[GRASS-SVN] r49115 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Nov 5 18:11:44 EDT 2011
Author: martinl
Date: 2011-11-05 15:11:44 -0700 (Sat, 05 Nov 2011)
New Revision: 49115
grass/trunk/lib/vector/Vlib/read_nat.c
grass/trunk/lib/vector/Vlib/read_ogr.c
vlib: rewrite Vect_read_next_line_ogr() to read features from topology structures
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c 2011-11-05 17:37:33 UTC (rev 49114)
+++ grass/trunk/lib/vector/Vlib/read_nat.c 2011-11-05 22:11:44 UTC (rev 49115)
@@ -162,7 +162,7 @@
if (Map->Constraint_region_flag)
Vect_get_constraint_box(Map, &mbox);
- while (1) {
+ while (TRUE) {
line = Map->next_line;
if (line > Map->plus.n_lines)
@@ -190,10 +190,11 @@
return ret;
+ /* NOTREACHED */
- /* NOTREACHED */ }
\brief Read line from coor file
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2011-11-05 17:37:33 UTC (rev 49114)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2011-11-05 22:11:44 UTC (rev 49115)
@@ -144,6 +144,8 @@
OGRFeatureH hFeature;
OGRGeometryH hGeom;
+ struct Format_info_ogr *fInfo;
G_debug(3, "V1_read_next_line_ogr()");
if (line_p != NULL)
@@ -154,10 +156,11 @@
+ fInfo = &(Map->fInfo.ogr);
while (TRUE) {
/* Read feature to cache if necessary */
- while (Map->fInfo.ogr.lines_next == Map->fInfo.ogr.lines_num) {
- hFeature = OGR_L_GetNextFeature(Map->fInfo.ogr.layer);
+ while (fInfo->lines_next == fInfo->lines_num) {
+ hFeature = OGR_L_GetNextFeature(fInfo->layer);
if (hFeature == NULL) {
return -2;
@@ -169,54 +172,53 @@
continue;
- Map->fInfo.ogr.feature_cache_id = (int)OGR_F_GetFID(hFeature);
- if (Map->fInfo.ogr.feature_cache_id == OGRNullFID) {
+ fInfo->feature_cache_id = (int)OGR_F_GetFID(hFeature);
+ if (fInfo->feature_cache_id == OGRNullFID) {
G_warning(_("OGR feature without ID"));
/* Cache the feature */
- Map->fInfo.ogr.lines_num = 0;
+ fInfo->lines_num = 0;
cache_feature(Map, hGeom, -1);
- G_debug(4, "%d lines read to cache", Map->fInfo.ogr.lines_num);
+ G_debug(4, "%d lines read to cache", fInfo->lines_num);
OGR_F_Destroy(hFeature);
- Map->fInfo.ogr.lines_next = 0; /* next to be read from cache */
+ fInfo->lines_next = 0; /* next to be read from cache */
/* Read next part of the feature */
- G_debug(4, "read next cached line %d", Map->fInfo.ogr.lines_next);
- itype = Map->fInfo.ogr.lines_types[Map->fInfo.ogr.lines_next];
+ G_debug(4, "read next cached line %d", fInfo->lines_next);
+ itype = fInfo->lines_types[fInfo->lines_next];
/* Constraint on Type of line
* Default is all of Point, Line, Area and whatever else comes along
if (Map->Constraint_type_flag) {
if (!(itype & Map->Constraint_type)) {
- Map->fInfo.ogr.lines_next++;
+ fInfo->lines_next++;
continue;
/* Constraint on specified region */
if (Map->Constraint_region_flag) {
- Vect_line_box(Map->fInfo.ogr.lines[Map->fInfo.ogr.lines_next],
+ Vect_line_box(fInfo->lines[fInfo->lines_next],
&lbox);
if (!Vect_box_overlap(&lbox, &mbox)) {
continue;
if (line_p != NULL)
Vect_append_points(line_p,
- Map->fInfo.ogr.lines[Map->fInfo.ogr.
- lines_next], GV_FORWARD);
+ fInfo->lines[fInfo->lines_next], GV_FORWARD);
- if (line_c != NULL && Map->fInfo.ogr.feature_cache_id != OGRNullFID)
- Vect_cat_set(line_c, 1, Map->fInfo.ogr.feature_cache_id);
+ if (line_c != NULL && fInfo->feature_cache_id != OGRNullFID)
+ Vect_cat_set(line_c, 1, fInfo->feature_cache_id);
G_debug(4, "next line read, type = %d", itype);
return itype;
@@ -240,12 +242,79 @@
int V2_read_next_line_ogr(struct Map_info *Map, struct line_pnts *line_p,
struct line_cats *line_c)
- if (Map->next_line > Map->plus.n_lines)
- return -2;
+ int line, ret;
+ struct P_line *Line;
+ struct bound_box lbox, mbox;
- Map->next_line++;
+ G_debug(3, "V2_read_next_line_ogr()");
+ if (Map->Constraint_region_flag)
+ Vect_get_constraint_box(Map, &mbox);
+ while(TRUE) {
+ line = Map->next_line;
+ if (Map->next_line > Map->plus.n_lines)
+ return -2;
+ Map->next_line++;
+ Line = Map->plus.Line[line];
+ if (Line == NULL) { /* Dead line */
+ continue;
- return V1_read_next_line_ogr(Map, line_p, line_c);
+ if ((Map->Constraint_type_flag &&
+ !(Line->type & Map->Constraint_type))) {
+ continue;
+ if (Line->type == GV_CENTROID) {
+ G_debug(4, "Centroid");
+ if (line_p != NULL) {
+ int i, found;
+ struct bound_box box;
+ struct boxlist list;
+ struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
+ /* get area bbox */
+ Vect_get_area_box(Map, topo->area, &box);
+ /* search in spatial index for centroid with area bbox */
+ dig_init_boxlist(&list, TRUE);
+ Vect_select_lines_by_box(Map, &box, Line->type, &list);
+ found = 0;
+ for (i = 0; i < list.n_values; i++) {
+ if (list.id[i] == line) {
+ found = i;
+ break;
+ Vect_reset_line(line_p);
+ Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
+ if (line_c != NULL) {
+ /* cat = FID and offset = FID for centroid */
+ Vect_reset_cats(line_c);
+ Vect_cat_set(line_c, 1, (int) Line->offset);
+ return GV_CENTROID;
+ ret = V1_read_next_line_ogr(Map, line_p, line_c);
+ if (Map->Constraint_region_flag) {
+ Vect_line_box(line_p, &lbox);
+ if (!Vect_box_overlap(&lbox, &mbox)) {
+ continue;
+ return ret;
