[GRASS-SVN] r46472 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue May 31 08:06:15 EDT 2011
Author: martinl
Date: 2011-05-31 05:06:15 -0700 (Tue, 31 May 2011)
New Revision: 46472
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
wxGUI/vdigit: minor fixes in vector digitizer
(merge r46471 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-05-31 12:04:02 UTC (rev 46471)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-05-31 12:06:15 UTC (rev 46472)
@@ -679,7 +679,7 @@
self.first = True
params = {} # no initial options parameters
# deselect active item
if self.layer_selected:
self.SelectItem(self.layer_selected, select = False)
@@ -732,19 +732,15 @@
text = '', ct_type = 1, wnd = ctrl)
else: # add first layer to the layer tree (first child of root)
layer = self.PrependItem(parent = self.root, text = '', ct_type = 1, wnd = ctrl)
# layer is initially unchecked as inactive (beside 'command')
# use predefined value if given
if lchecked is not None:
checked = lchecked
else:
checked = True
self.CheckItem(layer, checked = checked)
- # select new item
- self.SelectItem(layer, select = True)
- self.layer_selected = layer
# add text and icons for each layer ltype
label = _('(double click to set properties)') + ' ' * 35
@@ -795,9 +791,9 @@
elif ltype == 'group':
self.SetItemImage(layer, self.folder)
self.SetItemText(layer, grouptext)
self.first = False
if ltype != 'group':
if lcmd and len(lcmd) > 1:
cmd = lcmd
@@ -848,7 +844,7 @@
l_active = checked, l_hidden = False,
l_opacity = lopacity, l_render = render)
self.GetPyData(layer)[0]['maplayer'] = maplayer
# run properties dialog if no properties given
if len(cmd) == 0:
self.PropertiesDialog(layer, show = True)
@@ -861,7 +857,11 @@
'maplayer' : None,
'propwin' : None},
None))
+ # select new item
+ self.SelectItem(layer, select = True)
+ self.layer_selected = layer
# use predefined layer name if given
if lname:
@@ -1133,7 +1133,6 @@
bgmap = UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
internal = True)
- if digitToolbar:
if digitToolbar.GetLayer() == mapLayer:
self._setGradient('vdigit')
elif bgmap == mapLayer.GetName():
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2011-05-31 12:04:02 UTC (rev 46471)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2011-05-31 12:06:15 UTC (rev 46472)
@@ -1081,8 +1081,7 @@
self.parent.MapWindow.mouse['box'] = 'box'
def OnSelectMap (self, event):
- Select vector map layer for editing
+ """!Select vector map layer for editing
If there is a vector map layer already edited, this action is
firstly terminated. The map layer is closed. After this the
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-05-31 12:04:02 UTC (rev 46471)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-05-31 12:06:15 UTC (rev 46472)
@@ -403,8 +403,8 @@
'line' : line,
'offset' : offset })
- Debug.msg(3, "IVDigit._addActionToChangeset(): changeset=%d, type=%d, line=%d, offset=%d",
- changeset, type, line, offset)
+ Debug.msg(3, "IVDigit._addActionToChangeset(): changeset=%d, add=%d, line=%d, offset=%d",
+ changeset, add, line, offset)
def _removeActionFromChangeset(self, changeset, line, add):
"""!Remove action from changeset
