos,
+ pos = (row, 0), span = (1, 2))
- sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
- border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+ sizer.Add(item = gridSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 5)
+ border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 3)
# Layer Manager settings
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Layer Manager settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Layer Manager settings"))
# ask when removing map layer from layer tree
row = 0
- askOnRemoveLayer = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Ask when removing map layer from layer tree"),
- name='IsChecked')
- askOnRemoveLayer.SetValue(self.settings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'))
+ askOnRemoveLayer = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Ask when removing map layer from layer tree"),
+ askOnRemoveLayer.SetValue(self.settings.Get(group = 'manager', key = 'askOnRemoveLayer', subkey = 'enabled'))
self.winId['manager:askOnRemoveLayer:enabled'] = askOnRemoveLayer.GetId()
- gridSizer.Add(item=askOnRemoveLayer,
+ gridSizer.Add(item = askOnRemoveLayer,
row += 1
- askOnQuit = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Ask when quiting wxGUI or closing display"),
- name='IsChecked')
- askOnQuit.SetValue(self.settings.Get(group='manager', key='askOnQuit', subkey='enabled'))
+ askOnQuit = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Ask when quiting wxGUI or closing display"),
+ askOnQuit.SetValue(self.settings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'))
self.winId['manager:askOnQuit:enabled'] = askOnQuit.GetId()
- gridSizer.Add(item=askOnQuit,
+ gridSizer.Add(item = askOnQuit,
- border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+ border.Add(item = sizer, proportion = 0, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
+ # workspace
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Workspace settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer.AddGrowableCol(0)
+ row = 0
+ posDisplay = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Suppress positioning Map Display Window(s)"),
+ posDisplay.SetValue(self.settings.Get(group = 'general', key = 'workspace',
+ subkey = ['posDisplay', 'enabled']))
+ self.winId['general:workspace:posDisplay:enabled'] = posDisplay.GetId()
+ gridSizer.Add(item = posDisplay,
+ row +=1
+ posManager = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Suppress positioning Layer Manager window"),
+ posManager.SetValue(self.settings.Get(group = 'general', key = 'workspace',
+ subkey = ['posManager', 'enabled']))
+ self.winId['general:workspace:posManager:enabled'] = posManager.GetId()
+ gridSizer.Add(item = posManager,
+ panel.SetSizer(border)
+ return panel
return panel
- def _CreateAppearancePage(self, notebook):
+ def _createAppearancePage(self, notebook):
"""!Create notebook page for display settings"""
- notebook.AddPage(page=panel, text=_("Appearance"))
+ notebook.AddPage(page = panel, text = _("Appearance"))
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Font settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Font settings"))
# font settings
row = 0
- label=_("Font for command output:")),
+ label = _("Font for command output:")),
- pos=(row, 0))
- outfontButton = wx.Button(parent=panel, id=wx.ID_ANY,
- label=_("Set font"), size=(100, -1))
- gridSizer.Add(item=outfontButton,
+ pos = (row, 0))
+ outfontButton = wx.Button(parent = panel, id = wx.ID_ANY,
+ label = _("Set font"), size = (100, -1))
+ gridSizer.Add(item = outfontButton,
- pos=(row, 1))
+ pos = (row, 1))
# appearence
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Appearance settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Appearance settings"))
@@ -1255,70 +1258,70 @@
menuItemText = wx.Choice(parent = panel, id = wx.ID_ANY, size = (300, -1),
choices = listOfStyles,
- menuItemText.SetSelection(self.settings.Get(group='appearance', key='menustyle', subkey='selection'))
+ menuItemText.SetSelection(self.settings.Get(group = 'appearance', key = 'menustyle', subkey = 'selection'))
self.winId['appearance:menustyle:selection'] = menuItemText.GetId()
- gridSizer.Add(item=menuItemText,
- flag=wx.ALIGN_RIGHT,
- pos=(row, 1))
+ gridSizer.Add(item = menuItemText,
+ flag = wx.ALIGN_RIGHT,
+ pos = (row, 1))
# gselect.TreeCtrlComboPopup height
row += 1
- label=_("Height of map selection popup window (in pixels):")),
+ label = _("Height of map selection popup window (in pixels):")),
- pos=(row, 0))
- min = self.settings.Get(group='appearance', key='gSelectPopupHeight', subkey='min', internal=True)
- max = self.settings.Get(group='appearance', key='gSelectPopupHeight', subkey='max', internal=True)
- value = self.settings.Get(group='appearance', key='gSelectPopupHeight', subkey='value')
+ pos = (row, 0))
+ min = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'min', internal = True)
+ max = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'max', internal = True)
+ value = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'value')
- popupHeightSpin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1))
+ popupHeightSpin = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (100, -1))
popupHeightSpin.SetRange(min,max)
popupHeightSpin.SetValue(value)
self.winId['appearance:gSelectPopupHeight:value'] = popupHeightSpin.GetId()
- gridSizer.Add(item=popupHeightSpin,
- pos=(row, 1))
+ gridSizer.Add(item = popupHeightSpin,
+ pos = (row, 1))
# icon theme
row += 1
- label=_("Icon theme:")),
+ label = _("Icon theme:")),
- pos=(row, 0))
- iconTheme = wx.Choice(parent=panel, id=wx.ID_ANY, size=(100, -1),
- choices=self.settings.Get(group='appearance', key='iconTheme',
- name="GetStringSelection")
- iconTheme.SetStringSelection(self.settings.Get(group='appearance', key='iconTheme', subkey='type'))
+ pos = (row, 0))
+ iconTheme = wx.Choice(parent = panel, id = wx.ID_ANY, size = (100, -1),
+ choices = self.settings.Get(group = 'appearance', key = 'iconTheme',
+ name = "GetStringSelection")
+ iconTheme.SetStringSelection(self.settings.Get(group = 'appearance', key = 'iconTheme', subkey = 'type'))
self.winId['appearance:iconTheme:type'] = iconTheme.GetId()
- gridSizer.Add(item=iconTheme,
+ gridSizer.Add(item = iconTheme,
- pos=(row, 1))
+ pos = (row, 1))
row += 1
- label=_("Note: For changing the icon theme, "
+ label = _("Note: For changing the icon theme, "
"you must save the settings and restart this GUI.")),
- flag=wx.ALIGN_CENTER_VERTICAL,
+ flag = wx.ALIGN_CENTER_VERTICAL,
@@ -1329,46 +1332,46 @@
- def _CreateDisplayPage(self, notebook):
+ def _createDisplayPage(self, notebook):
- notebook.AddPage(page=panel, text=_("Map Display"))
+ notebook.AddPage(page = panel, text = _("Map Display"))
# font settings
row = 0
- label=_("Default font for GRASS displays:")),
+ label = _("Default font for GRASS displays:")),
- pos=(row, 0))
- fontButton = wx.Button(parent=panel, id=wx.ID_ANY,
- gridSizer.Add(item=fontButton,
+ pos = (row, 0))
+ fontButton = wx.Button(parent = panel, id = wx.ID_ANY,
+ gridSizer.Add(item = fontButton,
- pos=(row, 1))
+ pos = (row, 1))
# display settings
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Default display settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Default display settings"))
@@ -1376,9 +1379,9 @@
# display driver
row = 0
- label=_("Display driver:")),
+ label = _("Display driver:")),
pos=(row, 0))
listOfDrivers = self.settings.Get(group='display', key='driver', subkey='choices', internal=True)
@@ -1397,91 +1400,91 @@
driver.SetStringSelection(self.settings.Get(group='display', key='driver', subkey='type'))
self.winId['display:driver:type'] = driver.GetId()
- gridSizer.Add(item=driver,
- pos=(row, 1))
+ gridSizer.Add(item = driver,
+ pos = (row, 1))
# Statusbar mode
row += 1
- label=_("Statusbar mode:")),
+ label = _("Statusbar mode:")),
- pos=(row, 0))
- listOfModes = self.settings.Get(group='display', key='statusbarMode', subkey='choices', internal=True)
- statusbarMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(150, -1),
- choices=listOfModes,
- statusbarMode.SetSelection(self.settings.Get(group='display', key='statusbarMode', subkey='selection'))
+ pos = (row, 0))
+ listOfModes = self.settings.Get(group = 'display', key = 'statusbarMode', subkey = 'choices', internal = True)
+ statusbarMode = wx.Choice(parent = panel, id = wx.ID_ANY, size = (150, -1),
+ choices = listOfModes,
+ statusbarMode.SetSelection(self.settings.Get(group = 'display', key = 'statusbarMode', subkey = 'selection'))
self.winId['display:statusbarMode:selection'] = statusbarMode.GetId()
- gridSizer.Add(item=statusbarMode,
- pos=(row, 1))
+ gridSizer.Add(item = statusbarMode,
+ pos = (row, 1))
# Background color
row += 1
- label=_("Background color:")),
+ label = _("Background color:")),
- pos=(row, 0))
- bgColor = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
- colour=self.settings.Get(group='display', key='bgcolor', subkey='color'),
- size=globalvar.DIALOG_COLOR_SIZE)
+ pos = (row, 0))
+ bgColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
+ colour = self.settings.Get(group = 'display', key = 'bgcolor', subkey = 'color'),
+ size = globalvar.DIALOG_COLOR_SIZE)
bgColor.SetName('GetColour')
self.winId['display:bgcolor:color'] = bgColor.GetId()
- gridSizer.Add(item=bgColor,
- pos=(row, 1))
+ gridSizer.Add(item = bgColor,
+ pos = (row, 1))
# Use computation resolution
row += 1
- compResolution = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Constrain display resolution to computational settings"),
- name="IsChecked")
- compResolution.SetValue(self.settings.Get(group='display', key='compResolution', subkey='enabled'))
+ compResolution = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Constrain display resolution to computational settings"),
+ name = "IsChecked")
+ compResolution.SetValue(self.settings.Get(group = 'display', key = 'compResolution', subkey = 'enabled'))
self.winId['display:compResolution:enabled'] = compResolution.GetId()
- gridSizer.Add(item=compResolution,
+ gridSizer.Add(item = compResolution,
# auto-rendering
row += 1
- autoRendering = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Enable auto-rendering"),
- name="IsChecked")
- autoRendering.SetValue(self.settings.Get(group='display', key='autoRendering', subkey='enabled'))
+ autoRendering = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Enable auto-rendering"),
+ autoRendering.SetValue(self.settings.Get(group = 'display', key = 'autoRendering', subkey = 'enabled'))
self.winId['display:autoRendering:enabled'] = autoRendering.GetId()
- gridSizer.Add(item=autoRendering,
+ gridSizer.Add(item = autoRendering,
# auto-zoom
row += 1
- autoZooming = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Enable auto-zooming to selected map layer"),
- name="IsChecked")
- autoZooming.SetValue(self.settings.Get(group='display', key='autoZooming', subkey='enabled'))
+ autoZooming = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Enable auto-zooming to selected map layer"),
+ autoZooming.SetValue(self.settings.Get(group = 'display', key = 'autoZooming', subkey = 'enabled'))
self.winId['display:autoZooming:enabled'] = autoZooming.GetId()
- gridSizer.Add(item=autoZooming,
+ gridSizer.Add(item = autoZooming,
@@ -1490,16 +1493,16 @@
return panel
- def _CreateCmdPage(self, notebook):
+ def _createCmdPage(self, notebook):
"""!Create notebook page for commad dialog settings"""
- notebook.AddPage(page=panel, text=_("Command"))
+ notebook.AddPage(page = panel, text = _("Command"))
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Command dialog settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Command dialog settings"))
@@ -1507,71 +1510,71 @@
row = 0
# overwrite
- overwrite = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Allow output files to overwrite existing files"),
- name="IsChecked")
- overwrite.SetValue(self.settings.Get(group='cmd', key='overwrite', subkey='enabled'))
+ overwrite = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Allow output files to overwrite existing files"),
+ overwrite.SetValue(self.settings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
self.winId['cmd:overwrite:enabled'] = overwrite.GetId()
- gridSizer.Add(item=overwrite,
+ gridSizer.Add(item = overwrite,
row += 1
# close
- close = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Close dialog when command is successfully finished"),
- name="IsChecked")
- close.SetValue(self.settings.Get(group='cmd', key='closeDlg', subkey='enabled'))
+ close = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Close dialog when command is successfully finished"),
+ close.SetValue(self.settings.Get(group = 'cmd', key = 'closeDlg', subkey = 'enabled'))
self.winId['cmd:closeDlg:enabled'] = close.GetId()
- gridSizer.Add(item=close,
+ gridSizer.Add(item = close,
row += 1
# add layer
- add = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Add created map into layer tree"),
- name="IsChecked")
- add.SetValue(self.settings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
+ add = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Add created map into layer tree"),
+ add.SetValue(self.settings.Get(group = 'cmd', key = 'addNewLayer', subkey = 'enabled'))
self.winId['cmd:addNewLayer:enabled'] = add.GetId()
- gridSizer.Add(item=add,
+ gridSizer.Add(item = add,
row += 1
# interactive input
interactive = wx.CheckBox(parent = panel, id = wx.ID_ANY,
label = _("Allow interactive input"),
name = "IsChecked")
- interactive.SetValue(self.settings.Get(group='cmd', key='interactiveInput', subkey='enabled'))
+ interactive.SetValue(self.settings.Get(group = 'cmd', key = 'interactiveInput', subkey = 'enabled'))
self.winId['cmd:interactiveInput:enabled'] = interactive.GetId()
gridSizer.Add(item = interactive,
row += 1
# verbosity
- label=_("Verbosity level:")),
+ label = _("Verbosity level:")),
- pos=(row, 0))
- verbosity = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
- choices=self.settings.Get(group='cmd', key='verbosity', subkey='choices', internal=True),
- verbosity.SetStringSelection(self.settings.Get(group='cmd', key='verbosity', subkey='selection'))
+ pos = (row, 0))
+ verbosity = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
+ choices = self.settings.Get(group = 'cmd', key = 'verbosity', subkey = 'choices', internal = True),
+ verbosity.SetStringSelection(self.settings.Get(group = 'cmd', key = 'verbosity', subkey = 'selection'))
self.winId['cmd:verbosity:selection'] = verbosity.GetId()
- gridSizer.Add(item=verbosity,
- pos=(row, 1))
+ gridSizer.Add(item = verbosity,
+ pos = (row, 1))
# raster settings
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Raster settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Raster settings"))
@@ -1586,280 +1589,280 @@
gridSizer.Add(item=rasterOverlay,
# default color table
row += 1
- rasterCTCheck = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Default color table"),
- name='IsChecked')
- rasterCTCheck.SetValue(self.settings.Get(group='cmd', key='rasterColorTable', subkey='enabled'))
+ rasterCTCheck = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Default color table"),
+ rasterCTCheck.SetValue(self.settings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'enabled'))
self.winId['cmd:rasterColorTable:enabled'] = rasterCTCheck.GetId()
rasterCTCheck.Bind(wx.EVT_CHECKBOX, self.OnCheckColorTable)
- gridSizer.Add(item=rasterCTCheck,
- pos=(row, 0))
+ gridSizer.Add(item = rasterCTCheck,
+ pos = (row, 0))
- rasterCTName = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
- choices=utils.GetColorTables(),
- rasterCTName.SetStringSelection(self.settings.Get(group='cmd', key='rasterColorTable', subkey='selection'))
+ rasterCTName = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
+ choices = utils.GetColorTables(),
+ rasterCTName.SetStringSelection(self.settings.Get(group = 'cmd', key = 'rasterColorTable', subkey = 'selection'))
self.winId['cmd:rasterColorTable:selection'] = rasterCTName.GetId()
if not rasterCTCheck.IsChecked():
rasterCTName.Enable(False)
- gridSizer.Add(item=rasterCTName,
- pos=(row, 1))
+ gridSizer.Add(item = rasterCTName,
+ pos = (row, 1))
# vector settings
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Vector settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Vector settings"))
- gridSizer = wx.FlexGridSizer (cols=7, hgap=3, vgap=3)
+ gridSizer = wx.FlexGridSizer (cols = 7, hgap = 3, vgap = 3)
- label=_("Display:")),
- flag=wx.ALIGN_CENTER_VERTICAL)
+ label = _("Display:")),
+ flag = wx.ALIGN_CENTER_VERTICAL)
for type in ('point', 'line', 'centroid', 'boundary',
'area', 'face'):
- chkbox = wx.CheckBox(parent=panel, label=type)
- checked = self.settings.Get(group='cmd', key='showType',
- subkey=[type, 'enabled'])
+ chkbox = wx.CheckBox(parent = panel, label = type)
+ checked = self.settings.Get(group = 'cmd', key = 'showType',
+ subkey = [type, 'enabled'])
chkbox.SetValue(checked)
self.winId['cmd:showType:%s:enabled' % type] = chkbox.GetId()
- gridSizer.Add(item=chkbox)
+ gridSizer.Add(item = chkbox)
return panel
- def _CreateAttributeManagerPage(self, notebook):
+ def _createAttributeManagerPage(self, notebook):
"""!Create notebook page for 'Attribute Table Manager' settings"""
- notebook.AddPage(page=panel, text=_("Attributes"))
+ notebook.AddPage(page = panel, text = _("Attributes"))
pageSizer = wx.BoxSizer(wx.VERTICAL)
# highlighting
- highlightBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Highlighting"))
+ highlightBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Highlighting"))
highlightSizer = wx.StaticBoxSizer(highlightBox, wx.VERTICAL)
- flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer (cols = 2, hgap = 5, vgap = 5)
flexSizer.AddGrowableCol(0)
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Color:"))
- hlColor = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
- colour=self.settings.Get(group='atm', key='highlight', subkey='color'),
+ label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Color:"))
+ hlColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
+ colour = self.settings.Get(group = 'atm', key = 'highlight', subkey = 'color'),
hlColor.SetName('GetColour')
self.winId['atm:highlight:color'] = hlColor.GetId()
- flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(hlColor, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(label, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
+ flexSizer.Add(hlColor, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width (in pixels):"))
- hlWidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
- initial=self.settings.Get(group='atm', key='highlight',subkey='width'),
- min=1, max=1e6)
+ label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Line width (in pixels):"))
+ hlWidth = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (50, -1),
+ initial = self.settings.Get(group = 'atm', key = 'highlight',subkey = 'width'),
+ min = 1, max = 1e6)
self.winId['atm:highlight:width'] = hlWidth.GetId()
- flexSizer.Add(hlWidth, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(hlWidth, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- highlightSizer.Add(item=flexSizer,
- proportion=0,
- flag=wx.ALL | wx.EXPAND,
- border=5)
+ highlightSizer.Add(item = flexSizer,
+ proportion = 0,
+ flag = wx.ALL | wx.EXPAND,
+ border = 5)
- pageSizer.Add(item=highlightSizer,
- proportion=0,
- border=5)
+ pageSizer.Add(item = highlightSizer,
+ proportion = 0,
+ border = 5)
# data browser related settings
- dataBrowserBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Data browser"))
+ dataBrowserBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Data browser"))
dataBrowserSizer = wx.StaticBoxSizer(dataBrowserBox, wx.VERTICAL)
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Left mouse double click:"))
- leftDbClick = wx.Choice(parent=panel, id=wx.ID_ANY,
- choices=self.settings.Get(group='atm', key='leftDbClick', subkey='choices', internal=True),
- leftDbClick.SetSelection(self.settings.Get(group='atm', key='leftDbClick', subkey='selection'))
+ label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Left mouse double click:"))
+ leftDbClick = wx.Choice(parent = panel, id = wx.ID_ANY,
+ choices = self.settings.Get(group = 'atm', key = 'leftDbClick', subkey = 'choices', internal = True),
+ leftDbClick.SetSelection(self.settings.Get(group = 'atm', key = 'leftDbClick', subkey = 'selection'))
self.winId['atm:leftDbClick:selection'] = leftDbClick.GetId()
- flexSizer.Add(leftDbClick, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(leftDbClick, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
# encoding
- label=_("Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"))
- encoding = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- value=self.settings.Get(group='atm', key='encoding', subkey='value'),
- name="GetValue", size=(200, -1))
+ label = _("Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"))
+ encoding = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ value = self.settings.Get(group = 'atm', key = 'encoding', subkey = 'value'),
+ name = "GetValue", size = (200, -1))
self.winId['atm:encoding:value'] = encoding.GetId()
- flexSizer.Add(encoding, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(encoding, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
# ask on delete record
- askOnDeleteRec = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Ask when deleting data record(s) from table"),
- name='IsChecked')
- askOnDeleteRec.SetValue(self.settings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'))
+ askOnDeleteRec = wx.CheckBox(parent = panel, id = wx.ID_ANY,
+ label = _("Ask when deleting data record(s) from table"),
+ askOnDeleteRec.SetValue(self.settings.Get(group = 'atm', key = 'askOnDeleteRec', subkey = 'enabled'))
self.winId['atm:askOnDeleteRec:enabled'] = askOnDeleteRec.GetId()
- flexSizer.Add(askOnDeleteRec, proportion=0)
+ flexSizer.Add(askOnDeleteRec, proportion = 0)
- dataBrowserSizer.Add(item=flexSizer,
- proportion=0,
- border=5)
+ dataBrowserSizer.Add(item = flexSizer,
+ proportion = 0,
+ border = 5)
- pageSizer.Add(item=dataBrowserSizer,
- proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
- border=3)
+ pageSizer.Add(item = dataBrowserSizer,
+ proportion = 0,
+ flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+ border = 3)
# create table
- createTableBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Create table"))
+ createTableBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Create table"))
createTableSizer = wx.StaticBoxSizer(createTableBox, wx.VERTICAL)
- label=_("Key column:"))
- keyColumn = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- size=(250, -1))
- keyColumn.SetValue(self.settings.Get(group='atm', key='keycolumn', subkey='value'))
+ label = _("Key column:"))
+ keyColumn = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ size = (250, -1))
+ keyColumn.SetValue(self.settings.Get(group = 'atm', key = 'keycolumn', subkey = 'value'))
self.winId['atm:keycolumn:value'] = keyColumn.GetId()
- flexSizer.Add(keyColumn, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ flexSizer.Add(keyColumn, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
- createTableSizer.Add(item=flexSizer,
- proportion=0,
- border=5)
+ createTableSizer.Add(item = flexSizer,
+ proportion = 0,
+ border = 5)
- pageSizer.Add(item=createTableSizer,
- proportion=0,
- border=3)
+ pageSizer.Add(item = createTableSizer,
+ proportion = 0,
+ border = 3)
panel.SetSizer(pageSizer)
return panel
- def _CreateProjectionPage(self, notebook):
+ def _createProjectionPage(self, notebook):
"""!Create notebook page for workspace settings"""
- notebook.AddPage(page=panel, text=_("Projection"))
+ notebook.AddPage(page = panel, text = _("Projection"))
# projections statusbar settings
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Projection statusbar settings"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Projection statusbar settings"))
gridSizer.AddGrowableCol(1)
# epsg
row = 0
- label=_("EPSG code:"))
- epsgCode = wx.ComboBox(parent=panel, id=wx.ID_ANY,
- name="GetValue",
+ label = _("EPSG code:"))
+ epsgCode = wx.ComboBox(parent = panel, id = wx.ID_ANY,
size = (150, -1))
self.epsgCodeDict = dict()
- epsgCode.SetValue(str(self.settings.Get(group='projection', key='statusbar', subkey='epsg')))
+ epsgCode.SetValue(str(self.settings.Get(group = 'projection', key = 'statusbar', subkey = 'epsg')))
self.winId['projection:statusbar:epsg'] = epsgCode.GetId()
- gridSizer.Add(item=label,
- pos=(row, 0),
+ gridSizer.Add(item = label,
+ pos = (row, 0),
- gridSizer.Add(item=epsgCode,
- pos=(row, 1), span=(1, 2))
+ gridSizer.Add(item = epsgCode,
+ pos = (row, 1), span = (1, 2))
# proj
row += 1
- label=_("Proj.4 string (required):"))
- projString = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- value=self.settings.Get(group='projection', key='statusbar', subkey='proj4'),
- name="GetValue", size=(400, -1))
+ label = _("Proj.4 string (required):"))
+ projString = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ value = self.settings.Get(group = 'projection', key = 'statusbar', subkey = 'proj4'),
+ name = "GetValue", size = (400, -1))
self.winId['projection:statusbar:proj4'] = projString.GetId()
- pos=(row, 0),
+ pos = (row, 0),
+ gridSizer.Add(item = projString,
+ pos = (row, 1), span = (1, 2),
- gridSizer.Add(item=projString,
- pos=(row, 1), span=(1, 2),
- flag = wx.ALIGN_CENTER_VERTICAL)
# epsg file
row += 1
- label=_("EPSG file:"))
- projFile = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- value = self.settings.Get(group='projection', key='statusbar', subkey='projFile'),
+ label = _("EPSG file:"))
+ projFile = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ value = self.settings.Get(group = 'projection', key = 'statusbar', subkey = 'projFile'),
self.winId['projection:statusbar:projFile'] = projFile.GetId()
- pos=(row, 0),
- gridSizer.Add(item=projFile,
- pos=(row, 1),
+ pos = (row, 0),
+ gridSizer.Add(item = projFile,
+ pos = (row, 1),
# note + button
row += 1
note = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = _("Load EPSG codes (be patient), enter EPSG code or "
"insert Proj.4 string directly."))
- gridSizer.Add(item=note,
+ gridSizer.Add(item = note,
span = (1, 2),
- pos=(row, 0))
+ pos = (row, 0))
row += 1
- epsgLoad = wx.Button(parent=panel, id=wx.ID_ANY,
- label=_("&Load EPSG codes"))
- gridSizer.Add(item=epsgLoad,
+ epsgLoad = wx.Button(parent = panel, id = wx.ID_ANY,
+ label = _("&Load EPSG codes"))
+ gridSizer.Add(item = epsgLoad,
- pos=(row, 1))
+ pos = (row, 1))
# format
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Coordinates format"))
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Coordinates format"))
gridSizer.AddGrowableCol(2)
row = 0
@@ -1881,20 +1884,20 @@
precision.SetValue(int(self.settings.Get(group = 'projection', key = 'format', subkey = 'precision')))
self.winId['projection:format:precision'] = precision.GetId()
- gridSizer.Add(item=ll,
- pos=(row, 0))
- gridSizer.Add(item=wx.StaticText(parent = panel, id = wx.ID_ANY,
+ gridSizer.Add(item = ll,
+ pos = (row, 0))
label = _("Precision:")),
flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT | wx.LEFT,
border = 20,
- pos=(row, 1))
- gridSizer.Add(item=precision,
+ pos = (row, 1))
+ gridSizer.Add(item = precision,
- pos=(row, 2))
+ pos = (row, 2))
@@ -1905,50 +1908,6 @@
return panel
- def _CreateWorkspacePage(self, notebook):
- """!Create notebook page for workspace settings"""
- notebook.AddPage(page=panel, text=_("Workspace"))
- border = wx.BoxSizer(wx.VERTICAL)
- box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Loading workspace"))
- sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- gridSizer.AddGrowableCol(0)
- row = 0
- # positioning
- posDisplay = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Suppress positioning Map Display Window(s)"),
- name='IsChecked')
- posDisplay.SetValue(self.settings.Get(group='workspace', key='posDisplay', subkey='enabled'))
- self.winId['workspace:posDisplay:enabled'] = posDisplay.GetId()
- gridSizer.Add(item=posDisplay,
- row +=1
- posManager = wx.CheckBox(parent=panel, id=wx.ID_ANY,
- label=_("Suppress positioning Layer Manager window"),
- name='IsChecked')
- posManager.SetValue(self.settings.Get(group='workspace', key='posManager', subkey='enabled'))
- self.winId['workspace:posManager:enabled'] = posManager.GetId()
- gridSizer.Add(item=posManager,
- panel.SetSizer(border)
- return panel
def OnCheckColorTable(self, event):
"""!Set/unset default color table"""
win = self.FindWindowById(self.winId['cmd:rasterColorTable:selection'])
@@ -1965,9 +1924,9 @@
self.epsgCodeDict = utils.ReadEpsgCodes(path)
list = self.FindWindowById(self.winId['projection:statusbar:epsg'])
if type(self.epsgCodeDict) == type(''):
- message=_("Unable to read EPSG codes: %s") % self.epsgCodeDict,
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ message = _("Unable to read EPSG codes: %s") % self.epsgCodeDict,
+ caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
list.SetItems([])
list.SetValue('')
@@ -1994,18 +1953,18 @@
winCode = self.FindWindowById(event.GetId())
win = self.FindWindowById(self.winId['projection:statusbar:proj4'])
if not self.epsgCodeDict:
- message=_("EPSG code %s not found") % event.GetString(),
+ message = _("EPSG code %s not found") % event.GetString(),
winCode.SetValue('')
win.SetValue('')
try:
code = int(event.GetString())
except ValueError:
- message=_("EPSG code %s not found") % str(code),
+ message = _("EPSG code %s not found") % str(code),
win.SetValue('')
@@ -2013,63 +1972,63 @@
try:
win.SetValue(self.epsgCodeDict[code][1].replace('<>', '').strip())
except KeyError:
win.SetValue('')
def OnSetFont(self, event):
"""'Set font' button pressed"""
- dlg = DefaultFontDialog(parent=self, id=wx.ID_ANY,
- title=_('Select default display font'),
- style=wx.DEFAULT_DIALOG_STYLE,
- type='font')
+ dlg = DefaultFontDialog(parent = self,
+ title = _('Select default display font'),
+ style = wx.DEFAULT_DIALOG_STYLE,
+ type = 'font')
if dlg.ShowModal() == wx.ID_OK:
# set default font and encoding environmental variables
if dlg.font:
os.environ["GRASS_FONT"] = dlg.font
- self.settings.Set(group='display', value=dlg.font,
+ self.settings.Set(group = 'display', value = dlg.font,
if dlg.encoding and \
dlg.encoding != "ISO-8859-1":
os.environ["GRASS_ENCODING"] = dlg.encoding
- self.settings.Set(group='display', value=dlg.encoding,
+ self.settings.Set(group = 'display', value = dlg.encoding,
dlg.Destroy()
event.Skip()
def OnSetOutputFont(self, event):
- """'Set output font' button pressed"""
+ """'Set output font' button pressed
+ title = _('Select output font'),
+ type = 'outputfont')
- title=_('Select output font'),
- type='outputfont')
# set output font and font size variables
if dlg.font:
- self.settings.Set(group='appearance', value=dlg.font,
- key='outputfont', subkey='type')
- self.settings.Set(group='appearance', value=dlg.fontsize,
- key='outputfont', subkey='size')
+ self.settings.Set(group = 'appearance', value = dlg.font,
+ key = 'outputfont', subkey = 'type')
+ self.settings.Set(group = 'appearance', value = dlg.fontsize,
+ key = 'outputfont', subkey = 'size')
# Standard font dialog broken for Mac in OS X 10.6
-# type = self.settings.Get(group='display', key='outputfont', subkey='type')
+# type = self.settings.Get(group = 'display', key = 'outputfont', subkey = 'type')
-# size = self.settings.Get(group='display', key='outputfont', subkey='size')
+# size = self.settings.Get(group = 'display', key = 'outputfont', subkey = 'size')
# if size == None or size == 0: size = 10
# size = float(size)
# data = wx.FontData()
# data.EnableEffects(True)
-# data.SetInitialFont(wx.Font(pointSize=size, family=wx.FONTFAMILY_MODERN, faceName=type, style=wx.NORMAL, weight=0))
+# data.SetInitialFont(wx.Font(pointSize = size, family = wx.FONTFAMILY_MODERN, faceName = type, style = wx.NORMAL, weight = 0))
# dlg = wx.FontDialog(self, data)
@@ -2077,10 +2036,10 @@
# data = dlg.GetFontData()
# font = data.GetChosenFont()
-# self.settings.Set(group='display', value=font.GetFaceName(),
-# key='outputfont', subkey='type')
-# self.settings.Set(group='display', value=font.GetPointSize(),
-# key='outputfont', subkey='size')
+# self.settings.Set(group = 'display', value = font.GetFaceName(),
+# key = 'outputfont', subkey = 'type')
+# self.settings.Set(group = 'display', value = font.GetPointSize(),
+# key = 'outputfont', subkey = 'size')
dlg.Destroy()
@@ -2093,7 +2052,7 @@
# update default window dimension
- if self.settings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
+ if self.settings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled') is True:
dim = ''
# layer manager
pos = self.parent.GetPosition()
@@ -2106,9 +2065,9 @@
dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
- self.settings.Set(group='general', key='defWindowPos', subkey='dim', value=dim)
+ self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = dim)
else:
- self.settings.Set(group='general', key='defWindowPos', subkey='dim', value='')
+ self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = '')
return True
@@ -2117,85 +2076,84 @@
Opens a file selection dialog to select default font
to use in all GRASS displays
- def __init__(self, parent, id, title,
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE |
+ def __init__(self, parent, title, id = wx.ID_ANY,
+ style = wx.DEFAULT_DIALOG_STYLE |
wx.RESIZE_BORDER,
- settings=globalSettings,
- type='font'):
+ settings = globalSettings,
+ type = 'font'):
self.settings = settings
self.type = type
- wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+ wx.Dialog.__init__(self, parent, id, title, style = style)
- panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ panel = wx.Panel(parent = self, id = wx.ID_ANY)
self.fontlist = self.GetFonts()
- gridSizer = wx.GridBagSizer (hgap=5, vgap=5)
+ gridSizer = wx.GridBagSizer (hgap = 5, vgap = 5)
- label=_("Select font:"))
- flag=wx.ALIGN_TOP,
- pos=(0,0))
+ label = _("Select font:"))
+ flag = wx.ALIGN_TOP,
+ pos = (0,0))
- self.fontlb = wx.ListBox(parent=panel, id=wx.ID_ANY, pos=wx.DefaultPosition,
- choices=self.fontlist,
- style=wx.LB_SINGLE|wx.LB_SORT)
+ self.fontlb = wx.ListBox(parent = panel, id = wx.ID_ANY, pos = wx.DefaultPosition,
+ choices = self.fontlist,
+ style = wx.LB_SINGLE|wx.LB_SORT)
self.Bind(wx.EVT_LISTBOX, self.EvtListBox, self.fontlb)
self.Bind(wx.EVT_LISTBOX_DCLICK, self.EvtListBoxDClick, self.fontlb)
- gridSizer.Add(item=self.fontlb,
- flag=wx.EXPAND, pos=(1, 0))
+ gridSizer.Add(item = self.fontlb,
+ flag = wx.EXPAND, pos = (1, 0))
if self.type == 'font':
if "GRASS_FONT" in os.environ:
self.font = os.environ["GRASS_FONT"]
else:
- self.font = self.settings.Get(group='display',
- self.encoding = self.settings.Get(group='display',
+ self.font = self.settings.Get(group = 'display',
+ self.encoding = self.settings.Get(group = 'display',
- label=_("Character encoding:"))
- pos=(2, 0))
+ label = _("Character encoding:"))
+ pos = (2, 0))
- self.textentry = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- value=self.encoding)
- gridSizer.Add(item=self.textentry,
- flag=wx.EXPAND, pos=(3, 0))
+ self.textentry = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ value = self.encoding)
+ gridSizer.Add(item = self.textentry,
+ flag = wx.EXPAND, pos = (3, 0))
self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
elif self.type == 'outputfont':
- self.fontsize = self.settings.Get(group='display',
- label=_("Font size:"))
- pos=(2, 0))
+ self.font = self.settings.Get(group = 'appearance',
+ self.fontsize = self.settings.Get(group = 'appearance',
+ label = _("Font size:"))
+ pos = (2, 0))
- self.spin = wx.SpinCtrl(parent=panel, id=wx.ID_ANY)
+ self.spin = wx.SpinCtrl(parent = panel, id = wx.ID_ANY)
if self.fontsize:
self.spin.SetValue(self.fontsize)
self.spin.Bind(wx.EVT_SPINCTRL, self.OnSizeSpin)
self.spin.Bind(wx.EVT_TEXT, self.OnSizeSpin)
- gridSizer.Add(item=self.spin,
- pos=(3, 0))
+ gridSizer.Add(item = self.spin,
+ pos = (3, 0))
else:
return
@@ -2203,25 +2161,25 @@
if self.font:
self.fontlb.SetStringSelection(self.font, True)
- flag=wx.EXPAND | wx.ALL,
- border=5)
+ flag = wx.EXPAND | wx.ALL,
+ border = 5)
- border.Add(item=sizer, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=3)
+ border.Add(item = sizer, proportion = 1,
+ flag = wx.ALL | wx.EXPAND, border = 3)
btnsizer = wx.StdDialogButtonSizer()
- btn = wx.Button(parent=panel, id=wx.ID_OK)
+ btn = wx.Button(parent = panel, id = wx.ID_OK)
btn.SetDefault()
btnsizer.AddButton(btn)
- btn = wx.Button(parent=panel, id=wx.ID_CANCEL)
+ btn = wx.Button(parent = panel, id = wx.ID_CANCEL)
btnsizer.Realize()
- border.Add(item=btnsizer, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+ border.Add(item = btnsizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border = 5)
panel.SetAutoLayout(True)
@@ -2283,9 +2241,9 @@
decorations
def __init__(self, parent, id = wx.ID_ANY,
- title=_('Manage access to mapsets'),
- size = (350, 400),
- style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
+ title = _('Manage access to mapsets'),
+ size = (350, 400),
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
wx.Dialog.__init__(self, parent, id, title, size = size, style = style, **kwargs)
@@ -2296,21 +2254,21 @@
# make a checklistbox from available mapsets and check those that are active
sizer = wx.BoxSizer(wx.VERTICAL)
- label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_("Check a mapset to make it accessible, uncheck it to hide it.\n"
- " Notes:\n"
- " - The current mapset is always accessible.\n"
- " - You may only write to the current mapset.\n"
- " - You may only write to mapsets which you own."))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY,
+ label = _("Check a mapset to make it accessible, uncheck it to hide it.\n"
+ " Notes:\n"
+ " - The current mapset is always accessible.\n"
+ " - You may only write to the current mapset.\n"
+ " - You may only write to mapsets which you own."))
- sizer.Add(item=label, proportion=0,
+ sizer.Add(item = label, proportion = 0,
- self.mapsetlb = CheckListMapset(parent=self)
+ self.mapsetlb = CheckListMapset(parent = self)
self.mapsetlb.LoadData()
- sizer.Add(item=self.mapsetlb, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=5)
+ sizer.Add(item = self.mapsetlb, proportion = 1,
+ flag = wx.ALL | wx.EXPAND, border = 5)
# check all accessible mapsets
for mset in self.accessible_mapsets:
@@ -2320,10 +2278,10 @@
#self.mapsetlb.Enable(0, False)
# dialog buttons
- line = wx.StaticLine(parent=self, id=wx.ID_ANY,
- style=wx.LI_HORIZONTAL)
- sizer.Add(item=line, proportion=0,
- flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
+ line = wx.StaticLine(parent = self, id = wx.ID_ANY,
+ style = wx.LI_HORIZONTAL)
+ sizer.Add(item = line, proportion = 0,
+ flag = wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border = 5)
okbtn = wx.Button(self, wx.ID_OK)
@@ -2334,8 +2292,8 @@
btnsizer.AddButton(cancelbtn)
btnsizer.Realize()
- sizer.Add(item=btnsizer, proportion=0,
+ sizer.Add(item = btnsizer, proportion = 0,
# do layout
self.Layout()
@@ -2357,12 +2315,12 @@
class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
"""!List of mapset/owner/group"""
- def __init__(self, parent, pos=wx.DefaultPosition,
- log=None):
+ def __init__(self, parent, pos = wx.DefaultPosition,
+ log = None):
self.parent = parent
wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
- style=wx.LC_REPORT)
+ style = wx.LC_REPORT)
listmix.CheckListCtrlMixin.__init__(self)
self.log = log
@@ -2391,8 +2349,8 @@
self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
### self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
- self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
- ### self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
+ self.SetColumnWidth(col = 0, width = wx.LIST_AUTOSIZE)
+ ### self.SetColumnWidth(col = 1, width = wx.LIST_AUTOSIZE)
def OnCheckItem(self, index, flag):
"""!Mapset checked/unchecked"""
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2011-05-31 08:35:54 UTC (rev 46464)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2011-05-31 09:26:52 UTC (rev 46465)
@@ -33,7 +33,7 @@
iconPathDefault = grass2_icons.iconPath
iconSetDefault = grass2_icons.iconSet
-iconTheme = UserSettings.Get(group='appearance', key='iconTheme', subkey='type')
+iconTheme = UserSettings.Get(group = 'appearance', key = 'iconTheme', subkey = 'type')
if iconTheme == 'silk':
import silk_icons
iconPath = silk_icons.iconPath
