[GRASS-SVN] r49055 - grass/trunk/imagery/i.vi
svn_grass at osgeo.org
Wed Nov 2 16:51:27 EDT 2011
Author: ychemin
Date: 2011-11-02 13:51:27 -0700 (Wed, 02 Nov 2011)
New Revision: 49055
grass/trunk/imagery/i.vi/gari.c
grass/trunk/imagery/i.vi/main.c
grass/trunk/imagery/i.vi/msavi.c
grass/trunk/imagery/i.vi/msavi2.c
Added full configuration of MSAVI
Modified: grass/trunk/imagery/i.vi/gari.c
--- grass/trunk/imagery/i.vi/gari.c 2011-11-02 19:40:24 UTC (rev 49054)
+++ grass/trunk/imagery/i.vi/gari.c 2011-11-02 20:51:27 UTC (rev 49055)
@@ -2,19 +2,14 @@
#include<math.h>
#include<stdlib.h>
- /*GARI: green atmospherically resistant vegetation index */
-double ga_ri(double redchan, double nirchan, double bluechan,
- double greenchan)
+/*GARI: green atmospherically resistant vegetation index */
+double ga_ri(double redchan,double nirchan,double bluechan,double greenchan)
double result;
- result =
- (nirchan - (greenchan - (bluechan - redchan))) / (nirchan -
- (greenchan -
- (bluechan -
- redchan)));
- } return result;
+ result = (nirchan - (greenchan - (bluechan - redchan)))/(nirchan - (greenchan - (bluechan - redchan)));
+ return result;
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2011-11-02 19:40:24 UTC (rev 49054)
+++ grass/trunk/imagery/i.vi/main.c 2011-11-02 20:51:27 UTC (rev 49055)
@@ -40,7 +40,7 @@
double p_vi(double redchan, double nirchan);
double wd_vi(double redchan, double nirchan);
double sa_vi(double redchan, double nirchan);
-double msa_vi(double redchan, double nirchan);
+double msa_vi(double redchan, double nirchan, double soil_line_slope, double soil_line_intercept, double soil_noise_reduction_factor);
double msa_vi2(double redchan, double nirchan);
double ge_mi(double redchan, double nirchan);
double ar_vi(double redchan, double nirchan, double bluechan);
@@ -57,7 +57,7 @@
char *viflag; /*Switch for particular index */
struct GModule *module;
struct Option *input1, *input2, *input3, *input4, *input5, *input6,
- *input7, *output;
+ *input7, *input8, *input9, *input10, *output;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
@@ -73,6 +73,7 @@
RASTER_MAP_TYPE data_type_nirchan, data_type_greenchan;
RASTER_MAP_TYPE data_type_bluechan;
RASTER_MAP_TYPE data_type_chan5chan, data_type_chan7chan;
+ DCELL msavip1, msavip2, msavip3;
CELL val1, val2;
G_gisinit(argv[0]);
@@ -149,6 +150,27 @@
_("Name of the chan7 channel surface reflectance map");
input7->description = _("Range: [0.0;1.0]");
+ input8 = G_define_option();
+ input8->key = "soil_line_slope";
+ input8->type = TYPE_DOUBLE;
+ input8->required = NO;
+ input8->gisprompt = "value";
+ input8->description = _("MSAVI2: Value of the slope of the soil line");
+ input9 = G_define_option();
+ input9->key = "soil_line_intercept";
+ input9->type = TYPE_DOUBLE;
+ input9->required = NO;
+ input9->gisprompt = "value";
+ input9->description = _("MSAVI2: Value of the intercept of the soil line");
+ input10 = G_define_option();
+ input10->key = "soil_noise_reduction_factor";
+ input10->type = TYPE_DOUBLE;
+ input10->required = NO;
+ input10->gisprompt = "value";
+ input10->description = _("MSAVI2: Value of the factor of reduction of soil noise");
output = G_define_standard_option(G_OPT_R_OUTPUT);
if (G_parser(argc, argv))
@@ -161,6 +183,9 @@
bluechan = input5->answer;
chan5chan = input6->answer;
chan7chan = input7->answer;
+ msavip1 = atof(input8->answer);
+ msavip2 = atof(input9->answer);
+ msavip3 = atof(input10->answer);
result = output->answer;
if (!strcasecmp(viflag, "sr") && (!(input2->answer) || !(input3->answer)) )
@@ -187,8 +212,8 @@
if (!strcasecmp(viflag, "msavi") && (!(input2->answer) || !(input3->answer)) )
G_fatal_error(_("msavi index requires red and nir maps"));
- if (!strcasecmp(viflag, "msavi2") && (!(input2->answer) || !(input3->answer)) )
- G_fatal_error(_("msavi2 index requires red and nir maps"));
+ if (!strcasecmp(viflag, "msavi2") && (!(input2->answer) || !(input3->answer)||!(input8->answer) ||!(input9->answer)||!(input10->answer)) )
+ G_fatal_error(_("msavi2 index requires red and nir maps, and 3 parameters related to soil line"));
if (!strcasecmp(viflag, "gemi") && (!(input2->answer) || !(input3->answer)) )
G_fatal_error(_("gemi index requires red and nir maps"));
@@ -404,7 +429,7 @@
outrast[col] = sa_vi(d_redchan, d_nirchan);
if (!strcasecmp(viflag, "msavi"))
- outrast[col] = msa_vi(d_redchan, d_nirchan);
+ outrast[col] = msa_vi(d_redchan, d_nirchan, msavip1, msavip2, msavip3);
if (!strcasecmp(viflag, "msavi2"))
outrast[col] = msa_vi2(d_redchan, d_nirchan);
@@ -416,8 +441,7 @@
outrast[col] = ar_vi(d_redchan, d_nirchan, d_bluechan);
if (!strcasecmp(viflag, "gvi"))
- outrast[col] = g_vi(d_bluechan, d_greenchan, d_redchan, d_nirchan,
- d_chan5chan, d_chan7chan);
+ outrast[col] = g_vi(d_bluechan, d_greenchan, d_redchan, d_nirchan, d_chan5chan, d_chan7chan);
if (!strcasecmp(viflag, "gari"))
outrast[col] = ga_ri(d_redchan, d_nirchan, d_bluechan, d_greenchan);
Modified: grass/trunk/imagery/i.vi/msavi.c
--- grass/trunk/imagery/i.vi/msavi.c 2011-11-02 19:40:24 UTC (rev 49054)
+++ grass/trunk/imagery/i.vi/msavi.c 2011-11-02 20:51:27 UTC (rev 49055)
@@ -12,18 +12,18 @@
* which is set to minimize soil noise (0.08 in
* original papers).
+double msa_vi(double redchan, double nirchan, double soil_line_slope, double soil_line_intercept, double soil_noise_reduction_factor )
- double result;
+ double result, a, s, X;
+ s = soil_line_slope;
+ a = soil_line_intercept;
+ X = soil_noise_reduction_factor;
if ((nirchan + redchan) == 0.0) {
result = -1.0;
else {
- result =
- (1 / 2) * (2 * (nirchan + 1) -
- sqrt((2 * nirchan + 1) * (2 * nirchan + 1)) -
- (8 * (nirchan - redchan)));
+ result = s*(nirchan-s*redchan-a)/(a*nirchan+redchan-a*s+X*(1+s+s));
return result;
Modified: grass/trunk/imagery/i.vi/msavi2.c
--- grass/trunk/imagery/i.vi/msavi2.c 2011-11-02 19:40:24 UTC (rev 49054)
+++ grass/trunk/imagery/i.vi/msavi2.c 2011-11-02 20:51:27 UTC (rev 49055)
@@ -9,14 +9,13 @@
double result;
- if ((nirchan + redchan) == 0.0) {
+ if ((nirchan + redchan) == 0.0 || (2*nirchan+1)*(2*nirchan+1) <= 0.0)
result = -1.0;
- else {
- result =
+ else
+ result=0.5*(2*(nirchan+1)-sqrt((2*nirchan+1)*(2*nirchan+1)-8*(nirchan-redchan)));
return result;
