[GRASS-SVN] r49080 - grass/trunk/imagery/i.pca
svn_grass at osgeo.org
Thu Nov 3 14:02:42 EDT 2011
Author: mmetz
Date: 2011-11-03 11:02:42 -0700 (Thu, 03 Nov 2011)
New Revision: 49080
grass/trunk/imagery/i.pca/main.c
NULL/MASK fix, code cleanup
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2011-11-03 16:05:29 UTC (rev 49079)
+++ grass/trunk/imagery/i.pca/main.c 2011-11-03 18:02:42 UTC (rev 49080)
@@ -34,7 +34,7 @@
/* function prototypes */
static CELL round_c(double);
static int set_output_scale(struct Option *, int *, int *, int *);
-static int calc_mu(int *, double *, int);
+static off_t calc_mu(int *, double *, int);
static int calc_covariance(int *, double **, double *, int);
static int write_pca(double **, int *, char *, int, int, int, int);
@@ -53,6 +53,7 @@
double **eigmat;
int *inp_fd;
int scale, scale_max, scale_min;
+ off_t cells;
struct GModule *module;
struct Option *opt_in, *opt_out, *opt_scale;
@@ -128,7 +129,7 @@
G_verbose_message(_("Calculating covariance matrix..."));
- calc_mu(inp_fd, mu, bands);
+ cells = calc_mu(inp_fd, mu, bands);
calc_covariance(inp_fd, covar, mu, bands);
@@ -136,7 +137,7 @@
for (j = 0; j < bands; j++) {
covar[i][j] =
covar[i][j] /
- ((double)((Rast_window_rows() * Rast_window_cols()) - 1));
+ (cells - 1);
G_debug(3, "covar[%d][%d] = %f", i, j, covar[i][j]);
@@ -230,17 +231,20 @@
-static int calc_mu(int *fds, double *mu, int bands)
+static off_t calc_mu(int *fds, double *mu, int bands)
int i;
int rows = Rast_window_rows();
int cols = Rast_window_cols();
+ off_t cells;
void *rowbuf = NULL;
for (i = 0; i < bands; i++) {
RASTER_MAP_TYPE maptype;
int row, col;
double sum = 0.;
+ cells = 0;
maptype = Rast_get_map_type(fds[i]);
@@ -266,17 +270,18 @@
sum += Rast_get_d_value(ptr, maptype);
+ cells++;
ptr = G_incr_void_ptr(ptr, Rast_cell_size(maptype));
- mu[i] = sum / (double)(rows * cols);
+ mu[i] = sum / cells;
if (rowbuf)
G_free(rowbuf);
- return 0;
+ return cells;
@@ -360,19 +365,19 @@
double new_range = 0.;
- int cell_mapsiz = Rast_cell_size(CELL_TYPE);
- int dcell_mapsiz = Rast_cell_size(DCELL_TYPE);
+ /* why CELL_TYPE when scaling output ? */
+ int outmap_type = (scale) ? CELL_TYPE : DCELL_TYPE;
+ int outcell_mapsiz = Rast_cell_size(outmap_type);
DCELL *d_buf;
/* 2 passes for rescale. 1 pass for no rescale */
int PASSES = (scale) ? 2 : 1;
/* temporary row storage */
- d_buf = (DCELL *) G_malloc(cols * sizeof(double));
+ d_buf = Rast_allocate_d_buf();
/* allocate memory for output row buffer */
- outbuf = (scale) ? Rast_allocate_buf(CELL_TYPE) :
- Rast_allocate_buf(DCELL_TYPE);
+ outbuf = Rast_allocate_buf(outmap_type);
if (!outbuf)
G_fatal_error(_("Unable to allocate memory for raster row"));
@@ -387,12 +392,7 @@
G_message(_("Transforming <%s>..."), name);
/* open a new file for output */
- if (scale)
- out_fd = Rast_open_c_new(name);
- else {
- out_fd = Rast_open_fp_new(name);
- Rast_set_fp_type(DCELL_TYPE);
+ out_fd = Rast_open_new(name, outmap_type);
for (pass = 1; pass <= PASSES; pass++) {
@@ -435,15 +435,9 @@
for (col = 0; col < cols; col++) {
/* handle null cells */
if (Rast_is_null_value(rowptr, maptype)) {
- if (scale) {
- Rast_set_null_value(outptr, 1, CELL_TYPE);
- outptr = G_incr_void_ptr(outptr, cell_mapsiz);
- else {
- Rast_set_null_value(outptr, 1, DCELL_TYPE);
- outptr =
- G_incr_void_ptr(outptr, dcell_mapsiz);
+ Rast_set_null_value(outptr, 1, outmap_type);
+ outptr =
+ G_incr_void_ptr(outptr, outcell_mapsiz);
rowptr =
G_incr_void_ptr(rowptr,
@@ -483,19 +477,18 @@
scale_min);
Rast_set_c_value(outptr, tmpcell,
- CELL_TYPE);
+ outmap_type);
else { /* (!scale) */
Rast_set_d_value(outptr, d_buf[col],
- DCELL_TYPE);
+ outmap_type);
- outptr = (scale) ?
- G_incr_void_ptr(outptr, cell_mapsiz) :
+ outptr =
rowptr =
G_incr_void_ptr(rowptr, Rast_cell_size(maptype));
@@ -503,14 +496,11 @@
} /* for j = 0 to bands */
if (pass == PASSES) {
- if (scale)
- Rast_put_row(out_fd, outbuf, CELL_TYPE);
- else
- Rast_put_row(out_fd, outbuf, DCELL_TYPE);
+ Rast_put_row(out_fd, outbuf, outmap_type);
- G_percent(row, rows, 2);
+ G_percent(1, 1, 1);
/* close output file */
if (pass == PASSES)
