[GRASS-SVN] r49092 - grass/trunk/imagery/i.pca
svn_grass at osgeo.org
Fri Nov 4 09:41:20 EDT 2011
Author: mmetz
Date: 2011-11-04 06:41:20 -0700 (Fri, 04 Nov 2011)
New Revision: 49092
grass/trunk/imagery/i.pca/i.pca.html
grass/trunk/imagery/i.pca/main.c
fix NULL handling
Modified: grass/trunk/imagery/i.pca/i.pca.html
--- grass/trunk/imagery/i.pca/i.pca.html 2011-11-04 11:51:01 UTC (rev 49091)
+++ grass/trunk/imagery/i.pca/i.pca.html 2011-11-04 13:41:20 UTC (rev 49092)
@@ -44,10 +44,6 @@
<h2>NOTES</h2>
-If some of the input raster maps have NULL values but others do not have
-NULL values, a MASK should be created such that any NULL values are
-MASK'ed out.
-<p>
Richards (1986) gives a good example of the application of principal
components analysis (pca) to a time series of LANDSAT images of a burned
region in Australia.
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2011-11-04 11:51:01 UTC (rev 49091)
+++ grass/trunk/imagery/i.pca/main.c 2011-11-04 13:41:20 UTC (rev 49092)
@@ -34,7 +34,7 @@
/* function prototypes */
static CELL round_c(double);
static int set_output_scale(struct Option *, int *, int *, int *);
-static off_t calc_mu(int *, double *, double *, int);
+static int calc_mu(int *, double *, double *, int);
static int calc_covariance(int *, double **, double *, double *, int);
static int write_pca(double **, double *, double *, int *, char *, int,
int, int, int);
@@ -46,7 +46,7 @@
int main(int argc, char *argv[])
- int i, j; /* Loop control variables */
+ int i; /* Loop control variables */
int bands; /* Number of image bands */
double *mu; /* Mean vector for image bands */
double *stddev; /* Stddev vector for image bands */
@@ -55,7 +55,6 @@
double **eigmat;
int *inp_fd;
int scale, scale_max, scale_min;
- off_t cells;
struct GModule *module;
struct Option *opt_in, *opt_out, *opt_scale;
@@ -141,19 +140,11 @@
G_verbose_message(_("Calculating covariance matrix..."));
- cells = calc_mu(inp_fd, mu, stddev, bands);
+ if (!calc_mu(inp_fd, mu, stddev, bands))
+ G_fatal_error(_("No non-null values"));
calc_covariance(inp_fd, covar, mu, stddev, bands);
- for (i = 0; i < bands; i++) {
- for (j = 0; j < bands; j++) {
- covar[i][j] =
- covar[i][j] /
- (cells - 1);
- G_debug(3, "covar[%d][%d] = %f", i, j, covar[i][j]);
G_math_d_copy(covar[0], eigmat[0], bands*bands);
G_debug(1, "Calculating eigenvalues and eigenvectors...");
G_math_eigen(eigmat, eigval, bands);
@@ -243,142 +234,133 @@
-static off_t calc_mu(int *fds, double *mu, double *stddev, int bands)
+static int calc_mu(int *fds, double *mu, double *stddev, int bands)
int i;
+ int row, col;
int rows = Rast_window_rows();
int cols = Rast_window_cols();
- off_t cells;
- void *rowbuf = NULL;
+ off_t count = 0;
+ double *sumsq;
+ DCELL **rowbuf = (DCELL **) G_malloc(bands * sizeof(DCELL *));
- RASTER_MAP_TYPE maptype;
- int row, col;
- double sum = 0.;
- double sumsq = 0;
- cells = 0;
+ rowbuf[i] = Rast_allocate_d_buf();
- maptype = Rast_get_map_type(fds[i]);
+ if (stddev) {
+ G_message(_("Computing means and standard deviations..."));
+ sumsq = (double *)G_calloc(bands, sizeof(double));
+ else {
+ G_message(_("Computing means..."));
+ sumsq = NULL;
- /* don't assume each image is of the same type */
- if (rowbuf)
- G_free(rowbuf);
- if ((rowbuf = Rast_allocate_buf(maptype)) == NULL)
- G_fatal_error(_("Unable allocate memory for row buffer"));
+ for (row = 0; row < rows; row++) {
+ G_percent(row, rows, 2);
+ for (i = 0; i < bands; i++)
+ Rast_get_d_row(fds[i], rowbuf[i], row);
- G_message(_("Computing means for band %d..."), i + 1);
- for (row = 0; row < rows; row++) {
- void *ptr = rowbuf;
- DCELL dval;
- G_percent(row, rows - 1, 2);
- Rast_get_row(fds[i], rowbuf, row, maptype);
- for (col = 0; col < cols; col++) {
- /* skip null cells */
- if (Rast_is_null_value(ptr, maptype)) {
- ptr = G_incr_void_ptr(ptr, Rast_cell_size(maptype));
- continue;
- dval = Rast_get_d_value(ptr, maptype);
- sum += dval;
+ for (col = 0; col < cols; col++) {
+ /* ignore cells where any of the maps has null value */
+ if (Rast_is_d_null_value(&rowbuf[i][col]))
+ break;
+ if (i != bands)
+ continue;
+ count++;
+ for (i = 0; i < bands; i++) {
+ mu[i] += rowbuf[i][col];
if (stddev)
- sumsq += dval * dval;
- cells++;
+ sumsq[i] += rowbuf[i][col] * rowbuf[i][col];
+ G_percent(1, 1, 1);
+ if (count < 2)
+ return 0;
- mu[i] = sum / cells;
+ mu[i] = mu[i] / count;
if (stddev)
- stddev[i] = sqrt((cells / (cells - 1)) *
- (sumsq / cells - mu[i] * mu[i]));
+ stddev[i] = sqrt((count / (count - 1)) *
+ (sumsq[i] / count - mu[i] * mu[i]));
+ G_free(rowbuf[i]);
if (rowbuf)
G_free(rowbuf);
+ if (sumsq)
+ G_free(sumsq);
- return cells;
+ return 1;
static int calc_covariance(int *fds, double **covar, double *mu,
- int j, k;
+ int i, j;
+ int row, col;
- int row, col;
+ off_t count = 0;
- RASTER_MAP_TYPE maptype = Rast_get_map_type(fds[j]);
- void *rowbuf1 = NULL;
- void *rowbuf2 = NULL;
- if (rowbuf1)
- G_free(rowbuf1);
- if ((rowbuf1 = Rast_allocate_buf(maptype)) == NULL)
+ G_message(_("Computing covariance matrix..."));
- G_message(_("Computing row %d (of %d) of covariance matrix..."),
- j + 1, bands);
- void *ptr1, *ptr2;
+ break;
+ if (i != bands)
+ continue;
+ count++;
+ DCELL dval1 = rowbuf[i][col];
- Rast_get_row(fds[j], rowbuf1, row, maptype);
+ for (j = i; j < bands; j++) {
+ DCELL dval2 = rowbuf[j][col];
- for (k = j; k < bands; k++) {
- RASTER_MAP_TYPE maptype2 = Rast_get_map_type(fds[k]);
- if (rowbuf2)
- G_free(rowbuf2);
- if ((rowbuf2 = Rast_allocate_buf(maptype2)) == NULL)
- G_fatal_error(_("Unable to allocate memory for row buffer"));
- Rast_get_row(fds[k], rowbuf2, row, maptype2);
- ptr1 = rowbuf1;
- ptr2 = rowbuf2;
- DCELL dval1, dval2;
- if (Rast_is_null_value(ptr1, maptype) ||
- Rast_is_null_value(ptr2, maptype2)) {
- ptr1 = G_incr_void_ptr(ptr1, Rast_cell_size(maptype));
- ptr2 = G_incr_void_ptr(ptr2, Rast_cell_size(maptype2));
- continue;
- dval1 = Rast_get_d_value(ptr1, maptype);
- dval2 = Rast_get_d_value(ptr2, maptype2);
if (stddev) {
- covar[j][k] += (dval1 - mu[j]) * (dval2 - mu[k]) /
- (stddev[j] * stddev[k]);
+ covar[i][j] += (dval1 - mu[i]) * (dval2 - mu[j]) /
+ (stddev[i] * stddev[j]);
else {
- covar[j][k] += (dval1 - mu[j]) * (dval2 - mu[k]);
+ covar[i][j] += (dval1 - mu[i]) * (dval2 - mu[j]);
- covar[k][j] = covar[j][k];
+ covar[i][j] = covar[i][j] / (count - 1);
+ G_debug(3, "covar[%d][%d] = %f", i, j, covar[i][j]);
+ if (j != i)
+ covar[j][i] = covar[i][j];
+ G_free(rowbuf);
return 0;
