[GRASS-SVN] r49064 - in grass/branches/develbranch_6:
gui/wxpython/gui_modules lib/python
svn_grass at osgeo.org
Thu Nov 3 04:00:30 EDT 2011
Author: martinl
Date: 2011-11-03 01:00:30 -0700 (Thu, 03 Nov 2011)
New Revision: 49064
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/lib/python/task.py
attempt to fix #1485 (Cannot save workspace from wxGUI)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2011-11-03 05:55:21 UTC (rev 49063)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2011-11-03 08:00:30 UTC (rev 49064)
@@ -1917,7 +1917,13 @@
# parse the interface decription
if not self.grass_task:
- tree = etree.fromstring(gtask.get_interface_description(cmd))
+ enc = locale.getdefaultlocale()[1]
+ if enc and enc.lower() != "cp932":
+ p = re.compile('encoding="' + enc + "'", re.IGNORECASE)
+ tree = etree.fromstring(p.sub('encoding="utf-8"',
+ gtask.get_interface_description(cmd).decode(enc).encode('utf-8')))
+ else:
+ tree = etree.fromstring(gtask.get_interface_description(cmd))
self.grass_task = gtask.processTask(tree).get_task()
for p in self.grass_task.params:
Modified: grass/branches/develbranch_6/lib/python/task.py
--- grass/branches/develbranch_6/lib/python/task.py 2011-11-03 05:55:21 UTC (rev 49063)
+++ grass/branches/develbranch_6/lib/python/task.py 2011-11-03 08:00:30 UTC (rev 49064)
@@ -444,17 +444,17 @@
return cmdout.replace('grass-interface.dtd', os.path.join(os.getenv('GISBASE'), 'etc', 'grass-interface.dtd'))
def parse_interface(name, parser = processTask, blackList = None):
- """!Parse interface of given GRASS module
- @param name name of GRASS module to be parsed
- # enc = locale.getdefaultlocale()[1]
- # if enc and enc.lower() not in ("utf8", "utf-8"):
- # tree = etree.fromstring(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"))
- # else:
+ """!Parse interface of given GRASS module
+ @param name name of GRASS module to be parsed
+ if enc and enc.lower() == "cp932":
+ tree = etree.fromstring(get_interface_description(name).decode(enc).encode("utf-8"))
+ else:
tree = etree.fromstring(get_interface_description(name))
- return parser(tree, blackList = blackList).get_task()
+ return parser(tree, blackList = blackList).get_task()
def command_info(cmd):
"""!Returns meta information for any GRASS command as dictionary
