[GRASS-SVN] r49070 - in grass/trunk: include lib/gis
svn_grass at osgeo.org
Thu Nov 3 08:04:22 EDT 2011
Author: martinl
Date: 2011-11-03 05:04:22 -0700 (Thu, 03 Nov 2011)
New Revision: 49070
grass/trunk/include/gisdefs.h
grass/trunk/lib/gis/percent.c
libgis: add G_progress()
update doxygen strings for percent.c
Modified: grass/trunk/include/gisdefs.h
--- grass/trunk/include/gisdefs.h 2011-11-03 11:15:03 UTC (rev 49069)
+++ grass/trunk/include/gisdefs.h 2011-11-03 12:04:22 UTC (rev 49070)
@@ -489,6 +489,7 @@
/* percent.c */
void G_percent(long, long, int);
void G_percent_reset(void);
+void G_progress(long, int);
void G_set_percent_routine(int (*) (int));
void G_unset_percent_routine(void);
Modified: grass/trunk/lib/gis/percent.c
--- grass/trunk/lib/gis/percent.c 2011-11-03 11:15:03 UTC (rev 49069)
+++ grass/trunk/lib/gis/percent.c 2011-11-03 12:04:22 UTC (rev 49070)
@@ -1,16 +1,16 @@
- * \file gis/percent.c
- * \brief GIS Library - percentage progress functions.
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author GRASS GIS Development Team
+ \file lib/gis/percent.c
+ \brief GIS Library - percentage progress functions.
+ (C) 2001-2009, 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author GRASS GIS Development Team
#include <stdio.h>
#include <grass/gis.h>
@@ -23,14 +23,14 @@
static struct state *st = &state;
static int (*ext_percent) (int);
- * \brief Print percent complete messages.
- * This routine prints a percentage complete message to stderr. The
- * percentage complete is <i>(<b>n</b>/<b>d</b>)*100</i>, and these are
- * printed only for each <b>s</b> percentage. This is perhaps best
- * explained by example:
-\code
+ \brief Print percent complete messages.
+ This routine prints a percentage complete message to stderr. The
+ percentage complete is <i>(<b>n</b>/<b>d</b>)*100</i>, and these are
+ printed only for each <b>s</b> percentage. This is perhaps best
+ explained by example:
+ \code
#include <stdio.h>
int row;
@@ -44,24 +44,21 @@
do_calculation(row);
G_percent(1, 1, 1);
-\endcode
- * This example code will print completion messages at 10% increments;
- * i.e., 0%, 10%, 20%, 30%, etc., up to 100%. Each message does not appear
- * on a new line, but rather erases the previous message.
- * Note that to prevent the illusion of the module stalling, the G_percent()
- * call is placed before the time consuming part of the for loop, and an
- * additional call is generally needed after the loop to "finish it off"
- * at 100%.
- * \param n current element
- * \param d total number of elements
- * \param s increment size
- * \return always returns 0
+ \endcode
+ This example code will print completion messages at 10% increments;
+ i.e., 0%, 10%, 20%, 30%, etc., up to 100%. Each message does not appear
+ on a new line, but rather erases the previous message.
+ Note that to prevent the illusion of the module stalling, the G_percent()
+ call is placed before the time consuming part of the for loop, and an
+ additional call is generally needed after the loop to "finish it off"
+ at 100%.
+ \param n current element
+ \param d total number of elements
+ \param s increment size
void G_percent(long n, long d, int s)
int x, format;
@@ -116,36 +113,93 @@
- * \brief Reset G_percent() to 0%; do not add newline.
+ \brief Reset G_percent() to 0%; do not add newline.
st->prev = -1;
st->first = 1;
- * \brief Establishes percent_routine as the routine that will handle
- * the printing of percentage progress messages.
- * \param percent_routine routine will be called like this: percent_routine(x)
+ \brief Print progress info messages
+ Use G_percent() when number of elements is defined.
+ This routine prints a progress info message to stderr. The value
+ <b>n</b> is printed only for each <b>s</b>. This is perhaps best
+ \code
+ #include <grass/vector.h>
+ int line;
+ G_message(_("Reading features..."));
+ line = 0;
+ while(TRUE)
+ if (Vect_read_next_line(Map, Points, Cats) < 0)
+ break;
+ line++;
+ G_progress(line, 1e3);
+ G_progress(1, 1);
+ \endcode
+ This example code will print progress in messages at 1000
+ increments; i.e., 1000, 2000, 3000, 4000, etc., up to number of
+ features for given vector map. Each message does not appear on a new
+ line, but rather erases the previous message.
+ \return always returns 0
+void G_progress(long n, int s)
+ int format;
+ format = G_info_format();
+ /* be verbose only 1> */
+ if (format == G_INFO_FORMAT_SILENT || G_verbose() < 1)
+ return;
+ if (n == s && n == 1) {
+ if (format != G_INFO_FORMAT_PLAIN)
+ fprintf(stderr, "\r");
+ else
+ fprintf(stderr, "\n");
+ return;
+ if (n % s == 0) {
+ if (format == G_INFO_FORMAT_PLAIN)
+ fprintf(stderr, "%ld..", n);
+ else
+ fprintf(stderr, "%10ld\b\b\b\b\b\b\b\b\b\b", n);
+ \brief Establishes percent_routine as the routine that will handle
+ the printing of percentage progress messages.
+ \param percent_routine routine will be called like this: percent_routine(x)
void G_set_percent_routine(int (*percent_routine) (int))
ext_percent = percent_routine;
- * \brief After this call subsequent percentage progress messages will
- * be handled in the default method.
- * Percentage progress messages are printed directly to stderr.
+ \brief After this call subsequent percentage progress messages will
+ be handled in the default method.
+ Percentage progress messages are printed directly to stderr.
ext_percent = NULL;
