[GRASS-SVN] r49094 - grass/branches/releasebranch_6_4/lib/python
svn_grass at osgeo.org
Fri Nov 4 15:47:51 EDT 2011
Author: neteler
Date: 2011-11-04 12:47:51 -0700 (Fri, 04 Nov 2011)
New Revision: 49094
Removed:
grass/branches/releasebranch_6_4/lib/python/grasspythonlib.dox
remove outdated file
Deleted: grass/branches/releasebranch_6_4/lib/python/grasspythonlib.dox
--- grass/branches/releasebranch_6_4/lib/python/grasspythonlib.dox 2011-11-04 15:01:02 UTC (rev 49093)
+++ grass/branches/releasebranch_6_4/lib/python/grasspythonlib.dox 2011-11-04 19:47:51 UTC (rev 49094)
@@ -1,244 +0,0 @@
-/*! \page pythonlib GRASS Python Scripting Library
-by GRASS Development Team (http://grass.osgeo.org)
-\section pythonIntro Introduction
-The code in <tt>lib/python/</tt> provides <b>grass.script</b> in order
-to support GRASS scripts written in Python. The <tt>scripts/</tt>
-directory of GRASS contains a series of examples actually provided to
-the end users.
-See code in:
- - core.py
- - db.py
- - raster.py
- - vector.py
-<h2>Table of content</h2>
-- \subpage pythonScripting
-- \subpage pythonModules
- - \subpage pythonCore
- - \subpage pythonDb
- - \subpage pythonRaster
- - \subpage pythonVector
-\section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
-Usage:
-\code
-import grass.script as grass
-\endcode
-or just import selected module, e.g.
-\code
-from grass.script import core as grass
-\endcode
-Sample script
-\code
-#!/usr/bin/env python
-#%module
-#% description: Checks if vector map is 3D
-#% keywords: vector
-#%end
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc: name
-#% description: Name of vector map
-#% required: yes
-#%end
-import sys
-def main():
- info = grass.parse_command('v.info',
- flags = 't',
- map = options['map'])
- if info['map3d'] == '1':
- print 'Vector map is 3D'
- else:
- print 'Vector map is 2D'
- return 0
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
-\endcode
-\section pythonModules List of modules
-\subsection pythonCore Core
-<b>GRASS-oriented interface to subprocess module</b>
- - exec_command()
- - feed_command()
- - make_command()
- - parse_command()
- - pipe_command()
- - read_command()
- - run_command()
- - start_command()
- - write_command()
-<b>Interface to g.message</b>
-These all run g.message, differing only in which flag (if any) is
-used. fatal() is error(), but also calls sys.exit(1).
- - debug()
- - error()
- - fatal()
- - info()
- - message()
- - verbose()
- - warning()
-<b>Interface to g.parser</b>
-Interface to g.parser, intended to be run from the top-level, e.g.
-\code
- if __name__ == "__main__":
- main()
-\endcode
- - parser()
-<b>Interface to g.tempfile</b>
-Returns the name of a temporary file, created with g.tempfile.
- - tempfile()
-<b>Key-value parsers</b>
- - parse_key_val()
-<b>Interface to g.gisenv</b>
- - gisenv()
-<b>Interface to g.region</b>
- - del_temp_region()
- - region()
- - use_temp_region()
-<b>Interface to g.findfile</b>
- - find_file()
-<b>Interface to g.list</b>
- - list_grouped()
- - list_pairs()
- - list_strings()
- - mlist_grouped()
-<b>Color parsing</b>
- - parse_color()
-<b>Check GRASS environment variables</b>
- - overwrite()
- - verbosity()
-<b>Various utilities, not specific to GRASS</b>
- - basename()
- - find_program()
- - try_remove()
- - try_rmdir()
- - float_or_dms()
-\section pythonDb Database
-Interface for <tt>db.*</tt> modules.
-\code
-from grass.script import db as grass
-\endcode
- - db_connection()
- - db_describe()
-\section pythonRaster Raster
-Interface for <tt>r.*</tt> modules.
-\code
-from grass.script import raster as grass
-\endcode
- - raster_history()
- - raster_info()
- - mapcalc()
-\section pythonVector Vector
-Interface for <tt>v.*</tt> modules.
-\code
-from grass.script import vector as grass
-\endcode
- - vector_columns()
- - vector_db()
- - vector_db_select()
- - vector_history()
- - vector_info_topo()
- - vector_layer_db()
-\section pythonAuthors Authors
- Glynn Clements
- Martin Landa <landa.martin gmail.com>
